[U-Boot-Users] Dear All i come back now, very like this list
i am porting a pxa250's board to u-boot
i have initialize my MMU, STUART before the relocate, and i can see serial output now
but when my code bl to start_armboot the system maybe failed.
what's the reason may be ?
i have change the arm_boot to void start_armboot(void) { return ; } and i have get the serial output '012@3' the following is my start.S --------------------------------------------------------------------------------------------
/* * armboot - Startup Code for XScale * * Copyright (C) 1998 Dan Malek dmalek@jlc.net * Copyright (C) 1999 Magnus Damm <kieraypc01.p.y.kie.era.ericsson.se> * Copyright (C) 2000 Wolfgang Denk wd@denx.de * Copyright (C) 2001 Alex Z�pke azu@sysgo.de * Copyright (C) 2002 Kyle Harris kharris@nexus-tech.net * Copyright (C) 2003 Robert Schwebel r.schwebel@pengutronix.de * Copyright (C) 2003 Kai-Uwe Bloehm kai-uwe.bloem@auerswald.de * * See file CREDITS for list of people who contributed to this * project. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */
#include <config.h> #include "serial.h" #include <version.h>
.globl _start _start: b reset ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort ldr pc, _data_abort ldr pc, _not_used ldr pc, _irq ldr pc, _fiq
_undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort _data_abort: .word data_abort _not_used: .word not_used _irq: .word irq _fiq: .word fiq
.balignl 16,0xdeadbeef
/* * Startup Code (reset vector) * * do important init only if we don't start from memory! * - relocate armboot to ram * - setup stack * - jump to second stage */
_TEXT_BASE: .word TEXT_BASE
.globl _armboot_start _armboot_start: .word _start
/* * Note: _armboot_end_data and _armboot_end are defined * by the (board-dependent) linker script. * _armboot_end_data is the first usable FLASH address after armboot */ .globl _armboot_end_data _armboot_end_data: .word armboot_end_data .globl _armboot_end _armboot_end: .word armboot_end
/* * This is defined in the board specific linker script */ .globl _bss_start _bss_start: .word bss_start
.globl _bss_end _bss_end: .word bss_end
/* * _armboot_real_end is the first usable RAM address behind armboot * and the various stacks */ .globl _armboot_real_end _armboot_real_end: .word 0x0badc0de
/* * We relocate uboot to this address (end of RAM - 128 KiB) */ .globl _uboot_reloc _uboot_reloc: .word TEXT_BASE
#ifdef CONFIG_USE_IRQ /* IRQ stack memory (calculated at run-time) */ .globl IRQ_STACK_START IRQ_STACK_START: .word 0x0badc0de
/* IRQ stack memory (calculated at run-time) */ .globl FIQ_STACK_START FIQ_STACK_START: .word 0x0badc0de #endif
#ifdef CONFIG_GREENLAKE ser_init:
/* Enable UARTs GPIO GP46-RXD, GP47-TXD*/ /* GPIO Pin Direction GP46->in, GP47-out */ ldr r1, =0x40e00010 ldr r2, [r1] orr r2, r2, #0x8000 str r2, [r1]
/* GPIO Alternate Function GP46->10 GP47->01 */ ldr r1, =0x40e0005c ldr r2, [r1] orr r2, r2, #0x60000000 str r2, [r1]
/* Disable all interrupts */
ldr r1,=STUART_BASEADDR mov r2,#0 str r2,[r1,#IER_OFFSET]
