[U-Boot] [PATCH] i2c: mxs: Add I2C multibus support
The i.MX28 has two I2C IP blocks, but the MXS I2C driver is hard-coded to use the I2C block 0 . Add multibus support so we can use both I2C busses as seen fit.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- drivers/i2c/mxs_i2c.c | 47 +++++++++++++++++++++++++++++++++++++---------- include/configs/mxs.h | 1 + 2 files changed, 38 insertions(+), 10 deletions(-)
diff --git a/drivers/i2c/mxs_i2c.c b/drivers/i2c/mxs_i2c.c index de3b194..989cf07 100644 --- a/drivers/i2c/mxs_i2c.c +++ b/drivers/i2c/mxs_i2c.c @@ -24,9 +24,12 @@
#define MXS_I2C_MAX_TIMEOUT 1000000
+static struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; +static int mxs_i2c_bus; +static int mxs_i2c_speed = CONFIG_SYS_I2C_SPEED; + static void mxs_i2c_reset(void) { - struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; int ret; int speed = i2c_get_bus_speed();
@@ -48,8 +51,6 @@ static void mxs_i2c_reset(void)
static void mxs_i2c_setup_read(uint8_t chip, int len) { - struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; - writel(I2C_QUEUECMD_RETAIN_CLOCK | I2C_QUEUECMD_PRE_SEND_START | I2C_QUEUECMD_MASTER_MODE | I2C_QUEUECMD_DIRECTION | (1 << I2C_QUEUECMD_XFER_COUNT_OFFSET), @@ -67,7 +68,6 @@ static void mxs_i2c_setup_read(uint8_t chip, int len) static int mxs_i2c_write(uchar chip, uint addr, int alen, uchar *buf, int blen, int stop) { - struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; uint32_t data, tmp; int i, remain, off; int timeout = MXS_I2C_MAX_TIMEOUT; @@ -124,7 +124,6 @@ static int mxs_i2c_write(uchar chip, uint addr, int alen,
static int mxs_i2c_wait_for_ack(void) { - struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; uint32_t tmp; int timeout = MXS_I2C_MAX_TIMEOUT;
@@ -162,7 +161,6 @@ err:
int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) { - struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; uint32_t tmp = 0; int timeout = MXS_I2C_MAX_TIMEOUT; int ret; @@ -237,7 +235,6 @@ int i2c_probe(uchar chip)
int i2c_set_bus_speed(unsigned int speed) { - struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; /* * The timing derivation algorithm. There is no documentation for this * algorithm available, it was derived by using the scope and fiddling @@ -278,7 +275,6 @@ int i2c_set_bus_speed(unsigned int speed)
unsigned int i2c_get_bus_speed(void) { - struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; uint32_t clk = mxc_get_clock(MXC_XTAL_CLK); uint32_t timing0;
@@ -290,10 +286,41 @@ unsigned int i2c_get_bus_speed(void) return clk / ((((timing0 >> 16) - 3) * 2) + 38); }
-void i2c_init(int speed, int slaveadd) +int i2c_set_bus_num(unsigned int bus) { + uint32_t mxs_i2c_regs; + + switch (bus) { + case 0: + mxs_i2c_regs = MXS_I2C0_BASE; + break; +#ifdef CONFIG_MX28 + case 1: + mxs_i2c_regs = MXS_I2C1_BASE; + break; +#endif + default: + printf("Bad bus: %d\n", bus); + return -EINVAL; + } + + mxs_i2c_bus = bus; + i2c_regs = (struct mxs_i2c_regs *)mxs_i2c_regs; + mxs_i2c_reset(); - i2c_set_bus_speed(speed); + i2c_set_bus_speed(mxs_i2c_speed);
+ return 0; +} + +unsigned int i2c_get_bus_num(void) +{ + return mxs_i2c_bus; +} + +void i2c_init(int speed, int slaveadd) +{ + mxs_i2c_speed = speed; + i2c_set_bus_num(0); return; } diff --git a/include/configs/mxs.h b/include/configs/mxs.h index eb96fc1..3936029 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -149,6 +149,7 @@ /* I2C */ #ifdef CONFIG_CMD_I2C #define CONFIG_I2C_MXS +#define CONFIG_I2C_MULTI_BUS #define CONFIG_HARD_I2C #ifndef CONFIG_SYS_I2C_SPEED #define CONFIG_SYS_I2C_SPEED 400000
Hello Marek,
Am 23.09.2014 13:15, schrieb Marek Vasut:
Signed-off-by: Marek Vasutmarex@denx.de Cc: Stefano Babicsbabic@denx.de
Sorry, I have to NACK this patch. Please convert the driver for using the CONFIG_SYS_I2C framework, see for example the drivers/i2c/mxc_i2c.c driver, thanks!
bye, Heiko
- static void mxs_i2c_reset(void) {
- writel(I2C_QUEUECMD_RETAIN_CLOCK | I2C_QUEUECMD_PRE_SEND_START | I2C_QUEUECMD_MASTER_MODE | I2C_QUEUECMD_DIRECTION | (1<< I2C_QUEUECMD_XFER_COUNT_OFFSET),
- The timing derivation algorithm. There is no documentation for this
- algorithm available, it was derived by using the scope and fiddling
@@ -290,10 +286,41 @@ unsigned int i2c_get_bus_speed(void) return clk / ((((timing0>> 16) - 3) * 2) + 38); }
- uint32_t mxs_i2c_regs;
- switch (bus) {
- case 0:
break;
+#ifdef CONFIG_MX28
- case 1:
break;
- default:
return -EINVAL;
- mxs_i2c_bus = bus;
- i2c_regs = (struct mxs_i2c_regs *)mxs_i2c_regs;
- mxs_i2c_reset();
- return mxs_i2c_bus;
- mxs_i2c_speed = speed;
- i2c_set_bus_num(0); return; }
On Tue, Sep 23, 2014 at 8:48 AM, Heiko Schocher hs@denx.de wrote:
Hello Marek,
I think the conversion could be a follow up patch, I see no good reason to block this patch as is.
Hello Marek,
I disagree with you. Accepting this patch as is would only hinder progress toward the conversion and would set a bad example further down the line, leading only to more crap patches. Moreover, this is 2015.01 matter, so there is plenty of time for the rework to take place. Thus, I agree with Heiko.
Best regards, Marek Vasut
Hello Marek,
Am 23.09.2014 16:30, schrieb Marek Vasut:
On Tue, Sep 23, 2014 at 8:48 AM, Heiko Schocherhs@denx.de wrote:
Hello Marek,
Full ack ...
Ok, perfect, thanks! And reworking this driver should be easy...
bye, Heiko
Hi Marek,
switch (bus) {
case 0:
break;
+#ifdef CONFIG_MX28
case 1:
break;
default:
Something like "Invalid I2C bus" would be a clearer error message here.
Hello Fabio,
Am 23.09.2014 17:16, schrieb Fabio Estevam:
Hi Marek,
switch (bus) {
case 0:
break;
+#ifdef CONFIG_MX28
case 1:
break;
default:
If Marek convert this driver to the CONFIG_SYS_I2C framework, he can drop this function complete ...
bye, Heiko
Fabio Estevam
Heiko Schocher
Otavio Salvador
