[U-Boot] [PATCH 0/3] I2C designware patches
Hello Vipin,
I have prepared this patch after the work I have done for the new asic which embeds the I2C designware IP configured with the stop bit controlled by s/w.
I quickly tested it on both this asic AND the SPEAr1340, but if you can quickly check yourself would be good.
I think that this patch may be included in the work you are preparing on your own repo, but I rebased this work on the Heiko's u-boot-i2c.git repo.
Thx, Arm
Armando Visconti (3): designware_i2c.c: Added the support for MULTI_BUS designware_i2c: Added s/w generation of stop bit designware_i2c: Fixed the setting of the i2c bus speed
drivers/i2c/designware_i2c.c | 121 +++++++++++++++++++++++++++++++++++------- drivers/i2c/designware_i2c.h | 1 + 2 files changed, 103 insertions(+), 19 deletions(-)
This patch adds the capability to switch between 10 different I2C busses (from 0 to 9).
Signed-off-by: Armando Visconti armando.visconti@st.com --- drivers/i2c/designware_i2c.c | 82 +++++++++++++++++++++++++++++++++++++++++- 1 files changed, 81 insertions(+), 1 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index bf64a2a..4e4bfd4 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -26,7 +26,12 @@ #include <asm/arch/hardware.h> #include "designware_i2c.h"
-static struct i2c_regs *const i2c_regs_p = +#ifdef CONFIG_I2C_MULTI_BUS +static unsigned int bus_initialized[CONFIG_SYS_I2C_BUS_MAX]; +static unsigned int current_bus = 0; +#endif + +static struct i2c_regs *i2c_regs_p = (struct i2c_regs *)CONFIG_SYS_I2C_BASE;
/* @@ -150,6 +155,10 @@ void i2c_init(int speed, int slaveadd) enbl = readl(&i2c_regs_p->ic_enable); enbl |= IC_ENABLE_0B; writel(enbl, &i2c_regs_p->ic_enable); + +#ifdef CONFIG_I2C_MULTI_BUS + bus_initialized[current_bus] = 1; +#endif }
/* @@ -344,3 +353,74 @@ int i2c_probe(uchar chip)
return ret; } + +#ifdef CONFIG_I2C_MULTI_BUS +int i2c_set_bus_num(unsigned int bus) +{ + switch (bus) { + case 0: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE; + break; +#ifdef CONFIG_SYS_I2C_BASE1 + case 1: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE1; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE2 + case 2: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE2; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE3 + case 3: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE3; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE4 + case 4: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE4; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE5 + case 5: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE5; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE6 + case 6: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE6; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE7 + case 7: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE7; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE8 + case 8: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE8; + break; +#endif +#ifdef CONFIG_SYS_I2C_BASE9 + case 9: + i2c_regs_p = (void *)CONFIG_SYS_I2C_BASE9; + break; +#endif + default: + printf("Bad bus: %d\n", bus); + return -1; + } + + current_bus = bus; + + if (!bus_initialized[current_bus]) + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + return 0; +} + +int i2c_get_bus_num(void) +{ + return current_bus; +} +#endif
In the newer versions of designware i2c IP there is the possibility of configuring it with IC_EMPTYFIFO_HOLD_MASTER_EN=1, which basically requires the s/w to generate the stop bit condition directly, as the h/w will not automatically generate it when TX_FIFO is empty.
To avoid generation of an extra 0x0 byte sent as data, the IC_STOP command must be sent along with the last IC_CMD.
This patch always writes bit[9] of ic_data_cmd even in the older versions, assuming that it is a noop there.
