[PATCH 1/5] x86: fsp: Use mtrr_set_next_var() for graphics memory
At present this uses mtrr_add_request() & mtrr_commit() combination to program the MTRR for graphics memory. This usage has two major issues as below:
- mtrr_commit() will re-initialize all MTRR registers from index 0, using the settings previously added by mtrr_add_request() and saved in gd->arch.mtrr_req[], which won't cause any issue but is unnecessary - The way such combination works is based on the assumption that U-Boot has full control with MTRR programming (e.g.: U-Boot without any blob that does all low-level initialization on its own, or using FSP2 which does not touch MTRR), but this is not the case with FSP. FSP programs some MTRRs during its execution but U-Boot does not have the settings saved in gd->arch.mtrr_req[] and when doing mtrr_commit() it will corrupt what was already programmed previously.
Correct this to use mtrr_set_next_var() instead.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/lib/fsp/fsp_graphics.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/x86/lib/fsp/fsp_graphics.c b/arch/x86/lib/fsp/fsp_graphics.c index 2bcc49f605..09d5da8c84 100644 --- a/arch/x86/lib/fsp/fsp_graphics.c +++ b/arch/x86/lib/fsp/fsp_graphics.c @@ -110,8 +110,7 @@ static int fsp_video_probe(struct udevice *dev) if (ret) goto err;
- mtrr_add_request(MTRR_TYPE_WRCOMB, vesa->phys_base_ptr, 256 << 20); - mtrr_commit(true); + mtrr_set_next_var(MTRR_TYPE_WRCOMB, vesa->phys_base_ptr, 256 << 20);
printf("%dx%dx%d @ %x\n", uc_priv->xsize, uc_priv->ysize, vesa->bits_per_pixel, vesa->phys_base_ptr);
drivers/video/broadwell_igd.c | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/video/broadwell_igd.c b/drivers/video/broadwell_igd.c index 6aa4e27071..83b6c908a8 100644 --- a/drivers/video/broadwell_igd.c +++ b/drivers/video/broadwell_igd.c @@ -693,13 +693,9 @@ static int broadwell_igd_probe(struct udevice *dev)
/* Use write-combining for the graphics memory, 256MB */ fbbase = IS_ENABLED(CONFIG_VIDEO_COPY) ? plat->copy_base : plat->base; - ret = mtrr_add_request(MTRR_TYPE_WRCOMB, fbbase, 256 << 20); - if (!ret) - ret = mtrr_commit(true); - if (ret && ret != -ENOSYS) { - printf("Failed to add MTRR: Display will be slow (err %d)\n", - ret); - } + ret = mtrr_set_next_var(MTRR_TYPE_WRCOMB, fbbase, 256 << 20); + if (ret) + printf("Failed to add MTRR: Display will be slow (err %d)\n", ret);
debug("fb=%lx, size %x, display size=%d %d %d\n", plat->base, plat->size, uc_priv->xsize, uc_priv->ysize, uc_priv->bpix);
drivers/video/ivybridge_igd.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/video/ivybridge_igd.c b/drivers/video/ivybridge_igd.c index 9264dd6770..c2cc976618 100644 --- a/drivers/video/ivybridge_igd.c +++ b/drivers/video/ivybridge_igd.c @@ -774,8 +774,7 @@ static int bd82x6x_video_probe(struct udevice *dev)
/* Use write-combining for the graphics memory, 256MB */ fbbase = IS_ENABLED(CONFIG_VIDEO_COPY) ? plat->copy_base : plat->base; - mtrr_add_request(MTRR_TYPE_WRCOMB, fbbase, 256 << 20); - mtrr_commit(true); + mtrr_set_next_var(MTRR_TYPE_WRCOMB, fbbase, 256 << 20);
return 0; }
drivers/video/vesa.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/video/vesa.c b/drivers/video/vesa.c index cac3bb0c33..50912c5c8b 100644 --- a/drivers/video/vesa.c +++ b/drivers/video/vesa.c @@ -23,8 +23,7 @@ static int vesa_video_probe(struct udevice *dev)
return 0; }
This function used to be for adding a list of requests to be actioned on relocation. Revert it back to this purpose, to avoid problems with boards which need control of their MTRRs (i.e. those which don't use FSP).
