[PATCH 1/2] doc: Detailed example for netconsole setup
This adds details that I would have liked to have readily available, in particular how to activate the network interface before enabling netconsole, and how to integrate netconsole so you can use the U-Boot prompt.
Signed-off-by: Fiona Klute fiona.klute@gmx.de --- doc/usage/netconsole.rst | 33 ++++++++++++++++++++++++++++++++- 1 file changed, 32 insertions(+), 1 deletion(-)
diff --git a/doc/usage/netconsole.rst b/doc/usage/netconsole.rst index 2aa3b9ccc5..0c983e6970 100644 --- a/doc/usage/netconsole.rst +++ b/doc/usage/netconsole.rst @@ -18,7 +18,9 @@ broadcast address and port 6666 are used. If it is set to an IP address of 0 (or 0.0.0.0) then no messages are sent to the network. The source / listening port can be configured separately by setting the 'ncinport' environment variable and the destination port can be -configured by setting the 'ncoutport' environment variable. +configured by setting the 'ncoutport' environment variable. Note that +you need to set up the network interface (e.g. using DHCP) before it +can be used for network console.
For example, if your server IP is 192.168.1.1, you could use::
@@ -107,3 +109,32 @@ as follows:
Note that unlike the U-Boot implementation the Linux netconsole is unidirectional, i. e. you have console output only in Linux. + +Setup via environment +--------------------- + +If persistent environment is enabled in your U-Boot configuration, you +can configure the network console using the environment. For example:: + + => env set autoload no + => env set hostname "u-boot" + => env set bootdelay 5 + => env set nc 'dhcp; env set stdout nc; env set stdin nc' + => env set ncip 192.168.1.1 + => env set preboot "${preboot}; run nc;" + => env save + => reset + +``autoload no`` tells the ``dhcp`` command to configure the network +interface without trying to load an image. ``hostname "u-boot"`` sets +the hostname to be sent in DHCP requests, so they are easy to +recognize in the DHCP server log. The command in ``nc`` calls ``dhcp`` +to make sure the network interface is set up before enabling +netconsole. + +Adding ``nc`` to ``preboot`` tells U-Boot to activate netconsole +before trying to find any boot options, so you can interact with it if +desired. + +``env save`` stores the settings persistently, and ``reset`` then +triggers a fresh start that will use the changed settings. -- 2.43.0
As I understand the env command documentation the subcommand style is preferred, though the old format is still fully supported.
Signed-off-by: Fiona Klute fiona.klute@gmx.de --- doc/usage/netconsole.rst | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/doc/usage/netconsole.rst b/doc/usage/netconsole.rst index 0c983e6970..b5832843f3 100644 --- a/doc/usage/netconsole.rst +++ b/doc/usage/netconsole.rst @@ -24,9 +24,9 @@ can be used for network console.
- => setenv nc 'setenv stdout nc;setenv stdin nc' - => setenv ncip 192.168.1.1 - => saveenv + => env set nc 'env set stdout nc; env set stdin nc' + => env set ncip 192.168.1.1 + => env save => run nc
On the host side, please use this script to access the console -- 2.43.0
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- => saveenv
-- 2.43.0
Hi Fiona,
We would need "env set stderr nc" here, too.
All the best, Tony
=> env save
=> reset
2.43.0
Am 15.05.24 um 21:05 schrieb Tony Dinh:
Hi Fiona,
Thanks, I guess I should add that to the existing description and example as well then. I'll test it and then send an update.
Best regards, Fiona
Thanks for adding this information.
Prefixing lines with => makes copying harder. If you see value in showing the prompt, please, use
.. prompt:: bash =>
Best regards
Heinrich
- => env set autoload no
- => env set hostname "u-boot"
- => env set bootdelay 5
- => env set nc 'dhcp; env set stdout nc; env set stdin nc'
- => env set ncip 192.168.1.1
- => env set preboot "${preboot}; run nc;"
- => env save
- => reset
2.43.0
Am 17.05.24 um 09:32 schrieb Heinrich Schuchardt:
.. prompt:: bash =>
Good point, I've sent a v3 series to address this.
Best regards, Fiona
2.43.0
Fiona Klute
Tony Dinh
