[PATCH] pci: Do not enable PCIe ASMedia ASM2824 workaround by default
PCIe ASMedia ASM2824 workaround code unconditionally increase size of all SPL binaries with PCIe support, even those which do not use ASMedia ASM2824 PCIe switch.
Moreover this workaround is enabled for all existing hardware and also all future PCIe hardware, which opens a hole that other PCIe vendors may introduce same HW issue as ASMedia and nobody would notice it because U-Boot automatically apply workaround for it.
Last iteration of Linux kernel patch for this workaround is bound just to ASMedia ASM2824 vendor+device id and not enabled on all PCIe hardware.
So do not unconditionally enable PCIe ASMedia ASM2824 workaround on all hardware. Instead introduce a new config option which is disabled by default. This decrease SPL size and also ensure that workaround is not blindly or inexactly enabled.
To make workaround code local, move it into separate file, so pci_auto.c contains only genetic auto configuration code.
Signed-off-by: Pali Rohár pali@kernel.org --- Hello! What do you think about this change? I think it is good compromise between enable this workaround for all builds on all boards and enable it only based on device id. Or would it be better to restrict this workaround just for ASM2824 device like the last iteration of kernel patch? --- drivers/pci/Kconfig | 6 + drivers/pci/Makefile | 1 + drivers/pci/pci_auto.c | 171 +----------------------- drivers/pci/pcie_asm2824_workaround.c | 183 ++++++++++++++++++++++++++ 4 files changed, 194 insertions(+), 167 deletions(-) create mode 100644 drivers/pci/pcie_asm2824_workaround.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 47cd074aa14c..16894929214a 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -327,4 +327,10 @@ config PCIE_UNIPHIER Say Y here if you want to enable PCIe controller support on UniPhier SoCs.
+config PCIE_ASM2824_WORKAROUND + bool "ASMedia ASM2824 PCIe workaround" + help + Say Y here if you want to enable link training failures for + ASMedia ASM2824 PCIe switch. + endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 04f623652f09..4aa4e7c7285d 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -50,3 +50,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o +obj-$(CONFIG_PCIE_ASM2824_WORKAROUND) += pcie_asm2824_workaround.o diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index c7968926a17f..851bf3bc55b1 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -13,7 +13,6 @@ #include <errno.h> #include <log.h> #include <pci.h> -#include <time.h> #include "pci_internal.h"
/* the user can define CONFIG_SYS_PCI_CACHE_LINE_SIZE to avoid problems */ @@ -182,167 +181,7 @@ static void dm_pciauto_setup_device(struct udevice *dev, dm_pci_write_config8(dev, PCI_LATENCY_TIMER, 0x80); }
-/* - * Check if the link of a downstream PCIe port operates correctly. - * - * For that check if the optional Data Link Layer Link Active status gets - * on within a 200ms period or failing that wait until the completion of - * that period and check if link training has shown the completed status - * continuously throughout the second half of that period. - * - * Observation with the ASMedia ASM2824 Gen 3 switch indicates it takes - * 11-44ms to indicate the Data Link Layer Link Active status at 2.5GT/s, - * though it may take a couple of link training iterations. - */ -static bool dm_pciauto_exp_link_stable(struct udevice *dev, int pcie_off) -{ - u64 loops = 0, trcount = 0, ntrcount = 0, flips = 0; - bool dllla, lnktr, plnktr; - u16 exp_lnksta; - pci_dev_t bdf; - u64 end; - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); - plnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); - - end = get_ticks() + usec_to_tick(200000); - do { - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, - &exp_lnksta); - dllla = !!(exp_lnksta & PCI_EXP_LNKSTA_DLLLA); - lnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); - - flips += plnktr ^ lnktr; - if (lnktr) { - ntrcount = 0; - trcount++; - } else { - ntrcount++; - } - loops++; - - plnktr = lnktr; - } while (!dllla && get_ticks() < end); - - bdf = dm_pci_get_bdf(dev); - debug("PCI Autoconfig: %02x.%02x.%02x: Fixup link: DL active: %u; " - "%3llu flips, %6llu loops of which %6llu while training, " - "final %6llu stable\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), - (unsigned int)dllla, - (unsigned long long)flips, (unsigned long long)loops, - (unsigned long long)trcount, (unsigned long long)ntrcount); - - return dllla || ntrcount >= loops / 2; -} - -/* - * Retrain the link of a downstream PCIe port by hand if necessary. - * - * This is needed at least where a downstream port of the ASMedia ASM2824 - * Gen 3 switch is wired to the upstream port of the Pericom PI7C9X2G304 - * Gen 2 switch, and observed with the Delock Riser Card PCI Express x1 > - * 2 x PCIe x1 device, P/N 41433, plugged into the SiFive HiFive Unmatched - * board. - * - * In such a configuration the switches are supposed to negotiate the link - * speed of preferably 5.0GT/s, falling back to 2.5GT/s. However the link - * continues switching between the two speeds indefinitely and the data - * link layer never reaches the active state, with link training reported - * repeatedly active ~84% of the time. Forcing the target link speed to - * 2.5GT/s with the upstream ASM2824 device makes the two switches talk to - * each other correctly however. And more interestingly retraining with a - * higher target link speed afterwards lets the two successfully negotiate - * 5.0GT/s. - * - * As this can potentially happen with any device and is cheap in the case - * of correctly operating hardware, let's do it for all downstream ports, - * for root complexes, PCIe switches and PCI/PCI-X to PCIe bridges. - * - * First check if automatic link training may have failed to complete, as - * indicated by the optional Data Link Layer Link Active status being off - * and the Link Bandwidth Management Status indicating that hardware has - * changed the link speed or width in an attempt to correct unreliable - * link operation. If this is the case, then check if the link operates - * correctly by seeing whether it is being trained excessively. If it is, - * then conclude the link is broken. - * - * In that case restrict the speed to 2.5GT/s, observing that the Target - * Link Speed field is sticky and