[U-Boot] [PATCH 0/4] clk: add support for cdce9xx clock synthesizer
This series adds basic support for TI cdce9xx clock synthesizers. The code is loosely based on linux side driver for the same, the DT binding is pretty much directly copied over from there.
This is needed initially just for setting up the crystal capacitance value for the TI IDK board family, which is using the synthesizer for providing networking clocks. If the capacitance value is incorrect, lost packets may occur.
-Tero
-- Texas Instruments Finland Oy, Porkkalankatu 22, 00180 Helsinki. Y-tunnus/Business ID: 0615521-4. Kotipaikka/Domicile: Helsinki
Add support for CDCE913/925/937/949 family of devices. These are modular PLL-based low cost, high performance, programmable clock synthesizers, multipliers and dividers. They generate up to 9 output clocks from a single input frequency. The initial version of the driver does not support programming of the PLLs, and thus they run in the bypass mode only. The code is loosely based on the linux kernel cdce9xx driver.
Signed-off-by: Tero Kristo t-kristo@ti.com --- doc/device-tree-bindings/clock/ti,cdce9xx.txt | 49 ++++ drivers/clk/Kconfig | 7 + drivers/clk/Makefile | 1 + drivers/clk/clk-cdce9xx.c | 254 ++++++++++++++++++ 4 files changed, 311 insertions(+) create mode 100644 doc/device-tree-bindings/clock/ti,cdce9xx.txt create mode 100644 drivers/clk/clk-cdce9xx.c
diff --git a/doc/device-tree-bindings/clock/ti,cdce9xx.txt b/doc/device-tree-bindings/clock/ti,cdce9xx.txt new file mode 100644 index 0000000000..0d01f2d5cc --- /dev/null +++ b/doc/device-tree-bindings/clock/ti,cdce9xx.txt @@ -0,0 +1,49 @@ +Binding for TI CDCE913/925/937/949 programmable I2C clock synthesizers. + +Reference +This binding uses the common clock binding[1]. + +[1] Documentation/devicetree/bindings/clock/clock-bindings.txt +[2] http://www.ti.com/product/cdce913 +[3] http://www.ti.com/product/cdce925 +[4] http://www.ti.com/product/cdce937 +[5] http://www.ti.com/product/cdce949 + +The driver provides clock sources for each output Y1 through Y5. + +Required properties: + - compatible: Shall be one of the following: + - "ti,cdce913": 1-PLL, 3 Outputs + - "ti,cdce925": 2-PLL, 5 Outputs + - "ti,cdce937": 3-PLL, 7 Outputs + - "ti,cdce949": 4-PLL, 9 Outputs + - reg: I2C device address. + - clocks: Points to a fixed parent clock that provides the input frequency. + - #clock-cells: From common clock bindings: Shall be 1. + +Optional properties: + - xtal-load-pf: Crystal load-capacitor value to fine-tune performance on a + board, or to compensate for external influences. + +For all PLL1, PLL2, ... an optional child node can be used to specify spread +spectrum clocking parameters for a board. + - spread-spectrum: SSC mode as defined in the data sheet. + - spread-spectrum-center: Use "centered" mode instead of "max" mode. When + present, the clock runs at the requested frequency on average. Otherwise + the requested frequency is the maximum value of the SCC range. + + +Example: + + clockgen: cdce925pw@64 { + compatible = "cdce925"; + reg = <0x64>; + clocks = <&xtal_27Mhz>; + #clock-cells = <1>; + xtal-load-pf = <5>; + /* PLL options to get SSC 1% centered */ + PLL2 { + spread-spectrum = <4>; + spread-spectrum-center; + }; + }; diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 95fe0aea2c..210494ea4b 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -125,6 +125,13 @@ config CLK_STM32MP1 Enable the STM32 clock (RCC) driver. Enable support for manipulating STM32MP1's on-SoC clocks.
