[U-Boot] [PATCH 1/1] efi_loader: call __efi_exit_check in efi_exit
The calls to __efi_entry_check and __efi_exit_check have to match. If DEBUG is defined, panic() will be called otherwise.
If debugging is activated some Travis CI builds fail due to an assertion in EFI_CALL without the patch.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 5444b32530..ef3ae05126 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -828,6 +828,8 @@ static efi_status_t EFIAPI efi_exit(efi_handle_t image_handle, EFI_ENTRY("%p, %ld, %ld, %p", image_handle, exit_status, exit_data_size, exit_data);
+ __efi_exit_check(); + loaded_image_info->exit_status = exit_status; longjmp(&loaded_image_info->exit_jmp, 1);
On Fri, Aug 25, 2017 at 1:53 PM, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Thanks,
Reviewed-by: Rob Clark robdclark@gmail.com
__efi_exit_check();
-- 2.14.1
Rob Clark