The mtrr_set_next_var() function is available when the next free variable-MTRR must be set, so this can be used instead.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Fixes: 3bcd6cf89ef ("x86: mtrr: Skip MSRs that were already programmed..") Fixes: 596bd0589ad ("x86: mtrr: Do not clear the unused ones..") Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/cpu/mtrr.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/mtrr.c b/arch/x86/cpu/mtrr.c index d57fcface0..9c24ae984e 100644 --- a/arch/x86/cpu/mtrr.c +++ b/arch/x86/cpu/mtrr.c @@ -166,8 +166,12 @@ int mtrr_commit(bool do_caches) debug("open done\n"); qsort(req, gd->arch.mtrr_req_count, sizeof(*req), h_comp_mtrr); for (i = 0; i < gd->arch.mtrr_req_count; i++, req++) - mtrr_set_next_var(req->type, req->start, req->size); + set_var_mtrr(i, req->type, req->start, req->size);
+ /* Clear the ones that are unused */ + debug("clear\n"); + for (; i < mtrr_get_var_count(); i++) + wrmsrl(MTRR_PHYS_MASK_MSR(i), 0); debug("close\n"); mtrr_close(&state, do_caches); debug("mtrr done\n");
Hi Bin,
Thanks for looking into this. The series works fine on link. I suspect it will be find on samus too, but I cannot test right now. Sadly minnowmax is also dead right now but I hope to fix it soon. I don't expect any problems there.
However, for coral, this first patch breaks the mtrrs. With master we get:
=> mtrr CPU 0: Reg Valid Write-type Base || Mask || Size || 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000
with this patch on coral we get:
=> mtrr CPU 0: Reg Valid Write-type Base || Mask || Size || 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 2 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000
At present coral expects to handle the MTRRs itself, and it seems that perhaps the APL FSPv2 does not? Do we need a new Kconfig for dealing with FSPv2 perhaps?
Hi Simon,
On Sun, Jul 23, 2023 at 11:43 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
I am a little bit confused. The comment in arch/x86/lib/fsp/fsp_dram.c:: dram_init_banksize() says:
/* * For FSP1, the system memory and reserved memory used by FSP are * already programmed in the MTRR by FSP. Also it is observed that * FSP on Intel Queensbay platform reports the TSEG memory range * that has the same RES_MEM_RESERVED resource type whose address * is programmed by FSP to be near the top of 4 GiB space, which is * not what we want for DRAM. * * However it seems FSP2's behavior is different. We need to add the * DRAM range in MTRR otherwise the boot process goes very slowly, * which was observed on Chromebook Coral with FSP2. */
So on Coral with FSP2, U-Boot programs the MTTR by itself.
In this dram_init_banksize(), it calls mtrr_add_request() 3 times, 2 of which should be what you were seeing as 2 and 4 below:
The #3 should be the FSP graphics frame buffer. But I failed to understand how the FSP graphics programs a MTRR register in between the 2 memory regions programmed by dram_init_banksize() on u-boot/master, how could that happen?
On the other hand, with this patch, how could the FSP graphics memory programs a MTRR register that should be programmed by dram_init_banksize()?
Regards, Bin
Hi Bin,
On Sun, 23 Jul 2023 at 09:50, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Remember that the MTRRs are sorted, so the order or mtrr_add_request() calls does not matter.
I believe this adds a new mtrr and then commits the result.
Hi Simon,
On Mon, Jul 24, 2023 at 6:14 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Still cannot explain.
After we sort the mtrr memory range, #2 whose base is 0x0 should have been put to the first entry, then followed by #3 whose base is 0xb0000000.
Regards, Bin
Hi Bin,
On Tue, 25 Jul 2023 at 07:43, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Right, but the thing is, your first patch does not revert the behaviour of mtrr_add_request(). It is still just adding to the end.
i.e. mtrr_commt() adds new ones but does not overwrite those at the back.
Looking at your full series, this is what I see on coral:
But I see that do_mtrr is wrong for coral in init_cache_f_r():
do_mtrr &= !IS_ENABLED(CONFIG_SPL) &&
So with coral the mtrrs are never written?
