[U-Boot] [PATCH V2 1/3] imx: clock support enet2 anatop clock support
To i.MX6SX/UL, two ethernet interfaces are supported. Add ENET2 clock support: 1. Introduce a new input parameter "fec_id", only 0 and 1 are allowed. To value 1, only i.MX6SX/UL can pass the check. 2. Modify board code who use this api to follow new api prototype.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Heiko Schocher hs@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Stefan Roese sr@denx.de Cc: Nikolaos Pasaloukos Nikolaos.Pasaloukos@imgtec.com Cc: Stefano Babic sbabic@denx.de ---
Changes v2: Addressed Fabio's comments. Using "fec_id == 0", but not "0 == fec_id".
arch/arm/cpu/armv7/mx6/clock.c | 23 ++++++++++++++++++----- arch/arm/include/asm/arch-mx6/clock.h | 2 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 6 ++++++ board/aristainetos/aristainetos-v1.c | 2 +- board/barco/platinum/platinum_picon.c | 2 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 2 +- board/freescale/mx6slevk/mx6slevk.c | 2 +- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 2 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 2 +- 9 files changed, 31 insertions(+), 12 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 9cf4eec..ba6cc75 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -524,7 +524,7 @@ void enable_qspi_clk(int qspi_num) #endif
#ifdef CONFIG_FEC_MXC -int enable_fec_anatop_clock(enum enet_freq freq) +int enable_fec_anatop_clock(int fec_id, enum enet_freq freq) { u32 reg = 0; s32 timeout = 100000; @@ -535,9 +535,19 @@ int enable_fec_anatop_clock(enum enet_freq freq) if (freq < ENET_25MHZ || freq > ENET_125MHZ) return -EINVAL;
- reg = readl(&anatop->pll_enet); - reg &= ~BM_ANADIG_PLL_ENET_DIV_SELECT; - reg |= freq; + if (fec_id == 0) { + reg &= ~BM_ANADIG_PLL_ENET_DIV_SELECT; + reg |= BF_ANADIG_PLL_ENET_DIV_SELECT(freq); + } else if (fec_id == 1) { + /* Only i.MX6SX/UL support ENET2 */ + if (!(is_cpu_type(MXC_CPU_MX6SX) || + is_cpu_type(MXC_CPU_MX6UL))) + return -EINVAL; + reg &= ~BM_ANADIG_PLL_ENET2_DIV_SELECT; + reg |= BF_ANADIG_PLL_ENET2_DIV_SELECT(freq); + } else { + return -EINVAL; + }
if ((reg & BM_ANADIG_PLL_ENET_POWERDOWN) || (!(reg & BM_ANADIG_PLL_ENET_LOCK))) { @@ -552,7 +562,10 @@ int enable_fec_anatop_clock(enum enet_freq freq) }
/* Enable FEC clock */ - reg |= BM_ANADIG_PLL_ENET_ENABLE; + if (fec_id == 0) + reg |= BM_ANADIG_PLL_ENET_ENABLE; + else + reg |= BM_ANADIG_PLL_ENET2_ENABLE; reg &= ~BM_ANADIG_PLL_ENET_BYPASS; writel(reg, &anatop->pll_enet);
diff --git a/arch/arm/include/asm/arch-mx6/clock.h b/arch/arm/include/asm/arch-mx6/clock.h index 7b3bbb8..2b220d6 100644 --- a/arch/arm/include/asm/arch-mx6/clock.h +++ b/arch/arm/include/asm/arch-mx6/clock.h @@ -64,7 +64,7 @@ int enable_pcie_clock(void); int enable_i2c_clk(unsigned char enable, unsigned i2c_num); int enable_spi_clk(unsigned char enable, unsigned spi_num); void enable_ipu_clock(void); -int enable_fec_anatop_clock(enum enet_freq freq); +int enable_fec_anatop_clock(int fec_id, enum enet_freq freq); void enable_enet_clk(unsigned char enable); void enable_qspi_clk(int qspi_num); void enable_thermal_clk(void); diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index fe75da4..10306cd 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -1052,6 +1052,12 @@ struct mxc_ccm_reg { #define BF_ANADIG_PLL_ENET_DIV_SELECT(v) \ (((v) << 0) & BM_ANADIG_PLL_ENET_DIV_SELECT)
+/* ENET2 for i.MX6SX/UL */ +#define BM_ANADIG_PLL_ENET2_ENABLE 0x00100000 +#define BM_ANADIG_PLL_ENET2_DIV_SELECT 0x0000000C +#define BF_ANADIG_PLL_ENET2_DIV_SELECT(v) \ + (((v) << 2) & BM_ANADIG_PLL_ENET2_DIV_SELECT) + #define BM_ANADIG_PFD_480_PFD3_CLKGATE 0x80000000 #define BM_ANADIG_PFD_480_PFD3_STABLE 0x40000000 #define BP_ANADIG_PFD_480_PFD3_FRAC 24 diff --git a/board/aristainetos/aristainetos-v1.c b/board/aristainetos/aristainetos-v1.c index d6a7614..b8fed2e 100644 --- a/board/aristainetos/aristainetos-v1.c +++ b/board/aristainetos/aristainetos-v1.c @@ -185,7 +185,7 @@ int board_eth_init(bd_t *bis) /* clear gpr1[14], gpr1[18:17] to select anatop clock */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0);
