Re: [U-Boot] mx51evk build failure
On 10/19/2010 12:50 PM, Loïc Minier wrote:
Hey there
I'm following the u-boot list and see that some mx5 changes are being pushed regularly to u-boot.git master, but the board doesn't build for me (make CROSS_COMPILE=arm-linux-gnueabi- mrproper mx51evk_config + make CROSS_COMPILE=arm-linux-gnueabi- all), it fails with board.c:459: error: ‘CONFIG_SYS_SDRAM_BASE’ undeclared; I guess this is because the board needs porting to the relocation changes?
Yes. I have at least a patch that fix the compiling issues and I could test on a 2.5 board. However, it sets still CONFIG_SYS_ARM_WITHOUT_RELOC. Hoever, it is ugly that the board does not compile, and I weill send in anyway the patch to the ML.
I just wonder how the various patches related to mx5 get built; do you revert the relocation changes locally as a workaround before build?
No. There is a second MX5 board in mainline, that I used for testing.
Best regards, Stefano Babic
Stefano Babic