therefore the link will stay restricted - * even after a device reset is later made by an OS that is unaware of the - * problem. With the speed restricted request that the link be retrained - * and check again if the link operates correctly. If not, then set the - * Target Link Speed back to the original value. - * - * This requires the presence of the Link Control 2 register, so make sure - * the PCI Express Capability Version is at least 2. Also don't try, for - * obvious reasons, to limit the speed if 2.5GT/s is the only link speed - * supported. - */ -static void dm_pciauto_exp_fixup_link(struct udevice *dev, int pcie_off) -{ - u16 exp_lnksta, exp_lnkctl, exp_lnkctl2; - u16 exp_flags, exp_type, exp_version; - u32 exp_lnkcap; - pci_dev_t bdf; - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_FLAGS, &exp_flags); - exp_version = exp_flags & PCI_EXP_FLAGS_VERS; - if (exp_version < 2) - return; - - exp_type = (exp_flags & PCI_EXP_FLAGS_TYPE) >> 4; - switch (exp_type) { - case PCI_EXP_TYPE_ROOT_PORT: - case PCI_EXP_TYPE_DOWNSTREAM: - case PCI_EXP_TYPE_PCIE_BRIDGE: - break; - default: - return; - } - - dm_pci_read_config32(dev, pcie_off + PCI_EXP_LNKCAP, &exp_lnkcap); - if ((exp_lnkcap & PCI_EXP_LNKCAP_SLS) <= PCI_EXP_LNKCAP_SLS_2_5GB) - return; - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); - if ((exp_lnksta & (PCI_EXP_LNKSTA_LBMS | PCI_EXP_LNKSTA_DLLLA)) != - PCI_EXP_LNKSTA_LBMS) - return; - - if (dm_pciauto_exp_link_stable(dev, pcie_off)) - return; - - bdf = dm_pci_get_bdf(dev); - printf("PCI Autoconfig: %02x.%02x.%02x: " - "Downstream link non-functional\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - printf("PCI Autoconfig: %02x.%02x.%02x: " - "Retrying with speed restricted to 2.5GT/s...\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL, &exp_lnkctl); - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL2, &exp_lnkctl2); - - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, - (exp_lnkctl2 & ~PCI_EXP_LNKCTL2_TLS) | - PCI_EXP_LNKCTL2_TLS_2_5GT); - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, - exp_lnkctl | PCI_EXP_LNKCTL_RL); - - if (dm_pciauto_exp_link_stable(dev, pcie_off)) { - printf("PCI Autoconfig: %02x.%02x.%02x: Succeeded!\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - } else { - printf("PCI Autoconfig: %02x.%02x.%02x: Failed!\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, - exp_lnkctl2); - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, - exp_lnkctl | PCI_EXP_LNKCTL_RL); - } -} +void pcie_asm2824_workaround(struct udevice *dev);
void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus) { @@ -353,7 +192,6 @@ void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus) u8 io_32; struct udevice *ctlr = pci_get_controller(dev); struct pci_controller *ctlr_hose = dev_get_uclass_priv(ctlr); - int pcie_off;
pci_mem = ctlr_hose->pci_mem; pci_prefetch = ctlr_hose->pci_prefetch; @@ -440,10 +278,9 @@ void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus) } }
- /* For PCIe devices see if we need to retrain the link by hand */ - pcie_off = dm_pci_find_capability(dev, PCI_CAP_ID_EXP); - if (pcie_off) - dm_pciauto_exp_fixup_link(dev, pcie_off); +#ifdef CONFIG_PCIE_ASM2824_WORKAROUND + pcie_asm2824_workaround(dev); +#endif
/* Enable memory and I/O accesses, enable bus master */ dm_pci_write_config16(dev, PCI_COMMAND, cmdstat | PCI_COMMAND_MASTER); diff --git a/drivers/pci/pcie_asm2824_workaround.c b/drivers/pci/pcie_asm2824_workaround.c new file mode 100644 index 000000000000..9415346faf22 --- /dev/null +++ b/drivers/pci/pcie_asm2824_workaround.c @@ -0,0 +1,183 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ASMedia ASM2824 PCIe workaround + * + * Copyright (c) 2021 Maciej W. Rozycki macro@orcam.me.uk + */ + +#include <common.h> +#include <dm.h> +#include <pci.h> +#include <time.h> + +/* + * Check if the link of a downstream PCIe port operates correctly. + * + * For that check if the optional Data Link Layer Link Active status gets + * on within a 200ms period or failing that wait until the completion of + * that period and check if link training has shown the completed status + * continuously throughout the second half of that period. + * + * Observation with the ASMedia ASM2824 Gen 3 switch indicates it takes + * 11-44ms to indicate the Data Link Layer Link Active status at 2.5GT/s, + * though it may take a couple of link training iterations. + */ +static bool dm_pciauto_exp_link_stable(struct udevice *dev, int pcie_off) +{ + u64 loops = 0, trcount = 0, ntrcount = 0, flips = 0; + bool dllla, lnktr, plnktr; + u16 exp_lnksta; + pci_dev_t bdf; + u64 end; + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); + plnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); + + end = get_ticks() + usec_to_tick(200000); + do { + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, + &exp_lnksta); + dllla = !!(exp_lnksta & PCI_EXP_LNKSTA_DLLLA); + lnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); + + flips += plnktr ^ lnktr; + if (lnktr) { + ntrcount = 0; + trcount++; + } else { + ntrcount++; + } + loops++; + + plnktr = lnktr; + } while (!dllla && get_ticks() < end); + + bdf = dm_pci_get_bdf(dev); + debug("PCI Autoconfig: %02x.%02x.%02x: Fixup link: DL active: %u; " + "%3llu flips, %6llu loops of which %6llu while training, " + "final %6llu stable\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), + (unsigned int)dllla, + (unsigned long long)flips, (unsigned long long)loops, + (unsigned long long)trcount, (unsigned long long)ntrcount); + + return dllla || ntrcount >= loops / 2; +} + +/* + * Retrain the link of a downstream PCIe port by hand if necessary. + * + * This is needed at least where a downstream port of the ASMedia ASM2824 + * Gen 3 switch is wired to the upstream port of the Pericom PI7C9X2G304 + * Gen 2 switch, and observed with the Delock Riser Card PCI Express x1 > + * 2 x PCIe x1 device, P/N 41433, plugged into the SiFive HiFive Unmatched + * board. + * + * In such a configuration the switches are supposed to negotiate the link + * speed of preferably 5.0GT/s, falling back to 2.5GT/s. However the link + * continues switching between the two speeds indefinitely and the data + * link layer never reaches the active state, with link training reported + * repeatedly active ~84% of the time. Forcing the target link speed to + * 2.5GT/s with