[PATCH 1/3] rockchip: px30: sync the main rk3326 dtsi from mainline
From: Heiko Stuebner heiko.stuebner@theobroma-systems.com
The rk3326 is just a trimmed down px30 from a software perspective, so the mainline rk3326 dtsi also ist just a tiny addition.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/dts/rk3326.dtsi | 15 +++++++++++++++ 1 file changed, 15 insertions(+) create mode 100644 arch/arm/dts/rk3326.dtsi
diff --git a/arch/arm/dts/rk3326.dtsi b/arch/arm/dts/rk3326.dtsi new file mode 100644 index 0000000000..2ba6da1251 --- /dev/null +++ b/arch/arm/dts/rk3326.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Fuzhou Rockchip Electronics Co., Ltd + */ + +#include "px30.dtsi" + +&display_subsystem { + ports = <&vopb_out>; +}; + +/delete-node/ &dsi_in_vopl; +/delete-node/ &lvds_vopl_in; +/delete-node/ &vopl; +/delete-node/ &vopl_mmu;
Get the devicetree from mainline Linux and include it for U-Boot uses.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3326-odroid-go2.dts | 716 +++++++++++++++++++++++++++++ 2 files changed, 718 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3326-odroid-go2.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index db7859cd6c..f274c1232a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -71,7 +71,8 @@ dtb-$(CONFIG_MACH_S700) += \
dtb-$(CONFIG_ROCKCHIP_PX30) += \ px30-evb.dtb \ - px30-firefly.dtb + px30-firefly.dtb \ + rk3326-odroid-go2.dtb
dtb-$(CONFIG_ROCKCHIP_RK3036) += \ rk3036-sdk.dtb diff --git a/arch/arm/dts/rk3326-odroid-go2.dts b/arch/arm/dts/rk3326-odroid-go2.dts new file mode 100644 index 0000000000..8cd4688c49 --- /dev/null +++ b/arch/arm/dts/rk3326-odroid-go2.dts @@ -0,0 +1,716 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Hardkernel Co., Ltd + * Copyright (c) 2020 Theobroma Systems Design und Consulting GmbH + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3326.dtsi" + +/ { + model = "ODROID-GO Advance"; + compatible = "hardkernel,rk3326-odroid-go2", "rockchip,rk3326"; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + power-supply = <&vcc_bl>; + pwms = <&pwm1 0 25000 0>; + }; + + adc-joystick { + compatible = "adc-joystick"; + io-channels = <&saradc 1>, + <&saradc 2>; + #address-cells = <1>; + #size-cells = <0>; + + axis@0 { + reg = <0>; + abs-range = <172 772>; + abs-fuzz = <10>; + abs-flat = <10>; + linux,code = <ABS_X>; + }; + + axis@1 { + reg = <1>; + abs-range = <278 815>; + abs-fuzz = <10>; + abs-flat = <10>; + linux,code = <ABS_Y>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&btn_pins>; + + /* + * *** ODROIDGO2-Advance Switch layout *** + * |------------------------------------------------| + * | sw15 sw16 | + * |------------------------------------------------| + * | sw1 |-------------------| sw8 | + * | sw3 sw4 | | sw7 sw5 | + * | sw2 | LCD Display | sw6 | + * | | | | + * | |-------------------| | + * | sw9 sw10 sw11 sw12 sw13 sw14 | + * |------------------------------------------------| + */ + + sw1 { + gpios = <&gpio1 RK_PB4 GPIO_ACTIVE_LOW>; + label = "DPAD-UP"; + linux,code = <BTN_DPAD_UP>; + }; + sw2 { + gpios = <&gpio1 RK_PB5 GPIO_ACTIVE_LOW>; + label = "DPAD-DOWN"; + linux,code = <BTN_DPAD_DOWN>; + }; + sw3 { + gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_LOW>; + label = "DPAD-LEFT"; + linux,code = <BTN_DPAD_LEFT>; + }; + sw4 { + gpios = <&gpio1 RK_PB7 GPIO_ACTIVE_LOW>; + label = "DPAD-RIGHT"; + linux,code = <BTN_DPAD_RIGHT>; + }; + sw5 { + gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_LOW>; + label = "BTN-A"; + linux,code = <BTN_EAST>; + }; + sw6 { + gpios = <&gpio1 RK_PA5 GPIO_ACTIVE_LOW>; + label = "BTN-B"; + linux,code = <BTN_SOUTH>; + }; + sw7 { + gpios = <&gpio1 RK_PA6 GPIO_ACTIVE_LOW>; + label = "BTN-Y"; + linux,code = <BTN_WEST>; + }; + sw8 { + gpios = <&gpio1 RK_PA7 GPIO_ACTIVE_LOW>; + label = "BTN-X"; + linux,code = <BTN_NORTH>; + }; + sw9 { + gpios = <&gpio2 RK_PA0 GPIO_ACTIVE_LOW>; + label = "F1"; + linux,code = <BTN_TRIGGER_HAPPY1>; + }; + sw10 { + gpios = <&gpio2 RK_PA1 GPIO_ACTIVE_LOW>; + label = "F2"; + linux,code = <BTN_TRIGGER_HAPPY2>; + }; + sw11 { + gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_LOW>; + label = "F3"; + linux,code = <BTN_TRIGGER_HAPPY3>; + }; + sw12 { + gpios = <&gpio2 RK_PA3 GPIO_ACTIVE_LOW>; + label = "F4"; + linux,code = <BTN_TRIGGER_HAPPY4>; + }; + sw13 { + gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_LOW>; + label = "F5"; + linux,code = <BTN_TRIGGER_HAPPY5>; + }; + sw14 { + gpios = <&gpio2 RK_PA5 GPIO_ACTIVE_LOW>; + label = "F6"; + linux,code = <BTN_TRIGGER_HAPPY6>; + }; + sw15 { + gpios = <&gpio2 RK_PA6 GPIO_ACTIVE_LOW>; + label = "TOP-LEFT"; + linux,code = <BTN_TL>; + }; + sw16 { + gpios = <&gpio2 RK_PA7 GPIO_ACTIVE_LOW>; + label = "TOP-RIGHT"; + linux,code = <BTN_TR>; + }; + }; + + leds: gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&blue_led_pin>; + + blue_led: led-0 { + label = "blue:heartbeat"; + gpios = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + rk817-sound { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,name = "rockchip,rk817-codec"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,widgets = + "Microphone", "Mic Jack", + "Headphone", "Headphone Jack"; + simple-audio-card,routing = + "MIC_IN", "Mic Jack", + "Headphone Jack", "HPOL", + "Headphone Jack", "HPOR"; + simple-audio-card,hp-det-gpio = <&gpio2 RK_PC6 GPIO_ACTIVE_LOW>; + simple-audio-card,codec-hp-det = <1>; + + simple-audio-card,cpu { + sound-dai = <&i2s1_2ch>; + }; + + simple-audio-card,codec { + sound-dai = <&rk817_codec>; + }; + }; + + vccsys: vccsys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v8_sys"; + regulator-always-on; + regulator-min-microvolt = <3800000>; + regulator-max-microvolt = <3800000>; + }; + + vcc_host: vcc_host { + compatible = "regulator-fixed"; + regulator-name = "vcc_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + + gpio = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + vin-supply = <&vccsys>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&cpu1 { + cpu-supply = <&vdd_arm>; +}; + +&cpu2 { + cpu-supply = <&vdd_arm>; +}; + +&cpu3 { + cpu-supply = <&vdd_arm>; +}; + +&cru { + assigned-clocks = <&cru PLL_NPLL>, + <&cru ACLK_BUS_PRE>, <&cru ACLK_PERI_PRE>, + <&cru HCLK_BUS_PRE>, <&cru HCLK_PERI_PRE>, + <&cru PCLK_BUS_PRE>, <&cru SCLK_GPU>, + <&cru PLL_CPLL>; + + assigned-clock-rates = <1188000000>, + <200000000>, <200000000>, + <150000000>, <150000000>, + <100000000>, <200000000>, + <17000000>; +}; + +&display_subsystem { + status = "okay"; +}; + +&dsi { + status = "okay"; + + ports { + mipi_out: port@1 { + reg = <1>; + + mipi_out_panel: endpoint { + remote-endpoint = <&mipi_in_panel>; + }; + }; + }; + + panel@0 { + compatible = "elida,kd35t133"; + reg = <0>; + backlight = <&backlight>; + iovcc-supply = <&vcc_lcd>; + reset-gpios = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>; + vdd-supply = <&vcc_lcd>; + + port { + mipi_in_panel: endpoint { + remote-endpoint = <&mipi_out_panel>; + }; + }; + }; +}; + +&dsi_dphy { + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_logic>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-falling-time-ns = <16>; + i2c-scl-rising-time-ns = <280>; + status = "okay"; + + rk817: pmic@20 { + compatible = "rockchip,rk817"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default", "pmic-sleep", + "pmic-power-off", "pmic-reset"; + pinctrl-0 = <&pmic_int>; + pinctrl-1 = <&soc_slppin_slp>, <&rk817_slppin_slp>; + pinctrl-2 = <&soc_slppin_gpio>, <&rk817_slppin_pwrdn>; + pinctrl-3 = <&soc_slppin_rst>, <&rk817_slppin_rst>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "rk808-clkout1", "xin32k"; + + vcc1-supply = <&vccsys>; + vcc2-supply = <&vccsys>; + vcc3-supply = <&vccsys>; + vcc4-supply = <&vccsys>; + vcc5-supply = <&vccsys>; + vcc6-supply = <&vccsys>; + vcc7-supply = <&vccsys>; + + pinctrl_rk8xx: pinctrl_rk8xx { + gpio-controller; + #gpio-cells = <2>; + + rk817_ts_gpio1: rk817_ts_gpio1 { + pins = "gpio_ts"; + function = "pin_fun1"; + /* output-low; */ + /* input-enable; */ + }; + + rk817_gt_gpio2: rk817_gt_gpio2 { + pins = "gpio_gt"; + function = "pin_fun1"; + }; + + rk817_pin_ts: rk817_pin_ts { + pins = "gpio_ts"; + function = "pin_fun0"; + }; + + rk817_pin_gt: rk817_pin_gt { + pins = "gpio_gt"; + function = "pin_fun0"; + }; + + rk817_slppin_null: rk817_slppin_null { + pins = "gpio_slp"; + function = "pin_fun0"; + }; + + rk817_slppin_slp: rk817_slppin_slp { + pins = "gpio_slp"; + function = "pin_fun1"; + }; + + rk817_slppin_pwrdn: rk817_slppin_pwrdn { + pins = "gpio_slp"; + function = "pin_fun2"; + }; + + rk817_slppin_rst: rk817_slppin_rst { + pins = "gpio_slp"; + function = "pin_fun3"; + }; + }; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <1150000>; + regulator-ramp-delay = <6001>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <950000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <950000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_3v3: DCDC_REG4 { + regulator-name = "vcc_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_1v8: LDO_REG2 { + regulator-name = "vcc_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_1v0: LDO_REG3 { + regulator-name = "vdd_1v0"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc3v3_pmu: LDO_REG4 { + regulator-name = "vcc3v3_pmu"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_sd: LDO_REG6 { + regulator-name = "vcc_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_bl: LDO_REG7 { + regulator-name = "vcc_bl"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_lcd: LDO_REG8 { + regulator-name = "vcc_lcd"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <2800000>; + }; + }; + + vcc_cam: LDO_REG9 { + regulator-name = "vcc_cam"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + }; + + battery { + compatible = "rk817,battery"; + ocv_table = <3500 3625 3685 3697 3718 3735 3748 + 3760 3774 3788 3802 3816 3834 3853 + 3877 3908 3946 3975 4018 4071 4106>; + + /* KPL605475 Battery Spec */ + /* + Capacity : 3.7V 3000mA + Normal Voltage = 3.7V + Cut-Off Voltage : 3.1V + Internal Impedance : 180 mOhm + Charging Voltage : 4.2V + Charging Voltage Max : 4.25V + Sample resister : 10 mohm + */ + design_capacity = <3000>; + design_qmax = <3000>; + bat_res = <180>; + sleep_enter_current = <300>; + sleep_exit_current = <300>; + sleep_filter_current = <100>; + power_off_thresd = <3500>; + zero_algorithm_vol = <3700>; + max_soc_offset = <60>; + monitor_sec = <5>; + virtual_power = <0>; + sample_res = <10>; + }; + + charger { + compatible = "rk817,charger"; + min_input_voltage = <4500>; + max_input_current = <1500>; + max_chrg_current = <2000>; + max_chrg_voltage = <4200>; + chrg_term_mode = <0>; + chrg_finish_cur = <300>; + virtual_power = <0>; + sample_res = <10>; + + /* P.C.B rev0.2 DC Detect & Charger Status LED GPIO */ + dc_det_gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + chg_led_gpio = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; + + extcon = <&u2phy>; + }; + + rk817_codec: codec { + #sound-dai-cells = <0>; + compatible = "rockchip,rk817-codec"; + clocks = <&cru SCLK_I2S1_OUT>; + clock-names = "mclk"; + pinctrl-names = "default"; + pinctrl-0 = <&i2s1_2ch_mclk>; + hp-volume = <20>; + spk-volume = <3>; + status = "okay"; + }; + }; +}; + +/* EXT Header(P2): 7(SCL:GPIO0.C2), 8(SDA:GPIO0.C3) */ +&i2c1 { + clock-frequency = <400000>; + status = "okay"; +}; + +/* I2S 1 Channel Used */ +&i2s1_2ch { + status = "okay"; +}; + +&io_domains { + vccio1-supply = <&vcc_3v3>; + vccio2-supply = <&vccio_sd>; + vccio3-supply = <&vcc_3v3>; + vccio4-supply = <&vcc_3v3>; + vccio5-supply = <&vcc_3v3>; + vccio6-supply = <&vcc_3v3>; + status = "okay"; +}; + +&pmu_io_domains { + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc3v3_pmu>; + status = "okay"; +}; + +&pwm1 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + card-detect-delay = <200>; + cd-gpios = <&gpio0 RK_PA3 GPIO_ACTIVE_LOW>; /*[> CD GPIO <]*/ + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&tsadc { + status = "okay"; +}; + +&u2phy { + status = "okay"; + + u2phy_host: host-port { + status = "okay"; + }; + + u2phy_otg: otg-port { + status = "disabled"; + }; +}; + +&usb20_otg { + status = "okay"; +}; + +/* EXT Header(P2): 2(RXD:GPIO1.C0),3(TXD:.C1),4(CTS:.C2),5(RTS:.C3) */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_xfer &uart1_cts>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2m1_xfer>; + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&pinctrl { + btns { + btn_pins: btn-pins { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>, + <1 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>, + <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>, + <1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>, + <1 RK_PB4 RK_FUNC_GPIO &pcfg_pull_up>, + <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>, + <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up>, + <1 RK_PB7 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>, + <2 