/* set up the baud rate divisor (default 115200) */
mov r2, #0x80 str r2, [r1, #LCR_OFFSET] @ DLAB = 1 mov r2, #0x00 str r2, [r1, #DLH_OFFSET] /* 115200 */ mov r2, #8 str r2, [r1, #DLL_OFFSET]
/* Set the serial port to sensible defaults: no break, no interrupts, */ /* no parity, 8 databits, 1 stopbit. */ mov r2, #0x03 str r2, [r1, #LCR_OFFSET] str r2, [r1, #MCR_OFFSET]
/* Enable the transmitter and receiver FIFO's*/ mov r2, #0x01 str r2, [r1,#FCR_OFFSET] mov r2, #0x07 str r2, [r1,#FCR_OFFSET]
/* enable the UART */ mov r2,#0x40 str r2,[r1,#IER_OFFSET]
/* Enable the FFUART clock */ ldr r1,=0x41300000 ldr r2,[r1] orr r2,r2,#0x40 str r2,[r1]
mov pc, lr
led_show: ldr r0, =0x40e00000 ldr r3, [r0] orr r3, r3, #0x00000000 str r3, [r0]
ldr r0, =0x40e0000c ldr r3, [r0] orr r3, r3, #0x00010000 str r3, [r0]
ldr r0, =0x40e00024 ldr r3, [r0] orr r3, r3, #0x00010000 str r3, [r0]
mov pc, lr
.globl ser_printc
ser_printc: ldr r11,=STUART_BASEADDR ldr r11,[r11, #LSR_OFFSET] ands r11,r11,#0x020 beq ser_printc ldr r11,=STUART_BASEADDR str r0,[r11,#THR_OFFSET] teq r0,#'\n' moveq r0,#'\r' beq ser_printc mov pc,lr
#endif /****************************************************************************/
/* */ /* the actual reset code */ /* */ /****************************************************************************/
reset: mrs r0,cpsr /* set the cpu to SVC32 mode */ bic r0,r0,#0x1f /* (superviser mode, M=10011) */ orr r0,r0,#0x13 msr cpsr,r0 bl cpu_init_crit /* we do sys-critical inits */ #ifdef CONFIG_GREENLAKE mov r0, #'2' bl ser_printc #endif relocate: /* relocate U-Boot to RAM */ adr r0, _start /* r0 <- current position of code */ ldr r1, _TEXT_BASE /* test if we run from flash or RAM */ cmp r0, r1 /* don't reloc during debug */ beq stack_setup #ifdef CONFIG_GREENLAKE mov r2, r0 mov r0, #'@' bl ser_printc mov r0, r2 #endif #if 1 ldr r2, _armboot_start ldr r3, _armboot_end sub r2, r3, r2 /* r2 <- size of armboot */ add r2, r0, r2 /* r2 <- source end address */
copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ ble copy_loop #endif /* Set up the stack */
stack_setup: ldr r0, _uboot_reloc /* upper 128 KiB: relocated uboot */ sub r0, r0, #CFG_MALLOC_LEN /* malloc area */ /* FIXME: bdinfo should be here */ sub sp, r0, #12 /* leave 3 words for abort-stack */
clear_bss: ldr r0, _bss_start /* find start of bss segment */ add r0, r0, #4 /* start at first byte of bss */ ldr r1, _bss_end /* stop here */ mov r2, #0x00000000 /* clear */
clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 bne clbss_l #ifdef CONFIG_GREENLAKE mov r0, #'3' bl ser_printc #endif /* ldr pc, _start_armboot */ bl start_armboot mov r0, #'4' bl ser_printc
_start_armboot: .word start_armboot
/* */ /* CPU_init_critical registers */ /* */ /* - setup important registers */ /* - setup memory timing */ /* */ /****************************************************************************/
/* Interrupt-Controller base address */ IC_BASE: .word 0x40d00000 #define ICMR 0x04
/* Reset-Controller */ RST_BASE: .word 0x40f00030 #define RCSR 0x00