the upstream ASM2824 device makes the two switches talk to + * each other correctly however. And more interestingly retraining with a + * higher target link speed afterwards lets the two successfully negotiate + * 5.0GT/s. + * + * As this can potentially happen with any device and is cheap in the case + * of correctly operating hardware, let's do it for all downstream ports, + * for root complexes, PCIe switches and PCI/PCI-X to PCIe bridges. + * + * First check if automatic link training may have failed to complete, as + * indicated by the optional Data Link Layer Link Active status being off + * and the Link Bandwidth Management Status indicating that hardware has + * changed the link speed or width in an attempt to correct unreliable + * link operation. If this is the case, then check if the link operates + * correctly by seeing whether it is being trained excessively. If it is, + * then conclude the link is broken. + * + * In that case restrict the speed to 2.5GT/s, observing that the Target + * Link Speed field is sticky and therefore the link will stay restricted + * even after a device reset is later made by an OS that is unaware of the + * problem. With the speed restricted request that the link be retrained + * and check again if the link operates correctly. If not, then set the + * Target Link Speed back to the original value. + * + * This requires the presence of the Link Control 2 register, so make sure + * the PCI Express Capability Version is at least 2. Also don't try, for + * obvious reasons, to limit the speed if 2.5GT/s is the only link speed + * supported. + */ +static void dm_pciauto_exp_fixup_link(struct udevice *dev, int pcie_off) +{ + u16 exp_lnksta, exp_lnkctl, exp_lnkctl2; + u16 exp_flags, exp_type, exp_version; + u32 exp_lnkcap; + pci_dev_t bdf; + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_FLAGS, &exp_flags); + exp_version = exp_flags & PCI_EXP_FLAGS_VERS; + if (exp_version < 2) + return; + + exp_type = (exp_flags & PCI_EXP_FLAGS_TYPE) >> 4; + switch (exp_type) { + case PCI_EXP_TYPE_ROOT_PORT: + case PCI_EXP_TYPE_DOWNSTREAM: + case PCI_EXP_TYPE_PCIE_BRIDGE: + break; + default: + return; + } + + dm_pci_read_config32(dev, pcie_off + PCI_EXP_LNKCAP, &exp_lnkcap); + if ((exp_lnkcap & PCI_EXP_LNKCAP_SLS) <= PCI_EXP_LNKCAP_SLS_2_5GB) + return; + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); + if ((exp_lnksta & (PCI_EXP_LNKSTA_LBMS | PCI_EXP_LNKSTA_DLLLA)) != + PCI_EXP_LNKSTA_LBMS) + return; + + if (dm_pciauto_exp_link_stable(dev, pcie_off)) + return; + + bdf = dm_pci_get_bdf(dev); + printf("PCI Autoconfig: %02x.%02x.%02x: " + "Downstream link non-functional\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + printf("PCI Autoconfig: %02x.%02x.%02x: " + "Retrying with speed restricted to 2.5GT/s...\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL, &exp_lnkctl); + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL2, &exp_lnkctl2); + + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, + (exp_lnkctl2 & ~PCI_EXP_LNKCTL2_TLS) | + PCI_EXP_LNKCTL2_TLS_2_5GT); + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, + exp_lnkctl | PCI_EXP_LNKCTL_RL); + + if (dm_pciauto_exp_link_stable(dev, pcie_off)) { + printf("PCI Autoconfig: %02x.%02x.%02x: Succeeded!\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + } else { + printf("PCI Autoconfig: %02x.%02x.%02x: Failed!\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, + exp_lnkctl2); + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, + exp_lnkctl | PCI_EXP_LNKCTL_RL); + } +} + +void pcie_asm2824_workaround(struct udevice *dev) +{ + int pcie_off; + + /* For PCIe devices see if we need to retrain the link by hand */ + pcie_off = dm_pci_find_capability(dev, PCI_CAP_ID_EXP); + if (pcie_off) + dm_pciauto_exp_fixup_link(dev, pcie_off); +}
I agree, that we should not do this unconditionally in all cases, without the option for users to disable this. Or even have it disabled by default for most boards.
I'm not sure if we should name this "workaround" ASM2824, even though it's currently (only) targeted exactly for this PCIe switch. It might be helpful for other PCIe switches as well. So perhaps it's better to give this function a more generic name instead? With this change, it makes perhaps also sense to keep this function in pci_auto.c but also rename the Kconfig option to some more generic version.
Another comment below...
- bool "ASMedia ASM2824 PCIe workaround"
- help
"to enable link training failures" sound misleading IMHO. Perhaps somthing like this is better:
"...to enable link re-training upon failures for PCIe switches. This seems to be helpful on the ASMedia ASM2824 PCIe switch."
Thanks, Stefan
- endif
- Check if the link of a downstream PCIe port operates correctly.
- For that check if the optional Data Link Layer Link Active status gets
- on within a 200ms period or failing that wait until the completion of
- that period and check if link training has shown the completed status
- continuously throughout the second half of that period.
- Observation with the ASMedia ASM2824 Gen 3 switch indicates it takes
- 11-44ms to indicate the Data Link Layer Link Active status at 2.5GT/s,
- though it may take a couple of link training iterations.
- u16 exp_lnksta;
- pci_dev_t bdf;
- u64 end;
- do {
&exp_lnksta);
if (lnktr) {
ntrcount = 0;
trcount++;
} else {
ntrcount++;
loops++;
plnktr = lnktr;
- Retrain the link of a downstream PCIe port by hand if necessary.
- This is needed at least where a downstream port of the ASMedia ASM2824
- Gen 3 switch is wired to the upstream port of the Pericom PI7C9X2G304
- Gen 2 switch, and observed with the Delock Riser Card PCI Express x1 >
- 2 x PCIe x1 device, P/N 41433, plugged into the SiFive HiFive Unmatched
- board.
- In such a configuration the switches are supposed to negotiate the link
- speed of preferably 5.0GT/s, falling back to 2.5GT/s. However the link
- continues switching between the two speeds indefinitely and the data
- link layer never reaches the active state, with link training reported
- repeatedly active ~84% of the time. Forcing the target link speed to
- 2.5GT/s with the upstream ASM2824 device makes the two switches talk to
- each other correctly however. And more interestingly retraining with a
- higher target link speed afterwards lets the two successfully negotiate
- 5.0GT/s.