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + headphone { + hp_det: hp-det { + rockchip,pins = <2 RK_PC6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + leds { + blue_led_pin: blue-led-pin { + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + dc_det: dc-det { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pmic_int: pmic-int { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + soc_slppin_gpio: soc_slppin_gpio { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_output_low>; + }; + + soc_slppin_rst: soc_slppin_rst { + rockchip,pins = <0 RK_PA4 2 &pcfg_pull_none>; + }; + + soc_slppin_slp: soc_slppin_slp { + rockchip,pins = <0 RK_PA4 1 &pcfg_pull_none>; + }; + }; +};
Reviewed-by: Kever Yangkever.yang@rock-chips.com
Thanks, - Kever
- px30-firefly.dtb
px30-firefly.dtb \
- Copyright (c) 2019 Hardkernel Co., Ltd
- Copyright (c) 2020 Theobroma Systems Design und Consulting GmbH
- model = "ODROID-GO Advance";
- compatible = "hardkernel,rk3326-odroid-go2", "rockchip,rk3326";
- chosen {
- backlight: backlight {
- adc-joystick {
<&saradc 2>;
#size-cells = <0>;
axis@0 {
reg = <0>;
abs-fuzz = <10>;
abs-flat = <10>;
axis@1 {
reg = <1>;
abs-fuzz = <10>;
abs-flat = <10>;
- gpio-keys {
* | sw15 sw16 |
sw1 {
label = "DPAD-UP";
sw2 {
sw3 {
sw4 {
sw5 {
label = "BTN-A";
sw6 {
label = "BTN-B";
sw7 {
label = "BTN-Y";
sw8 {
label = "BTN-X";
sw9 {
label = "F1";
sw10 {
label = "F2";
sw11 {
label = "F3";
sw12 {
label = "F4";
sw13 {
label = "F5";
sw14 {
label = "F6";
sw15 {
label = "TOP-LEFT";
sw16 {
- leds: gpio-leds {
blue_led: led-0 {
- rk817-sound {
- vccsys: vccsys {
- vcc_host: vcc_host {
enable-active-high;
+&cpu0 {
- cpu-supply = <&vdd_arm>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&cru {
- assigned-clocks = <&cru PLL_NPLL>,
<&cru PLL_CPLL>;
- assigned-clock-rates = <1188000000>,
<17000000>;
- status = "okay";
+&dsi {
- status = "okay";
- ports {
mipi_out: port@1 {
reg = <1>;
- panel@0 {
reg = <0>;
port {
+&dsi_dphy {
- status = "okay";
+&gpu {
- mali-supply = <&vdd_logic>;
- status = "okay";
+&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-falling-time-ns = <16>;
- i2c-scl-rising-time-ns = <280>;
- status = "okay";
- rk817: pmic@20 {
reg = <0x20>;
wakeup-source;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
pins = "gpio_ts";
/* output-low; */
/* input-enable; */
pins = "gpio_gt";
pins = "gpio_ts";
pins = "gpio_gt";
pins = "gpio_slp";
pins = "gpio_slp";
pins = "gpio_slp";
pins = "gpio_slp";
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG2 {
regulator-boot-on;
vdd_1v0: LDO_REG3 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_sd: LDO_REG6 {
regulator-boot-on;
vcc_bl: LDO_REG7 {
vcc_lcd: LDO_REG8 {
vcc_cam: LDO_REG9 {
battery {
bat_res = <180>;
monitor_sec = <5>;
sample_res = <10>;
charger {
sample_res = <10>;
extcon = <&u2phy>;
hp-volume = <20>;
spk-volume = <3>;
status = "okay";
- status = "okay";
- status = "okay";
+&io_domains {
- vccio1-supply = <&vcc_3v3>;
- vccio2-supply = <&vccio_sd>;
- vccio3-supply = <&vcc_3v3>;
- vccio4-supply = <&vcc_3v3>;
- vccio5-supply = <&vcc_3v3>;
- vccio6-supply = <&vcc_3v3>;
- status = "okay";
+&pmu_io_domains {
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- status = "okay";
+&pwm1 {
