[U-Boot] [PATCH 0/1] cmd: efidebug: rework "boot dump"
This patch is a spin-off from my "non-volatile support" patch[1].
[1] https://lists.denx.de/pipermail/u-boot/2019-April/366214.html
Changes (Apr 26, 2019) * use memcmp() instead of u16_strncmp() * merge u16_isxdigit() and u16_tohex() into one function
AKASHI Takahiro (1): cmd: efidebug: rework "boot dump" sub-command using GetNextVariableName()
cmd/efidebug.c | 79 +++++++++++++++++++++++++++++++++++--------------- 1 file changed, 55 insertions(+), 24 deletions(-)
Currently in do_efi_boot_dump(), we directly read EFI variables from related environment variables. To accommodate alternative storage backends, we should switch to using the UEFI API instead.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/efidebug.c | 79 +++++++++++++++++++++++++++++++++++--------------- 1 file changed, 55 insertions(+), 24 deletions(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index a40c4f4be286..efe4ea873eec 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -693,6 +693,17 @@ static void show_efi_boot_opt(int id) free(data); }
+static int u16_tohex(u16 c) +{ + if (c >= '0' && c <= '9') + return c - '0'; + if (c >= 'A' && c <= 'F') + return c - 'A' + 10; + + /* not hexadecimal */ + return -1; +} + /** * show_efi_boot_dump() - dump all UEFI load options * @@ -709,38 +720,58 @@ static void show_efi_boot_opt(int id) static int do_efi_boot_dump(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - char regex[256]; - char * const regexlist[] = {regex}; - char *variables = NULL, *boot, *value; - int len; - int id; + u16 *var_name16, *p; + efi_uintn_t buf_size, size; + efi_guid_t guid; + int id, i, digit; + efi_status_t ret;
if (argc > 1) return CMD_RET_USAGE;
- snprintf(regex, 256, "efi_.*-.*-.*-.*-.*_Boot[0-9A-F]+"); - - /* TODO: use GetNextVariableName? */ - len = hexport_r(&env_htab, '\n', H_MATCH_REGEX | H_MATCH_KEY, - &variables, 0, 1, regexlist); - - if (!len) - return CMD_RET_SUCCESS; - - if (len < 0) + buf_size = 128; + var_name16 = malloc(buf_size); + if (!var_name16) return CMD_RET_FAILURE;
- boot = variables; - while (*boot) { - value = strstr(boot, "Boot") + 4; - id = (int)simple_strtoul(value, NULL, 16); - show_efi_boot_opt(id); - boot = strchr(boot, '\n'); - if (!*boot) + var_name16[0] = 0; + for (;;) { + size = buf_size; + ret = EFI_CALL(efi_get_next_variable_name(&size, var_name16, + &guid)); + if (ret == EFI_NOT_FOUND) break; - boot++; + if (ret == EFI_BUFFER_TOO_SMALL) { + buf_size = size; + p = realloc(var_name16, buf_size); + if (!p) { + free(var_name16); + return CMD_RET_FAILURE; + } + var_name16 = p; + ret = EFI_CALL(efi_get_next_variable_name(&size, + var_name16, + &guid)); + } + if (ret != EFI_SUCCESS) { + free(var_name16); + return CMD_RET_FAILURE; + } + + if (memcmp(var_name16, L"Boot", 8)) + continue; + + for (id = 0, i = 0; i < 4; i++) { + digit = u16_tohex(var_name16[4 + i]); + if (digit < 0) + break; + id = (id << 4) + digit; + } + if (i == 4 && !var_name16[8]) + show_efi_boot_opt(id); } - free(variables); + + free(var_name16);
return CMD_RET_SUCCESS; }
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
AKASHI Takahiro