- As this can potentially happen with any device and is cheap in the case
- of correctly operating hardware, let's do it for all downstream ports,
- for root complexes, PCIe switches and PCI/PCI-X to PCIe bridges.
- First check if automatic link training may have failed to complete, as
- indicated by the optional Data Link Layer Link Active status being off
- and the Link Bandwidth Management Status indicating that hardware has
- changed the link speed or width in an attempt to correct unreliable
- link operation. If this is the case, then check if the link operates
- correctly by seeing whether it is being trained excessively. If it is,
- then conclude the link is broken.
- In that case restrict the speed to 2.5GT/s, observing that the Target
- Link Speed field is sticky and therefore the link will stay restricted
- even after a device reset is later made by an OS that is unaware of the
- problem. With the speed restricted request that the link be retrained
- and check again if the link operates correctly. If not, then set the
- Target Link Speed back to the original value.
- This requires the presence of the Link Control 2 register, so make sure
- the PCI Express Capability Version is at least 2. Also don't try, for
- obvious reasons, to limit the speed if 2.5GT/s is the only link speed
- supported.
- u32 exp_lnkcap;
- pci_dev_t bdf;
return;
break;
- default:
return;
return;
return;
return;
- } else {
exp_lnkctl2);
int pcie_off;
- if (pcie_off)
- pcie_asm2824_workaround(dev);
- ASMedia ASM2824 PCIe workaround
- Copyright (c) 2021 Maciej W. Rozycki macro@orcam.me.uk
- u16 exp_lnksta;
- pci_dev_t bdf;
- u64 end;
- do {
&exp_lnksta);
if (lnktr) {
ntrcount = 0;
trcount++;
} else {
ntrcount++;
loops++;
plnktr = lnktr;
- board.
- 5.0GT/s.
- supported.
- u32 exp_lnkcap;
- pci_dev_t bdf;
return;
break;
- default:
return;
return;
return;
return;
- } else {
exp_lnkctl2);
- int pcie_off;
- if (pcie_off)
Viele Grüße, Stefan Roese
By now I have become somewhat tired arguing and explaining matters over and over again as things have been moving as slow as molasses in this area, but one point I want to raise here is while it is indeed the ASM2824 device that seems problematic, it may actually be downstream, so you won't know it's there until you go through the workaround, as observed with the root port of the SiFive FU740-C000 SOC (which has a separate workaround in U-boot, clearly for the same issue; cf. `pcie_sifive_force_gen1'). So it looks like the erratum is going to show up with some device combinations in which the device enumerator may not have a way to know an ASM2824 is there until the workaround applied to an upstream device has let the link work.
And as I previously already mentioned the Linux version of the workaround is only activated by the vendor:device ID because you cannot busy-loop polling on the Link Training bit in Linux (while you can do it in U-Boot, because U-Boot is not an OS). Arguably I could have broadened it to cover all Gen 3+ devices and poll on the Data Link Layer Link Active bit, which doesn't require busy-looping for meaningful results, but that would still leave Gen 2 devices out and chances are the system boots from U-Boot with the generic workaround applied and the link already negotiated at 2.5GT/s.
NB the ASM2824 switch has been used with option cards as well, e.g. https://www.amazon.com/dp/B07PRN2QCV, so it can be there in any system that has a connector of any kind that lets one use PCIe option cards.
FWIW,
Maciej
I see that Linux patch was not not merged yet and there are already comments that this issue is probably board or arch specific and maybe should be in arch/riscv linux dir: https://lore.kernel.org/linux-pci/20220421202711.GA1415244@bhelgaas/
From that comment I have feeling that the issue could be really specific
to board or combination of connected devices (ASM2824+PI7C9X2G304) as there is really no other report about this issue.
In any case it is weird.
Is is not _only_ because of this. For a longer time there is a direction to specify exact list of _affected_ hw which needs workaround. And not usage of wildcard which match all hardware, even unaffected. See for example comments which are adding workaround for broken GIC HW: https://lore.kernel.org/lkml/87ilsutb6w.wl-maz@kernel.org/
And this makes sense, workarounds should be targeted.
FWIW,
Maciej
Maybe, maybe not, and given the lack of cooperation shown by ASMedia I am not going to spend any money on their hardware to get this figured out, such as https://www.amazon.com/dp/B07PRN2QCV previously mentioned (plus the necessary M.2 to PCIe slot adapters).
Main concerns with my change so far appear to be some coding style issues which are due to my lack of following of the development of newer internal interfaces. That'll be fixed with the next iteration when I get to it (hopefully this coming weekend). I have a lot of stuff in progress (and a job and personal life too) and need to prioritise.
As I say, from the findings so far this seems to me like a protocol rather than signalling (electrical) issue, i.e. a design problem with either or both chips. A board design fault (such as improper decoupling, crosstalk, or whatever) could only result in a signalling issue. And if it was a signalling issue, then the 5GT/s rate couldn't be negotiated, whether automatically or by hand as with this workaround, and then work reliably over days to weeks.
It is exactly and only for this. I think I know why I wrote it this way.
Your observation only makes sense for a problem contained within a device itself and not for a problem with establishing a link between two devices.
If the problem is caused by a downstream device, then you cannot match on it to activate a workaround because you won't know it's there until you have activated the workaround. It hasn't been determined here whether the problem is the upstream device, the downstream device or a combination of the two.
And I don't think it is appropriate to put the burden onto the users to determine what the case is, by deliberately releasing a limited fix in a hope that something will break for someone and they will report it. It is an engineer's responsibility to ensure the quality of the solution made is of the highest quality feasible. If we knew what the exact actual cause is, then we could keep the workaround limited to the cases identified by the cause.
Also FWIW the next iteration of my Linux change will no longer match the quirk on a device ID and will instead use the PCI bridge class ID with a further qualification within. I had a concern about the safety of the change, but I have got it mentally resolved now and only the potentially unsafe part will be further qualified by a device ID.