- status = "okay";
+&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- card-detect-delay = <200>;
- cd-gpios = <&gpio0 RK_PA3 GPIO_ACTIVE_LOW>; /*[> CD GPIO <]*/
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_sd>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
+&tsadc {
- status = "okay";
+&u2phy {
- status = "okay";
- u2phy_host: host-port {
status = "okay";
- u2phy_otg: otg-port {
+&usb20_otg {
- status = "okay";
- pinctrl-names = "default";
- pinctrl-0 = <&uart1_xfer &uart1_cts>;
- status = "okay";
+&uart2 {
- pinctrl-0 = <&uart2m1_xfer>;
- status = "okay";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&pinctrl {
- btns {
- headphone {
hp_det: hp-det {
- leds {
- pmic {
dc_det: dc-det {
Also known as Odroid Go Advance but named Go2 internally by the vendor it seems.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi | 72 +++++++++++++ arch/arm/mach-rockchip/px30/Kconfig | 4 + board/hardkernel/odroid_go2/Kconfig | 15 +++ board/hardkernel/odroid_go2/MAINTAINERS | 6 ++ board/hardkernel/odroid_go2/Makefile | 7 ++ board/hardkernel/odroid_go2/go2.c | 4 + configs/odroid-go2_defconfig | 119 +++++++++++++++++++++ include/configs/odroid_go2.h | 17 +++ 8 files changed, 244 insertions(+) create mode 100644 arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi create mode 100644 board/hardkernel/odroid_go2/Kconfig create mode 100644 board/hardkernel/odroid_go2/MAINTAINERS create mode 100644 board/hardkernel/odroid_go2/Makefile create mode 100644 board/hardkernel/odroid_go2/go2.c create mode 100644 configs/odroid-go2_defconfig create mode 100644 include/configs/odroid_go2.h
diff --git a/arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi b/arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi new file mode 100644 index 0000000000..34c9e62025 --- /dev/null +++ b/arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Theobroma Systems Design und Consulting GmbH + */ + +/ { + chosen { + u-boot,spl-boot-order = &sdmmc; + }; +}; + +&cru { + u-boot,dm-pre-reloc; +}; + +&dmc { + u-boot,dm-pre-reloc; +}; + +&gpio0 { + u-boot,dm-pre-reloc; +}; + +&gpio1 { + u-boot,dm-pre-reloc; +}; + +&gpio2 { + u-boot,dm-pre-reloc; +}; + +&gpio3 { + u-boot,dm-pre-reloc; +}; + +&grf { + u-boot,dm-pre-reloc; +}; + +&pmucru { + u-boot,dm-pre-reloc; +}; + +&pmugrf { + u-boot,dm-pre-reloc; +}; + +&saradc { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&sdmmc { + u-boot,dm-pre-reloc; + + /* mmc to sram can't do dma, prevent aborts transfering TF-A parts */ + u-boot,spl-fifo-mode; +}; + +&uart1 { + clock-frequency = <24000000>; + u-boot,dm-pre-reloc; +}; + +&uart2 { + clock-frequency = <24000000>; + u-boot,dm-pre-reloc; +}; + +&xin24m { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/mach-rockchip/px30/Kconfig b/arch/arm/mach-rockchip/px30/Kconfig index 9f3ad4f623..f5373c6f9f 100644 --- a/arch/arm/mach-rockchip/px30/Kconfig +++ b/arch/arm/mach-rockchip/px30/Kconfig @@ -3,6 +3,9 @@ if ROCKCHIP_PX30 config TARGET_EVB_PX30 bool "EVB_PX30"
+config TARGET_ODROID_GO2 + bool "ODROID_GO2" + config ROCKCHIP_BOOT_MODE_REG default 0xff010200
@@ -36,6 +39,7 @@ config DEBUG_UART_CHANNEL For using the UART for early debugging the route to use needs to be declared (0 or 1).
