[U-Boot] [PATCH 5/5] cmd_sf: Fix code cleanup
- line over 80 characters - add tabs
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- common/cmd_sf.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/cmd_sf.c b/common/cmd_sf.c index 0a17782..1daff70 100644 --- a/common/cmd_sf.c +++ b/common/cmd_sf.c @@ -468,7 +468,8 @@ static int do_spi_flash_test(int argc, char * const argv[]) } #endif /* CONFIG_CMD_SF_TEST */
-static int do_spi_flash(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +static int do_spi_flash(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) { const char *cmd; int ret; @@ -524,7 +525,7 @@ U_BOOT_CMD( "SPI flash sub-system", "probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus\n" " and chip select\n" - "sf read addr offset len - read `len' bytes starting at\n" + "sf read addr offset len - read `len' bytes starting at\n" " `offset' to memory at `addr'\n" "sf write addr offset len - write `len' bytes from memory\n" " at `addr' to flash at `offset'\n"