Hi Simon,
On Thu, Jul 27, 2023 at 8:55 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Yes, it seems this place is the culprit. The comment says:
* Note: if there is an SPL, then it has already set up MTRRs so we * don't need to do that here
So on Coral, the assumption of SPL programming MTRRs is wrong.
Maybe we should do:
bool do_mtrr = CONFIG_IS_ENABLED(X86_32BIT_INIT);
do_mtrr &= (!IS_ENABLED(CONFIG_SPL) || IS_ENABLED(CONFIG_FSP_VERSION2)) && !IS_ENABLED(CONFIG_FSP_VERSION1) && !IS_ENABLED(CONFIG_SYS_SLIMBOOTLOADER);
Will this work?
Regards, Bin
Hi Bin,
On Fri, 28 Jul 2023 at 03:38, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
On Fri, 21 Jul 2023 at 10:12, Bin Meng bmeng.cn@gmail.com wrote: > > At present this uses mtrr_add_request() & mtrr_commit() combination > to program the MTRR for graphics memory. This usage has two major > issues as below: > > - mtrr_commit() will re-initialize all MTRR registers from index 0, > using the settings previously added by mtrr_add_request() and saved > in gd->arch.mtrr_req[], which won't cause any issue but is unnecessary > - The way such combination works is based on the assumption that U-Boot > has full control with MTRR programming (e.g.: U-Boot without any blob > that does all low-level initialization on its own, or using FSP2 which > does not touch MTRR), but this is not the case with FSP. FSP programs > some MTRRs during its execution but U-Boot does not have the settings > saved in gd->arch.mtrr_req[] and when doing mtrr_commit() it will > corrupt what was already programmed previously. > > Correct this to use mtrr_set_next_var() instead. > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > --- > > arch/x86/lib/fsp/fsp_graphics.c | 3 +-- > 1 file changed, 1 insertion(+), 2 deletions(-)
Maybe we should do:
Will this work?
Unfortunately not. In fact I don't think we need to change this function.
For coral the sequence is: SPL manually messes with MTRRs to add two MTRRs for SPI flash SPL jumps to U-Boot proper now we start the global_data with 0 MTRR requests fsp_init_banksize() runs and adds two MTRR requests (uncommitted) init_cache_f_r() runs, but does not call mtrr_commit() fsp_graphics_probe() adds one MTRR request, making 5 in total fsp_graphics_probe() calls mtrr_commit()
So I think if we adjust fsp_graphics to either add a request and commit (for FSP2) or just add next var (for other things) we might be OK
Here is a run on coral with my modifications at https://github.com/sjg20/u-boot/tree/for-bin
U-Boot 2023.10-rc1-00014-g37d6c899d4b (Jul 28 2023 - 09:58:37 -0600)
CPU: Intel(R) Celeron(R) CPU N3450 @ 1.10GHz DRAM: dram - add req - add req dram done 4 GiB (effective 3.9 GiB) do_mtrr 0 Core: 67 devices, 35 uclasses, devicetree: separate MMC: sdmmc@1b,0: 1, emmc@1c,0: 0 Loading Environment from nowhere... OK Video: graphics Reg Valid Write-type Base || Mask || Size || 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 2 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 4 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 - add req commit, do_caches=1 Reg Valid Write-type Base || Mask || Size || 0 Y Back 0000000000000000 0000007f80000000 0000000080000000 1 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 2 Y Back 0000000100000000 0000007f80000000 0000000080000000 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 4 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 graphics done 1024x768x32 @ b0000000 Model: Google Coral Net: eth_initialize() No ethernet found. SF: Detected w25q128fw with page size 256 Bytes, erase size 4 KiB, total 16 MiB Hit any key to stop autoboot: 0 => mtrr CPU 0: Reg Valid Write-type Base || Mask || Size || 0 Y Back 0000000000000000 0000007f80000000 0000000080000000 1 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 2 Y Back 0000000100000000 0000007f80000000 0000000080000000 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 4 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 =>
Hi Simon,
On Sat, Jul 29, 2023 at 12:03 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
