[PATCH 1/1] ARM: dts: chameleonv3: Update handoffs
Update the chameleonv3 handoffs with the ones generated from the final FPGA design.
Signed-off-by: Paweł Anikiel panikiel@google.com --- ...ocfpga_arria10_chameleonv3_480_2_handoff.h | 22 +++++++++---------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/arch/arm/dts/socfpga_arria10_chameleonv3_480_2_handoff.h b/arch/arm/dts/socfpga_arria10_chameleonv3_480_2_handoff.h index caaff604eb..37cd5d653d 100644 --- a/arch/arm/dts/socfpga_arria10_chameleonv3_480_2_handoff.h +++ b/arch/arm/dts/socfpga_arria10_chameleonv3_480_2_handoff.h @@ -13,9 +13,9 @@ #define EMAC2_CLK_HZ 250000000 #define EOSC1_CLK_HZ 33330000 #define F2H_FREE_CLK_HZ 200000000 -#define H2F_USER0_CLK_HZ 200000000 +#define H2F_USER0_CLK_HZ 250000000 #define H2F_USER1_CLK_HZ 100000000 -#define L3_MAIN_FREE_CLK_HZ 200000000 +#define L3_MAIN_FREE_CLK_HZ 250000000 #define SDMMC_CLK_HZ 200000000 #define TPIU_CLK_HZ 100000000 #define MAINPLLGRP_CNTR15CLK_CNT 900 @@ -24,7 +24,7 @@ #define MAINPLLGRP_CNTR4CLK_CNT 900 #define MAINPLLGRP_CNTR5CLK_CNT 900 #define MAINPLLGRP_CNTR6CLK_CNT 9 -#define MAINPLLGRP_CNTR7CLK_CNT 9 +#define MAINPLLGRP_CNTR7CLK_CNT 7 #define MAINPLLGRP_CNTR7CLK_SRC 0 #define MAINPLLGRP_CNTR8CLK_CNT 19 #define MAINPLLGRP_CNTR9CLK_CNT 900 @@ -68,7 +68,7 @@ #define CLKMGR_TESTIOCTRL_PERICLKSEL 8 #define ALTERAGRP_MPUCLK_MAINCNT 1 #define ALTERAGRP_MPUCLK_PERICNT 900 -#define ALTERAGRP_NOCCLK_MAINCNT 9 +#define ALTERAGRP_NOCCLK_MAINCNT 7 #define ALTERAGRP_NOCCLK_PERICNT 900 #define ALTERAGRP_MPUCLK ((ALTERAGRP_MPUCLK_PERICNT << 16) | \ (ALTERAGRP_MPUCLK_MAINCNT)) @@ -120,9 +120,9 @@ #define CONFIG_IO_15_WK_PU_EN 1 #define CONFIG_IO_16_INPUT_BUF_EN 0 #define CONFIG_IO_16_PD_DRV_STRG 10 -#define CONFIG_IO_16_PD_SLW_RT 1 +#define CONFIG_IO_16_PD_SLW_RT 0 #define CONFIG_IO_16_PU_DRV_STRG 8 -#define CONFIG_IO_16_PU_SLW_RT 1 +#define CONFIG_IO_16_PU_SLW_RT 0 #define CONFIG_IO_16_RTRIM 1 #define CONFIG_IO_16_WK_PU_EN 0 #define CONFIG_IO_17_INPUT_BUF_EN 1 @@ -169,9 +169,9 @@ #define CONFIG_IO_5_WK_PU_EN 0 #define CONFIG_IO_6_INPUT_BUF_EN 0 #define CONFIG_IO_6_PD_DRV_STRG 10 -#define CONFIG_IO_6_PD_SLW_RT 1 +#define CONFIG_IO_6_PD_SLW_RT 0 #define CONFIG_IO_6_PU_DRV_STRG 8 -#define CONFIG_IO_6_PU_SLW_RT 1 +#define CONFIG_IO_6_PU_SLW_RT 0 #define CONFIG_IO_6_RTRIM 1 #define CONFIG_IO_6_WK_PU_EN 0 #define CONFIG_IO_7_INPUT_BUF_EN 1 @@ -213,7 +213,7 @@ #define PINMUX_DEDICATED_IO_9_SEL 8 #define PINMUX_I2C0_USEFPGA_SEL 1 #define PINMUX_I2C1_USEFPGA_SEL 0 -#define PINMUX_I2CEMAC0_USEFPGA_SEL 0 +#define PINMUX_I2CEMAC0_USEFPGA_SEL 1 #define PINMUX_I2CEMAC1_USEFPGA_SEL 0 #define PINMUX_I2CEMAC2_USEFPGA_SEL 0 #define PINMUX_NAND_USEFPGA_SEL 0 @@ -283,10 +283,10 @@ /* Bridge Configuration */ #define F2H_AXI_SLAVE 1 #define F2SDRAM0_AXI_SLAVE 1 -#define F2SDRAM1_AXI_SLAVE 1 +#define F2SDRAM1_AXI_SLAVE 0 #define F2SDRAM2_AXI_SLAVE 1 #define H2F_AXI_MASTER 1 -#define LWH2F_AXI_MASTER 1 +#define LWH2F_AXI_MASTER 0
/* Voltage Select for Config IO */ #define CONFIG_IO_BANK_VSEL \
Paweł Anikiel
