[PATCH v3] imx8mq: configs: add support for distro boot commands
Supported boot device types in iMX8MQ: MMC, DHCP.
CONFIG_DISTRO_DEFAULTS is added for enabling the DISTRO_DEFAULTS option.
CONFIG_BOOTCOMMAND which is defined in include/configs/imx8mq_evk.h is deleted because "run distro_bootcmd" is required to be the default boot mode.
scriptaddr is the location in RAM where boot.scr.uimg/boot.scr will be loaded to prior to execution.
kernel_addr_r is the location in RAM where the kernel will be loaded to.
Delete unnecessary environment variables because "run distro_bootcmd" is set to be the default boot mode.
Signed-off-by: Alice Guo alice.guo@nxp.com ---
Changes for v3: - enable the DISTRO_DEFAULTS option by adding CONFIG_DISTRO_DEFAULTS=y - modify commit log Changes for v2: - re-add boot_fdt, initrd_addr and bootm_size which may need to be used
configs/imx8mq_evk_defconfig | 1 + include/configs/imx8mq_evk.h | 75 ++++++------------------------------ 2 files changed, 13 insertions(+), 63 deletions(-)
diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index de91a76d41..424301bf4d 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 96bfff749c..1861ebad18 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -74,20 +74,20 @@ #define IMX_FEC_BASE 0x30BE0000 #endif
-#define CONFIG_MFG_ENV_SETTINGS \ - "mfgtool_args=setenv bootargs console=${console},${baudrate} " \ - "rdinit=/linuxrc " \ - "g_mass_storage.stall=0 g_mass_storage.removable=1 " \ - "g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF "\ - "g_mass_storage.iSerialNumber="" "\ - "clk_ignore_unused "\ - "\0" \ - "initrd_addr=0x43800000\0" \ - "bootcmd_mfg=run mfgtool_args;booti ${loadaddr} ${initrd_addr} ${fdt_addr};\0" \ +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> +#endif + /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ - CONFIG_MFG_ENV_SETTINGS \ - "script=boot.scr\0" \ + BOOTENV \ + "scriptaddr=0x43500000\0" \ + "kernel_addr_r=0x40880000\0" \ "image=Image\0" \ "console=ttymxc0,115200\0" \ "fdt_addr=0x43000000\0" \ @@ -95,59 +95,8 @@ "fdt_file=imx8mq-evk.dtb\0" \ "initrd_addr=0x43800000\0" \ "bootm_size=0x10000000\0" \ - "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ - "mmcautodetect=yes\0" \ - "mmcargs=setenv bootargs console=${console} root=${mmcroot}\0 " \ - "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source\0" \ - "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ - "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if run loadfdt; then " \ - "booti ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "else " \ - "echo wait for boot; " \ - "fi;\0" \ - "netargs=setenv bootargs console=${console} " \ - "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "if test ${ip_dyn} = yes; then " \ - "setenv get_cmd dhcp; " \ - "else " \ - "setenv get_cmd tftp; " \ - "fi; " \ - "${get_cmd} ${loadaddr} ${image}; " \ - "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ - "booti ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "else " \ - "booti; " \ - "fi;\0" - -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadimage; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "fi; " \ - "else booti ${loadaddr} - ${fdt_addr}; fi"
/* Link Definitions */ #define CONFIG_LOADADDR 0x40480000 -- 2.17.1
From: Alice Guo alice.guo@nxp.com Supported boot device types in iMX8MQ: MMC, DHCP. CONFIG_DISTRO_DEFAULTS is added for enabling the DISTRO_DEFAULTS option. CONFIG_BOOTCOMMAND which is defined in include/configs/imx8mq_evk.h is deleted because "run distro_bootcmd" is required to be the default boot mode. scriptaddr is the location in RAM where boot.scr.uimg/boot.scr will be loaded to prior to execution. kernel_addr_r is the location in RAM where the kernel will be loaded to. Delete unnecessary environment variables because "run distro_bootcmd" is set to be the default boot mode. Signed-off-by: Alice Guo alice.guo@nxp.com
Best regards, Stefano Babic
Alice Guo (OSS)
sbabic@denx.de