On Sun, Jul 23, 2023 at 11:43 AM Simon Glass sjg@chromium.org wrote: > > Hi Bin, > > On Fri, 21 Jul 2023 at 10:12, Bin Meng bmeng.cn@gmail.com wrote: > > > > At present this uses mtrr_add_request() & mtrr_commit() combination > > to program the MTRR for graphics memory. This usage has two major > > issues as below: > > > > - mtrr_commit() will re-initialize all MTRR registers from index 0, > > using the settings previously added by mtrr_add_request() and saved > > in gd->arch.mtrr_req[], which won't cause any issue but is unnecessary > > - The way such combination works is based on the assumption that U-Boot > > has full control with MTRR programming (e.g.: U-Boot without any blob > > that does all low-level initialization on its own, or using FSP2 which > > does not touch MTRR), but this is not the case with FSP. FSP programs > > some MTRRs during its execution but U-Boot does not have the settings > > saved in gd->arch.mtrr_req[] and when doing mtrr_commit() it will > > corrupt what was already programmed previously. > > > > Correct this to use mtrr_set_next_var() instead. > > > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > > --- > > > > arch/x86/lib/fsp/fsp_graphics.c | 3 +-- > > 1 file changed, 1 insertion(+), 2 deletions(-) > > Thanks for looking into this. The series works fine on link. I suspect > it will be find on samus too, but I cannot test right now. Sadly > minnowmax is also dead right now but I hope to fix it soon. I don't > expect any problems there. > > However, for coral, this first patch breaks the mtrrs. With master we get: > > => mtrr > CPU 0: > Reg Valid Write-type Base || Mask || Size || > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > with this patch on coral we get: > > => mtrr > CPU 0: > Reg Valid Write-type Base || Mask || Size || > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > 2 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > At present coral expects to handle the MTRRs itself, and it seems that > perhaps the APL FSPv2 does not? Do we need a new Kconfig for dealing > with FSPv2 perhaps?
Maybe we should do:
Will this work?
But with my proposed change, mtrr_commit() should be called here. Why does it not work?
- add req
- add req
- add req
Regards, Bin
Hi Bin,
On Fri, 28 Jul 2023 at 10:44, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
On Sun, 23 Jul 2023 at 09:50, Bin Meng bmeng.cn@gmail.com wrote: > > Hi Simon, > > On Sun, Jul 23, 2023 at 11:43 AM Simon Glass sjg@chromium.org wrote: > > > > Hi Bin, > > > > On Fri, 21 Jul 2023 at 10:12, Bin Meng bmeng.cn@gmail.com wrote: > > > > > > At present this uses mtrr_add_request() & mtrr_commit() combination > > > to program the MTRR for graphics memory. This usage has two major > > > issues as below: > > > > > > - mtrr_commit() will re-initialize all MTRR registers from index 0, > > > using the settings previously added by mtrr_add_request() and saved > > > in gd->arch.mtrr_req[], which won't cause any issue but is unnecessary > > > - The way such combination works is based on the assumption that U-Boot > > > has full control with MTRR programming (e.g.: U-Boot without any blob > > > that does all low-level initialization on its own, or using FSP2 which > > > does not touch MTRR), but this is not the case with FSP. FSP programs > > > some MTRRs during its execution but U-Boot does not have the settings > > > saved in gd->arch.mtrr_req[] and when doing mtrr_commit() it will > > > corrupt what was already programmed previously. > > > > > > Correct this to use mtrr_set_next_var() instead. > > > > > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > > > --- > > > > > > arch/x86/lib/fsp/fsp_graphics.c | 3 +-- > > > 1 file changed, 1 insertion(+), 2 deletions(-) > > > > Thanks for looking into this. The series works fine on link. I suspect > > it will be find on samus too, but I cannot test right now. Sadly > > minnowmax is also dead right now but I hope to fix it soon. I don't > > expect any problems there. > > > > However, for coral, this first patch breaks the mtrrs. With master we get: > > > > => mtrr > > CPU 0: > > Reg Valid Write-type Base || Mask || Size || > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > with this patch on coral we get: > > > > => mtrr > > CPU 0: > > Reg Valid Write-type Base || Mask || Size || > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > 2 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > At present coral expects to handle the MTRRs itself, and it seems that > > perhaps the APL FSPv2 does not? Do we need a new Kconfig for dealing > > with FSPv2 perhaps? > > I am a little bit confused. The comment in arch/x86/lib/fsp/fsp_dram.c:: > dram_init_banksize() says: > > /* > * For FSP1, the system memory and reserved memory used by FSP are > * already programmed in the MTRR by FSP. Also it is observed that > * FSP on Intel Queensbay platform reports the TSEG memory range > * that has the same RES_MEM_RESERVED resource type whose address > * is programmed by FSP to be near the top of 4 GiB space, which is > * not what we want for DRAM. > * > * However it seems FSP2's behavior is different. We need to add the > * DRAM range in MTRR otherwise the boot process goes very slowly, > * which was observed on Chromebook Coral with FSP2. > */ > > So on Coral with FSP2, U-Boot programs the MTTR by itself. > > In this dram_init_banksize(), it calls mtrr_add_request() 3 times, 2 > of which should be what you were seeing as 2 and 4 below: > > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > The #3 should be the FSP graphics frame buffer. But I failed to > understand how the FSP graphics programs a MTRR register in between > the 2 memory regions programmed by dram_init_banksize() on > u-boot/master, how could that happen?
Maybe we should do:
Will this work?
Firstly it is still running from SPI flash, so the commit makes everything run very slow from this point, since it drops those two MTRRs. So we don't want to commit the MTRRs yet.
But yes it does work, in that we end up with three MTRRs (two DRAM and one graphics). It's just very slow getting to that point. That's why I think we should stick with fsp_graphics_probe() doing the commit, for FSPv2.
- add req
- add req
- add req
Hi Simon,
On Sat, Jul 29, 2023 at 1:11 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
On Mon, Jul 24, 2023 at 6:14 AM Simon Glass sjg@chromium.org wrote: > > Hi Bin, > > On Sun, 23 Jul 2023 at 09:50, Bin Meng bmeng.cn@gmail.com wrote: > > > > Hi Simon, > > > > On Sun, Jul 23, 2023 at 11:43 AM Simon Glass sjg@chromium.org wrote: > > > > > > Hi Bin, > > > > > > On Fri, 21 Jul 2023 at 10:12, Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > At present this uses mtrr_add_request() & mtrr_commit() combination > > > > to program the MTRR for graphics memory. This usage has two major > > > > issues as below: > > > > > > > > - mtrr_commit() will re-initialize all MTRR registers from index 0, > > > > using the settings previously added by mtrr_add_request() and saved > > > > in gd->arch.mtrr_req[], which won't cause any issue but is unnecessary > > > > - The way such combination works is based on the assumption that U-Boot > > > > has full control with MTRR programming (e.g.: U-Boot without any blob > > > > that does all low-level initialization on its own, or using FSP2 which > > > > does not touch MTRR), but this is not the case with FSP. FSP programs > > > > some MTRRs during its execution but U-Boot does not have the settings > > > > saved in gd->arch.mtrr_req[] and when doing mtrr_commit() it will > > > > corrupt what was already programmed previously. > > > > > > > > Correct this to use mtrr_set_next_var() instead. > > > > > > > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > > > > --- > > > > > > > > arch/x86/lib/fsp/fsp_graphics.c | 3 +-- > > > > 1 file changed, 1 insertion(+), 2 deletions(-) > > > > > > Thanks for looking into this. The series works fine on link. I suspect > > > it will be find on samus too, but I cannot test right now. Sadly > > > minnowmax is also dead right now but I hope to fix it soon. I don't > > > expect any problems there. > > > > > > However, for coral, this first patch breaks the mtrrs. With master we get: > > > > > > => mtrr > > > CPU 0: > > > Reg Valid Write-type Base || Mask || Size || > > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > > 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > > with this patch on coral we get: > > > > > > => mtrr > > > CPU 0: > > > Reg Valid Write-type Base || Mask || Size || > > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > > 2 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > > At present coral expects to handle the MTRRs itself, and it seems that > > > perhaps the APL FSPv2 does not? Do we need a new Kconfig for dealing > > > with FSPv2 perhaps? > > > > I am a little bit confused. The comment in