[U-Boot] [PATCH 1/2] spl: Move check for SPL_LIBCOMMON support to header
Print statements in SPL depend on lib/common support, so many such statements are ifdef'd, move the check to the common.h header and remove these inline checks.
Signed-off-by: Andrew F. Davis afd@ti.com --- common/spl/spl.c | 2 -- common/spl/spl_ext.c | 8 -------- common/spl/spl_fat.c | 6 ------ common/spl/spl_fit.c | 4 ---- common/spl/spl_mmc.c | 18 ------------------ common/spl/spl_sata.c | 2 -- common/spl/spl_usb.c | 2 -- drivers/mmc/mmc.c | 10 ---------- drivers/mmc/mmc_legacy.c | 2 -- include/common.h | 3 ++- 10 files changed, 2 insertions(+), 55 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index b7ec333c8a..30b540797f 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -404,9 +404,7 @@ static int spl_load_image(u32 boot_device) return spl_board_load_image(); #endif default: -#if defined(CONFIG_SPL_SERIAL_SUPPORT) && defined(CONFIG_SPL_LIBCOMMON_SUPPORT) puts("SPL: Unsupported Boot Device!\n"); -#endif return -ENODEV; }
diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index a85dc85ffe..9fe1c026bf 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -31,9 +31,7 @@ int spl_load_image_ext(struct blk_desc *block_dev,
err = ext4fs_mount(0); if (!err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: ext4fs mount err - %d\n", __func__, err); -#endif goto end; }
@@ -57,11 +55,9 @@ int spl_load_image_ext(struct blk_desc *block_dev, err = ext4fs_read((char *)spl_image.load_addr, filelen, &actlen);
end: -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT if (err < 0) printf("%s: error reading image %s, err - %d\n", __func__, filename, err); -#endif
return err < 0; } @@ -83,9 +79,7 @@ int spl_load_image_ext_os(struct blk_desc *block_dev, int partition)
err = ext4fs_mount(0); if (!err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: ext4fs mount err - %d\n", __func__, err); -#endif return -1; } #if defined(CONFIG_SPL_ENV_SUPPORT) @@ -127,10 +121,8 @@ defaults:
err = ext4fs_read((void *)CONFIG_SYS_SPL_ARGS_ADDR, filelen, &actlen); if (err < 0) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: error reading image %s, err - %d\n", __func__, CONFIG_SPL_FS_LOAD_ARGS_NAME, err); -#endif return -1; }
diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index 73d33f54fc..bb78445d6a 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -29,9 +29,7 @@ static int spl_register_fat_device(struct blk_desc *block_dev, int partition)
err = fat_register_device(block_dev, partition); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: fat register err - %d\n", __func__, err); -#endif return err; }
@@ -93,11 +91,9 @@ int spl_load_image_fat(struct blk_desc *block_dev, }
end: -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT if (err <= 0) printf("%s: error reading image %s, err - %d\n", __func__, filename, err); -#endif
return (err <= 0); } @@ -141,10 +137,8 @@ defaults: err = file_fat_read(CONFIG_SPL_FS_LOAD_ARGS_NAME, (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); if (err <= 0) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: error reading image %s, err - %d\n", __func__, CONFIG_SPL_FS_LOAD_ARGS_NAME, err); -#endif return -1; }
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index be86072c24..372eae85ce 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -40,10 +40,8 @@ static int spl_fit_select_fdt(const void *fdt, int images, int *fdt_offsetp) node = fdt_next_subnode(fdt, node)) { name = fdt_getprop(fdt, node, "description", &len); if (!name) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: Missing FDT description in DTB\n", __func__); -#endif return -EINVAL; } if (board_fit_config_name_match(name)) @@ -72,7 +70,6 @@ static int spl_fit_select_fdt(const void *fdt, int images, int *fdt_offsetp) return len; }
-#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("No matching DT out of these options:\n"); for (node = fdt_first_subnode(fdt, conf); node >= 0; @@ -80,7 +77,6 @@ static int spl_fit_select_fdt(const void *fdt, int images, int *fdt_offsetp) name = fdt_getprop(fdt, node, "description", &len); printf(" %s\n", name); } -#endif
return -ENOENT; } diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 7c7f32959b..0c561513c0 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -86,9 +86,7 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector)
end: if (ret) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("mmc_load_image_raw_sector: mmc block read error\n"); -#endif return -1; }
@@ -105,9 +103,7 @@ int spl_mmc_get_device_index(u32 boot_device) return 1; }
-#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: unsupported mmc boot device.\n"); -#endif
return -ENODEV; } @@ -125,9 +121,7 @@ static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device)
err = mmc_initialize(NULL); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: could not initialize mmc. error: %d\n", err); -#endif return err; }
@@ -140,9 +134,7 @@ static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) err = *mmcp ? 0 : -ENODEV; #endif if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: could not find mmc device. error: %d\n", err); -#endif return err; }
@@ -157,9 +149,7 @@ static int mmc_load_image_raw_partition(struct mmc *mmc, int partition)