+config CLK_CDCE9XX + bool "Enable CDCD9XX clock driver" + depends on CLK + help + Enable the clock synthesizer driver for CDCE913/925/937/949 + series of chips. + source "drivers/clk/analogbits/Kconfig" source "drivers/clk/at91/Kconfig" source "drivers/clk/exynos/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 68aabe1ca9..40b1f3b5b2 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -43,3 +43,4 @@ obj-$(CONFIG_SANDBOX) += clk_sandbox_test.o obj-$(CONFIG_SANDBOX_CLK_CCF) += clk_sandbox_ccf.o obj-$(CONFIG_STM32H7) += clk_stm32h7.o obj-$(CONFIG_CLK_TI_SCI) += clk-ti-sci.o +obj-$(CONFIG_CLK_CDCE9XX) += clk-cdce9xx.o diff --git a/drivers/clk/clk-cdce9xx.c b/drivers/clk/clk-cdce9xx.c new file mode 100644 index 0000000000..5d1489ab0e --- /dev/null +++ b/drivers/clk/clk-cdce9xx.c @@ -0,0 +1,254 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments CDCE913/925/937/949 clock synthesizer driver + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * Tero Kristo t-kristo@ti.com + * + * Based on Linux kernel clk-cdce925.c. + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <clk-uclass.h> +#include <i2c.h> + +#define MAX_NUMBER_OF_PLLS 4 +#define MAX_NUMER_OF_OUTPUTS 9 + +#define CDCE9XX_REG_GLOBAL1 0x01 +#define CDCE9XX_REG_Y1SPIPDIVH 0x02 +#define CDCE9XX_REG_PDIV1L 0x03 +#define CDCE9XX_REG_XCSEL 0x05 + +#define CDCE9XX_PDIV1_H_MASK 0x3 + +#define CDCE9XX_REG_PDIV(clk) (0x16 + (((clk) - 1) & 1) + \ + ((clk) - 1) / 2 * 0x10) + +#define CDCE9XX_PDIV_MASK 0x7f + +#define CDCE9XX_BYTE_TRANSFER BIT(7) + +struct cdce9xx_chip_info { + int num_plls; + int num_outputs; +}; + +struct cdce9xx_clk_data { + struct udevice *i2c; + struct cdce9xx_chip_info *chip; + u32 xtal_rate; +}; + +static const struct cdce9xx_chip_info cdce913_chip_info = { + .num_plls = 1, .num_outputs = 3, +}; + +static const struct cdce9xx_chip_info cdce925_chip_info = { + .num_plls = 2, .num_outputs = 5, +}; + +static const struct cdce9xx_chip_info cdce937_chip_info = { + .num_plls = 3, .num_outputs = 7, +}; + +static const struct cdce9xx_chip_info cdce949_chip_info = { + .num_plls = 4, .num_outputs = 9, +}; + +static int cdce9xx_reg_read(struct udevice *dev, u8 addr, u8 *buf) +{ + struct cdce9xx_clk_data *data = dev_get_priv(dev); + int ret; + + ret = dm_i2c_read(data->i2c, addr | CDCE9XX_BYTE_TRANSFER, buf, 1); + if (ret) + dev_err(dev, "%s: failed for addr:%x, ret:%d\n", __func__, + addr, ret); + + return ret; +} + +static int cdce9xx_reg_write(struct udevice *dev, u8 addr, u8 val) +{ + struct cdce9xx_clk_data *data = dev_get_priv(dev); + int ret; + + ret = dm_i2c_write(data->i2c, addr | CDCE9XX_BYTE_TRANSFER, &val, 1); + if (ret) + dev_err(dev, "%s: failed for addr:%x, ret:%d\n", __func__, + addr, ret); + + return ret; +} + +static int cdce9xx_clk_of_xlate(struct clk *clk, + struct ofnode_phandle_args *args) +{ + struct cdce9xx_clk_data *data = dev_get_priv(clk->dev); + + if (args->args_count != 1) + return -EINVAL; + + if (args->args[0] > data->chip->num_outputs) + return -EINVAL; + + clk->id = args->args[0]; + + return 0; +} + +static int cdce9xx_clk_probe(struct udevice *dev) +{ + struct cdce9xx_clk_data *data = dev_get_priv(dev); + struct cdce9xx_chip_info *chip = (void *)dev_get_driver_data(dev); + int ret; + u32 val; + struct clk clk; + + val = (u32)dev_read_addr_ptr(dev); + + ret = i2c_get_chip(dev->parent, val, 1, &data->i2c); + if (ret) { + dev_err(dev, "I2C probe failed.