arch/x86/lib/fsp/fsp_dram.c:: > > dram_init_banksize() says: > > > > /* > > * For FSP1, the system memory and reserved memory used by FSP are > > * already programmed in the MTRR by FSP. Also it is observed that > > * FSP on Intel Queensbay platform reports the TSEG memory range > > * that has the same RES_MEM_RESERVED resource type whose address > > * is programmed by FSP to be near the top of 4 GiB space, which is > > * not what we want for DRAM. > > * > > * However it seems FSP2's behavior is different. We need to add the > > * DRAM range in MTRR otherwise the boot process goes very slowly, > > * which was observed on Chromebook Coral with FSP2. > > */ > > > > So on Coral with FSP2, U-Boot programs the MTTR by itself. > > > > In this dram_init_banksize(), it calls mtrr_add_request() 3 times, 2 > > of which should be what you were seeing as 2 and 4 below: > > > > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > > > The #3 should be the FSP graphics frame buffer. But I failed to > > understand how the FSP graphics programs a MTRR register in between > > the 2 memory regions programmed by dram_init_banksize() on > > u-boot/master, how could that happen? > > Remember that the MTRRs are sorted, so the order or mtrr_add_request() > calls does not matter. >
Maybe we should do:
Will this work?
It's possible that someone does not include FSP_GRAPHICS on Coral so you rely on fsp_graphics_probe() doing the commit is not going to work.
Besides, the logic of doing mtrr commit in fsp_graphics_probe() does not keep everything in consistency.
This Coral issue, it sounds like we should fix arch/x86/cpu/apollolake/cpu_spl.c::arch_cpu_init_spl() to call mtrr_commit() for the cache of SPI flash in the SPL phase.
- add req
- add req
- add req
Hi Simon,
On Mon, Jul 31, 2023 at 7:01 AM Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
On Tue, 25 Jul 2023 at 07:43, Bin Meng bmeng.cn@gmail.com wrote: > > Hi Simon, > > On Mon, Jul 24, 2023 at 6:14 AM Simon Glass sjg@chromium.org wrote: > > > > Hi Bin, > > > > On Sun, 23 Jul 2023 at 09:50, Bin Meng bmeng.cn@gmail.com wrote: > > > > > > Hi Simon, > > > > > > On Sun, Jul 23, 2023 at 11:43 AM Simon Glass sjg@chromium.org wrote: > > > > > > > > Hi Bin, > > > > > > > > On Fri, 21 Jul 2023 at 10:12, Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > At present this uses mtrr_add_request() & mtrr_commit() combination > > > > > to program the MTRR for graphics memory. This usage has two major > > > > > issues as below: > > > > > > > > > > - mtrr_commit() will re-initialize all MTRR registers from index 0, > > > > > using the settings previously added by mtrr_add_request() and saved > > > > > in gd->arch.mtrr_req[], which won't cause any issue but is unnecessary > > > > > - The way such combination works is based on the assumption that U-Boot > > > > > has full control with MTRR programming (e.g.: U-Boot without any blob > > > > > that does all low-level initialization on its own, or using FSP2 which > > > > > does not touch MTRR), but this is not the case with FSP. FSP programs > > > > > some MTRRs during its execution but U-Boot does not have the settings > > > > > saved in gd->arch.mtrr_req[] and when doing mtrr_commit() it will > > > > > corrupt what was already programmed previously. > > > > > > > > > > Correct this to use mtrr_set_next_var() instead. > > > > > > > > > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > > > > > --- > > > > > > > > > > arch/x86/lib/fsp/fsp_graphics.c | 3 +-- > > > > > 1 file changed, 1 insertion(+), 2 deletions(-) > > > > > > > > Thanks for looking into this. The series works fine on link. I suspect > > > > it will be find on samus too, but I cannot test right now. Sadly > > > > minnowmax is also dead right now but I hope to fix it soon. I don't > > > > expect any problems there. > > > > > > > > However, for coral, this first patch breaks the mtrrs. With master we get: > > > > > > > > => mtrr > > > > CPU 0: > > > > Reg Valid Write-type Base || Mask || Size || > > > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > > > 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > > > > with this patch on coral we get: > > > > > > > > => mtrr > > > > CPU 0: > > > > Reg Valid Write-type Base || Mask || Size || > > > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > > > 2 