sdhci_data_transfer: Trasnfer data timeout
Hi, I have made a custom board based on ARM A53. I use a NOR-flash, eMMC and DDR3.
I can start the Uboot from NOR and communicate with the eMMC. But for some reason it is timing out the first time I connect to the eMMC.
*(CLK =25MHz)* => run mmc_format eMMC: INT_STATUS = 00018000 eMMC: INT_STATUS = 00018001 sdhci_transfer_data: Transfer data timeout sdhci_transfer_data: Transfer data timeout
After this part it can communicate:
*(CLK = 50MHz)* success! Writing GPT: success! Saving Environment to SPI Flash... SF: Detected n25q128a13 with page size 256 Bytes, erase size 4 KiB, total 16 MiB Erasing SPI flash...Writing to SPI flash...done Valid environment: 1 OK
This Timeout might cause problems with the DDR3 (I am having problems with the Kernel not booting corretly). I think there is an issue with the communication with the eMMC and DDR, due to the timeout.
What can generate the timing-out-issue?
To make it clear; I can communicate with the eMMC. The first time it is really slow and is timing out with 25 MHz FLASH-clk. The second time it goes directly into sync:
=> run mmc_format success! Writing GPT: success! Saving Environment to SPI Flash... Erasing SPI flash...Writing to SPI flash...done Valid environment: 2 OK
I sounds like a HW-issue, but what can cause this in the code?
If I reset the system it is timing out again the first time.
Kind Regards
-- Sent from: http://u-boot.10912.n7.nabble.com/
Hi
You can enable MMC_TRACE, then you can see more information.
Best Regards, Jaehoon Chung
Kind Regards
aregaard
Jaehoon Chung
