[PATCH v2 0/4] imx8m: convert i.MX8MM/Q/N/P-EVK to OF_UPSTREAM
This patchset is to convert NXP i.MX8M[Q,M,N,P] EVK boards to OF_UPSTREAM
Signed-off-by: Peng Fan peng.fan@nxp.com --- Changes in v2: - Sorry for the quick respin. - Drop the dtb build in arch/arm/dts/Makefile - Link to v1: https://lore.kernel.org/r/20240328-imx8m-v1-0-2be5e6657a88@nxp.com
--- Peng Fan (4): imx: imx8mq_evk: convert to OF_UPSTREAM imx: imx8mm_evk: convert to OF_UPSTREAM imx: imx8mn-evk: convert to OF_UPSTREAM imx: imx8mp_evk: convert to OF_UPSTREAM
arch/arm/dts/Makefile | 5 - arch/arm/dts/imx8mm-evk.dts | 128 ------- arch/arm/dts/imx8mm-evk.dtsi | 615 -------------------------------- arch/arm/dts/imx8mn-ddr4-evk.dts | 160 --------- arch/arm/dts/imx8mn-evk.dts | 128 ------- arch/arm/dts/imx8mp-evk.dts | 684 ------------------------------------ arch/arm/dts/imx8mq-evk.dts | 712 -------------------------------------- arch/arm/mach-imx/imx8m/Kconfig | 5 + configs/imx8mm_evk_defconfig | 2 +- configs/imx8mm_evk_fspi_defconfig | 2 +- configs/imx8mn_ddr4_evk_defconfig | 2 +- configs/imx8mn_evk_defconfig | 2 +- configs/imx8mp_evk_defconfig | 2 +- configs/imx8mq_evk_defconfig | 2 +- 14 files changed, 11 insertions(+), 2438 deletions(-) --- base-commit: ab8d9ca3044acf51d8ff3bf3c4718c48f30ad606 change-id: 20240328-imx8m-b6e89715c5dc
Convert i.MX8MQ EVK to OF_UPSTREAM
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx8mq-evk.dts | 712 ---------------------------------------- arch/arm/mach-imx/imx8m/Kconfig | 1 + configs/imx8mq_evk_defconfig | 2 +- 4 files changed, 2 insertions(+), 714 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d85a33055c9..b76ee4d609b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1090,7 +1090,6 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-cm.dtb \ imx8mn-evk.dtb \ imx8mn-var-som-symphony.dtb \ - imx8mq-evk.dtb \ imx8mm-beacon-kit.dtb \ imx8mn-beacon-kit.dtb \ imx8mq-mnt-reform2.dtb \ diff --git a/arch/arm/dts/imx8mq-evk.dts b/arch/arm/dts/imx8mq-evk.dts deleted file mode 100644 index 82387b9cb80..00000000000 --- a/arch/arm/dts/imx8mq-evk.dts +++ /dev/null @@ -1,712 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) -/* - * Copyright 2017 NXP - * Copyright (C) 2017-2018 Pengutronix, Lucas Stach kernel@pengutronix.de - */ - -/dts-v1/; - -#include "imx8mq.dtsi" - -/ { - model = "NXP i.MX8MQ EVK"; - compatible = "fsl,imx8mq-evk", "fsl,imx8mq"; - - chosen { - stdout-path = &uart1; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0x00000000 0x40000000 0 0xc0000000>; - }; - - pcie0_refclk: pcie0-refclk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <100000000>; - }; - - reg_pcie1: regulator-pcie { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie1_reg>; - regulator-name = "MPCIE_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio5 10 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_usdhc2_vmmc: regulator-vsd-3v3 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2>; - compatible = "regulator-fixed"; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - buck2_reg: regulator-buck2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_buck2>; - compatible = "regulator-gpio"; - regulator-name = "vdd_arm"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1000000>; - gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; - states = <1000000 0x0 - 900000 0x1>; - regulator-boot-on; - regulator-always-on; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio1 12 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_ir>; - linux,autosuspend-period = <125>; - }; - - audio_codec_bt_sco: audio-codec-bt-sco { - compatible = "linux,bt-sco"; - #sound-dai-cells = <1>; - }; - - wm8524: audio-codec { - #sound-dai-cells = <0>; - compatible = "wlf,wm8524"; - wlf,mute-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>; - }; - - sound-bt-sco { - compatible = "simple-audio-card"; - simple-audio-card,name = "bt-sco-audio"; - simple-audio-card,format = "dsp_a"; - simple-audio-card,bitclock-inversion; - simple-audio-card,frame-master = <&btcpu>; - simple-audio-card,bitclock-master = <&btcpu>; - - btcpu: simple-audio-card,cpu { - sound-dai = <&sai3>; - dai-tdm-slot-num = <2>; - dai-tdm-slot-width = <16>; - }; - - simple-audio-card,codec { - sound-dai = <&audio_codec_bt_sco 1>; - }; - }; - - sound-wm8524 { - compatible = "simple-audio-card"; - simple-audio-card,name = "wm8524-audio"; - simple-audio-card,format = "i2s"; - simple-audio-card,frame-master = <&cpudai>; - simple-audio-card,bitclock-master = <&cpudai>; - simple-audio-card,widgets = - "Line", "Left Line Out Jack", - "Line", "Right Line Out Jack"; - simple-audio-card,routing = - "Left Line Out Jack", "LINEVOUTL", - "Right Line Out Jack", "LINEVOUTR"; - - cpudai: simple-audio-card,cpu { - sound-dai = <&sai2>; - }; - - link_codec: simple-audio-card,codec { - sound-dai = <&wm8524>; - clocks = <&clk IMX8MQ_CLK_SAI2_ROOT>; - }; - }; - - sound-spdif { - compatible = "fsl,imx-audio-spdif"; - model = "imx-spdif"; - spdif-controller = <&spdif1>; - spdif-out; - spdif-in; - }; - - sound-hdmi-arc { - compatible = "fsl,imx-audio-spdif"; - model = "imx-hdmi-arc"; - spdif-controller = <&spdif2>; - spdif-in; - }; -}; - -&A53_0 { - cpu-supply = <&buck2_reg>; -}; - -&A53_1 { - cpu-supply = <&buck2_reg>; -}; - -&A53_2 { - cpu-supply = <&buck2_reg>; -}; - -&A53_3 { - cpu-supply = <&buck2_reg>; -}; - -&ddrc { - operating-points-v2 = <&ddrc_opp_table>; - status = "okay"; - - ddrc_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-25M { - opp-hz = /bits/ 64 <25000000>; - }; - - opp-100M { - opp-hz = /bits/ 64 <100000000>; - }; - - /* - * On imx8mq B0 PLL can't be bypassed so low bus is 166M - */ - opp-166M { - opp-hz = /bits/ 64 <166935483>; - }; - - opp-800M { - opp-hz = /bits/ 64 <800000000>; - }; - }; -}; - -&dphy { - status = "okay"; -}; - -&fec1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec1>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy0>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; - reset-assert-us = <10000>; - qca,disable-smarteee; - vddio-supply = <&vddh>; - - vddh: vddh-regulator { - }; - }; - }; -}; - -&gpio5 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wifi_reset>; - - wl-reg-on-hog { - gpio-hog; - gpios = <29 GPIO_ACTIVE_HIGH>; - output-high; - }; -}; - -&i2c1 { - clock-frequency = <100000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - status = "okay"; - - pmic@8 { - compatible = "fsl,pfuze100"; - reg = <0x8>; - - regulators { - sw1a_reg: sw1ab { - regulator-min-microvolt = <825000>; - regulator-max-microvolt = <1100000>; - }; - - sw1c_reg: sw1c { - regulator-min-microvolt = <825000>; - regulator-max-microvolt = <1100000>; - }; - - sw2_reg: sw2 { - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-always-on; - }; - - sw3a_reg: sw3ab { - regulator-min-microvolt = <825000>; - regulator-max-microvolt = <1100000>; - regulator-always-on; - }; - - sw4_reg: sw4 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - swbst_reg: swbst { - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5150000>; - }; - - snvs_reg: vsnvs { - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - }; - - vref_reg: vrefddr { - regulator-always-on; - }; - - vgen1_reg: vgen1 { - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1550000>; - }; - - vgen2_reg: vgen2 { - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <975000>; - regulator-always-on; - }; - - vgen3_reg: vgen3 { - regulator-min-microvolt = <1675000>; - regulator-max-microvolt = <1975000>; - regulator-always-on; - }; - - vgen4_reg: vgen4 { - regulator-min-microvolt = <1625000>; - regulator-max-microvolt = <1875000>; - regulator-always-on; - }; - - vgen5_reg: vgen5 { - regulator-min-microvolt = <3075000>; - regulator-max-microvolt = <3625000>; - regulator-always-on; - }; - - vgen6_reg: vgen6 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - }; - }; - }; -}; - -&lcdif { - status = "okay"; -}; - -&mipi_dsi { - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - panel@0 { - pinctrl-0 = <&pinctrl_mipi_dsi>; - pinctrl-names = "default"; - compatible = "raydium,rm67191"; - reg = <0>; - reset-gpios = <&gpio5 6 GPIO_ACTIVE_LOW>; - dsi-lanes = <4>; - - port { - panel_in: endpoint { - remote-endpoint = <&mipi_dsi_out>; - }; - }; - }; - - ports { - port@1 { - reg = <1>; - mipi_dsi_out: endpoint { - remote-endpoint = <&panel_in>; - }; - }; - }; -}; - -&pcie0 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie0>; - reset-gpio = <&gpio5 28 GPIO_ACTIVE_LOW>; - clocks = <&clk IMX8MQ_CLK_PCIE1_ROOT>, - <&clk IMX8MQ_CLK_PCIE1_AUX>, - <&clk IMX8MQ_CLK_PCIE1_PHY>, - <&pcie0_refclk>; - clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus"; - vph-supply = <&vgen5_reg>; - status = "okay"; -}; - -&pcie1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie1>; - reset-gpio = <&gpio5 12 GPIO_ACTIVE_LOW>; - clocks = <&clk IMX8MQ_CLK_PCIE2_ROOT>, - <&clk IMX8MQ_CLK_PCIE2_AUX>, - <&clk IMX8MQ_CLK_PCIE2_PHY>, - <&pcie0_refclk>; - clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus"; - vpcie-supply = <®_pcie1>; - vph-supply = <&vgen5_reg>; - status = "okay"; -}; - -&pgc_gpu { - power-supply = <&sw1a_reg>; -}; - -&pgc_vpu { - power-supply = <&sw1c_reg>; -}; - -&qspi0 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_qspi>; - status = "okay"; - - n25q256a: flash@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <1>; - compatible = "micron,n25q256a", "jedec,spi-nor"; - spi-max-frequency = <29000000>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <4>; - }; -}; - -&sai2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sai2>; - assigned-clocks = <&clk IMX8MQ_AUDIO_PLL1_BYPASS>, <&clk IMX8MQ_CLK_SAI2>; - assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1>, <&clk IMX8MQ_AUDIO_PLL1_OUT>; - assigned-clock-rates = <0>, <24576000>; - status = "okay"; -}; - -&sai3 { - #sound-dai-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sai3>; - assigned-clocks = <&clk IMX8MQ_CLK_SAI3>; - assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; - assigned-clock-rates = <24576000>; - status = "okay"; -}; - -&snvs_pwrkey { - status = "okay"; -}; - -&spdif1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_spdif1>; - assigned-clocks = <&clk IMX8MQ_CLK_SPDIF1>; - assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; - assigned-clock-rates = <24576000>; - status = "okay"; -}; - -&spdif2 { - assigned-clocks = <&clk IMX8MQ_CLK_SPDIF2>; - assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; - assigned-clock-rates = <24576000>; - status = "okay"; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&usb3_phy1 { - status = "okay"; -}; - -&usb_dwc3_1 { - dr_mode = "host"; - status = "okay"; -}; - -&usdhc1 { - assigned-clocks = <&clk IMX8MQ_CLK_USDHC1>; - assigned-clock-rates = <400000000>; - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1_100mhz>; - pinctrl-2 = <&pinctrl_usdhc1_200mhz>; - vqmmc-supply = <&sw4_reg>; - bus-width = <8>; - non-removable; - no-sd; - no-sdio; - status = "okay"; -}; - -&usdhc2 { - assigned-clocks = <&clk IMX8MQ_CLK_USDHC2>; - assigned-clock-rates = <200000000>; - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; - vmmc-supply = <®_usdhc2_vmmc>; - status = "okay"; -}; - -&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; - status = "okay"; -}; - -&iomuxc { - pinctrl_buck2: vddarmgrp { - fsl,pins = < - MX8MQ_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x19 - >; - }; - - pinctrl_fec1: fec1grp { - fsl,pins = < - MX8MQ_IOMUXC_ENET_MDC_ENET1_MDC 0x3 - MX8MQ_IOMUXC_ENET_MDIO_ENET1_MDIO 0x23 - MX8MQ_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f - MX8MQ_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f - MX8MQ_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f - MX8MQ_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f - MX8MQ_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 - MX8MQ_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 - MX8MQ_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 - MX8MQ_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 - MX8MQ_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f - MX8MQ_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 - MX8MQ_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 - MX8MQ_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f - MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x19 - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x4000007f - MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x4000007f - >; - }; - - pinctrl_ir: irgrp { - fsl,pins = < - MX8MQ_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x4f - >; - }; - - pinctrl_mipi_dsi: mipidsigrp { - fsl,pins = < - MX8MQ_IOMUXC_ECSPI1_SCLK_GPIO5_IO6 0x16 - >; - }; - - pinctrl_pcie0: pcie0grp { - fsl,pins = < - MX8MQ_IOMUXC_I2C4_SCL_PCIE1_CLKREQ_B 0x76 - MX8MQ_IOMUXC_UART4_RXD_GPIO5_IO28 0x16 - >; - }; - - pinctrl_pcie1: pcie1grp { - fsl,pins = < - MX8MQ_IOMUXC_I2C4_SDA_PCIE2_CLKREQ_B 0x76 - MX8MQ_IOMUXC_ECSPI2_MISO_GPIO5_IO12 0x16 - >; - }; - - pinctrl_pcie1_reg: pcie1reggrp { - fsl,pins = < - MX8MQ_IOMUXC_ECSPI2_SCLK_GPIO5_IO10 0x16 - >; - }; - - pinctrl_qspi: qspigrp { - fsl,pins = < - MX8MQ_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x82 - MX8MQ_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x82 - MX8MQ_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x82 - MX8MQ_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x82 - MX8MQ_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x82 - MX8MQ_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x82 - >; - }; - - pinctrl_reg_usdhc2: regusdhc2gpiogrp { - fsl,pins = < - MX8MQ_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 - >; - }; - - pinctrl_sai2: sai2grp { - fsl,pins = < - MX8MQ_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0xd6 - MX8MQ_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0xd6 - MX8MQ_IOMUXC_SAI2_MCLK_SAI2_MCLK 0xd6 - MX8MQ_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0xd6 - MX8MQ_IOMUXC_GPIO1_IO08_GPIO1_IO8 0xd6 - >; - }; - - pinctrl_sai3: sai3grp { - fsl,pins = < - MX8MQ_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 - MX8MQ_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0xd6 - MX8MQ_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0xd6 - MX8MQ_IOMUXC_SAI3_RXD_SAI3_RX_DATA0 0xd6 - >; - }; - - pinctrl_spdif1: spdif1grp { - fsl,pins = < - MX8MQ_IOMUXC_SPDIF_TX_SPDIF1_OUT 0xd6 - MX8MQ_IOMUXC_SPDIF_RX_SPDIF1_IN 0xd6 - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x49 - MX8MQ_IOMUXC_UART1_TXD_UART1_DCE_TX 0x49 - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83 - MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3 - MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3 - MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3 - MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3 - MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3 - MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3 - MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3 - MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3 - MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3 - MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x83 - MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 - >; - }; - - pinctrl_usdhc1_100mhz: usdhc1-100grp { - fsl,pins = < - MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x8d - MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xcd - MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xcd - MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xcd - MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xcd - MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xcd - MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xcd - MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xcd - MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xcd - MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xcd - MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x8d - MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 - >; - }; - - pinctrl_usdhc1_200mhz: usdhc1-200grp { - fsl,pins = < - MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x9f - MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xdf - MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xdf - MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xdf - MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xdf - MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xdf - MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xdf - MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xdf - MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xdf - MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xdf - MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x9f - MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 - >; - }; - - pinctrl_usdhc2_gpio: usdhc2gpiogrp { - fsl,pins = < - MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x41 - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x83 - MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc3 - MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc3 - MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc3 - MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc3 - MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc3 - MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2-100grp { - fsl,pins = < - MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x85 - MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc5 - MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc5 - MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc5 - MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc5 - MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc5 - MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2-200grp { - fsl,pins = < - MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x87 - MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc7 - MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc7 - MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc7 - MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc7 - MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc7 - MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 - >; - }; - - pinctrl_wdog: wdog1grp { - fsl,pins = < - MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 - >; - }; - - pinctrl_wifi_reset: wifiresetgrp { - fsl,pins = < - MX8MQ_IOMUXC_UART4_TXD_GPIO5_IO29 0x16 - >; - }; -}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 5db643c1958..6f68ee2c27d 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -53,6 +53,7 @@ config TARGET_IMX8MQ_EVK select FSL_CAAM select ARCH_MISC_INIT select SPL_CRYPTO if SPL + imply OF_UPSTREAM
config TARGET_IMX8MQ_PHANBELL bool "imx8mq_phanbell" diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 941b845006a..3a2d88aec45 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -11,7 +11,7 @@ CONFIG_SYS_I2C_MXC_I2C1=y CONFIG_SYS_I2C_MXC_I2C2=y CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mq-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mq-evk" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_IMX8MQ_EVK=y CONFIG_DM_RESET=y
Convert i.MX8MM EVK to OF_UPSTREAM
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx8mm-evk.dts | 128 -------- arch/arm/dts/imx8mm-evk.dtsi | 615 -------------------------------------- arch/arm/mach-imx/imx8m/Kconfig | 1 + configs/imx8mm_evk_defconfig | 2 +- configs/imx8mm_evk_fspi_defconfig | 2 +- 6 files changed, 3 insertions(+), 746 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b76ee4d609b..b7992491389 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1074,7 +1074,6 @@ dtb-$(CONFIG_ARCH_IMX8ULP) += \
dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-data-modul-edm-sbc.dtb \ - imx8mm-evk.dtb \ imx8mm-icore-mx8mm-ctouch2.dtb \ imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-kontron-bl.dtb \ diff --git a/arch/arm/dts/imx8mm-evk.dts b/arch/arm/dts/imx8mm-evk.dts deleted file mode 100644 index a2b24d4d4e3..00000000000 --- a/arch/arm/dts/imx8mm-evk.dts +++ /dev/null @@ -1,128 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019-2020 NXP - */ - -/dts-v1/; - -#include <dt-bindings/usb/pd.h> -#include "imx8mm-evk.dtsi" - -/ { - model = "FSL i.MX8MM EVK board"; - compatible = "fsl,imx8mm-evk", "fsl,imx8mm"; - - aliases { - spi0 = &flexspi; - }; -}; - -&ddrc { - operating-points-v2 = <&ddrc_opp_table>; - - ddrc_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-25M { - opp-hz = /bits/ 64 <25000000>; - }; - - opp-100M { - opp-hz = /bits/ 64 <100000000>; - }; - - opp-750M { - opp-hz = /bits/ 64 <750000000>; - }; - }; -}; - -&flexspi { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexspi>; - status = "okay"; - - flash@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <80000000>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <4>; - }; -}; - -&usdhc3 { - assigned-clocks = <&clk IMX8MM_CLK_USDHC3_ROOT>; - assigned-clock-rates = <400000000>; - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc3>; - pinctrl-1 = <&pinctrl_usdhc3_100mhz>; - pinctrl-2 = <&pinctrl_usdhc3_200mhz>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&iomuxc { - pinctrl_flexspi: flexspigrp { - fsl,pins = < - MX8MM_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x1c2 - MX8MM_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x82 - MX8MM_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x82 - MX8MM_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x82 - MX8MM_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x82 - MX8MM_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x82 - >; - }; - - pinctrl_usdhc3: usdhc3grp { - fsl,pins = < - MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 - MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 - MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 - MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 - MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 - MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 - MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 - MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 - MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 - MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 - MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 - MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 - >; - }; - - pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { - fsl,pins = < - MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 - MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 - MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 - MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 - MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 - MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 - MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 - MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 - MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 - MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 - MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 - >; - }; - - pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { - fsl,pins = < - MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 - MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 - MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 - MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 - MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 - MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 - MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 - MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 - MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 - MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 - MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 - >; - }; -}; diff --git a/arch/arm/dts/imx8mm-evk.dtsi b/arch/arm/dts/imx8mm-evk.dtsi deleted file mode 100644 index 7d6317d95b1..00000000000 --- a/arch/arm/dts/imx8mm-evk.dtsi +++ /dev/null @@ -1,615 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2020 NXP - */ - -/dts-v1/; - -#include <dt-bindings/phy/phy-imx8-pcie.h> -#include <dt-bindings/usb/pd.h> -#include "imx8mm.dtsi" - -/ { - chosen { - stdout-path = &uart2; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0x0 0x40000000 0 0x80000000>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_gpio_led>; - - status { - label = "status"; - gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; - default-state = "on"; - }; - }; - - pcie0_refclk: pcie0-refclk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <100000000>; - }; - - reg_pcie0: regulator-pcie { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie0_reg>; - regulator-name = "MPCIE_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio1 5 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - pwms = <&pwm1 0 5000000 0>; - brightness-levels = <0 255>; - num-interpolated-steps = <255>; - default-brightness-level = <250>; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio1 13 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_ir>; - linux,autosuspend-period = <125>; - }; - - audio_codec_bt_sco: audio-codec-bt-sco { - compatible = "linux,bt-sco"; - #sound-dai-cells = <1>; - }; - - wm8524: audio-codec { - #sound-dai-cells = <0>; - compatible = "wlf,wm8524"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_gpio_wlf>; - wlf,mute-gpios = <&gpio5 21 GPIO_ACTIVE_LOW>; - }; - - sound-bt-sco { - compatible = "simple-audio-card"; - simple-audio-card,name = "bt-sco-audio"; - simple-audio-card,format = "dsp_a"; - simple-audio-card,bitclock-inversion; - simple-audio-card,frame-master = <&btcpu>; - simple-audio-card,bitclock-master = <&btcpu>; - - btcpu: simple-audio-card,cpu { - sound-dai = <&sai2>; - dai-tdm-slot-num = <2>; - dai-tdm-slot-width = <16>; - }; - - simple-audio-card,codec { - sound-dai = <&audio_codec_bt_sco 1>; - }; - }; - - sound-wm8524 { - compatible = "simple-audio-card"; - simple-audio-card,name = "wm8524-audio"; - simple-audio-card,format = "i2s"; - simple-audio-card,frame-master = <&cpudai>; - simple-audio-card,bitclock-master = <&cpudai>; - simple-audio-card,widgets = - "Line", "Left Line Out Jack", - "Line", "Right Line Out Jack"; - simple-audio-card,routing = - "Left Line Out Jack", "LINEVOUTL", - "Right Line Out Jack", "LINEVOUTR"; - - cpudai: simple-audio-card,cpu { - sound-dai = <&sai3>; - dai-tdm-slot-num = <2>; - dai-tdm-slot-width = <32>; - }; - - simple-audio-card,codec { - sound-dai = <&wm8524>; - clocks = <&clk IMX8MM_CLK_SAI3_ROOT>; - }; - }; -}; - -&A53_0 { - cpu-supply = <&buck2_reg>; -}; - -&A53_1 { - cpu-supply = <&buck2_reg>; -}; - -&A53_2 { - cpu-supply = <&buck2_reg>; -}; - -&A53_3 { - cpu-supply = <&buck2_reg>; -}; - -&fec1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec1>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy0>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; - reset-assert-us = <10000>; - qca,disable-smarteee; - vddio-supply = <&vddio>; - - vddio: vddio-regulator { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - }; - }; -}; - -&i2c1 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - status = "okay"; - - pmic@4b { - compatible = "rohm,bd71847"; - reg = <0x4b>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pmic>; - interrupt-parent = <&gpio1>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - rohm,reset-snvs-powered; - - #clock-cells = <0>; - clocks = <&osc_32k 0>; - clock-output-names = "clk-32k-out"; - - regulators { - buck1_reg: BUCK1 { - regulator-name = "buck1"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1300000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <1250>; - }; - - buck2_reg: BUCK2 { - regulator-name = "buck2"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1300000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <1250>; - rohm,dvs-run-voltage = <1000000>; - rohm,dvs-idle-voltage = <900000>; - }; - - buck3_reg: BUCK3 { - // BUCK5 in datasheet - regulator-name = "buck3"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1350000>; - regulator-boot-on; - regulator-always-on; - }; - - buck4_reg: BUCK4 { - // BUCK6 in datasheet - regulator-name = "buck4"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5_reg: BUCK5 { - // BUCK7 in datasheet - regulator-name = "buck5"; - regulator-min-microvolt = <1605000>; - regulator-max-microvolt = <1995000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6_reg: BUCK6 { - // BUCK8 in datasheet - regulator-name = "buck6"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1_reg: LDO1 { - regulator-name = "ldo1"; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo2_reg: LDO2 { - regulator-name = "ldo2"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <900000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo3_reg: LDO3 { - regulator-name = "ldo3"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4_reg: LDO4 { - regulator-name = "ldo4"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo6_reg: LDO6 { - regulator-name = "ldo6"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; -}; - -&i2c2 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - status = "okay"; - - ptn5110: tcpc@50 { - compatible = "nxp,ptn5110"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_typec1>; - reg = <0x50>; - interrupt-parent = <&gpio2>; - interrupts = <11 8>; - status = "okay"; - - port { - typec1_dr_sw: endpoint { - remote-endpoint = <&usb1_drd_sw>; - }; - }; - - typec1_con: connector { - compatible = "usb-c-connector"; - label = "USB-C"; - power-role = "dual"; - data-role = "dual"; - try-power-role = "sink"; - source-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>; - sink-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM) - PDO_VAR(5000, 20000, 3000)>; - op-sink-microwatt = <15000000>; - self-powered; - }; - }; -}; - -&i2c3 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - status = "okay"; - - pca6416: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&pcie_phy { - fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; - fsl,tx-deemph-gen1 = <0x2d>; - fsl,tx-deemph-gen2 = <0xf>; - clocks = <&pcie0_refclk>; - status = "okay"; -}; - -&pcie0 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie0>; - reset-gpio = <&gpio4 21 GPIO_ACTIVE_LOW>; - clocks = <&clk IMX8MM_CLK_PCIE1_ROOT>, <&clk IMX8MM_CLK_PCIE1_AUX>, - <&pcie0_refclk>; - clock-names = "pcie", "pcie_aux", "pcie_bus"; - assigned-clocks = <&clk IMX8MM_CLK_PCIE1_AUX>, - <&clk IMX8MM_CLK_PCIE1_CTRL>; - assigned-clock-rates = <10000000>, <250000000>; - assigned-clock-parents = <&clk IMX8MM_SYS_PLL2_50M>, - <&clk IMX8MM_SYS_PLL2_250M>; - vpcie-supply = <®_pcie0>; - status = "okay"; -}; - -&sai2 { - #sound-dai-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sai2>; - assigned-clocks = <&clk IMX8MM_CLK_SAI2>; - assigned-clock-parents = <&clk IMX8MM_AUDIO_PLL1_OUT>; - assigned-clock-rates = <24576000>; - status = "okay"; -}; - -&sai3 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sai3>; - assigned-clocks = <&clk IMX8MM_CLK_SAI3>; - assigned-clock-parents = <&clk IMX8MM_AUDIO_PLL1_OUT>; - assigned-clock-rates = <24576000>; - status = "okay"; -}; - -&snvs_pwrkey { - status = "okay"; -}; - -&uart2 { /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart2>; - status = "okay"; -}; - -&usbotg1 { - dr_mode = "otg"; - hnp-disable; - srp-disable; - adp-disable; - usb-role-switch; - disable-over-current; - samsung,picophy-pre-emp-curr-control = <3>; - samsung,picophy-dc-vol-level-adjust = <7>; - status = "okay"; - - port { - usb1_drd_sw: endpoint { - remote-endpoint = <&typec1_dr_sw>; - }; - }; -}; - -&usdhc2 { - assigned-clocks = <&clk IMX8MM_CLK_USDHC2>; - assigned-clock-rates = <200000000>; - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; - bus-width = <4>; - vmmc-supply = <®_usdhc2_vmmc>; - status = "okay"; -}; - -&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; - status = "okay"; -}; - -&pwm1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_backlight>; - status = "okay"; -}; - -&iomuxc { - pinctrl_fec1: fec1grp { - fsl,pins = < - MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 - MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 - MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f - MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f - MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f - MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f - MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 - MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 - MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 - MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 - MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f - MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 - MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 - MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f - MX8MM_IOMUXC_SAI2_RXC_GPIO4_IO22 0x19 - >; - }; - - pinctrl_gpio_led: gpioledgrp { - fsl,pins = < - MX8MM_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 - >; - }; - - pinctrl_ir: irgrp { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x4f - >; - }; - - pinctrl_gpio_wlf: gpiowlfgrp { - fsl,pins = < - MX8MM_IOMUXC_I2C4_SDA_GPIO5_IO21 0xd6 - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 - MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 - >; - }; - - pinctrl_i2c2: i2c2grp { - fsl,pins = < - MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 - MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 - >; - }; - - pinctrl_i2c3: i2c3grp { - fsl,pins = < - MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 - MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 - >; - }; - - pinctrl_pcie0: pcie0grp { - fsl,pins = < - MX8MM_IOMUXC_I2C4_SCL_PCIE1_CLKREQ_B 0x61 - MX8MM_IOMUXC_SAI2_RXFS_GPIO4_IO21 0x41 - >; - }; - - pinctrl_pcie0_reg: pcie0reggrp { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x41 - >; - }; - - pinctrl_pmic: pmicirqgrp { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x141 - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX8MM_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 - >; - }; - - pinctrl_sai2: sai2grp { - fsl,pins = < - MX8MM_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0xd6 - MX8MM_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0xd6 - MX8MM_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0xd6 - MX8MM_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0xd6 - >; - }; - - pinctrl_sai3: sai3grp { - fsl,pins = < - MX8MM_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 - MX8MM_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0xd6 - MX8MM_IOMUXC_SAI3_MCLK_SAI3_MCLK 0xd6 - MX8MM_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0xd6 - >; - }; - - pinctrl_typec1: typec1grp { - fsl,pins = < - MX8MM_IOMUXC_SD1_STROBE_GPIO2_IO11 0x159 - >; - }; - - pinctrl_uart2: uart2grp { - fsl,pins = < - MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 - MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 - >; - }; - - pinctrl_usdhc2_gpio: usdhc2grpgpiogrp { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x1c4 - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 - MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 - MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 - MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 - MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 - MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 - MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { - fsl,pins = < - MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 - MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 - MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 - MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 - MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 - MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 - MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { - fsl,pins = < - MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 - MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 - MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 - MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 - MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 - MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 - MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; - - pinctrl_wdog: wdoggrp { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x166 - >; - }; - - pinctrl_backlight: backlightgrp { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO01_PWM1_OUT 0x06 - >; - }; -}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 6f68ee2c27d..dd139c1b223 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -79,6 +79,7 @@ config TARGET_IMX8MM_EVK select FSL_CAAM select ARCH_MISC_INIT select SPL_CRYPTO if SPL + imply OF_UPSTREAM
config TARGET_IMX8MM_ICORE_MX8MM bool "Engicam i.Core MX8M Mini SOM" diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index b51e3931d24..e41facd8513 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mm-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mm-evk" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_IMX8MM_EVK=y CONFIG_SYS_MONITOR_LEN=524288 diff --git a/configs/imx8mm_evk_fspi_defconfig b/configs/imx8mm_evk_fspi_defconfig index 34e8071611b..3aaf7a4d0d5 100644 --- a/configs/imx8mm_evk_fspi_defconfig +++ b/configs/imx8mm_evk_fspi_defconfig @@ -11,7 +11,7 @@ CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_IMX_CONFIG="board/freescale/imx8mm_evk/imximage-8mm-lpddr4-fspi.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mm-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mm-evk" CONFIG_SPL_TEXT_BASE=0x7E2000 CONFIG_TARGET_IMX8MM_EVK=y CONFIG_SYS_MONITOR_LEN=524288
Convert i.MX8MN-EVK and i.MX8MN-DDR4-EVK to OF_UPSTREAM