Sadly I still need to limit the workaround to data link layer link active reporting capable devices, which will undoubtedly exclude some up to 5GT/s only hardware, due to the need to avoid busy-looping on the Link Training bit, which is a no-no in an OS. So the U-Boot code will remain the only workaround for some configurations.
Maciej
FYI it didn't happen as I got distracted with an emergency PSU repair in another system where I discovered leaks from electrolytic capacitors that posed a risk of damaging other components or the PCB even if powered off, so faulty parts had to be replaced as a matter of urgency.
And then I've had a need to put the Unmatched board in GCC verification, which it has been running ever since, certainly longer than expected. It means I cannot take it offline to do Linux kernel verification for the foreseeable future.
Therefore I have no new ETA at the moment, but as always I'll do my best.
Maciej
PCIe GEN3 link retrain workaround, specially designed for system with PCIe ASMedia ASM2824 Switch and other Endpoint devices, unconditionally increase size of all SPL binaries with PCIe support, even those which do not require it.
Moreover this workaround is enabled for all existing hardware and also all future PCIe hardware, which opens a hole that other PCIe vendors may introduce same HW issue as on systems where this workaround is required and nobody would notice it because U-Boot automatically apply workaround for it.
So do not unconditionally enable this workaround on all hardware. Instead introduce a new config option which is disabled by default. This decrease SPL size and also ensure that workaround is not blindly or inexactly enabled.
To make workaround code local, move it into separate file, so pci_auto.c contains only generic auto configuration code.
Signed-off-by: Pali Rohár pali@kernel.org --- Changes in v2: * Rename config option to CONFIG_PCIE_GEN3_RETRAIN_WORKAROUND as it is generic workaround and does not have to be needed only for ASMedia switch (moreover it looks like issue is triggered by combination of ASMedia switch with other endpoint PCIe device) * Rephrase Kconfig help text as suggected by Stefan --- drivers/pci/Kconfig | 9 + drivers/pci/Makefile | 1 + drivers/pci/pci_auto.c | 171 +------------------ drivers/pci/pcie_gen3_retrain_workaround.c | 183 +++++++++++++++++++++ 4 files changed, 197 insertions(+), 167 deletions(-) create mode 100644 drivers/pci/pcie_gen3_retrain_workaround.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 22f4995453ed..f56c8e89141c 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -365,4 +365,13 @@ config PCIE_UNIPHIER Say Y here if you want to enable PCIe controller support on UniPhier SoCs.
+config PCIE_GEN3_RETRAIN_WORKAROUND + bool "PCIe GEN3 retrain workaround" + help + Say Y here if you want to enable link re-training upon failures + for all PCIe Root Ports, PCIe Switch Downstream Ports and also + for PCIe to PCI/PCI-X Bridges. This seems to be helpful on the + ASMedia ASM2824 PCIe Switch. + Compliant PCIe hierarchy does not need this workaround. + endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index cfcd6fd6c52f..57587205d198 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o +obj-$(CONFIG_PCIE_GEN3_RETRAIN_WORKAROUND) += pcie_gen3_retrain_workaround.o diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index c7968926a17f..4583ff8b384e 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -13,7 +13,6 @@ #include <errno.h> #include <log.h> #include <pci.h> -#include <time.h> #include "pci_internal.h"
-/* - * Check if the link of a downstream PCIe port operates correctly. - * - * For that check if the optional Data Link Layer Link Active status gets - * on within a 200ms period or failing that wait until the completion of - * that period and check if link training has shown the completed status - * continuously throughout the second half of that period. - * - * Observation with the ASMedia ASM2824 Gen 3 switch indicates it takes - * 11-44ms to indicate the Data Link Layer Link Active status at 2.5GT/s, - * though it may take a couple of link training iterations. - */ -static bool dm_pciauto_exp_link_stable(struct udevice *dev, int pcie_off) -{ - u64 loops = 0, trcount = 0, ntrcount = 0, flips = 0; - bool dllla, lnktr, plnktr; - u16 exp_lnksta; - pci_dev_t bdf; - u64 end; - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); - plnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); - - end = get_ticks() + usec_to_tick(200000); - do { - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, - &exp_lnksta); - dllla = !!(exp_lnksta & PCI_EXP_LNKSTA_DLLLA); - lnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); - - flips += plnktr ^ lnktr; - if (lnktr) { - ntrcount = 0; - trcount++; - } else { - ntrcount++; - } - loops++; - - plnktr = lnktr; - } while (!dllla && get_ticks() < end); - - bdf = dm_pci_get_bdf(dev); - debug("PCI Autoconfig: %02x.%02x.%02x: Fixup link: DL active: %u; " - "%3llu flips, %6llu loops of which %6llu while training, " - "final %6llu stable\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), - (unsigned int)dllla, - (unsigned long long)flips, (unsigned long long)loops, - (unsigned long long)trcount, (unsigned long long)ntrcount); - - return dllla || ntrcount >= loops / 2; -} - -/* - * Retrain the link of a downstream PCIe port by hand if necessary. - * - * This is needed at least where a downstream port of the ASMedia ASM2824 - * Gen 3 switch is wired to the upstream port of the Pericom PI7C9X2G304 - * Gen 2 switch, and observed with the Delock Riser Card PCI Express x1 > - * 2 x PCIe x1 device, P/N 41433, plugged into the SiFive HiFive Unmatched - * board. - * - * In such a configuration the switches are supposed to negotiate the link - * speed of preferably 5.0GT/s, falling back to 2.5GT/s. However the link - * continues switching between the two speeds indefinitely and the data - * link layer never reaches the active state, with link training reported - * repeatedly active ~84% of the time. Forcing the target link speed to - * 2.5GT/s with the upstream ASM2824 device makes the two switches talk to - * each other correctly however. And more interestingly retraining with a - * higher target link speed afterwards lets the two successfully negotiate - * 5.0GT/s. - * - * As this can potentially happen with any