[PATCH] qcom_defconfig: enable msm8916 and msm8996
Enable the clock/pinctrl drivers for these two SoCs. Previously left out due to only being used on the db410c and db820c respectively which both have their own board code. We can still boot these with most features working without that board code.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- I nabbed this commit from one of Caleb's work trees. Along with the carveout patch I just sent, this gets U-Boot to successfully boot when chained from lk2nd on msm8916 devices supported by that bootloader.
A similar plea on this patch as with the "mach-snapdragon: do carveouts for qcs404 only" patch: if we could scrape these changes into the 2024.07 release that would be positively sublime.
Signed-off-by: Sam Day me@samcday.com --- configs/qcom_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 80ad3b32e1..c438aeef8e 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -37,6 +37,8 @@ CONFIG_OF_LIVE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BUTTON_QCOM_PMIC=y CONFIG_CLK=y +CONFIG_CLK_QCOM_APQ8016=y +CONFIG_CLK_QCOM_APQ8096=y CONFIG_CLK_QCOM_QCM2290=y CONFIG_CLK_QCOM_QCS404=y CONFIG_CLK_QCOM_SDM845=y @@ -73,6 +75,8 @@ CONFIG_PHY_QCOM_QUSB2=y CONFIG_PHY_QCOM_USB_SNPS_FEMTO_V2=y CONFIG_PHY_QCOM_SNPS_EUSB2=y CONFIG_PINCTRL=y +CONFIG_PINCTRL_QCOM_APQ8016=y +CONFIG_PINCTRL_QCOM_APQ8096=y CONFIG_PINCTRL_QCOM_QCM2290=y CONFIG_PINCTRL_QCOM_QCS404=y CONFIG_PINCTRL_QCOM_SDM845=y
--- base-commit: 1c40dda60f5f7e83a6d6f541cf5a57eb7e8ec43c change-id: 20240507-qcom-defconfig-msm8916-61c8437a0b2e
Hi Sam,
Thanks, it's nice to have this in, even if USB doesn't work.
Applied, thanks!
[1/1] qcom_defconfig: enable msm8916 and msm8996 https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/commit/9291868d...
Caleb Connolly
Sam Day