err = part_get_info(mmc_get_blk_desc(mmc), partition, &info); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("spl: partition error\n"); -#endif return -1; }
@@ -189,9 +179,7 @@ static int mmc_load_image_raw_os(struct mmc *mmc) CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, (void *) CONFIG_SYS_SPL_ARGS_ADDR); if (count == 0) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("mmc_load_image_raw_os: mmc block read error\n"); -#endif return -1; }
@@ -280,9 +268,7 @@ int spl_mmc_load_image(u32 boot_device)
err = mmc_init(mmc); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: mmc init failed with error: %d\n", err); -#endif return err; }
@@ -302,9 +288,7 @@ int spl_mmc_load_image(u32 boot_device)
err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("spl: mmc partition switch failed\n"); -#endif return err; } /* Fall through */ @@ -337,10 +321,8 @@ int spl_mmc_load_image(u32 boot_device)
break; case MMCSD_MODE_UNDEFINED: -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT default: puts("spl: mmc: wrong boot mode\n"); -#endif }
return err; diff --git a/common/spl/spl_sata.c b/common/spl/spl_sata.c index 9d8cc7c2dd..d91cc724be 100644 --- a/common/spl/spl_sata.c +++ b/common/spl/spl_sata.c @@ -27,9 +27,7 @@ int spl_sata_load_image(void)
err = init_sata(CONFIG_SPL_SATA_BOOT_DEVICE); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: sata init failed: err - %d\n", err); -#endif return err; } else { /* try to recognize storage devices immediately */ diff --git a/common/spl/spl_usb.c b/common/spl/spl_usb.c index 04fa66758c..05dc06a2db 100644 --- a/common/spl/spl_usb.c +++ b/common/spl/spl_usb.c @@ -30,9 +30,7 @@ int spl_usb_load_image(void) usb_stop(); err = usb_init(); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: usb init failed: err - %d\n", __func__, err); -#endif return err; }
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 43ea0bba76..d7b2b6e21a 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -148,10 +148,8 @@ int mmc_send_status(struct mmc *mmc, int timeout) MMC_STATE_PRG) break; else if (cmd.response[0] & MMC_STATUS_MASK) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("Status Error: 0x%08X\n", cmd.response[0]); -#endif return -ECOMM; } } else if (--retries < 0) @@ -165,9 +163,7 @@ int mmc_send_status(struct mmc *mmc, int timeout)
mmc_trace_state(mmc, &cmd); if (timeout <= 0) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("Timeout waiting card ready\n"); -#endif return -ETIMEDOUT; }
@@ -219,9 +215,7 @@ static int mmc_read_blocks(struct mmc *mmc, void *dst, lbaint_t start, cmd.cmdarg = 0; cmd.resp_type = MMC_RSP_R1b; if (mmc_send_cmd(mmc, &cmd, NULL)) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("mmc fail to send stop cmd\n"); -#endif return 0; } } @@ -1526,9 +1520,7 @@ int mmc_start_init(struct mmc *mmc) #endif if (no_card) { mmc->has_init = 0; -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("MMC: no card present\n"); -#endif return -ENOMEDIUM; }
@@ -1572,9 +1564,7 @@ int mmc_start_init(struct mmc *mmc) err = mmc_send_op_cond(mmc);
if (err) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("Card did not respond to voltage select!\n"); -#endif return -EOPNOTSUPP; } } diff --git a/drivers/mmc/mmc_legacy.c b/drivers/mmc/mmc_legacy.c index 25361d10f6..e57a065f73 100644 --- a/drivers/mmc/mmc_legacy.c +++ b/drivers/mmc/mmc_legacy.c @@ -25,9 +25,7 @@ struct mmc *find_mmc_device(int dev_num) return m; }
-#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("MMC Device %d not found\n", dev_num); -#endif
return NULL; } diff --git a/include/common.h b/include/common.h index e9f0dea308..0336917cc9 100644 --- a/include/common.h +++ b/include/common.h @@ -866,7 +866,8 @@ int getc(void); int tstc(void);
/* stdout */ -#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_SPL_SERIAL_SUPPORT) +#if defined(CONFIG_SPL_BUILD) && !(defined(CONFIG_SPL_SERIAL_SUPPORT) && + defined(CONFIG_SPL_LIBCOMMON_SUPPORT)) #define putc(...) do { } while (0) #define puts(...) do { } while (0) #define printf(...) do { } while (0)
These files are only included for build by the make system when CONFIG_SPL_{EXT,FAT}_SUPPORT is enabled, remove the unneed checks for these in the source files.
Signed-off-by: Andrew F. Davis afd@ti.com --- common/spl/spl_ext.c | 2 -- common/spl/spl_fat.c | 2 -- 2 files changed, 4 deletions(-)
diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index 9fe1c026bf..954891f570 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -9,7 +9,6 @@ #include <errno.h> #include <image.h>
-#ifdef CONFIG_SPL_EXT_SUPPORT int spl_load_image_ext(struct blk_desc *block_dev, int partition, const char *filename) @@ -135,4 +134,3 @@ int spl_load_image_ext_os(struct blk_desc *block_dev, int partition) return -ENOSYS; } #endif -#endif diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index bb78445d6a..9339dc81a3 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -19,7 +19,6 @@
static int fat_registered;
-#ifdef CONFIG_SPL_FAT_SUPPORT static int spl_register_fat_device(struct blk_desc *block_dev, int partition) { int err = 0; @@ -151,4 +150,3 @@ int spl_load_image_fat_os(struct blk_desc *block_dev, int partition) return -ENOSYS; } #endif -#endif
This is not based on the latest upstream, please ignore.
Sorry for the noise.
Andrew
break;
if (err) {
Andrew F. Davis
