[U-Boot] [PATCH v2 1/3] armv8: ls1012a: Add USB 2.0 controller phy type for ls1012aqds board
Without this propertiy, U-Boot will pop warning of 'USB phy type not defined' when select CONFIG_HAS_FSL_DR_USB.
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- arch/arm/dts/fsl-ls1012a-qds.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1012a-qds.dtsi b/arch/arm/dts/fsl-ls1012a-qds.dtsi index dde7134..d17cd99 100644 --- a/arch/arm/dts/fsl-ls1012a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1012a-qds.dtsi @@ -121,3 +121,8 @@ &duart0 { status = "okay"; }; + +&usb0 { + status = "okay"; + phy_type = "ulpi"; +};
When enable CONFIG_HAS_FSL_DR_USB, we might encounter below compile warning, apply this patch can fix it:
drivers/usb/host/ehci-fsl.c:109:4: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] ((u32)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); ^ drivers/usb/host/ehci-fsl.c:108:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] hcor = (struct ehci_hcor *) ^ drivers/usb/host/ehci-fsl.c:115:8: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] (u32)hccr, (u32)hcor, ^ include/log.h:131:26: note: in definition of macro 'debug_cond' printf(pr_fmt(fmt), ##args); \ ^~~~ drivers/usb/host/ehci-fsl.c:114:2: note: in expansion of macro 'debug' debug("ehci-fsl: init hccr %x and hcor %x hc_length %d\n", ^~~~~ drivers/usb/host/ehci-fsl.c:115:19: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] (u32)hccr, (u32)hcor, ^ include/log.h:131:26: note: in definition of macro 'debug_cond' printf(pr_fmt(fmt), ##args); \ ^~~~ drivers/usb/host/ehci-fsl.c:114:2: note: in expansion of macro 'debug' debug("ehci-fsl: init hccr %x and hcor %x hc_length %d\n", ^~~~~
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- drivers/usb/host/ehci-fsl.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 62c431b..17d1fae 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -106,14 +106,14 @@ static int ehci_fsl_probe(struct udevice *dev) ehci = (struct usb_ehci *)priv->hcd_base; hccr = (struct ehci_hccr *)(&ehci->caplength); hcor = (struct ehci_hcor *) - ((u32)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + ((void *)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
if (ehci_fsl_init(priv, ehci, hccr, hcor) < 0) return -ENXIO;
- debug("ehci-fsl: init hccr %x and hcor %x hc_length %d\n", - (u32)hccr, (u32)hcor, - (u32)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + debug("ehci-fsl: init hccr %p and hcor %p hc_length %d\n", + (void *)hccr, (void *)hcor, + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
return ehci_register(dev, hccr, hcor, &fsl_ehci_ops, 0, USB_INIT_HOST); }
Rename to USB_EHCI_FSL, use Kconfig to select ehci accordingly.
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- drivers/usb/host/Kconfig | 6 ++++++ include/configs/ls1012aqds.h | 11 ----------- include/configs/ls1021aqds.h | 11 ----------- include/configs/ls1021atwr.h | 20 -------------------- 4 files changed, 6 insertions(+), 42 deletions(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index c79f866..90b2f78 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -186,6 +186,12 @@ config USB_EHCI_GENERIC ---help--- Enables support for generic EHCI controller.
+config USB_EHCI_FSL + bool "Support for FSL on-chip EHCI USB controller" + default n + select CONFIG_EHCI_HCD_INIT_AFTER_RESET + ---help--- + Enables support for the on-chip EHCI controller on FSL chips. endif # USB_EHCI_HCD
config USB_OHCI_HCD diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index af5f37c..bf4262a 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -107,17 +107,6 @@ #define CONFIG_SF_DEFAULT_BUS 1 #define CONFIG_SF_DEFAULT_CS 0
-/* -* USB -*/ -/* EHCI Support - disbaled by default */ -/*#define CONFIG_HAS_FSL_DR_USB*/ - -#ifdef CONFIG_HAS_FSL_DR_USB -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#endif - /* MMC */ #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 6669f2f..d088e83 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -394,17 +394,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* - * USB - */ -/* EHCI Support - disbaled by default */ -/*#define CONFIG_HAS_FSL_DR_USB*/ - -#ifdef CONFIG_HAS_FSL_DR_USB -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#endif - -/* * Video */ #ifdef CONFIG_VIDEO_FSL_DCU_FB diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 3db7ef1..15d6638 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -24,26 +24,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR OCRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE OCRAM_SIZE
-/* - * USB - */ - -/* - * EHCI Support - disbaled by default as - * there is no signal coming out of soc on - * this board for this controller. However, - * the silicon still has this controller, - * and anyone can use this controller by - * taking signals out on their board. - */ - -/*#define CONFIG_HAS_FSL_DR_USB*/ - -#ifdef CONFIG_HAS_FSL_DR_USB -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#endif - #define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 100000000
Ran Wang