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 2 - arch/arm/dts/imx8mn-ddr4-evk.dts | 160 -------------------------------------- arch/arm/dts/imx8mn-evk.dts | 128 ------------------------------ arch/arm/mach-imx/imx8m/Kconfig | 2 + configs/imx8mn_ddr4_evk_defconfig | 2 +- configs/imx8mn_evk_defconfig | 2 +- 6 files changed, 4 insertions(+), 292 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b7992491389..56623d01240 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1085,9 +1085,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-verdin-wifi-dev.dtb \ imx8mn-bsh-smm-s2.dtb \ imx8mn-bsh-smm-s2pro.dtb \ - imx8mn-ddr4-evk.dtb \ imx8mq-cm.dtb \ - imx8mn-evk.dtb \ imx8mn-var-som-symphony.dtb \ imx8mm-beacon-kit.dtb \ imx8mn-beacon-kit.dtb \ diff --git a/arch/arm/dts/imx8mn-ddr4-evk.dts b/arch/arm/dts/imx8mn-ddr4-evk.dts deleted file mode 100644 index d8ce217c601..00000000000 --- a/arch/arm/dts/imx8mn-ddr4-evk.dts +++ /dev/null @@ -1,160 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 NXP - */ - -/dts-v1/; - -#include "imx8mn.dtsi" -#include "imx8mn-evk.dtsi" - -/ { - model = "NXP i.MX8MNano DDR4 EVK board"; - compatible = "fsl,imx8mn-ddr4-evk", "fsl,imx8mn"; -}; - -&A53_0 { - cpu-supply = <&buck2_reg>; -}; - -&A53_1 { - cpu-supply = <&buck2_reg>; -}; - -&A53_2 { - cpu-supply = <&buck2_reg>; -}; - -&A53_3 { - cpu-supply = <&buck2_reg>; -}; - -&ddrc { - operating-points-v2 = <&ddrc_opp_table>; - - ddrc_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-25M { - opp-hz = /bits/ 64 <25000000>; - }; - - opp-100M { - opp-hz = /bits/ 64 <100000000>; - }; - - opp-600M { - opp-hz = /bits/ 64 <600000000>; - }; - }; -}; - -&i2c1 { - pmic@4b { - compatible = "rohm,bd71847"; - reg = <0x4b>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pmic>; - interrupt-parent = <&gpio1>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - rohm,reset-snvs-powered; - - #clock-cells = <0>; - clocks = <&osc_32k 0>; - clock-output-names = "clk-32k-out"; - - regulators { - buck1_reg: BUCK1 { - regulator-name = "buck1"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1300000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <1250>; - }; - - buck2_reg: BUCK2 { - regulator-name = "buck2"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1300000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <1250>; - }; - - buck3_reg: BUCK3 { - // BUCK5 in datasheet - regulator-name = "buck3"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1350000>; - }; - - buck4_reg: BUCK4 { - // BUCK6 in datasheet - regulator-name = "buck4"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5_reg: BUCK5 { - // BUCK7 in datasheet - regulator-name = "buck5"; - regulator-min-microvolt = <1605000>; - regulator-max-microvolt = <1995000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6_reg: BUCK6 { - // BUCK8 in datasheet - regulator-name = "buck6"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1_reg: LDO1 { - regulator-name = "ldo1"; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo2_reg: LDO2 { - regulator-name = "ldo2"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <900000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo3_reg: LDO3 { - regulator-name = "ldo3"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4_reg: LDO4 { - regulator-name = "ldo4"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo6_reg: LDO6 { - regulator-name = "ldo6"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; -}; diff --git a/arch/arm/dts/imx8mn-evk.dts b/arch/arm/dts/imx8mn-evk.dts deleted file mode 100644 index 4eb467df5ba..00000000000 --- a/arch/arm/dts/imx8mn-evk.dts +++ /dev/null @@ -1,128 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 NXP - */ - -/dts-v1/; - -#include "imx8mn.dtsi" -#include "imx8mn-evk.dtsi" -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - model = "NXP i.MX8MNano EVK board"; - compatible = "fsl,imx8mn-evk", "fsl,imx8mn"; -}; - -&A53_0 { - cpu-supply = <&buck2>; -}; - -&A53_1 { - cpu-supply = <&buck2>; -}; - -&A53_2 { - cpu-supply = <&buck2>; -}; - -&A53_3 { - cpu-supply = <&buck2>; -}; - -&i2c1 { - pmic: pmic@25 { - compatible = "nxp,pca9450b"; - reg = <0x25>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pmic>; - interrupt-parent = <&gpio1>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - - regulators { - buck1: BUCK1{ - regulator-name = "VDD_SOC"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <950000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck2: BUCK2 { - regulator-name = "VDD_ARM_0V9"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - nxp,dvs-run-voltage = <950000>; - nxp,dvs-standby-voltage = <850000>; - }; - - buck4: BUCK4{ - regulator-name = "VDD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5: BUCK5{ - regulator-name = "VDD_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6: BUCK6 { - regulator-name = "NVCC_DRAM_1V1"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1: LDO1 { - regulator-name = "NVCC_SNVS_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo2: LDO2 { - regulator-name = "VDD_SNVS_0V8"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo3: LDO3 { - regulator-name = "VDDA_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4: LDO4 { - regulator-name = "VDD_PHY_1V2"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo5: LDO5 { - regulator-name = "NVCC_SD2"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; -}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index dd139c1b223..cb8afce241d 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -151,6 +151,7 @@ config TARGET_IMX8MN_EVK select IMX8M_LPDDR4 select FSL_CAAM select SPL_CRYPTO if SPL + imply OF_UPSTREAM
config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" @@ -159,6 +160,7 @@ config TARGET_IMX8MN_DDR4_EVK select IMX8M_DDR4 select FSL_CAAM select SPL_CRYPTO if SPL + imply OF_UPSTREAM
config TARGET_IMX8MN_VENICE bool "Support Gateworks Venice iMX8M Nano module" diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index 743dea5c6c1..56b88808ebd 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mn-ddr4-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mn-ddr4-evk" CONFIG_SPL_TEXT_BASE=0x912000 CONFIG_TARGET_IMX8MN_DDR4_EVK=y CONFIG_SYS_MONITOR_LEN=524288 diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 5098fe527d8..91b7586a657 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mn-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mn-evk" CONFIG_SPL_TEXT_BASE=0x912000 CONFIG_TARGET_IMX8MN_EVK=y CONFIG_SYS_MONITOR_LEN=524288
Convert to OF_UPSTREAM for i.MX8MP EVK
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx8mp-evk.dts | 684 ---------------------------------------- arch/arm/mach-imx/imx8m/Kconfig | 1 + configs/imx8mp_evk_defconfig | 2 +- 4 files changed, 2 insertions(+), 686 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 56623d01240..7b7788f7550 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1101,7 +1101,6 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mp-dhcom-pdk2.dtb \ imx8mp-dhcom-pdk3.dtb \ imx8mp-dhcom-pdk3-overlay-rev100.dtbo \ - imx8mp-evk.dtb \ imx8mp-icore-mx8mp-edimm2.2.dtb \ imx8mp-msc-sm2s.dtb \ imx8mp-phyboard-pollux-rdk.dtb \ diff --git a/arch/arm/dts/imx8mp-evk.dts b/arch/arm/dts/imx8mp-evk.dts deleted file mode 100644 index 9f1469db554..00000000000 --- a/arch/arm/dts/imx8mp-evk.dts +++ /dev/null @@ -1,684 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 NXP - */ - -/dts-v1/; - -#include <dt-bindings/phy/phy-imx8-pcie.h> -#include "imx8mp.dtsi" - -/ { - model = "NXP i.MX8MPlus EVK board"; - compatible = "fsl,imx8mp-evk", "fsl,imx8mp"; - - chosen { - stdout-path = &uart2; - }; - - gpio-leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_gpio_led>; - - status { - label = "yellow:status"; - gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; - default-state = "on"; - }; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0x0 0x40000000 0 0xc0000000>, - <0x1 0x00000000 0 0xc0000000>; - }; - - pcie0_refclk: pcie0-refclk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <100000000>; - }; - - reg_can1_stby: regulator-can1-stby { - compatible = "regulator-fixed"; - regulator-name = "can1-stby"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan1_reg>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio5 5 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_can2_stby: regulator-can2-stby { - compatible = "regulator-fixed"; - regulator-name = "can2-stby"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan2_reg>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_pcie0: regulator-pcie { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie0_reg>; - regulator-name = "MPCIE_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 6 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; -}; - -&A53_0 { - cpu-supply = <®_arm>; -}; - -&A53_1 { - cpu-supply = <®_arm>; -}; - -&A53_2 { - cpu-supply = <®_arm>; -}; - -&A53_3 { - cpu-supply = <®_arm>; -}; - -&eqos { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_eqos>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy0>; - snps,force_thresh_dma_mode; - snps,mtl-tx-config = <&mtl_tx_setup>; - snps,mtl-rx-config = <&mtl_rx_setup>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - eee-broken-1000t; - reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - realtek,clkout-disable; - }; - }; - - mtl_tx_setup: tx-queues-config { - snps,tx-queues-to-use = <5>; - snps,tx-sched-sp; - - queue0 { - snps,dcb-algorithm; - snps,priority = <0x1>; - }; - - queue1 { - snps,dcb-algorithm; - snps,priority = <0x2>; - }; - - queue2 { - snps,dcb-algorithm; - snps,priority = <0x4>; - }; - - queue3 { - snps,dcb-algorithm; - snps,priority = <0x8>; - }; - - queue4 { - snps,dcb-algorithm; - snps,priority = <0xf0>; - }; - }; - - mtl_rx_setup: rx-queues-config { - snps,rx-queues-to-use = <5>; - snps,rx-sched-sp; - - queue0 { - snps,dcb-algorithm; - snps,priority = <0x1>; - snps,map-to-dma-channel = <0>; - }; - - queue1 { - snps,dcb-algorithm; - snps,priority = <0x2>; - snps,map-to-dma-channel = <1>; - }; - - queue2 { - snps,dcb-algorithm; - snps,priority = <0x4>; - snps,map-to-dma-channel = <2>; - }; - - queue3 { - snps,dcb-algorithm; - snps,priority = <0x8>; - snps,map-to-dma-channel = <3>; - }; - - queue4 { - snps,dcb-algorithm; - snps,priority = <0xf0>; - snps,map-to-dma-channel = <4>; - }; - }; -}; - -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy1>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy1: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - eee-broken-1000t; - reset-gpios = <&gpio4 2 GPIO_ACTIVE_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <80000>; - realtek,clkout-disable; - }; - }; -}; - -&flexcan1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan1>; - xceiver-supply = <®_can1_stby>; - status = "okay"; -}; - -&flexcan2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan2>; - xceiver-supply = <®_can2_stby>; - status = "disabled";/* can2 pin conflict with pdm */ -}; - -&i2c1 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - status = "okay"; - - pmic@25 { - compatible = "nxp,pca9450c"; - reg = <0x25>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pmic>; - interrupt-parent = <&gpio1>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - - regulators { - BUCK1 { - regulator-name = "BUCK1"; - regulator-min-microvolt = <720000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - reg_arm: BUCK2 { - regulator-name = "BUCK2"; - regulator-min-microvolt = <720000>; - regulator-max-microvolt = <1025000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - nxp,dvs-run-voltage = <950000>; - nxp,dvs-standby-voltage = <850000>; - }; - - BUCK4 { - regulator-name = "BUCK4"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3600000>; - regulator-boot-on; - regulator-always-on; - }; - - BUCK5 { - regulator-name = "BUCK5"; - regulator-min-microvolt = <1650000>; - regulator-max-microvolt = <1950000>; - regulator-boot-on; - regulator-always-on; - }; - - BUCK6 { - regulator-name = "BUCK6"; - regulator-min-microvolt = <1045000>; - regulator-max-microvolt = <1155000>; - regulator-boot-on; - regulator-always-on; - }; - - LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <1650000>; - regulator-max-microvolt = <1950000>; - regulator-boot-on; - regulator-always-on; - }; - - LDO3 { - regulator-name = "LDO3"; - regulator-min-microvolt = <1710000>; - regulator-max-microvolt = <1890000>; - regulator-boot-on; - regulator-always-on; - }; - - LDO5 { - regulator-name = "LDO5"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; -}; - -&i2c3 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - status = "okay"; - - pca6416: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pca6416_int>; - interrupt-parent = <&gpio1>; - interrupts = <12 IRQ_TYPE_LEVEL_LOW>; - gpio-line-names = "EXT_PWREN1", - "EXT_PWREN2", - "CAN1/I2C5_SEL", - "PDM/CAN2_SEL", - "FAN_EN", - "PWR_MEAS_IO1", - "PWR_MEAS_IO2", - "EXP_P0_7", - "EXP_P1_0", - "EXP_P1_1", - "EXP_P1_2", - "EXP_P1_3", - "EXP_P1_4", - "EXP_P1_5", - "EXP_P1_6", - "EXP_P1_7"; - }; -}; - -/* I2C on expansion connector J22. */ -&i2c5 { - clock-frequency = <100000>; /* Lower clock speed for external bus. */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c5>; - status = "disabled"; /* can1 pins conflict with i2c5 */ - - /* GPIO 2 of PCA6416 is used to switch between CAN1 and I2C5 functions: - * LOW: CAN1 (default, pull-down) - * HIGH: I2C5 - * You need to set it to high to enable I2C5 (for example, add gpio-hog - * in pca6416 node). - */ -}; - -&pcie_phy { - fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; - clocks = <&pcie0_refclk>; - clock-names = "ref"; - status = "okay"; -}; - -&pcie { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie0>; - reset-gpio = <&gpio2 7 GPIO_ACTIVE_LOW>; - clocks = <&clk IMX8MP_CLK_HSIO_ROOT>, - <&clk IMX8MP_CLK_PCIE_ROOT>, - <&clk IMX8MP_CLK_HSIO_AXI>; - clock-names = "pcie", "pcie_aux", "pcie_bus"; - assigned-clocks = <&clk IMX8MP_CLK_PCIE_AUX>; - assigned-clock-rates = <10000000>; - assigned-clock-parents = <&clk IMX8MP_SYS_PLL2_50M>; - vpcie-supply = <®_pcie0>; - status = "okay"; -}; - -&snvs_pwrkey { - status = "okay"; -}; - -&uart2 { - /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart2>; - status = "okay"; -}; - -&usb3_phy1 { - status = "okay"; -}; - -&usb3_1 { - status = "okay"; -}; - -&usb_dwc3_1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb1_vbus>; - dr_mode = "host"; - status = "okay"; -}; - -&usdhc2 { - assigned-clocks = <&clk IMX8MP_CLK_USDHC2>; - assigned-clock-rates = <400000000>; - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; - vmmc-supply = <®_usdhc2_vmmc>; - bus-width = <4>; - status = "okay"; -}; - -&usdhc3 { - assigned-clocks = <&clk IMX8MP_CLK_USDHC3>; - assigned-clock-rates = <400000000>; - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc3>; - pinctrl-1 = <&pinctrl_usdhc3_100mhz>; - pinctrl-2 = <&pinctrl_usdhc3_200mhz>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; - status = "okay"; -}; - -&iomuxc { - pinctrl_eqos: eqosgrp { - fsl,pins = < - MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x2 - MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x2 - MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x90 - MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x90 - MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x90 - MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x90 - MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x90 - MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x90 - MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x16 - MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x16 - MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x16 - MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x16 - MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x16 - MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x16 - MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x10 - >; - }; - - pinctrl_fec: fecgrp { - fsl,pins = < - MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x2 - MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x2 - MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x90 - MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x90 - MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x90 - MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x90 - MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x90 - MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x90 - MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x16 - MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x16 - MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x16 - MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x16 - MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x16 - MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x16 - MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x10 - >; - }; - - pinctrl_flexcan1: flexcan1grp { - fsl,pins = < - MX8MP_IOMUXC_SPDIF_RX__CAN1_RX 0x154 - MX8MP_IOMUXC_SPDIF_TX__CAN1_TX 0x154 - >; - }; - - pinctrl_flexcan2: flexcan2grp { - fsl,pins = < - MX8MP_IOMUXC_SAI5_MCLK__CAN2_RX 0x154 - MX8MP_IOMUXC_SAI5_RXD3__CAN2_TX 0x154 - >; - }; - - pinctrl_flexcan1_reg: flexcan1reggrp { - fsl,pins = < - MX8MP_IOMUXC_SPDIF_EXT_CLK__GPIO5_IO05 0x154 /* CAN1_STBY */ - >; - }; - - pinctrl_flexcan2_reg: flexcan2reggrp { - fsl,pins = < - MX8MP_IOMUXC_SAI2_MCLK__GPIO4_IO27 0x154 /* CAN2_STBY */ - >; - }; - - pinctrl_gpio_led: gpioledgrp { - fsl,pins = < - MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x140 - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x400001c2 - MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x400001c2 - >; - }; - - pinctrl_i2c3: i2c3grp { - fsl,pins = < - MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c2 - MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c2 - >; - }; - - pinctrl_i2c5: i2c5grp { - fsl,pins = < - MX8MP_IOMUXC_SPDIF_RX__I2C5_SDA 0x400001c2 - MX8MP_IOMUXC_SPDIF_TX__I2C5_SCL 0x400001c2 - >; - }; - - pinctrl_pcie0: pcie0grp { - fsl,pins = < - MX8MP_IOMUXC_I2C4_SCL__PCIE_CLKREQ_B 0x61 /* open drain, pull up */ - MX8MP_IOMUXC_SD1_DATA5__GPIO2_IO07 0x41 - >; - }; - - pinctrl_pcie0_reg: pcie0reggrp { - fsl,pins = < - MX8MP_IOMUXC_SD1_DATA4__GPIO2_IO06 0x41 - >; - }; - - pinctrl_pmic: pmicgrp { - fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO03__GPIO1_IO03 0x000001c0 - >; - }; - - pinctrl_pca6416_int: pca6416_int_grp { - fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO12__GPIO1_IO12 0x146 /* Input pull-up. */ - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x40 - >; - }; - - pinctrl_uart2: uart2grp { - fsl,pins = < - MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x140 - MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x140 - >; - }; - - pinctrl_usb1_vbus: usb1grp { - fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO14__USB2_OTG_PWR 0x10 - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x190 - MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d0 - MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d0 - MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0 - MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0 - MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { - fsl,pins = < - MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194 - MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4 - MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d4 - MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4 - MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4 - MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { - fsl,pins = < - MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196 - MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6 - MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d6 - MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6 - MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6 - MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 - >; - }; - - pinctrl_usdhc2_gpio: usdhc2gpiogrp { - fsl,pins = < - MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4 - >; - }; - - pinctrl_usdhc3: usdhc3grp { - fsl,pins = < - MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x190 - MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d0 - MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d0 - MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d0 - MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d0 - MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d0 - MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d0 - MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d0 - MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d0 - MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d0 - MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x190 - >; - }; - - pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { - fsl,pins = < - MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x194 - MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d4 - MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d4 - MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d4 - MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d4 - MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d4 - MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d4 - MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d4 - MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d4 - MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d4 - MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x194 - >; - }; - - pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { - fsl,pins = < - MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x196 - MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d6 - MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d6 - MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d6 - MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d6 - MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d6 - MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d6 - MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d6 - MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d6 - MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d6 - MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x196 - >; - }; - - pinctrl_wdog: wdoggrp { - fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0x166 - >; - }; -}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index cb8afce241d..fbde476a7f1 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -222,6 +222,7 @@ config TARGET_IMX8MP_EVK select FSL_CAAM select ARCH_MISC_INIT select SPL_CRYPTO if SPL + imply OF_UPSTREAM
config TARGET_IMX8MP_VENICE bool "Support Gateworks Venice iMX8M Plus module" diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index 2846faa8352..7e5dfce2ab6 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx8mp-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx8mp-evk" CONFIG_SPL_TEXT_BASE=0x920000 CONFIG_TARGET_IMX8MP_EVK=y CONFIG_SYS_MONITOR_LEN=524288
On Wed, Mar 27, 2024 at 10:46 PM Peng Fan (OSS) peng.fan@oss.nxp.com wrote:
This patchset is to convert NXP i.MX8M[Q,M,N,P] EVK boards to OF_UPSTREAM
Changes in v2:
- Sorry for the quick respin.
- Drop the dtb build in arch/arm/dts/Makefile
- Link to v1: https://lore.kernel.org/r/20240328-imx8m-v1-0-2be5e6657a88@nxp.com
Applied to u-boot-imx/next, thanks.
Fabio Estevam
Peng Fan (OSS)
