[U-Boot] [PATCH v2] net: phy: Add support for Texas Instruments DP83867
From: "Edgar E. Iglesias" edgar.iglesias@xilinx.com
Code is taken from Linux kernel driver.
Signed-off-by: Edgar E. Iglesias edgar.iglesias@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: - Add missing function declaration to phy.h - Remove BIT macro and fix macro indentation - Remove comment about moving code to generic location - Fix typo register -> registers
drivers/net/phy/Makefile | 1 + drivers/net/phy/phy.c | 3 + drivers/net/phy/ti.c | 200 +++++++++++++++++++++++++++++++++++++++++++++++ include/phy.h | 1 + 4 files changed, 205 insertions(+) create mode 100644 drivers/net/phy/ti.c
diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index d096db87a276..9e4d4927e676 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -24,4 +24,5 @@ obj-$(CONFIG_PHY_NATSEMI) += natsemi.o obj-$(CONFIG_PHY_REALTEK) += realtek.o obj-$(CONFIG_PHY_SMSC) += smsc.o obj-$(CONFIG_PHY_TERANETICS) += teranetics.o +obj-$(CONFIG_PHY_TI) += ti.o obj-$(CONFIG_PHY_VITESSE) += vitesse.o diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index d7364ffc34f2..5633ec2402b0 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -484,6 +484,9 @@ int phy_init(void) #ifdef CONFIG_PHY_TERANETICS phy_teranetics_init(); #endif +#ifdef CONFIG_PHY_TI + phy_ti_init(); +#endif #ifdef CONFIG_PHY_VITESSE phy_vitesse_init(); #endif diff --git a/drivers/net/phy/ti.c b/drivers/net/phy/ti.c new file mode 100644 index 000000000000..541a57f98028 --- /dev/null +++ b/drivers/net/phy/ti.c @@ -0,0 +1,200 @@ +/* + * TI PHY drivers + * + * SPDX-License-Identifier: GPL-2.0 + * + */ +#include <common.h> +#include <phy.h> + +/* TI DP83867 */ +#define DP83867_DEVADDR 0x1f + +#define MII_DP83867_PHYCTRL 0x10 +#define MII_DP83867_MICR 0x12 +#define DP83867_CTRL 0x1f + +/* Extended Registers */ +#define DP83867_RGMIICTL 0x0032 +#define DP83867_RGMIIDCTL 0x0086 + +#define DP83867_SW_RESET BIT(15) +#define DP83867_SW_RESTART BIT(14) + +/* MICR Interrupt bits */ +#define MII_DP83867_MICR_AN_ERR_INT_EN BIT(15) +#define MII_DP83867_MICR_SPEED_CHNG_INT_EN BIT(14) +#define MII_DP83867_MICR_DUP_MODE_CHNG_INT_EN BIT(13) +#define MII_DP83867_MICR_PAGE_RXD_INT_EN BIT(12) +#define MII_DP83867_MICR_AUTONEG_COMP_INT_EN BIT(11) +#define MII_DP83867_MICR_LINK_STS_CHNG_INT_EN BIT(10) +#define MII_DP83867_MICR_FALSE_CARRIER_INT_EN BIT(8) +#define MII_DP83867_MICR_SLEEP_MODE_CHNG_INT_EN BIT(4) +#define MII_DP83867_MICR_WOL_INT_EN BIT(3) +#define MII_DP83867_MICR_XGMII_ERR_INT_EN BIT(2) +#define MII_DP83867_MICR_POL_CHNG_INT_EN BIT(1) +#define MII_DP83867_MICR_JABBER_INT_EN BIT(0) + +/* RGMIICTL bits */ +#define DP83867_RGMII_TX_CLK_DELAY_EN BIT(1) +#define DP83867_RGMII_RX_CLK_DELAY_EN BIT(0) + +/* PHY CTRL bits */ +#define DP83867_PHYCR_FIFO_DEPTH_SHIFT 14 + +/* RGMIIDCTL bits */ +#define DP83867_RGMII_TX_CLK_DELAY_SHIFT 4 + +#define MII_MMD_CTRL 0x0d /* MMD Access Control Register */ +#define MII_MMD_DATA 0x0e /* MMD Access Data Register */ + +/* MMD Access Control register fields */ +#define MII_MMD_CTRL_DEVAD_MASK 0x1f /* Mask MMD DEVAD*/ +#define MII_MMD_CTRL_ADDR 0x0000 /* Address */ +#define MII_MMD_CTRL_NOINCR 0x4000 /* no post increment */ +#define MII_MMD_CTRL_INCR_RDWT 0x8000 /* post increment on reads & writes */ +#define MII_MMD_CTRL_INCR_ON_WT 0xC000 /* post increment on writes only */ + +/** + * phy_read_mmd_indirect - reads data from the MMD registers + * @phydev: The PHY device bus + * @prtad: MMD Address + * @devad: MMD DEVAD + * @addr: PHY address on the MII bus + * + * Description: it reads data from the MMD registers (clause 22 to access to + * clause 45) of the specified phy address. + * To read these registers we have: + * 1) Write reg 13 // DEVAD + * 2) Write reg 14 // MMD Address + * 3) Write reg 13 // MMD Data Command for MMD DEVAD + * 3) Read reg 14 // Read MMD data + */ +int phy_read_mmd_indirect(struct phy_device *phydev, int prtad, + int devad, int addr) +{ + int value = -1; + + /* Write the desired MMD Devad */ + phy_write(phydev, addr, MII_MMD_CTRL, devad); + + /* Write the desired MMD register address */ + phy_write(phydev, addr, MII_MMD_DATA, prtad); + + /* Select the Function : DATA with no post increment */ + phy_write(phydev, addr, MII_MMD_CTRL, (devad | MII_MMD_CTRL_NOINCR)); + + /* Read the content of the MMD's selected register */ + value = phy_read(phydev, addr, MII_MMD_DATA); + return value; +} + +/** + * phy_write_mmd_indirect - writes data to the MMD registers + * @phydev: The PHY device + * @prtad: MMD Address + * @devad: MMD DEVAD + * @addr: PHY address on the MII bus + * @data: data to write in the MMD register + * + * Description: Write data from the MMD registers of the specified + * phy address. + * To write these registers we have: + * 1) Write reg 13 // DEVAD + * 2) Write reg 14 // MMD Address + * 3) Write reg 13 // MMD Data Command for MMD DEVAD + * 3) Write reg 14 // Write MMD data + */ +void phy_write_mmd_indirect(struct phy_device *phydev, int prtad, + int devad, int addr, u32 data) +{ + /* Write the desired MMD Devad */ + phy_write(phydev, addr, MII_MMD_CTRL, devad); + + /* Write the desired MMD register address */ + phy_write(phydev, addr, MII_MMD_DATA, prtad); + + /* Select the Function : DATA with no post increment */ + phy_write(phydev, addr, MII_MMD_CTRL, (devad | MII_MMD_CTRL_NOINCR)); + + /* Write the data into MMD's selected register */ + phy_write(phydev, addr, MII_MMD_DATA, data); +} + +/** + * phy_interface_is_rgmii - Convenience function for testing if a PHY interface + * is RGMII (all variants) + * @phydev: the phy_device struct + */ +static inline bool phy_interface_is_rgmii(struct phy_device *phydev) +{ + return phydev->interface >= PHY_INTERFACE_MODE_RGMII && + phydev->interface <= PHY_INTERFACE_MODE_RGMII_TXID; +} + +/* User setting - can be taken from DTS */ +#define RX_ID_DELAY 8 +#define TX_ID_DELAY 0xa +#define FIFO_DEPTH 1 + +static int dp83867_config(struct phy_device *phydev) +{ + unsigned int val, delay; + int ret; + + /* Restart the PHY. */ + val = phy_read(phydev, MDIO_DEVAD_NONE, DP83867_CTRL); + phy_write(phydev, MDIO_DEVAD_NONE, DP83867_CTRL, + val | DP83867_SW_RESTART); + + if (phy_interface_is_rgmii(phydev)) { + ret = phy_write(phydev, MDIO_DEVAD_NONE, MII_DP83867_PHYCTRL, + (FIFO_DEPTH << DP83867_PHYCR_FIFO_DEPTH_SHIFT)); + if (ret) + return ret; + } + + if ((phydev->interface >= PHY_INTERFACE_MODE_RGMII_ID) && + (phydev->interface <= PHY_INTERFACE_MODE_RGMII_RXID)) { + val = phy_read_mmd_indirect(phydev, DP83867_RGMIICTL, + DP83867_DEVADDR, phydev->addr); + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + val |= (DP83867_RGMII_TX_CLK_DELAY_EN | + DP83867_RGMII_RX_CLK_DELAY_EN); + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID) + val |= DP83867_RGMII_TX_CLK_DELAY_EN; + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID) + val |= DP83867_RGMII_RX_CLK_DELAY_EN; + + phy_write_mmd_indirect(phydev, DP83867_RGMIICTL, + DP83867_DEVADDR, phydev->addr, val); + + delay = (RX_ID_DELAY | + (TX_ID_DELAY << DP83867_RGMII_TX_CLK_DELAY_SHIFT)); + + phy_write_mmd_indirect(phydev, DP83867_RGMIIDCTL, + DP83867_DEVADDR, phydev->addr, delay); + } + + genphy_config_aneg(phydev); + return 0; +} + +static struct phy_driver DP83867_driver = { + .name = "TI DP83867", + .uid = 0x2000a231, + .mask = 0xfffffff0, + .features = PHY_GBIT_FEATURES, + .config = &dp83867_config, + .startup = &genphy_startup, + .shutdown = &genphy_shutdown, +}; + +int phy_ti_init(void) +{ + phy_register(&DP83867_driver); + return 0; +} diff --git a/include/phy.h b/include/phy.h index 3f826b66f71f..66cf61bdfb93 100644 --- a/include/phy.h +++ b/include/phy.h @@ -251,6 +251,7 @@ int phy_natsemi_init(void); int phy_realtek_init(void); int phy_smsc_init(void); int phy_teranetics_init(void); +int phy_ti_init(void); int phy_vitesse_init(void);
int board_phy_config(struct phy_device *phydev);
Which kernel tag / git hash? Makes future re-syncs for bug fixes easier.
Kernel v4.2. I will make it explicit in the commit message.
Thanks, Michal
Michal Simek