/* Operating System Timer */ OSTIMER_BASE: .word 0x40a00000 #define OSMR3 0x0C #define OSCR 0x10 #define OWER 0x18 #define OIER 0x1C
/* Clock Manager Registers */ CC_BASE: .word 0x41300000 #define CCCR 0x00 cpuspeed: .word CFG_CPUSPEED
/* RS: ??? */ .macro CPWAIT mrc p15,0,r0,c2,c0,0 mov r0,r0 sub pc,pc,#4 .endm
cpu_init_crit: mov r9, lr #ifdef CONFIG_GREENLAKE /* Enable access to co-processor 0. CP14 & CP15 cannot be disabled */ mrc p15, 0, r1, c15, c1, 0 orr r1, r1, #1 mcr p15, 0, r1, c15, c1, 0 CPWAIT
/* Make sure the MMU and caches are disabled. */ mrc p15, 0, r1, c1, c0, 0 ldr r2,=0x00000805 mvn r2, r2 and r1, r1, r2 mcr p15, 0, r1, c1, c0, 0
CPWAIT /* Flush the instruction, data cach, and the BTB */ mcr p15, 0, r1, c7, c7, 0
CPWAIT
/* Drain the write buffer and fill buffer */ mcr p15, 0, r1, c7, c10, 4 nop nop nop nop nop nop
/* light the LED9 */ mov ip, lr bl led_show mov lr, ip
mov ip, lr bl ser_init mov lr, ip
mov r0, #'x' mov ip, lr bl ser_printc mov lr, ip
mov r0, #'0' mov ip, lr bl ser_printc mov lr, ip #endif
/* mask all IRQs */ ldr r0, IC_BASE mov r1, #0x00 str r1, [r0, #ICMR] #if defined(CFG_CPUSPEED)
/* set clock speed */ ldr r0, CC_BASE ldr r1, cpuspeed str r1, [r0, #CCCR] mov r0, #2 mcr p14, 0, r0, c6, c0, 0
setspeed_done: #endif
/* * before relocating, we have to setup RAM timing * because memory timing is board-dependend, you will * find a memsetup.S in your board directory. */ mov ip, lr bl memsetup mov lr, ip #ifdef CONFIG_GREENLAKE mov r0, #'1' mov ip, lr bl ser_printc mov lr, ip #endif #if 0 /* Memory interfaces are working. Disable MMU and enable I-cache. */
ldr r0, =0x2001 /* enable access to all coproc. */ mcr p15, 0, r0, c15, c1, 0 CPWAIT
mcr p15, 0, r0, c7, c10, 4 /* drain the write & fill buffers */ CPWAIT
mcr p15, 0, r0, c7, c7, 0 /* flush Icache, Dcache and BTB */ CPWAIT
mcr p15, 0, r0, c8, c7, 0 /* flush instuction and data TLBs */ CPWAIT
/* Enable the Icache */ /* mrc p15, 0, r0, c1, c0, 0 orr r0, r0, #0x1800 mcr p15, 0, r0, c1, c0, 0 CPWAIT */ #endif mov lr, r9 mov pc, lr
/* */ /* Interrupt handling */ /* */ /****************************************************************************/
/* IRQ stack frame */
#define S_FRAME_SIZE 72
#define S_OLD_R0 68 #define S_PSR 64 #define S_PC 60 #define S_LR 56 #define S_SP 52
#define S_IP 48 #define S_FP 44 #define S_R10 40 #define S_R9 36 #define S_R8 32 #define S_R7 28 #define S_R6 24 #define S_R5 20 #define S_R4 16 #define S_R3 12 #define S_R2 8 #define S_R1 4 #define S_R0 0
#define MODE_SVC 0x13
/* use bad_save_user_regs for abort/prefetch/undef/swi ... */
.macro bad_save_user_regs sub sp, sp, #S_FRAME_SIZE stmia sp, {r0 - r12} /* Calling r0-r12 */ add r8, sp, #S_PC
ldr r2, _armboot_end add r2, r2, #CONFIG_STACKSIZE sub r2, r2, #8 ldmia r2, {r2 - r4} /* get pc, cpsr, old_r0 */ add r0, sp, #S_FRAME_SIZE /* restore sp_SVC */
add r5, sp, #S_SP mov r1, lr stmia r5, {r0 - r4} /* save sp_SVC, lr_SVC, pc, cpsr, old_r */ mov r0, sp .endm
/* use irq_save_user_regs / irq_restore_user_regs for */ /* IRQ/FIQ handling */