device and is cheap in the case - * of correctly operating hardware, let's do it for all downstream ports, - * for root complexes, PCIe switches and PCI/PCI-X to PCIe bridges. - * - * First check if automatic link training may have failed to complete, as - * indicated by the optional Data Link Layer Link Active status being off - * and the Link Bandwidth Management Status indicating that hardware has - * changed the link speed or width in an attempt to correct unreliable - * link operation. If this is the case, then check if the link operates - * correctly by seeing whether it is being trained excessively. If it is, - * then conclude the link is broken. - * - * In that case restrict the speed to 2.5GT/s, observing that the Target - * Link Speed field is sticky and therefore the link will stay restricted - * even after a device reset is later made by an OS that is unaware of the - * problem. With the speed restricted request that the link be retrained - * and check again if the link operates correctly. If not, then set the - * Target Link Speed back to the original value. - * - * This requires the presence of the Link Control 2 register, so make sure - * the PCI Express Capability Version is at least 2. Also don't try, for - * obvious reasons, to limit the speed if 2.5GT/s is the only link speed - * supported. - */ -static void dm_pciauto_exp_fixup_link(struct udevice *dev, int pcie_off) -{ - u16 exp_lnksta, exp_lnkctl, exp_lnkctl2; - u16 exp_flags, exp_type, exp_version; - u32 exp_lnkcap; - pci_dev_t bdf; - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_FLAGS, &exp_flags); - exp_version = exp_flags & PCI_EXP_FLAGS_VERS; - if (exp_version < 2) - return; - - exp_type = (exp_flags & PCI_EXP_FLAGS_TYPE) >> 4; - switch (exp_type) { - case PCI_EXP_TYPE_ROOT_PORT: - case PCI_EXP_TYPE_DOWNSTREAM: - case PCI_EXP_TYPE_PCIE_BRIDGE: - break; - default: - return; - } - - dm_pci_read_config32(dev, pcie_off + PCI_EXP_LNKCAP, &exp_lnkcap); - if ((exp_lnkcap & PCI_EXP_LNKCAP_SLS) <= PCI_EXP_LNKCAP_SLS_2_5GB) - return; - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); - if ((exp_lnksta & (PCI_EXP_LNKSTA_LBMS | PCI_EXP_LNKSTA_DLLLA)) != - PCI_EXP_LNKSTA_LBMS) - return; - - if (dm_pciauto_exp_link_stable(dev, pcie_off)) - return; - - bdf = dm_pci_get_bdf(dev); - printf("PCI Autoconfig: %02x.%02x.%02x: " - "Downstream link non-functional\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - printf("PCI Autoconfig: %02x.%02x.%02x: " - "Retrying with speed restricted to 2.5GT/s...\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL, &exp_lnkctl); - dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL2, &exp_lnkctl2); - - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, - (exp_lnkctl2 & ~PCI_EXP_LNKCTL2_TLS) | - PCI_EXP_LNKCTL2_TLS_2_5GT); - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, - exp_lnkctl | PCI_EXP_LNKCTL_RL); - - if (dm_pciauto_exp_link_stable(dev, pcie_off)) { - printf("PCI Autoconfig: %02x.%02x.%02x: Succeeded!\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - } else { - printf("PCI Autoconfig: %02x.%02x.%02x: Failed!\n", - PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); - - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, - exp_lnkctl2); - dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, - exp_lnkctl | PCI_EXP_LNKCTL_RL); - } -} +void pcie_gen3_retrain_workaround(struct udevice *dev);
- /* For PCIe devices see if we need to retrain the link by hand */ - pcie_off = dm_pci_find_capability(dev, PCI_CAP_ID_EXP); - if (pcie_off) - dm_pciauto_exp_fixup_link(dev, pcie_off); +#ifdef CONFIG_PCIE_GEN3_RETRAIN_WORKAROUND + pcie_gen3_retrain_workaround(dev); +#endif
/* Enable memory and I/O accesses, enable bus master */ dm_pci_write_config16(dev, PCI_COMMAND, cmdstat | PCI_COMMAND_MASTER); diff --git a/drivers/pci/pcie_gen3_retrain_workaround.c b/drivers/pci/pcie_gen3_retrain_workaround.c new file mode 100644 index 000000000000..e4fe3368652d --- /dev/null +++ b/drivers/pci/pcie_gen3_retrain_workaround.c @@ -0,0 +1,183 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * PCIe GEN3 retrain workaround + * + * Copyright (c) 2021 Maciej W. Rozycki macro@orcam.me.uk + */ + +#include <common.h> +#include <dm.h> +#include <pci.h> +#include <time.h> + +/* + * Check if the link of a downstream PCIe port operates correctly. + * + * For that check if the optional Data Link Layer Link Active status gets + * on within a 200ms period or failing that wait until the completion of + * that period and check if link training has shown the completed status + * continuously throughout the second half of that period. + * + * Observation with the ASMedia ASM2824 Gen 3 switch indicates it takes + * 11-44ms to indicate the Data Link Layer Link Active status at 2.5GT/s, + * though it may take a couple of link training iterations. + */ +static bool dm_pciauto_exp_link_stable(struct udevice *dev, int pcie_off) +{ + u64 loops = 0, trcount = 0, ntrcount = 0, flips = 0; + bool dllla, lnktr, plnktr; + u16 exp_lnksta; + pci_dev_t bdf; + u64 end; + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); + plnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); + + end = get_ticks() + usec_to_tick(200000); + do { + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, + &exp_lnksta); + dllla = !!(exp_lnksta & PCI_EXP_LNKSTA_DLLLA); + lnktr = !!(exp_lnksta & PCI_EXP_LNKSTA_LT); + + flips += plnktr ^ lnktr; + if (lnktr) { + ntrcount = 0; + trcount++; + } else { + ntrcount++; + } + loops++; + + plnktr = lnktr; + } while (!dllla && get_ticks() < end); + + bdf = dm_pci_get_bdf(dev); + debug("PCI Autoconfig: %02x.%02x.