Re: [U-Boot] u-boot jumps to some location
On 21/12/2011 12:36, siddharth baisane wrote:
Hi, I have generated u-boot-spl.bin but when I am trying to load it using code composer studio it is giving me error saying "could not determine target type of file".
Please send your answer always to the ML.
Sorry, I cannot help - I do not know why you are loading with Composer Studio, and if the tool has some check and do not allow to load any kind of binaries. You report you have a JTAG debugger, check into its manual to see how you can load a binary - a JTAG debugger has often a console with a set of commands.
Best regards, Stefano Babic
Please try loading u-boot-spl(ELF format) instead of u-boot-spl.bin, that may work.
br, Aneesh
Hi, so I am now trying to load u-boot-spl.bin using teraterm as per process given in following link "http://processors.wiki.ti.com/index.php/AM335x_U-Boot_User%27s_Guide#UART" *1)I kept uart mode and throug teraterm transfered u-boot-spl.bin.*2)As per document "After image is successfully downloaded, the ROM code will boot it" I did not get display of character on teraterm.
3)Then I transfered u-boot.img and this time also did not get display of any character on teraterm.
Am I doing anything wrong while transfering files or is there any specific way to do this ?? What ouput I should get after loading both files ?? I am trying to load these files on am3517 crane board.
Boot Over UART
*Note*
- The release package does not contain the binary for UART boot. Please follow the steps mentioned herehttp://processors.wiki.ti.com/index.php/AM335x_U-Boot_User%27s_Guide#Building_U-Bootfor compiling u-boot and use the *spl/u-boot-spl.bin* file that is produced.
1. Switch ON EVM with switch settings for UART boothttp://processors.wiki.ti.com/index.php/AM335x_U-Boot_User%27s_Guide#UART. When “CCCC” characters appear on TeraTerm window, from the File Menu select Transfer --> XMODEM --> Send (1K mode) 2. Select “u-boot-spl.bin” for the transfer 3. After image is successfully downloaded, the ROM code will boot it. 4. When “CCCC” characters appear on TeraTerm window, from the File Menu select Transfer --> YMODEM --> Send (1K mode) 5. Select “u-boot.img” for the transfer 6. After image is successfully downloaded, U-Boot will boot it. 7. Hit enter and get to u-boot prompt “U-Boot# ”
Siddharth,
[snip] [snip]
The wiki page only speaks about AM335x Board and the steps are tested on AM335x Board.
Also, just for info 1. Make sure while loading the u-boot-spl.bin, the Teraterm is using X-Modem protocol to send the Image
2. For sending u-boot.img, Teraterm should be using y-modem protocol.
Also, can you try with the latest Version of Teraterm. Old version had some issues with x & y modem protocol.
Boot Over UART
*Note*
- Switch ON EVM with switch settings for UART
boothttp://processors.wiki.ti.com/index.php/AM335x_U-Boot_User%27s_Guide#UART. When "CCCC" characters appear on TeraTerm window, from the File Menu select Transfer --> XMODEM --> Send (1K mode) 2. Select "u-boot-spl.bin" for the transfer 3. After image is successfully downloaded, the ROM code will boot it. 4. When "CCCC" characters appear on TeraTerm window, from the File Menu select Transfer --> YMODEM --> Send (1K mode) 5. Select "u-boot.img" for the transfer 6. After image is successfully downloaded, U-Boot will boot it. 7. Hit enter and get to u-boot prompt "U-Boot# "
Regards, Gururaja
Aneesh V
Hebbar, Gururaja
siddharth baisane
Stefano Babic
