[U-Boot] [PATCH 1/2] sandbox: Introduce Kconfig option for 32/64 bit host
It seems most of the time we are building and running sandbox on 64-bit host. But we do support 32-bit host as well. Introduce Kconfig option for this.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/sandbox/Kconfig | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/sandbox/Kconfig b/arch/sandbox/Kconfig index f7a6e1a..7b07bff 100644 --- a/arch/sandbox/Kconfig +++ b/arch/sandbox/Kconfig @@ -18,4 +18,21 @@ config SYS_CONFIG_NAME default "sandbox_spl" if SANDBOX_SPL default "sandbox" if !SANDBOX_SPL
+choice + prompt "Run sandbox on 32/64-bit host" + default SANDBOX_64BIT + help + Sandbox can be built on 32-bit and 64-bit hosts. + The default is to build on a 64-bit host and run + on a 64-bit host. If you want to run sandbox on + a 32-bit host, change it here. + +config SANDBOX_32BIT + bool "32-bit host" + +config SANDBOX_64BIT + bool "64-bit host" + +endchoice + endmenu
Convert SANDBOX_BITS_PER_LONG to Kconfig and assign it a correct number depending on which host we are going to build and run.
arch/sandbox/Kconfig | 5 +++++ board/sandbox/README.sandbox | 7 +++---- scripts/config_whitelist.txt | 1 - 3 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/arch/sandbox/Kconfig b/arch/sandbox/Kconfig index 7b07bff..87418e3 100644 --- a/arch/sandbox/Kconfig +++ b/arch/sandbox/Kconfig @@ -35,4 +35,9 @@ config SANDBOX_64BIT
endchoice
+config SANDBOX_BITS_PER_LONG + int + default 32 if SANDBOX_32BIT + default 64 if SANDBOX_64BIT + endmenu diff --git a/board/sandbox/README.sandbox b/board/sandbox/README.sandbox index 9dc2eb0..2e2c819 100644 --- a/board/sandbox/README.sandbox +++ b/board/sandbox/README.sandbox @@ -24,6 +24,9 @@ single board in board/sandbox. CONFIG_SANDBOX_BIG_ENDIAN should be defined when running on big-endian machines.
+By default sandbox builds and runs on 64-bit hosts. If you are going to build +and run sandbox on a 32-bit host, select CONFIG_SANDBOX_32BIT. + Note that standalone/API support is not available at present.
@@ -44,10 +47,6 @@ Note: make sandbox_defconfig all NO_SDL=1 ./u-boot
- If you are building on a 32-bit machine you may get errors from __ffs.h - about shifting more than the machine word size. Edit the config file - include/configs/sandbox.h and change CONFIG_SANDBOX_BITS_PER_LONG to 32. - U-Boot will start on your computer, showing a sandbox emulation of the serial console:
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e630314..70f22e1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2005,7 +2005,6 @@ CONFIG_SAMSUNG CONFIG_SAMSUNG_ONENAND CONFIG_SANDBOX_ARCH CONFIG_SANDBOX_BIG_ENDIAN -CONFIG_SANDBOX_BITS_PER_LONG CONFIG_SANDBOX_SDL CONFIG_SANDBOX_SPI_MAX_BUS CONFIG_SANDBOX_SPI_MAX_CS
Hi Bin,
Is it OK to build 64-bit sandbox on a 32-bit machine? Does that actually work?
If then I think we need a 3-way setting like:
- 32-bit - 64-bit - native (i.e. whatever the host is)
- Simon
Hi Simon,
On Thu, Aug 3, 2017 at 11:24 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
- 32-bit
- 64-bit
That means cross-compiling sandbox. So far this is not working. I will take a look.
Regards, Bin
Hi Bin,
On 3 August 2017 at 18:17, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
- 32-bit
- 64-bit
Or perhaps we just require it to use the bit size of the host? Does compiling 64-bit U-Boot on a 32-bit machine actually work?
Hi Simon,
On Sun, Aug 6, 2017 at 1:16 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
- 32-bit
- 64-bit
I have not looked into that further but I suspect there is more work than the bit size of the host, for example, linking 64-bit vs. 32-bit libraries?
Regards, Bin
Hi Bin,
On 6 August 2017 at 03:13, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
- 32-bit
- 64-bit
But does it compile 64-bit sandbox OK on a 32-bit machine? I would have thought it would complain.
I'm not really asking for this feature, it's just that I don't understand how your patch works, and don't necessarily want to lose the ability to build a 32-bit sandbox. It is to some extent a helpful build/unit test for 32-bit boards which we still have many of.
Hi Simon,
On Sun, Aug 13, 2017 at 11:35 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
- 32-bit
- 64-bit
No. Compiling 64-bit sandbox never worked on a 32-bit machine. So far sandbox build only supports:
1). build from a 32-bit host and run from a 32-bit host 2). build from a 64-bit host and run from a 64-bit host (current default setting)
This patch does not introduce any functional changes. It just converts SANDBOX_BITS_PER_LONG to Kconfig so that this can be changed from defconfigs or 'make menuconfig' to make it more user friendly if we are building (a 32-bit) sandbox on a 32-bit host. Ideally we should add such cross-build functionality to sandbox build.
Regards, Bin
Hi Bin,
On 13 August 2017 at 19:26, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
On 1 August 2017 at 17:33, Bin Meng bmeng.cn@gmail.com wrote: > Convert SANDBOX_BITS_PER_LONG to Kconfig and assign it a correct > number depending on which host we are going to build and run. > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > --- > > arch/sandbox/Kconfig | 5 +++++ > board/sandbox/README.sandbox | 7 +++---- > scripts/config_whitelist.txt | 1 - > 3 files changed, 8 insertions(+), 5 deletions(-)
- 32-bit
- 64-bit
Then I think this patch is fine.
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
- 32-bit
- 64-bit
Applied to u-boot-dm, thanks!
+choice
help
bool "32-bit host"
bool "64-bit host"
+endchoice
endmenu
2.9.2
Bin Meng
sjg@google.com