\n"); + return ret; + } + + data->chip = chip; + + ret = clk_get_by_index(dev, 0, &clk); + data->xtal_rate = clk_get_rate(&clk); + + val = dev_read_u32_default(dev, "xtal-load-pf", -1); + if (val >= 0) + cdce9xx_reg_write(dev, CDCE9XX_REG_XCSEL, val << 3); + + return 0; +} + +static u16 cdce9xx_clk_get_pdiv(struct clk *clk) +{ + u8 val; + u16 pdiv; + int ret; + + if (clk->id == 0) { + ret = cdce9xx_reg_read(clk->dev, CDCE9XX_REG_Y1SPIPDIVH, &val); + if (ret) + return 0; + + pdiv = (val & CDCE9XX_PDIV1_H_MASK) << 8; + + ret = cdce9xx_reg_read(clk->dev, CDCE9XX_REG_PDIV1L, &val); + if (ret) + return 0; + + pdiv |= val; + } else { + ret = cdce9xx_reg_read(clk->dev, CDCE9XX_REG_PDIV(clk->id), + &val); + if (ret) + return 0; + + pdiv = val & CDCE9XX_PDIV_MASK; + } + + return pdiv; +} + +static u32 cdce9xx_clk_get_parent_rate(struct clk *clk) +{ + struct cdce9xx_clk_data *data = dev_get_priv(clk->dev); + + return data->xtal_rate; +} + +static ulong cdce9xx_clk_get_rate(struct clk *clk) +{ + u32 parent_rate; + u16 pdiv; + + parent_rate = cdce9xx_clk_get_parent_rate(clk); + + pdiv = cdce9xx_clk_get_pdiv(clk); + + return parent_rate / pdiv; +} + +static ulong cdce9xx_clk_set_rate(struct clk *clk, ulong rate) +{ + u32 parent_rate; + int pdiv; + u32 diff; + u8 val; + int ret; + + parent_rate = cdce9xx_clk_get_parent_rate(clk); + + pdiv = parent_rate / rate; + + diff = rate - parent_rate / pdiv; + + if (rate - parent_rate / (pdiv + 1) < diff) + pdiv++; + + if (clk->id == 0) { + ret = cdce9xx_reg_read(clk->dev, CDCE9XX_REG_Y1SPIPDIVH, &val); + if (ret) + return ret; + + val &= ~CDCE9XX_PDIV1_H_MASK; + + val |= (pdiv >> 8); + + ret = cdce9xx_reg_write(clk->dev, CDCE9XX_REG_Y1SPIPDIVH, val); + if (ret) + return ret; + + ret = cdce9xx_reg_write(clk->dev, CDCE9XX_REG_PDIV1L, + (pdiv & 0xff)); + if (ret) + return ret; + } else { + ret = cdce9xx_reg_read(clk->dev, CDCE9XX_REG_PDIV(clk->id), + &val); + if (ret) + return ret; + + val &= ~CDCE9XX_PDIV_MASK; + + val |= pdiv; + + ret = cdce9xx_reg_write(clk->dev, CDCE9XX_REG_PDIV(clk->id), + val); + if (ret) + return ret; + } + + return 0; +} + +static const struct udevice_id cdce9xx_clk_of_match[] = { + { .compatible = "ti,cdce913", .data = (u32)&cdce913_chip_info }, + { .compatible = "ti,cdce925", .data = (u32)&cdce925_chip_info }, + { .compatible = "ti,cdce937", .data = (u32)&cdce937_chip_info }, + { .compatible = "ti,cdce949", .data = (u32)&cdce949_chip_info }, + { /* sentinel */ }, +}; + +static const struct clk_ops cdce9xx_clk_ops = { + .of_xlate = cdce9xx_clk_of_xlate, + .get_rate = cdce9xx_clk_get_rate, + .set_rate = cdce9xx_clk_set_rate, +}; + +U_BOOT_DRIVER(cdce9xx_clk) = { + .name = "cdce9xx-clk", + .id = UCLASS_CLK, + .of_match = cdce9xx_clk_of_match, + .probe = cdce9xx_clk_probe, + .priv_auto_alloc_size = sizeof(struct cdce9xx_clk_data), + .ops = &cdce9xx_clk_ops, +};
AM57xx-IDK boards contain the CDCE913 clock synthesizer, and their reset crystal capacitance load value of 10pF is wrong leading into lost packets in certain networking tests. Add DT data for this device, and probe it from the board file to program the crystal capacitance load value to 0pF to avoid any problems.
Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/dts/am571x-idk-u-boot.dtsi | 5 +++++ arch/arm/dts/am572x-idk-u-boot.dtsi | 5 +++++ arch/arm/dts/am574x-idk-u-boot.dtsi | 5 +++++ arch/arm/dts/am57xx-idk-common-u-boot.dtsi | 23 ++++++++++++++++++++++ board/ti/am57xx/board.c | 5 +++++ configs/am57xx_evm_defconfig | 2 ++ 6 files changed, 45 insertions(+) create mode 100644 arch/arm/dts/am571x-idk-u-boot.dtsi create mode 100644 arch/arm/dts/am572x-idk-u-boot.dtsi create mode 100644 arch/arm/dts/am574x-idk-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-idk-common-u-boot.dtsi
diff --git a/arch/arm/dts/am571x-idk-u-boot.dtsi b/arch/arm/dts/am571x-idk-u-boot.dtsi new file mode 100644 index 0000000000..65199200ed --- /dev/null +++ b/arch/arm/dts/am571x-idk-u-boot.dtsi @@ -0,0 +1,5 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "am57xx-idk-common-u-boot.dtsi" diff --git a/arch/arm/dts/am572x-idk-u-boot.dtsi b/arch/arm/dts/am572x-idk-u-boot.dtsi new file mode 100644 index 0000000000..65199200ed --- /dev/null +++ b/arch/arm/dts/am572x-idk-u-boot.dtsi @@ -0,0 +1,5 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "am57xx-idk-common-u-boot.dtsi" diff --git a/arch/arm/dts/am574x-idk-u-boot.dtsi b/arch/arm/dts/am574x-idk-u-boot.dtsi new file mode 100644 index 0000000000..65199200ed --- /dev/null +++ b/arch/arm/dts/am574x-idk-u-boot.dtsi @@ -0,0 +1,5 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "am57xx-idk-common-u-boot.dtsi" diff --git a/arch/arm/dts/am57xx-idk-common-u-boot.dtsi b/arch/arm/dts/am57xx-idk-common-u-boot.dtsi new file mode 100644 index 0000000000..b07aea0048 --- /dev/null +++ b/arch/arm/dts/am57xx-idk-common-u-boot.dtsi @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "omap5-u-boot.dtsi" + +/ { + xtal25mhz: xtal25mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; +}; + +&i2c1 { + cdce913: cdce913@65 { + compatible = "ti,cdce913"; + reg = <0x65>; + clocks = <&xtal25mhz>; + #clock-cells = <1>; + xtal-load-pf = <0>; + }; +}; diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index f78e6c2e1f..237a834c53 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -30,6 +30,7 @@ #include <dwc3-omap-uboot.h> #include <ti-usb-phy-uboot.h> #include <mmc.h> +#include <dm/uclass.h>
#include "../common/board_detect.h" #include "mux_data.h" @@ -689,6 +690,7 @@ int board_late_init(void) { setup_board_eeprom_env(); u8 val; + struct udevice *dev;
/* * DEV_CTRL.DEV_ON = 1 please - else palmas switches off in 8 seconds @@ -720,6 +722,9 @@ int board_late_init(void)
am57x_idk_lcd_detect();
+ /* Just probe the potentially supported cdce913 device */ + uclass_get_device(UCLASS_CLK, 0, &dev); + #if !defined(CONFIG_SPL_BUILD) board_ti_set_ethaddr(2); #endif diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 3b613e135c..e2f558cde7 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -98,3 +98,5 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 +CONFIG_CLK=y +CONFIG_CLK_CDCE9XX=y
AM43xx-IDK boards contain the CDCE913 clock synthesizer, and their reset crystal capacitance load value of 10pF is wrong leading into lost packets in certain networking tests. Add DT data for this device, and probe it from the board file to program the crystal capacitance load value to 0pF to avoid any problems.
Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/dts/am437x-idk-evm-u-boot.dtsi | 14 ++++++++++++++ board/ti/am43xx/board.c | 5 +++++ configs/am43xx_evm_defconfig | 2 ++ 3 files changed, 21 insertions(+)
diff --git a/arch/arm/dts/am437x-idk-evm-u-boot.dtsi b/arch/arm/dts/am437x-idk-evm-u-boot.dtsi index 3aa9195e44..50fe09cfc3 100644 --- a/arch/arm/dts/am437x-idk-evm-u-boot.dtsi +++ b/arch/arm/dts/am437x-idk-evm-u-boot.dtsi @@ -9,6 +9,12 @@ ocp { u-boot,dm-spl; }; + + xtal25mhz: xtal25mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; };
&uart0 { @@ -17,6 +23,14 @@
&i2c0 { u-boot,dm-spl; + + cdce913: cdce913@65 { + compatible = "ti,cdce913"; + reg = <0x65>; + clocks = <&xtal25mhz>; + #clock-cells = <1>; + xtal-load-pf = <0>; + }; };
&mmc1 { diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 2e09cc20e8..f5ecf871bc 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -720,6 +720,7 @@ static int device_okay(const char *path)
int board_late_init(void) { + struct udevice *dev; #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG set_board_info_env(NULL);
@@ -737,6 +738,10 @@ int board_late_init(void) if (device_okay("/ocp/omap_dwc3@483c0000")) enable_usb_clocks(1); #endif + + /* Just probe the potentially supported cdce913 device */ + uclass_get_device(UCLASS_CLK, 0, &dev); + return 0; } #endif diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 7c74047f3a..7367c6952b 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -78,3 +78,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0403 CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y +CONFIG_CLK=y +CONFIG_CLK_CDCE9XX=y
AM335x-ICE boards contain the CDCE913 clock synthesizer, and their reset crystal capacitance load value of 10pF is wrong leading into lost packets in certain networking tests. Add DT data for this device, and probe it from the board file to program the crystal capacitance load value to 0pF to avoid any problems.
Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/dts/am335x-icev2-u-boot.dtsi | 21 +++++++++++++++++++++ board/ti/am335x/board.c | 4 ++++ configs/am335x_evm_defconfig | 2 ++ 3 files changed, 27 insertions(+) create mode 100644 arch/arm/dts/am335x-icev2-u-boot.dtsi
diff --git a/arch/arm/dts/am335x-icev2-u-boot.dtsi b/arch/arm/dts/am335x-icev2-u-boot.dtsi new file mode 100644 index 0000000000..cc9569af03 --- /dev/null +++ b/arch/arm/dts/am335x-icev2-u-boot.dtsi @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ +/ { + xtal25mhz: xtal25mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; +}; + +&i2c0 { + cdce913: cdce913@65 { + compatible = "ti,cdce913"; + reg = <0x65>; + clocks = <&xtal25mhz>; + #clock-cells = <1>; + xtal-load-pf = <0>; + }; +}; diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 7eaa6cd96d..499c872227 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -791,6 +791,7 @@ int board_init(void) #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { + struct udevice *dev; #if !defined(CONFIG_SPL_BUILD) uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo; @@ -871,6 +872,9 @@ int board_late_init(void) env_set("serial#", board_serial); }
+ /* Just probe the potentially supported cdce913 device */ + uclass_get_device(UCLASS_CLK, 0, &dev); + return 0; } #endif diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 2aa9b65caf..93a28b290b 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -77,3 +77,5 @@ CONFIG_DYNAMIC_CRC_TABLE=y CONFIG_RSA=y CONFIG_LZO=y # CONFIG_OF_LIBFDT_OVERLAY is not set +CONFIG_CLK=y +CONFIG_CLK_CDCE9XX=y
Tero Kristo
