[PATCH] arch: mach-k3: Fix incorrect mapping of higher DDR addresses as device memory
Entry for physical address 0x500000000 in memory map table for MMU configuration is spilling over and inadvertently making DDR available at higher address (above 4GB address space) get mapped as device memory (nGnRnE).
Fix this by adjusting entry size. Tested on AM62A SK. Before this patch:
=> time crc32 0x881000000 0x20000000 crc32 for 881000000 ... 8a0ffffff ==> 7f34d7ca
time: 1 minutes, 14.716 seconds
After patch:
time: 2.710 seconds
Acked-by: Andrew Davis afd@ti.com Signed-off-by: Sekhar Nori nsekhar@ti.com --- Applies to u-boot/next
arch/arm/mach-k3/arm64-mmu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/arm64-mmu.c b/arch/arm/mach-k3/arm64-mmu.c index b4308205b2..0e07b1b7ce 100644 --- a/arch/arm/mach-k3/arm64-mmu.c +++ b/arch/arm/mach-k3/arm64-mmu.c @@ -41,7 +41,7 @@ struct mm_region k3_mem_map[] = { }, { .virt = 0x500000000UL, .phys = 0x500000000UL, - .size = 0x400000000UL, + .size = 0x380000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN
After patch:
time: 2.710 seconds
.attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN.size = 0x380000000UL,
-- 2.40.0
Thanks.
Reviewed-by: Nishanth Menon nm@ti.com
After patch:
time: 2.710 seconds
Acked-by: Andrew Davis afd@ti.com Signed-off-by: Sekhar Nori nsekhar@ti.com Reviewed-by: Nishanth Menon nm@ti.com
Nishanth Menon
Sekhar Nori
