[U-Boot] [RESEND PATCH] include: nand: move endif to end of file
The terminator endif of ifdef _NAND_H_ should be at the end of file as a fail safe.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- Link on prev version [1] https://patchwork.ozlabs.org/patch/604738/
I've kept "Reviewed-by" from [1], pls inform me in case of any issues.
include/nand.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/nand.h b/include/nand.h index b6eb223..692c4db 100644 --- a/include/nand.h +++ b/include/nand.h @@ -131,8 +131,6 @@ void board_nand_select_device(struct nand_chip *nand, int chip);
__attribute__((noreturn)) void nand_boot(void);
-#endif - #ifdef CONFIG_ENV_OFFSET_OOB #define ENV_OOB_MARKER 0x30425645 /*"EVB0" in little-endian -- offset is stored as block number*/ @@ -145,3 +143,5 @@ int spl_nand_erase_one(int block, int page);
/* platform specific init functions */ void sunxi_nand_init(void); + +#endif /* _NAND_H_ */
Grygorii Strashko