+source "board/hardkernel/odroid_go2/Kconfig" source "board/rockchip/evb_px30/Kconfig"
endif diff --git a/board/hardkernel/odroid_go2/Kconfig b/board/hardkernel/odroid_go2/Kconfig new file mode 100644 index 0000000000..cf3f7c91d9 --- /dev/null +++ b/board/hardkernel/odroid_go2/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ODROID_GO2 + +config SYS_BOARD + default "odroid_go2" + +config SYS_VENDOR + default "hardkernel" + +config SYS_CONFIG_NAME + default "odroid_go2" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/hardkernel/odroid_go2/MAINTAINERS b/board/hardkernel/odroid_go2/MAINTAINERS new file mode 100644 index 0000000000..eab622a70b --- /dev/null +++ b/board/hardkernel/odroid_go2/MAINTAINERS @@ -0,0 +1,6 @@ +GO2 +M: Heiko Stuebner heiko.stuebner@theobroma-systems.com +S: Maintained +F: board/odroid/go2 +F: include/configs/odroid_go2.h +F: configs/odroid-go2_defconfig diff --git a/board/hardkernel/odroid_go2/Makefile b/board/hardkernel/odroid_go2/Makefile new file mode 100644 index 0000000000..51b9d24cfb --- /dev/null +++ b/board/hardkernel/odroid_go2/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (c) 2020 Theobroma Systems Design und Consulting GmbH +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += go2.o diff --git a/board/hardkernel/odroid_go2/go2.c b/board/hardkernel/odroid_go2/go2.c new file mode 100644 index 0000000000..29464ae63e --- /dev/null +++ b/board/hardkernel/odroid_go2/go2.c @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig new file mode 100644 index 0000000000..6eb85a97f7 --- /dev/null +++ b/configs/odroid-go2_defconfig @@ -0,0 +1,119 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x4000 +CONFIG_ROCKCHIP_PX30=y +CONFIG_TARGET_ODROID_GO2=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF160000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_CHANNEL=1 +CONFIG_SPL_TEXT_BASE=0x00000000 +CONFIG_TPL_SYS_MALLOC_F_LEN=0x600 +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_CONSOLE_MUX is not set +CONFIG_DEFAULT_FDT_FILE="rk3326-odroidgo2.dtb" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_BOOTROM_SUPPORT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 +# CONFIG_TPL_BANNER_PRINT is not set +CONFIG_SPL_CRC32_SUPPORT=y +CONFIG_SPL_ATF=y +# CONFIG_TPL_FRAMEWORK is not set +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_LZMADEC is not set +# CONFIG_CMD_UNZIP is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPT=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_ITEST is not set +CONFIG_CMD_SETEXPR=y +# CONFIG_CMD_MISC is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_DEFAULT_DEVICE_TREE="rk3326-odroid-go2" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_FASTBOOT_BUF_SIZE=0x04000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_OTP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_ROCKCHIP_SDRAM_COMMON=y +CONFIG_DM_RESET=y +# CONFIG_SPECIFY_CONSOLE_INDEX is not set +# CONFIG_TPL_DM_SERIAL is not set +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_SOUND=y +CONFIG_SYSRESET=y +CONFIG_OPTEE=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_LCD=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_LZ4=y +CONFIG_LZO=y +CONFIG_ERRNO_STR=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/odroid_go2.h b/include/configs/odroid_go2.h new file mode 100644 index 0000000000..00eac2d2a8 --- /dev/null +++ b/include/configs/odroid_go2.h @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd + */ + +#ifndef __EVB_PX30_H +#define __EVB_PX30_H + +#include <configs/px30_common.h> + +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif
Thanks, - Kever
- chosen {
+&cru {
- u-boot,dm-pre-reloc;
+&dmc {
+&gpio0 {
+&gpio1 {
+&gpio2 {
+&gpio3 {
+&grf {
+&pmucru {
+&pmugrf {
+&saradc {
- status = "okay";
+&sdmmc {
- /* mmc to sram can't do dma, prevent aborts transfering TF-A parts */
- u-boot,spl-fifo-mode;
+&uart1 {
- clock-frequency = <24000000>;
+&uart2 {
+&xin24m {
- bool "ODROID_GO2"
- config ROCKCHIP_BOOT_MODE_REG default 0xff010200
+config SYS_BOARD
- default "odroid_go2"
+config SYS_VENDOR
- default "hardkernel"
- def_bool y
- (C) Copyright 2019 Rockchip Electronics Co., Ltd
- (C) Copyright 2017 Rockchip Electronics Co., Ltd
Thanks, - Kever
- Copyright (c) 2020 Fuzhou Rockchip Electronics Co., Ltd
- ports = <&vopb_out>;
Heiko Stuebner
Kever Yang
