[PATCH] btrfs: fix some error checking for btrfs_decompress()
The btrfs_decompress() function mostly (u32)-1 on error but it can also return -EPERM or other kernel error codes from zstd_decompress(). The "ret" variable is an int, so we could just check for negatives.
Signed-off-by: Dan Carpenter dan.carpenter@linaro.org --- fs/btrfs/inode.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/fs/btrfs/inode.c b/fs/btrfs/inode.c index 38e285bf94b0..4691612eda33 100644 --- a/fs/btrfs/inode.c +++ b/fs/btrfs/inode.c @@ -390,7 +390,7 @@ int btrfs_read_extent_inline(struct btrfs_path *path, csize); ret = btrfs_decompress(btrfs_file_extent_compression(leaf, fi), cbuf, csize, dbuf, dsize); - if (ret == (u32)-1) { + if (ret < 0) { ret = -EIO; goto out; } @@ -500,7 +500,7 @@ int btrfs_read_extent_reg(struct btrfs_path *path,
Reviewed-by: Qu Wenruo wqu@suse.com
Thanks, Qu
- if (ret < 0) { ret = -EIO; goto out; }
Signed-off-by: Dan Carpenter dan.carpenter@linaro.org Reviewed-by: Qu Wenruo wqu@suse.com
Dan Carpenter
Qu Wenruo
