Re: [U-Boot] [linux-sunxi] Re: [PATCH 5/8] sunxi: Add clock support for DE2/HDMI/TCON on newer SoCs
2017年3月13日 20:33于 Simon Glass sjg@chromium.org写道:
On 8 March 2017 at 16:34, Jernej Skrabec jernej.skrabec@siol.net wrote:
This is needed for HDMI, which will be added later.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net
arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 54 +++++++++++++++++++++++++++ arch/arm/mach-sunxi/clock_sun6i.c | 40 +++++++++++++++++++- drivers/video/sunxi/lcdc.c | 4 ++ include/configs/sun50i.h | 2 + include/configs/sun8i.h | 4 ++ scripts/config_whitelist.txt | 1 + 6 files changed, 104 insertions(+), 1 deletion(-)
Please see below.
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index 1aefd5a64c..ebb642747b 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -67,13 +67,22 @@ struct sunxi_ccm_reg { u32 dram_pll_cfg; /* 0xf8 PLL_DDR cfg register, A33 only */ u32 mbus_reset; /* 0xfc MBUS reset control, A33 only */ u32 dram_clk_gate; /* 0x100 DRAM module gating */ +#ifdef CONFIG_SUNXI_DE2 + u32 de_clk_cfg; /* 0x104 DE module clock */ +#else u32 be0_clk_cfg; /* 0x104 BE0 module clock */ +#endif u32 be1_clk_cfg; /* 0x108 BE1 module clock */ u32 fe0_clk_cfg; /* 0x10c FE0 module clock */ u32 fe1_clk_cfg; /* 0x110 FE1 module clock */ u32 mp_clk_cfg; /* 0x114 MP module clock */ +#ifdef CONFIG_SUNXI_DE2 + u32 lcd0_clk_cfg; /* 0x118 LCD0 module clock */ + u32 lcd1_clk_cfg; /* 0x11c LCD1 module clock */ +#else u32 lcd0_ch0_clk_cfg; /* 0x118 LCD0 CH0 module clock */ u32 lcd1_ch0_clk_cfg; /* 0x11c LCD1 CH0 module clock */ +#endif u32 reserved14[3]; u32 lcd0_ch1_clk_cfg; /* 0x12c LCD0 CH1 module clock */ u32 lcd1_ch1_clk_cfg; /* 0x130 LCD1 CH1 module clock */ @@ -85,7 +94,11 @@ struct sunxi_ccm_reg { u32 dmic_clk_cfg; /* 0x148 Digital Mic module clock*/ u32 reserved15; u32 hdmi_clk_cfg; /* 0x150 HDMI module clock */ +#ifdef CONFIG_SUNXI_DE2 + u32 hdmi_slow_clk_cfg; /* 0x154 HDMI slow module clock */ +#else u32 ps_clk_cfg; /* 0x154 PS module clock */ +#endif u32 mtc_clk_cfg; /* 0x158 MTC module clock */ u32 mbus0_clk_cfg; /* 0x15c MBUS0 module clock */ u32 mbus1_clk_cfg; /* 0x160 MBUS1 module clock */ @@ -193,6 +206,7 @@ struct sunxi_ccm_reg { #define CCM_PLL3_CTRL_N_MASK (0x7f << CCM_PLL3_CTRL_N_SHIFT) #define CCM_PLL3_CTRL_N(n) ((((n) - 1) & 0x7f) << 8) #define CCM_PLL3_CTRL_INTEGER_MODE (0x1 << 24) +#define CCM_PLL3_CTRL_LOCK (0x1 << 28) #define CCM_PLL3_CTRL_EN (0x1 << 31)
#define CCM_PLL5_CTRL_M(n) ((((n) - 1) & 0x3) << 0) @@ -222,6 +236,16 @@ struct sunxi_ccm_reg { #define CCM_MIPI_PLL_CTRL_LDO_EN (0x3 << 22) #define CCM_MIPI_PLL_CTRL_EN (0x1 << 31)
+#define CCM_PLL10_CTRL_M_SHIFT 0 +#define CCM_PLL10_CTRL_M_MASK (0xf << CCM_PLL10_CTRL_M_SHIFT) +#define CCM_PLL10_CTRL_M(n) ((((n) - 1) & 0xf) << 0) +#define CCM_PLL10_CTRL_N_SHIFT 8 +#define CCM_PLL10_CTRL_N_MASK (0x7f << CCM_PLL10_CTRL_N_SHIFT) +#define CCM_PLL10_CTRL_N(n) ((((n) - 1) & 0x7f) << 8) +#define CCM_PLL10_CTRL_INTEGER_MODE (0x1 << 24) +#define CCM_PLL10_CTRL_LOCK (0x1 << 28) +#define CCM_PLL10_CTRL_EN (0x1 << 31)
#define CCM_PLL11_CTRL_N(n) ((((n) - 1) & 0x3f) << 8) #define CCM_PLL11_CTRL_SIGMA_DELTA_EN (0x1 << 24) #define CCM_PLL11_CTRL_UPD (0x1 << 30) @@ -273,9 +297,15 @@ struct sunxi_ccm_reg { #define AHB_GATE_OFFSET_DRC0 25 #define AHB_GATE_OFFSET_DE_FE0 14 #define AHB_GATE_OFFSET_DE_BE0 12 +#define AHB_GATE_OFFSET_DE 12 #define AHB_GATE_OFFSET_HDMI 11 +#ifndef CONFIG_SUNXI_DE2 #define AHB_GATE_OFFSET_LCD1 5 #define AHB_GATE_OFFSET_LCD0 4 +#else +#define AHB_GATE_OFFSET_LCD1 4 +#define AHB_GATE_OFFSET_LCD0 3 +#endif
#define CCM_MMC_CTRL_M(x) ((x) - 1) #define CCM_MMC_CTRL_OCLK_DLY(x) ((x) << 8) @@ -357,6 +387,12 @@ struct sunxi_ccm_reg { #define CCM_LCD_CH1_CTRL_PLL7_2X (3 << 24) #define CCM_LCD_CH1_CTRL_GATE (0x1 << 31)
+#define CCM_LCD0_CTRL_GATE (0x1 << 31) +#define CCM_LCD0_CTRL_M(n) ((((n) - 1) & 0xf) << 0)
+#define CCM_LCD1_CTRL_GATE (0x1 << 31) +#define CCM_LCD1_CTRL_M(n) ((((n) - 1) & 0xf) << 0)
#define CCM_HDMI_CTRL_M(n) ((((n) - 1) & 0xf) << 0) #define CCM_HDMI_CTRL_PLL_MASK (3 << 24) #define CCM_HDMI_CTRL_PLL3 (0 << 24) @@ -366,6 +402,8 @@ struct sunxi_ccm_reg { #define CCM_HDMI_CTRL_DDC_GATE (0x1 << 30) #define CCM_HDMI_CTRL_GATE (0x1 << 31)
+#define CCM_HDMI_SLOW_CTRL_DDC_GATE (1 << 31)
I think 1UL << 31 would be safer.
The registers are always 32-bit on AW SoCs. Use UL here will make this constant 64-bit on A64/H5.
-- You received this message because you are subscribed to the Google Groups "linux-sunxi" group. To unsubscribe from this group and stop receiving emails from it, send an email to linux-sunxi+unsubscribe@googlegroups.com. For more options, visit https://groups.google.com/d/optout.
Icenowy Zheng