%02x: Fixup link: DL active: %u; " + "%3llu flips, %6llu loops of which %6llu while training, " + "final %6llu stable\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), + (unsigned int)dllla, + (unsigned long long)flips, (unsigned long long)loops, + (unsigned long long)trcount, (unsigned long long)ntrcount); + + return dllla || ntrcount >= loops / 2; +} + +/* + * Retrain the link of a downstream PCIe port by hand if necessary. + * + * This is needed at least where a downstream port of the ASMedia ASM2824 + * Gen 3 switch is wired to the upstream port of the Pericom PI7C9X2G304 + * Gen 2 switch, and observed with the Delock Riser Card PCI Express x1 > + * 2 x PCIe x1 device, P/N 41433, plugged into the SiFive HiFive Unmatched + * board. + * + * In such a configuration the switches are supposed to negotiate the link + * speed of preferably 5.0GT/s, falling back to 2.5GT/s. However the link + * continues switching between the two speeds indefinitely and the data + * link layer never reaches the active state, with link training reported + * repeatedly active ~84% of the time. Forcing the target link speed to + * 2.5GT/s with the upstream ASM2824 device makes the two switches talk to + * each other correctly however. And more interestingly retraining with a + * higher target link speed afterwards lets the two successfully negotiate + * 5.0GT/s. + * + * As this can potentially happen with any device and is cheap in the case + * of correctly operating hardware, let's do it for all downstream ports, + * for root complexes, PCIe switches and PCI/PCI-X to PCIe bridges. + * + * First check if automatic link training may have failed to complete, as + * indicated by the optional Data Link Layer Link Active status being off + * and the Link Bandwidth Management Status indicating that hardware has + * changed the link speed or width in an attempt to correct unreliable + * link operation. If this is the case, then check if the link operates + * correctly by seeing whether it is being trained excessively. If it is, + * then conclude the link is broken. + * + * In that case restrict the speed to 2.5GT/s, observing that the Target + * Link Speed field is sticky and therefore the link will stay restricted + * even after a device reset is later made by an OS that is unaware of the + * problem. With the speed restricted request that the link be retrained + * and check again if the link operates correctly. If not, then set the + * Target Link Speed back to the original value. + * + * This requires the presence of the Link Control 2 register, so make sure + * the PCI Express Capability Version is at least 2. Also don't try, for + * obvious reasons, to limit the speed if 2.5GT/s is the only link speed + * supported. + */ +static void dm_pciauto_exp_fixup_link(struct udevice *dev, int pcie_off) +{ + u16 exp_lnksta, exp_lnkctl, exp_lnkctl2; + u16 exp_flags, exp_type, exp_version; + u32 exp_lnkcap; + pci_dev_t bdf; + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_FLAGS, &exp_flags); + exp_version = exp_flags & PCI_EXP_FLAGS_VERS; + if (exp_version < 2) + return; + + exp_type = (exp_flags & PCI_EXP_FLAGS_TYPE) >> 4; + switch (exp_type) { + case PCI_EXP_TYPE_ROOT_PORT: + case PCI_EXP_TYPE_DOWNSTREAM: + case PCI_EXP_TYPE_PCIE_BRIDGE: + break; + default: + return; + } + + dm_pci_read_config32(dev, pcie_off + PCI_EXP_LNKCAP, &exp_lnkcap); + if ((exp_lnkcap & PCI_EXP_LNKCAP_SLS) <= PCI_EXP_LNKCAP_SLS_2_5GB) + return; + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKSTA, &exp_lnksta); + if ((exp_lnksta & (PCI_EXP_LNKSTA_LBMS | PCI_EXP_LNKSTA_DLLLA)) != + PCI_EXP_LNKSTA_LBMS) + return; + + if (dm_pciauto_exp_link_stable(dev, pcie_off)) + return; + + bdf = dm_pci_get_bdf(dev); + printf("PCI Autoconfig: %02x.%02x.%02x: " + "Downstream link non-functional\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + printf("PCI Autoconfig: %02x.%02x.%02x: " + "Retrying with speed restricted to 2.5GT/s...\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL, &exp_lnkctl); + dm_pci_read_config16(dev, pcie_off + PCI_EXP_LNKCTL2, &exp_lnkctl2); + + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, + (exp_lnkctl2 & ~PCI_EXP_LNKCTL2_TLS) | + PCI_EXP_LNKCTL2_TLS_2_5GT); + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, + exp_lnkctl | PCI_EXP_LNKCTL_RL); + + if (dm_pciauto_exp_link_stable(dev, pcie_off)) { + printf("PCI Autoconfig: %02x.%02x.%02x: Succeeded!\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + } else { + printf("PCI Autoconfig: %02x.%02x.%02x: Failed!\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL2, + exp_lnkctl2); + dm_pci_write_config16(dev, pcie_off + PCI_EXP_LNKCTL, + exp_lnkctl | PCI_EXP_LNKCTL_RL); + } +} + +void pcie_gen3_retrain_workaround(struct udevice *dev) +{ + int pcie_off; + + /* For PCIe devices see if we need to retrain the link by hand */ + pcie_off = dm_pci_find_capability(dev, PCI_CAP_ID_EXP); + if (pcie_off) + dm_pciauto_exp_fixup_link(dev, pcie_off); +}
Changes in v2:
- Rename config option to CONFIG_PCIE_GEN3_RETRAIN_WORKAROUND as it is generic workaround and does not have to be needed only for ASMedia switch (moreover it looks like issue is triggered by combination of ASMedia switch with other endpoint PCIe device)
- Rephrase Kconfig help text as suggected by Stefan
Why is it a problem? Is the intent to cause hassle to end users and force them to take action when they have a non-working piece of hardware?
I'd say in 99% of cases this will only cause frustration and they won't bother. They will just conclude that either piece of hardware involved is broken and will throw it away. Just as I almost did. The seller has offered me a refund, which seems thought to be a universal solution nowadays (but I need to do what I meant to and getting money back doesn't solve it).
And at least I know what U-boot (or indeed firmware) is and have a general understanding of how computers work. Most people just want to plug stuff in and use it for whatever their need is. Expecting them to take action to get things working is wasting their time (which BTW seems to have been a growing trend in last ~30 years: putting burden on the end user to get our problems solved, which saves our time and money at the expense of end user's).
NB I'm slowly getting fed up with the amount of non-working stuff piling up around. Every other piece of equipment I try doesn't work for one reason or another and I need to either chase bugs myself or to spend days and weeks to persuade someone at least to believe a problem is there to get that sorted. All in my free time I'd rather spend on something else. I'd welcome things working automagically for a change so that I could focus on what I mean to be doing, and therefore I take breaking things deliberately as a major offence.
FWIW,
Maciej
I think I wrote it. One issue is that it is increasing size of SPL image and we really should not include into SPL things which are not required for all target platforms. Lot of boards have size constrained memory requirements and unnecessary features should not be automatically enabled.