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > > 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > > > > At present coral expects to handle the MTRRs itself, and it seems that > > > > perhaps the APL FSPv2 does not? Do we need a new Kconfig for dealing > > > > with FSPv2 perhaps? > > > > > > I am a little bit confused. The comment in arch/x86/lib/fsp/fsp_dram.c:: > > > dram_init_banksize() says: > > > > > > /* > > > * For FSP1, the system memory and reserved memory used by FSP are > > > * already programmed in the MTRR by FSP. Also it is observed that > > > * FSP on Intel Queensbay platform reports the TSEG memory range > > > * that has the same RES_MEM_RESERVED resource type whose address > > > * is programmed by FSP to be near the top of 4 GiB space, which is > > > * not what we want for DRAM. > > > * > > > * However it seems FSP2's behavior is different. We need to add the > > > * DRAM range in MTRR otherwise the boot process goes very slowly, > > > * which was observed on Chromebook Coral with FSP2. > > > */ > > > > > > So on Coral with FSP2, U-Boot programs the MTTR by itself. > > > > > > In this dram_init_banksize(), it calls mtrr_add_request() 3 times, 2 > > > of which should be what you were seeing as 2 and 4 below: > > > > > > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > > > > > The #3 should be the FSP graphics frame buffer. But I failed to > > > understand how the FSP graphics programs a MTRR register in between > > > the 2 memory regions programmed by dram_init_banksize() on > > > u-boot/master, how could that happen? > > > > Remember that the MTRRs are sorted, so the order or mtrr_add_request() > > calls does not matter. > > > > Still cannot explain. > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > After we sort the mtrr memory range, #2 whose base is 0x0 should have > been put to the first entry, then followed by #3 whose base is > 0xb0000000.
Maybe we should do:
Will this work?
Another possible place to insert the mtrr_commit() is ich_spi_probe().
Currently it programmed the MTRR for TPL, but not for SPL.
I suspect the TPL phase is duplicate since it is already programmed in the arch/x86/cpu/apollolake/cpu_spl.c::arch_cpu_init_tpl().
Regards, Bin
Hi Bin,
On Sun, 30 Jul 2023 at 17:18, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
On Thu, Jul 27, 2023 at 8:55 AM Simon Glass sjg@chromium.org wrote: > > Hi Bin, > > On Tue, 25 Jul 2023 at 07:43, Bin Meng bmeng.cn@gmail.com wrote: > > > > Hi Simon, > > > > On Mon, Jul 24, 2023 at 6:14 AM Simon Glass sjg@chromium.org wrote: > > > > > > Hi Bin, > > > > > > On Sun, 23 Jul 2023 at 09:50, Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > Hi Simon, > > > > > > > > On Sun, Jul 23, 2023 at 11:43 AM Simon Glass sjg@chromium.org wrote: > > > > > > > > > > Hi Bin, > > > > > > > > > > On Fri, 21 Jul 2023 at 10:12, Bin Meng bmeng.cn@gmail.com wrote: > > > > > > > > > > > > At present this uses mtrr_add_request() & mtrr_commit() combination > > > > > > to program the MTRR for graphics memory. This usage has two major > > > > > > issues as below: > > > > > > > > > > > > - mtrr_commit() will re-initialize all MTRR registers from index 0, > > > > > > using the settings previously added by mtrr_add_request() and saved > > > > > > in gd->arch.mtrr_req[], which won't cause any issue but is unnecessary > > > > > > - The way such combination works is based on the assumption that U-Boot > > > > > > has full control with MTRR programming (e.g.: U-Boot without any blob > > > > > > that does all low-level initialization on its own, or using FSP2 which > > > > > > does not touch MTRR), but this is not the case with FSP. FSP programs > > > > > > some MTRRs during its execution but U-Boot does not have the settings > > > > > > saved in gd->arch.mtrr_req[] and when doing mtrr_commit() it will > > > > > > corrupt what was already programmed previously. > > > > > > > > > > > > Correct this to use mtrr_set_next_var() instead. > > > > > > > > > > > > Signed-off-by: Bin Meng bmeng.cn@gmail.com > > > > > > --- > > > > > > > > > > > > arch/x86/lib/fsp/fsp_graphics.c | 3 +-- > > > > > > 1 file changed, 1 insertion(+), 2 deletions(-) > > > > > > > > > > Thanks for looking into this. The series works fine on link. I suspect > > > > > it will be find on samus too, but I cannot test right