[U-Boot] [PATCH] am335x: Enable DDR PHY dynamic power down bit for DDR3 boards
Enable DDR PHY dynamic power down bit, which enables powering down the IO receiver when not performing read.
This also helps in reducing overall power consumption in low power states (suspend/standby).
Signed-off-by: Vaibhav Hiremath hvaibhav@ti.com Signed-off-by: Satyanarayana, Sandhya sandhya.satyanarayana@ti.com Cc: Tom Rini trini@ti.com --- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 1 + board/ti/am335x/board.c | 6 ++++-- 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index ae43ef8..7ab3baf 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -28,6 +28,7 @@ #define VTP_CTRL_START_EN (0x1) #define PHY_DLL_LOCK_DIFF 0x0 #define DDR_CKE_CTRL_NORMAL 0x1 +#define PHY_EN_DYN_PWRDN (0x1 << 20)
/* Micron MT47H128M16RT-25E */ #define MT47H128M16RT25E_EMIF_READ_LATENCY 0x100005 diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 48e6896..22d7b25 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -251,7 +251,8 @@ static struct emif_regs ddr3_emif_reg_data = { .sdram_tim2 = MT41J128MJT125_EMIF_TIM2, .sdram_tim3 = MT41J128MJT125_EMIF_TIM3, .zq_config = MT41J128MJT125_ZQ_CFG, - .emif_ddr_phy_ctlr_1 = MT41J128MJT125_EMIF_READ_LATENCY, + .emif_ddr_phy_ctlr_1 = MT41J128MJT125_EMIF_READ_LATENCY | + PHY_EN_DYN_PWRDN, };
static struct emif_regs ddr3_evm_emif_reg_data = { @@ -261,7 +262,8 @@ static struct emif_regs ddr3_evm_emif_reg_data = { .sdram_tim2 = MT41J512M8RH125_EMIF_TIM2, .sdram_tim3 = MT41J512M8RH125_EMIF_TIM3, .zq_config = MT41J512M8RH125_ZQ_CFG, - .emif_ddr_phy_ctlr_1 = MT41J512M8RH125_EMIF_READ_LATENCY, + .emif_ddr_phy_ctlr_1 = MT41J512M8RH125_EMIF_READ_LATENCY | + PHY_EN_DYN_PWRDN, }; #endif
- .emif_ddr_phy_ctlr_1 = MT41J128MJT125_EMIF_READ_LATENCY |
PHY_EN_DYN_PWRDN,
- .emif_ddr_phy_ctlr_1 = MT41J512M8RH125_EMIF_READ_LATENCY |
PHY_EN_DYN_PWRDN,
}; #endif
Reviewed-by: Tom Rini trini@ti.com
Lars, I suspect pcm051 also could use a change like this.
PHY_EN_DYN_PWRDN,
PHY_EN_DYN_PWRDN,
}; #endif
Many thanks for the hint! Yes, I think this could also be of use for pcm051. I can care about it and make a patch for pcm051 after my two weeks holiday :)
Lars
Signed-off-by: Vaibhav Hiremath hvaibhav@ti.com Signed-off-by: Satyanarayana, Sandhya sandhya.satyanarayana@ti.com Cc: Tom Rini trini@ti.com Reviewed-by: Tom Rini trini@ti.com
Applied to u-boot-ti/master (and already pulled into u-boot-arm), thanks!
Lars Poeschel
Vaibhav Hiremath
