[U-Boot-Users] How to add device tree support to a board?
I'm trying to understand how to add flatten device tree support to a specific board (MAI/AmigaOneG3SE in this case). Besides setting CONFIG_OF_LIBFDT, is it necessary to add any code to the board's platform code? Which nodes are automatically added to the fdt by U-boot? Does the device tree include nodes for e.g. the PCI bus and its devices?
regards,
Gerhard
PS: Please put me on CC:
regards,
Gerhard
Hi Gerhard,
It is hard to say. I've done the Freescale MPC8360EMDS eval board, which is a whole different animal than an AmigaOneG3SE (and I don't know exactly what an AmigaOneG3SE is). If you don't have any fixups/additions necessary for the fdt, then it theoretically is "enable and it just works" but you will be blazing new ground and I wouldn't bet on it being quite that simple. It never seems to be. :-/
If you look at my page FDT page, you will see a table of known conversions, most of which have not happened yet (only the MPC8360 family has been worked on). http://www.denx.de/wiki/UBoot/UBootFdtInfo#adapt
There are three areas that fix up fdt entries: board setup, CPU setup, and PCI setup. These do fixups on things like ethernet MAC addresses (set them from the env variables) and clock frequencies. I would guess that your AmigaOneG3SE won't need these fixed up, with the possible exception of the MAC addresses. The current boards that have fixups have different boards and/or configurations that can run with different PCI and CPU clock frequencies, for instance, so the fdt property has to be fixed up with the correct frequency for the given configuration.
FWIIW, I'm coming out of my busy cycle of the month (first 2+ weeks) and am getting ready to update the u-boot-fdt fork with respins of some of the existing patches and some improvements (primarily addressing Kim's concerns). I hope to get this published and pushed to the u-boot-fdt repo this week, probably spilling into next week.
Good luck, gvb
-------- Original-Nachricht -------- Datum: Thu, 21 Jun 2007 21:22:06 -0400 Von: Jerry Van Baren gvb.uboot@gmail.com An: Gerhard Pircher gerhard_pircher@gmx.net CC: u-boot-users@lists.sourceforge.net Betreff: Re: [U-Boot-Users] How to add device tree support to a board?
Sorry! My fault. Well, the AmigaOne is a ATX motherboard with a G3/G4 PPC CPU, a common VIA 82C686B southbridge (with an i8259 interrupt controller, IDE, USB, etc.), an onboard ethernet controller and a number of PCI/AGP slots.
That depends on what U-boot automatically adds to the device tree. I don't think that U-boot adds nodes for every ISA device found in the PCI2ISA bridge, right? If so, I have to do some fixups anyway, either in U-boot or in the Linux kernel.
Thanks! I was searching through the U-boot documentation on www.denx.de, but didn't find anything about Fdt yet.
Looks like the AmigaOne U-boot code has to do a lot fixups (for different CPU frequencies, resource fixups for invisible PCI I/O bars, ISA devices, etc.).
BTW: As far as I understand there are two implementations for flattened device trees in U-boot. Is libfdt compatible with operating systems that expect only the old bd_t stucture? AFAIK the other implementation is deprecated, but can be switched off by setting an environment variable.
Good luck,
Thanks!
Gerhard
I meant more that I couldn't give you much concrete information. I still cannot since I don't know (and don't want to know ;-) the details. As they say, the devil is in the details. :-/ Your job, should you chose to accept it, is to conquer that devil. ;-)
Any fixups you would need to add. Welcome to the bleeding edge.
There are two ways to go: if there is sufficient stable (constant) information, you can build a static tree. If you (linux) needs information from the tree that isn't static, you (u-boot) will have to add/fix properties with those values. If linux can probe for the values, you should be OK without having them in the tree.
On the eval boards, this is the case with clocks, for instance. There are jumpers and/or hardware config words that set frequencies that get communicated to the linux kernel via the fdt. The linux kernel cannot probe (or would be nasty to probe) for these values, so they get added and/or updated in the fdt.
Be aware, I don't know much about the ISA stuff, how it is set up, configured, probed, etc. so the above could be a bunch of BS.
More bleeding. :-/
Sounds like a big ouch. My 2c is to make as much static in the fdt as possible.
Yes, CONFIG_OF_FLAT_TREE is the original fdt implementation that I'm working on supplanting with a more elaborate implementation (including the "fdt" command) based on libfdt which is controlled via CONFIG_OF_LIBFDT.
The bd_t structure is tacked onto the end of the fdt blob (strictly speaking, the fdt blob is put in front of the bd_t structure). This is done in the cmd_bootm.c code.
In addition, if you enable CONFIG_OF_HAS_BD_T, the bd_t structure gets recreated as a blob node with properties.
I don't know how well the above work, I presume as well as before. I inherited it and did not change it in my LIBFDT modifications.
Good luck,
Thanks!
Gerhard
gvb
Gerhard Pircher
Jerry Van Baren
