[U-Boot] [PATCH] CONFIG_BOOTDELAY default should not affect runtime
Because the code that handles bootdelay is compiled in conditionally based on the default value, you are restricted in the default, regardless of what you want the runtime options to be.
Change the source to always check if any default is given so that other values can be selected and used at runtime.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- common/main.c | 14 ++++++-------- 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/common/main.c b/common/main.c index e2d2e09..0973c59 100644 --- a/common/main.c +++ b/common/main.c @@ -95,7 +95,7 @@ extern void mdm_init(void); /* defined in board.c */ * Watch for 'delay' seconds for autoboot stop or autoboot delay string. * returns: 0 - no key string, allow autoboot 1 - got key string, abort */ -#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) +#if defined(CONFIG_BOOTDELAY) # if defined(CONFIG_AUTOBOOT_KEYED) #ifndef CONFIG_MENU static inline @@ -279,7 +279,7 @@ int abortboot(int bootdelay) return abort; } # endif /* CONFIG_AUTOBOOT_KEYED */ -#endif /* CONFIG_BOOTDELAY >= 0 */ +#endif /* CONFIG_BOOTDELAY */
/* * Runs the given boot command securely. Specifically: @@ -295,8 +295,7 @@ int abortboot(int bootdelay) * printing the error message to console. */
-#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) && \ - defined(CONFIG_OF_CONTROL) +#if defined(CONFIG_BOOTDELAY) && defined(CONFIG_OF_CONTROL) static void secure_boot_cmd(char *cmd) { cmd_tbl_t *cmdtp; @@ -358,11 +357,10 @@ void main_loop (void) int rc = 1; int flag; #endif -#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) && \ - defined(CONFIG_OF_CONTROL) +#if defined(CONFIG_BOOTDELAY) && defined(CONFIG_OF_CONTROL) char *env; #endif -#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) +#if defined(CONFIG_BOOTDELAY) char *s; int bootdelay; #endif @@ -431,7 +429,7 @@ void main_loop (void) update_tftp (0UL); #endif /* CONFIG_UPDATE_TFTP */
-#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) +#if defined(CONFIG_BOOTDELAY) s = getenv ("bootdelay"); bootdelay = s ? (int)simple_strtol(s, NULL, 10) : CONFIG_BOOTDELAY;
Dear Joe Hershberger,
In message 1360355280-1197-1-git-send-email-joe.hershberger@ni.com you wrote:
- Watch for 'delay' seconds for autoboot stop or autoboot delay string.
- returns: 0 - no key string, allow autoboot 1 - got key string, abort
Careful!! This is probably changing behaviour of a number of boards significantly.
we have to check if we really want this, and if yes, we have to announce it and provide a grace period (eventually using doc/feature-removal-schedule.txt ?)
Hello Wolfgang,
It seems the CONFIG_BOOTDELAY as < 0 is not very common:
~/hacking/u-boot% git grep CONFIG_BOOTDELAY | egrep 'BOOTDELAY\s* -[0-9]' include/configs/RPXsuper.h:#define CONFIG_BOOTDELAY -1 include/configs/ep8260.h:#define CONFIG_BOOTDELAY -1 include/configs/espt.h:#define CONFIG_BOOTDELAY -1 include/configs/scb9328.h:#define CONFIG_BOOTDELAY -1 include/configs/sh7763rdp.h:#define CONFIG_BOOTDELAY -1
So maybe those could have CONFIG_BOOTDELAY undefined keeping them working as before?
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Dear Otavio Salvador,
In message CAP9ODKqs5Fsw+NVQzNvm6+4VVK6jfC1vD6eZQfumdKvxzCqsjQ@mail.gmail.com you wrote:
You do not know all the many out-of-tree ports...
[OK, we don't care much about these, true...]
Yes, they could. But it is a change of a long-standing behaviour, and we try to avoid breaking existing boards. At minimum this needs to be announced, the respective board maintainers need to be modified, and given sufficient time to react.
Yes; I agree but breaking out of tree boards ... well, it is the price of not working upstream so I think it cannot be a blocker for U-Boot improvements and cleanups.
In message CAP9ODKr3xaU_Vg7YgjYOsntD03YvLaygRdSZC-Y4jQgDi+D7sw@mail.gmail.com you wrote:
You also change behaviour (and thus potentially break) at least 5 boards in mainline. See also [1] about breaking user space in Linux (which is pretty much equivalent to what would happen here).
[1] http://article.gmane.org/gmane.linux.kernel/1414106
I see it different; I understand we cannot break current boards so a patch should also convert the boards to the new behavior.
I also don't see a compare it to user space in Linux fair, I think it'd be more like a driver API change in Linux and Linux breaks API for out of tree drivers very ofthen so I think same fits here.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 02/09/2013 11:21 AM, Otavio Salvador wrote:
Hello Wolfgang,
I count 49 boards with git grep -E 'CONFIG_BOOTDELAY[[:blank:]]+-[0-9]' so it's not _that_ uncommon.
The problem is that as I read the README, we document CONFIG_BOOTDELAY as having a valid value range of from -2 to sane positive value. So yes, if we want to change this we need to (a) change the README too and (b) give some sort of heads-up.
Off the top of my head, we could change to: CONFIG_AUTOBOOT_DISABLED and CONFIG_FORCE_AUTOBOOT_NO_DELAY and update doc/README.autoboot as well and add some sanity #warning checks for a release or two in some common generated config related file or something like that.
- -- Tom
Hi Tom,
Hello Wolfgang,
The change has no effect on the behavior, it simply changes what is compiled in. If the default value is not changed, then the behavior is unchanged. The only impact this may have on existing boards is to make the code size slightly larger. If that is an issue for some reason, then CONFIG_BOOTDELAY can be undefined.
If we want to add other config options, that's fine, but that's more involved that I was hoping for.
Thanks, -Joe
On Wed, Feb 27, 2013 at 02:11:31PM -0600, Joe Hershberger wrote:
Hi Tom,
Hello Wolfgang,
I think we do have a behavior change as previously negative bootdelay would not result in bootdelay being saved to the default env and thus not in the env. Now, it's possible we can mostly retain compatibility by making bootdelay part of the env if set, rather than if set >= 0. Or am I still missing it and really, there's no change in behavior?
Hi Tom,
Hi Tom,
Hello Wolfgang,
The behavior change you are describing doesn't happen. The condition was not removed from include/env_default.h so the default env should remain exactly the same as before. The difference is that now the code that checks for the var to exists will initially hit the default case until "bootdelay" is added to the env.
Cheers, -Joe
participants (5)
Joe Hershberger
Joe Hershberger
Otavio Salvador