Signed-off-by: Armando Visconti armando.visconti@st.com --- drivers/i2c/designware_i2c.c | 11 ++++++++--- drivers/i2c/designware_i2c.h | 1 + 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 4e4bfd4..eab3131 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -283,7 +283,10 @@ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len)
start_time_rx = get_timer(0); while (len) { - writel(IC_CMD, &i2c_regs_p->ic_cmd_data); + if (len == 1) + writel(IC_CMD | IC_STOP, &i2c_regs_p->ic_cmd_data); + else + writel(IC_CMD, &i2c_regs_p->ic_cmd_data);
if (readl(&i2c_regs_p->ic_status) & IC_STATUS_RFNE) { *buffer++ = (uchar)readl(&i2c_regs_p->ic_cmd_data); @@ -322,9 +325,11 @@ int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) start_time_tx = get_timer(0); while (len) { if (readl(&i2c_regs_p->ic_status) & IC_STATUS_TFNF) { - writel(*buffer, &i2c_regs_p->ic_cmd_data); + if (--len == 0) + writel(*buffer | IC_STOP, &i2c_regs_p->ic_cmd_data); + else + writel(*buffer, &i2c_regs_p->ic_cmd_data); buffer++; - len--; start_time_tx = get_timer(0);
} else if (get_timer(start_time_tx) > (nb * I2C_BYTE_TO)) { diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 03b520e..e004152 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -95,6 +95,7 @@ struct i2c_regs {
/* i2c data buffer and command register definitions */ #define IC_CMD 0x0100 +#define IC_STOP 0x0200
/* i2c interrupt status register definitions */ #define IC_GEN_CALL 0x0800
There are three couple (hcnt/lcnt) of registers for each speed (SS/FS/HS). The driver needs to set the proper couple of regs according to what speed we are setting.
Signed-off-by: Armando Visconti armando.visconti@st.com --- drivers/i2c/designware_i2c.c | 28 +++++++++++++--------------- 1 files changed, 13 insertions(+), 15 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index eab3131..6653870 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -44,7 +44,6 @@ static void set_speed(int i2c_spd) { unsigned int cntl; unsigned int hcnt, lcnt; - unsigned int high, low; unsigned int enbl;
/* to set speed cltr must be disabled */ @@ -52,39 +51,38 @@ static void set_speed(int i2c_spd) enbl &= ~IC_ENABLE_0B; writel(enbl, &i2c_regs_p->ic_enable);
- cntl = (readl(&i2c_regs_p->ic_con) & (~IC_CON_SPD_MSK));
switch (i2c_spd) { case IC_SPEED_MODE_MAX: cntl |= IC_CON_SPD_HS; - high = MIN_HS_SCL_HIGHTIME; - low = MIN_HS_SCL_LOWTIME; + hcnt = (IC_CLK * MIN_HS_SCL_HIGHTIME) / NANO_TO_MICRO; + writel(hcnt, &i2c_regs_p->ic_hs_scl_hcnt); + lcnt = (IC_CLK * MIN_HS_SCL_LOWTIME) / NANO_TO_MICRO; + writel(lcnt, &i2c_regs_p->ic_hs_scl_lcnt); break;
case IC_SPEED_MODE_STANDARD: cntl |= IC_CON_SPD_SS; - high = MIN_SS_SCL_HIGHTIME; - low = MIN_SS_SCL_LOWTIME; + hcnt = (IC_CLK * MIN_SS_SCL_HIGHTIME) / NANO_TO_MICRO; + writel(hcnt, &i2c_regs_p->ic_ss_scl_hcnt); + lcnt = (IC_CLK * MIN_SS_SCL_LOWTIME) / NANO_TO_MICRO; + writel(lcnt, &i2c_regs_p->ic_ss_scl_lcnt); break;
case IC_SPEED_MODE_FAST: default: cntl |= IC_CON_SPD_FS; - high = MIN_FS_SCL_HIGHTIME; - low = MIN_FS_SCL_LOWTIME; + hcnt = (IC_CLK * MIN_FS_SCL_HIGHTIME) / NANO_TO_MICRO; + writel(hcnt, &i2c_regs_p->ic_fs_scl_hcnt); + lcnt = (IC_CLK * MIN_FS_SCL_LOWTIME) / NANO_TO_MICRO; + writel(lcnt, &i2c_regs_p->ic_fs_scl_lcnt); break; }
writel(cntl, &i2c_regs_p->ic_con);
- hcnt = (IC_CLK * high) / NANO_TO_MICRO; - writel(hcnt, &i2c_regs_p->ic_fs_scl_hcnt); - - lcnt = (IC_CLK * low) / NANO_TO_MICRO; - writel(lcnt, &i2c_regs_p->ic_fs_scl_lcnt); - - /* re-enable i2c ctrl back now that speed is set */ + /* Enable back i2c now speed set */ enbl |= IC_ENABLE_0B; writel(enbl, &i2c_regs_p->ic_enable); }
Armando Visconti
