[U-Boot] [PATCH] Network AT91 AVR32: generic way of addressing USRIO register layout
The MACB IP used by AVR32 & AT91 have two different layout for USRIO register. We have to differentiate this in the driver code. No more cpu specific #ifdefs in driver: we manage a configuration variable.
Signed-off-by: Nicolas Ferre nicolas.ferre@atmel.com --- drivers/net/macb.c | 6 ++---- drivers/net/macb.h | 7 +++++++ 2 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 6de0a04..1023315 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -446,15 +446,13 @@ static int macb_init(struct eth_device *netdev, bd_t *bd)
/* choose RMII or MII mode. This depends on the board */ #ifdef CONFIG_RMII -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ - defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) +#if defined(CONFIG_MACB_USRIO_CFG1) macb_writel(macb, USRIO, MACB_BIT(RMII) | MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, 0); #endif #else -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ - defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) +#if defined(CONFIG_MACB_USRIO_CFG1) macb_writel(macb, USRIO, MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, MACB_BIT(MII)); diff --git a/drivers/net/macb.h b/drivers/net/macb.h index f92a20c..349499c 100644 --- a/drivers/net/macb.h +++ b/drivers/net/macb.h @@ -212,6 +212,13 @@ #define MACB_SOF_OFFSET 30 #define MACB_SOF_SIZE 2
+/* MACB IP used by AVR32 & AT91 have two + * different layout for USRIO register. */ +#if !defined(CONFIG_AVR32) +/* Use AT91 USRIO layout */ +#define CONFIG_MACB_USRIO_CFG1 1 +#endif + /* Bitfields in USRIO */ #define MACB_MII_OFFSET 0 #define MACB_MII_SIZE 1
Ack-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Haavard is ok for you too?
Best Regards, J.
Sure.
Acked-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com
Sure.
Ben is ok for you?
Best Regards, J.
Sure.
Ben is ok for you?
It's definitely an improvement, although I'm not fond of placing the conditional macro in the header file. Overall OK, though. I'll pick it up.
regards, Ben
Ben Warren
Haavard Skinnemoen
Nicolas Ferre