- ret = enable_fec_anatop_clock(ENET_50MHZ); + ret = enable_fec_anatop_clock(0, ENET_50MHZ); if (ret) return ret;
diff --git a/board/barco/platinum/platinum_picon.c b/board/barco/platinum/platinum_picon.c index b2eab76..0384a26 100644 --- a/board/barco/platinum/platinum_picon.c +++ b/board/barco/platinum/platinum_picon.c @@ -148,7 +148,7 @@ int platinum_setup_enet(void) /* set GPIO_16 as ENET_REF_CLK_OUT */ setbits_le32(&iomux->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK);
- return enable_fec_anatop_clock(ENET_50MHZ); + return enable_fec_anatop_clock(0, ENET_50MHZ); }
int platinum_setup_i2c(void) diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6qsabreauto/mx6qsabreauto.c index 98602f8..7c0e90a 100644 --- a/board/freescale/mx6qsabreauto/mx6qsabreauto.c +++ b/board/freescale/mx6qsabreauto/mx6qsabreauto.c @@ -361,7 +361,7 @@ static void setup_fec(void) * select ENET MAC0 TX clock from PLL */ imx_iomux_set_gpr_register(5, 9, 1, 1); - enable_fec_anatop_clock(ENET_125MHZ); + enable_fec_anatop_clock(0, ENET_125MHZ); }
setup_iomux_enet(); diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index 7c18c90..98e3ef0 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -279,7 +279,7 @@ static int setup_fec(void) /* clear gpr1[14], gpr1[18:17] to select anatop clock */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0);
- return enable_fec_anatop_clock(ENET_50MHZ); + return enable_fec_anatop_clock(0, ENET_50MHZ); } #endif
diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index d58a79a..ffc0046 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -170,7 +170,7 @@ static int setup_fec(void) reg |= BM_ANADIG_PLL_ENET_REF_25M_ENABLE; writel(reg, &anatop->pll_enet);
- return enable_fec_anatop_clock(ENET_125MHZ); + return enable_fec_anatop_clock(0, ENET_125MHZ); }
int board_eth_init(bd_t *bis) diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 9b1ecf0..8247e43 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -164,7 +164,7 @@ int board_eth_init(bd_t *bis) struct mii_dev *bus; struct phy_device *phydev;
- int ret = enable_fec_anatop_clock(ENET_25MHZ); + int ret = enable_fec_anatop_clock(0, ENET_25MHZ); if (ret) return ret;
The MIB RAM and FIFO receive start register does not exist on i.MX6UL. Accessing these register will cause enet not work well.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Fugang Duan B38611@freescale.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Stefano Babic sbabic@denx.de ---
Changes v2: Using runtime check, but not hardcoding "#ifdef". This patch depends on the runtime checking patch: https://patchwork.ozlabs.org/patch/505621/.
drivers/net/fec_mxc.c | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index c5dcbbb..bff5fd1 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -17,6 +17,7 @@
#include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> +#include <asm/imx-common/sys_proto.h> #include <asm/io.h> #include <asm/errno.h> #include <linux/compiler.h> @@ -551,12 +552,15 @@ static int fec_init(struct eth_device *dev, bd_t* bd) writel(0x00000000, &fec->eth->gaddr2);
- /* clear MIB RAM */ - for (i = mib_ptr; i <= mib_ptr + 0xfc; i += 4) - writel(0, i); + /* Do not access reserved register for i.MX6UL */ + if (!is_cpu_type(MXC_CPU_MX6UL)) { + /* clear MIB RAM */ + for (i = mib_ptr; i <= mib_ptr + 0xfc; i += 4) + writel(0, i);
- /* FIFO receive start register */ - writel(0x520, &fec->eth->r_fstart); + /* FIFO receive start register */ + writel(0x520, &fec->eth->r_fstart); + }
/* size and address of each buffer */ writel(FEC_MAX_PKT_SIZE, &fec->eth->emrbr);
Add enet support for mx6ul_14x14_evk board: 1. add pinmux settings 2. implement board_eth_init 3. implement board_phy_config
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com ---
Changes v2: Addressed Fabio's comments, using "fec_id == 0", but not "0 == fec_id".
