[U-Boot] [PULL] u-boot-usb/master
The following changes since commit 3c99166441bf3ea325af2da83cfe65430b49c066:
Prepare v2019.04 (2019-04-08 21:40:40 -0400)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 69535b33bc1fce43dcc10b646cf44db81cffa131:
usb: ehci-mx6: Use common code to extract dr_mode (2019-04-09 13:11:45 +0200)
---------------------------------------------------------------- Adam Ford (1): usb: ehci-mx6: Use common code to extract dr_mode
Ismael Luceno Cortes (2): usb: host: Print device name when scanning usb: Make portspeed return a read-only string
cmd/usb.c | 18 +++++------------- common/usb_hub.c | 18 +++++------------- drivers/usb/host/ehci-mx6.c | 29 +++++++++++++++-------------- drivers/usb/host/usb-uclass.c | 12 ++++-------- 4 files changed, 29 insertions(+), 48 deletions(-)
