[U-Boot] [PATCH v2 2/4] mips: ath79: add spi driver
Signed-off-by: Wills Wang wills.wang@live.com ---
drivers/spi/Makefile | 1 + drivers/spi/ath79_spi.c | 142 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 143 insertions(+) create mode 100644 drivers/spi/ath79_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 3eca745..7fb2926 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -17,6 +17,7 @@ endif
obj-$(CONFIG_ALTERA_SPI) += altera_spi.o obj-$(CONFIG_ARMADA100_SPI) += armada100_spi.o +obj-$(CONFIG_ATH79_SPI) += ath79_spi.o obj-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o obj-$(CONFIG_BFIN_SPI) += bfin_spi.o diff --git a/drivers/spi/ath79_spi.c b/drivers/spi/ath79_spi.c new file mode 100644 index 0000000..e9a9dd2 --- /dev/null +++ b/drivers/spi/ath79_spi.c @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <asm/arch/ar71xx_regs.h> + +#define REG_READ(b, o) readl(KSEG1ADDR(b + o)) +#define REG_WRITE(b, o, v) writel((v), KSEG1ADDR(b + o)) +#define SPI_READ(a) REG_READ(AR71XX_SPI_BASE, a) +#define SPI_WRITE(a, v) REG_WRITE(AR71XX_SPI_BASE, a, v) + +/* CLOCK_DIVIDER = 3 (SPI clock = 200 / 8 ~ 25 MHz) */ +#define SPI_CLK_DIV(x) ((x >> 1) - 1) + +struct ar71xx_spi_slave { + struct spi_slave slave; + unsigned int mode; +}; + +static inline struct ar71xx_spi_slave *to_ar71xx_spi(struct spi_slave *slave) +{ + return container_of(slave, struct ar71xx_spi_slave, slave); +} + +void spi_init(void) +{ + /* Init SPI Hardware, disable remap, set clock */ + SPI_WRITE(AR71XX_SPI_REG_FS, AR71XX_SPI_FS_GPIO); + SPI_WRITE(AR71XX_SPI_REG_CTRL, AR71XX_SPI_CTRL_RD | SPI_CLK_DIV(8)); + SPI_WRITE(AR71XX_SPI_REG_FS, 0); +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct ar71xx_spi_slave *ss; + + if (bus || (cs > 2)) + return NULL; + + ss = malloc(sizeof(struct ar71xx_spi_slave)); + if (!ss) + return NULL; + memset(ss, 0, sizeof(struct ar71xx_spi_slave)); + + ss->slave.bus = bus; + ss->slave.cs = cs; + ss->slave.memory_map = (void *)KSEG0ADDR(AR71XX_SPI_BASE); + ss->mode = mode; + + return &ss->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct ar71xx_spi_slave *ss = to_ar71xx_spi(slave); + + free(ss); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + uint8_t *rx = din; + const uint8_t *tx = dout; + uint8_t curbyte, curbitlen, restbits; + uint32_t bytes = bitlen / 8; + uint32_t out; + uint32_t in; + + if (flags & SPI_XFER_BEGIN) { + SPI_WRITE(AR71XX_SPI_REG_FS, AR71XX_SPI_FS_GPIO); + SPI_WRITE(AR71XX_SPI_REG_IOC, AR71XX_SPI_IOC_CS_ALL); + } + + restbits = (bitlen % 8); + if (restbits) + bytes++; + + /* enable chip select */ + out = AR71XX_SPI_IOC_CS_ALL & ~(AR71XX_SPI_IOC_CS(slave->cs)); + while (bytes--) { + curbyte = 0; + if (tx) + curbyte = *tx++; + + if (restbits) { + curbitlen = restbits; + curbyte <<= 8 - restbits; + } else { + curbitlen = 8; + } + + /* clock starts at inactive polarity */ + for (curbyte <<= (8 - curbitlen); curbitlen; curbitlen--) { + if (curbyte & 0x80) + out |= AR71XX_SPI_IOC_DO; + else + out &= ~(AR71XX_SPI_IOC_DO); + + /* setup MSB (to slave) on trailing edge */ + SPI_WRITE(AR71XX_SPI_REG_IOC, out); + SPI_WRITE(AR71XX_SPI_REG_IOC, out | AR71XX_SPI_IOC_CLK); + + curbyte <<= 1; + } + + in = SPI_READ(AR71XX_SPI_REG_RDS); + if (rx) { + if (restbits) + *rx++ = (in << (8 - restbits)); + else + *rx++ = in; + } + } + + if (flags & SPI_XFER_END) { + SPI_WRITE(AR71XX_SPI_REG_IOC, AR71XX_SPI_IOC_CS(slave->cs)); + SPI_WRITE(AR71XX_SPI_REG_IOC, AR71XX_SPI_IOC_CS_ALL); + SPI_WRITE(AR71XX_SPI_REG_FS, 0); + } + + return 0; +}
Please write it on driver-model, we're accepting new drivers will be in driver-model format.
- (C) Copyright 2015
- Wills Wang, wills.wang@live.com
unsigned int mode;
return NULL;
if (!ss)
return NULL;
ss->slave.cs = cs;
ss->mode = mode;
return &ss->slave;
free(ss);
uint8_t *rx = din;
uint32_t out;
uint32_t in;
if (restbits)
bytes++;
while (bytes--) {
curbyte = 0;
if (tx)
curbyte = *tx++;
if (restbits) {
} else {
curbitlen = 8;
if (curbyte & 0x80)
else
curbyte <<= 1;
if (rx) {
if (restbits)
else
*rx++ = in;
1.9.1
Jagan Teki
Wills Wang