board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 110 ++++++++++++++++++++++ configs/mx6ul_14x14_evk_defconfig | 3 + include/configs/mx6ul_14x14_evk.h | 21 +++++ 3 files changed, 134 insertions(+)
diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index 8f712cb..d9af220 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -19,8 +19,10 @@ #include <common.h> #include <fsl_esdhc.h> #include <i2c.h> +#include <miiphy.h> #include <linux/sizes.h> #include <mmc.h> +#include <netdev.h> #include <usb.h> #include <usb/ehci-fsl.h>
@@ -43,6 +45,18 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_ODE)
+#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_SPEED_HIGH | \ + PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST) + +#define MDIO_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST | PAD_CTL_ODE) + +#define ENET_CLK_PAD_CTRL (PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define ENET_RX_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_SPEED_HIGH | PAD_CTL_SRE_FAST) + #define IOX_SDI IMX_GPIO_NR(5, 10) #define IOX_STCP IMX_GPIO_NR(5, 7) #define IOX_SHCP IMX_GPIO_NR(5, 11) @@ -457,6 +471,98 @@ int board_ehci_hcd_init(int port) } #endif
+#ifdef CONFIG_FEC_MXC +/* + * pin conflicts for fec1 and fec2, GPIO1_IO06 and GPIO1_IO07 can only + * be used for ENET1 or ENET2, cannot be used for both. + */ +static iomux_v3_cfg_t const fec1_pads[] = { + MX6_PAD_GPIO1_IO06__ENET1_MDIO | MUX_PAD_CTRL(MDIO_PAD_CTRL), + MX6_PAD_GPIO1_IO07__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_EN__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_ER__ENET1_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_EN__ENET1_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static iomux_v3_cfg_t const fec2_pads[] = { + MX6_PAD_GPIO1_IO06__ENET2_MDIO | MUX_PAD_CTRL(MDIO_PAD_CTRL), + MX6_PAD_GPIO1_IO07__ENET2_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + + MX6_PAD_ENET2_TX_DATA0__ENET2_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_TX_DATA1__ENET2_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL), + MX6_PAD_ENET2_TX_EN__ENET2_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + + MX6_PAD_ENET2_RX_DATA0__ENET2_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_RX_DATA1__ENET2_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_RX_EN__ENET2_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_RX_ER__ENET2_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static void setup_iomux_fec(int fec_id) +{ + if (fec_id == 0) + imx_iomux_v3_setup_multiple_pads(fec1_pads, + ARRAY_SIZE(fec1_pads)); + else + imx_iomux_v3_setup_multiple_pads(fec2_pads, + ARRAY_SIZE(fec2_pads)); +} + +int board_eth_init(bd_t *bis) +{ + setup_iomux_fec(CONFIG_FEC_ENET_DEV); + + return fecmxc_initialize_multi(bis, CONFIG_FEC_ENET_DEV, + CONFIG_FEC_MXC_PHYADDR, IMX_FEC_BASE); +} + +static int setup_fec(int fec_id) +{ + struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + int ret; + + if (fec_id == 0) { + /* + * Use 50M anatop loopback REF_CLK1 for ENET1, + * clear gpr1[13], set gpr1[17]. + */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK, + IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK); + } else { + /* + * Use 50M anatop loopback REF_CLK2 for ENET2, + * clear gpr1[14], set gpr1[18]. + */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC2_MASK, + IOMUX_GPR1_FEC2_CLOCK_MUX1_SEL_MASK); + } + + ret = enable_fec_anatop_clock(fec_id, ENET_50MHZ); + if (ret) + return ret; + + enable_enet_clk(1); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x8190); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + int board_early_init_f(void) { setup_iomux_uart(); @@ -477,6 +583,10 @@ int board_init(void) setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); #endif
+#ifdef CONFIG_FEC_MXC + setup_fec(CONFIG_FEC_ENET_DEV); +#endif + #ifdef CONFIG_USB_EHCI_MX6 setup_usb(); #endif diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index b6eefaf..85952e4 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -2,3 +2,6 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6UL" CONFIG_ARM=y CONFIG_TARGET_MX6UL_14X14_EVK=y CONFIG_SPL=y +CONFIG_CMD_NET=y +CONFIG_CMD_PING=y +CONFIG_CMD_DHCP=y diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 757aa6a..f643e4d 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -221,6 +221,27 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif
+#ifdef CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define CONFIG_FEC_ENET_DEV 1 + +#if (CONFIG_FEC_ENET_DEV == 0) +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x2 +#define CONFIG_FEC_XCV_TYPE RMII +#elif (CONFIG_FEC_ENET_DEV == 1) +#define IMX_FEC_BASE ENET2_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1 +#define CONFIG_FEC_XCV_TYPE RMII +#endif +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_FEC_DMA_MINALIGN 64 +#endif + #define CONFIG_IMX6_THERMAL
#endif
- Introduce a new input parameter "fec_id", only 0 and 1 are allowed. To value 1, only i.MX6SX/UL can pass the check.
- Modify board code who use this api to follow new api prototype.
Thanks, Stefan
Peng Fan
Stefan Roese
