[PATCH] configs: imx8m{m, n}_venice: remove unneeded CONFIG_FEC_MXC_PHYADDR
The IMX8M based Venice boards all have device-tree fec nodes that use proper dt with a phy-handle pointing to a phy with reg assigned to the proper phy address.
There is no need to keep using the CONFIG_FEC_MXC_PHYADDR hack when a proper dt is used - remove it.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/imx8mm_venice.h | 1 - include/configs/imx8mn_venice.h | 1 - 2 files changed, 2 deletions(-)
diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 1b26e0280e1c..28417c55b9b6 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -112,7 +112,6 @@ sizeof(CONFIG_SYS_PROMPT) + 16)
/* FEC */ -#define CONFIG_FEC_MXC_PHYADDR 0 #define FEC_QUIRK_ENET_MAC
#endif diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index a4826779022a..0379c27f11a5 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -108,7 +108,6 @@ sizeof(CONFIG_SYS_PROMPT) + 16)
#endif
Tim Harvey