Vendors should really test their hardware without any automatic workaround. Otherwise we are going into the hell if some workarounds are automatically enabled and nobody notice broken behavior. And vendors really build software with default options and do not care about it if default options are suitable.
There is already direction to make all workaround targeted and enabled only for platforms / hardware which really need it.
So enabling some workaround for all platforms which are produced and will be produced in the future is step backward.
The another issue here is that it was not fully investigated where the issue is. If it is processor specific, PCIe switch specific or endpoint specific, or combination of these options. It was just observed that proposed workaround fix this issue on one specific combination. And you confirmed this in previous post, that you are unsure if it is not specific to downstream ports of the switch.
We really should not include such "bloatware" code to be enabled for everything, on every one board. You are the first who reported this issue. Nobody else complained about it, so I really do not see reason why all other users and developers must be forced to have it in their U-Boot binaries. Moreover lot of boards on which is U-Boot running do not have PCIe bus exported on the slot and have PCIe devices integrated and soldered on the board. Why on the earth I have to need this workaround also on these boards (which are moreover sized constrained)?
FWIW,
Maciej
What other U-Boot developers think?
I have to agree with Pali here. We need to be careful with size increase in the SPL images, as some of the build targets are very limited here. So making this workaround configurable is definitely a good idea.
The question remains, at least for me, if the Kconfig option should be enable per default or not. For SPL my suggestions is to disable is per default because of the size remarks above. For U-Boot proper I'm not so sure. Please see below...
All this makes sense to me. You both have good points AFAICT. Please see below...
Agreed. But I also understand the reasoning from Maciej, at least in parts. Thinking a bit more about this, my preference would be to still include this workaround per default in U-Boot proper though. To not make things too complicated here.
Just my 0.02$.
FWIW,
Maciej
Please see above.
Thanks, Stefan
Just my 0.02$.
I understand it.
Anyway, I would really to know where is the issue (in which part of PCIe hierarchy) and what exactly is affected.
I think that deep understanding of the issue is important or at least confirmation from the vendor (which we know that it would not come).
FWIW,
Maciej
Please see above.
Thanks, Stefan
Just my 0.02$.
I understand it.
Here's the hierarchy tree of the system affected:
-[0000:00]---00.0-[01-0b]----00.0-[02-0b]--+-00.0-[03]-- +-02.0-[04]----00.0 +-03.0-[05-09]----00.0-[06-09]--+-01.0-[07]--+-00.0 | | -00.3 | -02.0-[08-09]----00.0-[09]--+-01.0 | -02.0 +-04.0-[0a]----00.0 -08.0-[0b]--+-00.0 -00.1
and the issue is between 0000:02:03.0 and 0000:05:00.0. This has nothing to do with the host CPU and the ASM2824 part is a generic PCIe switch also available on option cards with slots. So it can be plugged by a user into any system out there that has PCIe slot connectivity (also a conventional PCI system via a PCI-to-PCIe reverse bridge or IIUC a Thunderbolt bridge). Of course if a given system has no external PCI/e connectivity and no affected devices onboard, then there is no point in having the workaround included in the firmware.
Indeed that would help a lot, but we need to live with what we have.
FWIW I have finally found time and an availability slot with my HiFive Unmatched hardware to get an updated version of the Linux fix made, verified and posted upstream; cf. https://lore.kernel.org/linux-pci/alpine.DEB.2.21.2209061238050.2275@angie.orcam.me.uk/.
Maciej
I object to having just a single workaround configurable as I expect it to be beyond the capability of people on average to get right. You simply start getting lost at one point, just as I am with all the random options the Linux kernel has nowadays. And the dozens added with every release.
I agree on the SPL side and on a global option. I think it only makes sense to have individual workarounds selectable for onboard devices with hardware that has no external PCI/e connectivity. Those should not be exposed to the user and instead implicitly selected by the scriptery based on the base machine chosen.
FWIW Linux has a global PCI_QUIRKS option available in the expert mode only that lets one disable all workarounds:
config PCI_QUIRKS default y bool "Enable PCI quirk workarounds" if EXPERT help This enables workarounds for various PCI chipset bugs/quirks. Disable this only if your target machine is unaffected by PCI quirks.
for U-Boot I could envisage something like:
config PCI_QUIRKS bool "Enable PCI quirk workarounds" if EXPERT default y if !SPL [...]
Leaving just a single workaround out, especially for option card devices is asking for people getting it wrong.
If there are individual workarounds required by hardware with no external PCI/e connectivity, then we could have say:
config PCI_QUIRKS bool "Enable PCI quirk workarounds" if EXPERT default y if !SPL select SPECIFIC_QUIRK_FOR_BADLY_BROKEN_BOARD
config BADLY_BROKEN_BOARD bool "Enable support for Badly Broken Board" select SPECIFIC_QUIRK_FOR_BADLY_BROKEN_BOARD
config SPECIFIC_QUIRK_FOR_BADLY_BROKEN_BOARD bool
and then wire the specific quirk to SPECIFIC_QUIRK_FOR_BADLY_BROKEN_BOARD rather than PCI_QUIRKS in the Makefile system.
Thank you for your input.
Maciej
I agree on the SPL side.
I suspect that most vendors of PCIe option cards do not verify them with U-Boot at all.
Well workarounds for option cards do necessarily have to be included with all hardware that has external PCI/e connectivity I'm afraid.
The ASMedia ASM2824 switch is used with the StarTech PEX8M2E2 dual M.2 M-Key adapter. Also sold under the Ableconn brand as PEXM2-130. And M.2 M-Key to PCIe slot adapters are widely available.
The Pericom PI7C9X2G304 switch is used with the Delock 41433 dual PCIe slot adapter. Also sold under the SYBA IOCrest brand as SI-PEX60016. They have both been withdrawn AFAICT now, so availability may vary though.
You can plug these option cards into any system.
It was and the outcome detailed along with the original submission.
It was determined that the two generic PCIe switches named above fail to negotiate link. I would expect other parts from the same vendors to show the same problem as IP blocks get reused between silicon.
You need to have a way to specify the absence of slot connectivity in board configuration then. This will allow one to say:
depends on PCI_SLOT || BADLY_BROKEN_BOARD
etc.
Maciej
Maciej W. Rozycki
Pali Rohár
Stefan Roese