.macro irq_save_user_regs sub sp, sp, #S_FRAME_SIZE stmia sp, {r0 - r12} /* Calling r0-r12 */ add r8, sp, #S_PC stmdb r8, {sp, lr}^ /* Calling SP, LR */ str lr, [r8, #0] /* Save calling PC */ mrs r6, spsr str r6, [r8, #4] /* Save CPSR */ str r0, [r8, #8] /* Save OLD_R0 */ mov r0, sp .endm
.macro irq_restore_user_regs ldmia sp, {r0 - lr}^ @ Calling r0 - lr mov r0, r0 ldr lr, [sp, #S_PC] @ Get PC add sp, sp, #S_FRAME_SIZE subs pc, lr, #4 @ return & move spsr_svc into cpsr .endm
.macro get_bad_stack ldr r13, _armboot_end @ setup our mode stack add r13, r13, #CONFIG_STACKSIZE @ resides at top of normal stack sub r13, r13, #8
str lr, [r13] @ save caller lr / spsr mrs lr, spsr str lr, [r13, #4]
mov r13, #MODE_SVC @ prepare SVC-Mode msr spsr_c, r13 mov lr, pc movs pc, lr .endm
.macro get_irq_stack @ setup IRQ stack ldr sp, IRQ_STACK_START .endm
.macro get_fiq_stack @ setup FIQ stack ldr sp, FIQ_STACK_START .endm
/* */ /* exception handlers */ /* */ /****************************************************************************/
.align 5 undefined_instruction: get_bad_stack bad_save_user_regs bl do_undefined_instruction
.align 5 software_interrupt: get_bad_stack bad_save_user_regs bl do_software_interrupt
.align 5 prefetch_abort: get_bad_stack bad_save_user_regs bl do_prefetch_abort
.align 5 data_abort: get_bad_stack bad_save_user_regs bl do_data_abort
.align 5 not_used: get_bad_stack bad_save_user_regs bl do_not_used
.align 5 irq: get_irq_stack irq_save_user_regs bl do_irq irq_restore_user_regs
.align 5 fiq: get_fiq_stack irq_save_user_regs /* someone ought to write a more */ bl do_fiq /* effiction fiq_save_user_regs */ irq_restore_user_regs
#else
.align 5 irq: get_bad_stack bad_save_user_regs bl do_irq
.align 5 fiq: get_bad_stack bad_save_user_regs bl do_fiq
#endif
/* */ /* Reset function: the PXA250 doesn't have a reset function, so we have to */ /* perform a watchdog timeout for a soft reset. */ /* */ /****************************************************************************/
.align 5 .globl reset_cpu
/* FIXME: this code is PXA250 specific. How is this handled on */ /* other XScale processors? */
reset_cpu:
/* We set OWE:WME (watchdog enable) and wait until timeout happens */
ldr r0, OSTIMER_BASE ldr r1, [r0, #OWER] orr r1, r1, #0x0001 /* bit0: WME */ str r1, [r0, #OWER]
/* OS timer does only wrap every 1165 seconds, so we have to set */ /* the match register as well. */
ldr r1, [r0, #OSCR] /* read OS timer */ add r1, r1, #0x800 /* let OSMR3 match after */ add r1, r1, #0x800 /* 4096*(1/3.6864MHz)=1ms */ str r1, [r0, #OSMR3]
reset_endless:
b reset_endless
_________________________________________________________________ ������� MSN Explorer: http://explorer.msn.com/lccn/
"tang kelphon" kelphon@hotmail.com schreibt:
Which version of u-boot are you using?
- _armboot_real_end is the first usable RAM address behind armboot
- and the various stacks
Aww, this looks suspiciously like code from u-boot 0.x.x - please use a recent version (certain versions of the 0 series had trouble with XScale).
Cheers Anders
Anders Larsen
tang kelphon