now. Sadly > > > > > minnowmax is also dead right now but I hope to fix it soon. I don't > > > > > expect any problems there. > > > > > > > > > > However, for coral, this first patch breaks the mtrrs. With master we get: > > > > > > > > > > => mtrr > > > > > CPU 0: > > > > > Reg Valid Write-type Base || Mask || Size || > > > > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > > > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > > > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > > > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > > > > 5 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > 6 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > 7 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > 8 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > 9 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > > > > > > with this patch on coral we get: > > > > > > > > > > => mtrr > > > > > CPU 0: > > > > > Reg Valid Write-type Base || Mask || Size || > > > > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > > > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > > > > 2 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > > > 3 N Uncacheable 0000000000000000 0000000000000000 0000008000000000 > > > > > > > > > > At present coral expects to handle the MTRRs itself, and it seems that > > > > > perhaps the APL FSPv2 does not? Do we need a new Kconfig for dealing > > > > > with FSPv2 perhaps? > > > > > > > > I am a little bit confused. The comment in arch/x86/lib/fsp/fsp_dram.c:: > > > > dram_init_banksize() says: > > > > > > > > /* > > > > * For FSP1, the system memory and reserved memory used by FSP are > > > > * already programmed in the MTRR by FSP. Also it is observed that > > > > * FSP on Intel Queensbay platform reports the TSEG memory range > > > > * that has the same RES_MEM_RESERVED resource type whose address > > > > * is programmed by FSP to be near the top of 4 GiB space, which is > > > > * not what we want for DRAM. > > > > * > > > > * However it seems FSP2's behavior is different. We need to add the > > > > * DRAM range in MTRR otherwise the boot process goes very slowly, > > > > * which was observed on Chromebook Coral with FSP2. > > > > */ > > > > > > > > So on Coral with FSP2, U-Boot programs the MTTR by itself. > > > > > > > > In this dram_init_banksize(), it calls mtrr_add_request() 3 times, 2 > > > > of which should be what you were seeing as 2 and 4 below: > > > > > > > > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > > > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > > > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > > > > > > > The #3 should be the FSP graphics frame buffer. But I failed to > > > > understand how the FSP graphics programs a MTRR register in between > > > > the 2 memory regions programmed by dram_init_banksize() on > > > > u-boot/master, how could that happen? > > > > > > Remember that the MTRRs are sorted, so the order or mtrr_add_request() > > > calls does not matter. > > > > > > > Still cannot explain. > > > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > > 2 Y Back 0000000000000000 0000007f80000000 0000000080000000 > > 3 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > 4 Y Back 0000000100000000 0000007f80000000 0000000080000000 > > > > After we sort the mtrr memory range, #2 whose base is 0x0 should have > > been put to the first entry, then followed by #3 whose base is > > 0xb0000000. > > Right, but the thing is, your first patch does not revert the > behaviour of mtrr_add_request(). It is still just adding to the end. > > i.e. mtrr_commt() adds new ones but does not overwrite those at the back. > > Looking at your full series, this is what I see on coral: > > 0 Y Back 00000000fef00000 0000007ffff80000 0000000000080000 > 1 Y Back 00000000fef80000 0000007ffffc0000 0000000000040000 > 2 Y Combine 00000000b0000000 0000007ff0000000 0000000010000000 > > But I see that do_mtrr is wrong for coral in init_cache_f_r(): > > do_mtrr &= !IS_ENABLED(CONFIG_SPL) && > > So with coral the mtrrs are never written?
Maybe we should do:
Will this work?
Yes there is probably some other stuff going on in SPL/TPL.
But with your v2 series I found that if we change the condition at the top of init_cache_f_r() it works. I will send the updated patch.
Bin Meng
