[U-Boot] serial atag tag in devicetree ?
Hi All,
I'm sending this mail because Paul Kocialkowski (in the Cc) has submitted a patch for upstream u-boot to set the serial atag tag from u-boot for Allwinner SoCs, using the SoCs SID, which is a 128 bit register containing a unique number for each SoC.
In some cases a manufacturer may want to override this with its own serial from say an eeprom, as such it is desirable to communicate the serial from u-boot to the kernel rather then reproducing the sid reading code in the kernel.
For old atag using kernels there is an atag for this, and the contents of this tag will show up in /proc/cpuinfo, currently there is no equivalent for this in devicetree.
I'm a bit reluctant to merge Paul's patch into u-boot because of this as it will enable a feature on older kernels while leaving the upstream kernel without it.
So I was wondering how to deal with this in devicetree, at least one board in u-boot already sets a devicetree property for this:
board/gateworks/gw_ventana/gw_ventana.c 1202: * serial# env var 1207: char *serial = getenv("serial#"); 1432: setenv("serial#", str); 1512: fdt_setprop(blob, 0, "system-serial", getenv("serial#"), 1513: strlen(getenv("serial#")) + 1);
Which sets a system-serial property in the root node, so at the same level where we also have the model string this seems to make sense to me.
So do we want to add a devicetree binding for system serials, and if we do should we make it a string like above, or should we make it an 64 bit integer like the atag?
If we make it a string we can store longer serials, but how should we deal with those wrt /proc/cpuinfo? Only show the first 64 bits ?
Regards,
Hans
On Sun, Mar 22, 2015 at 6:26 AM, Hans de Goede hdegoede@redhat.com wrote:
Hi All,
We shouldn't really be adding ATAGs to newer platforms...
system-serial is new to me...
There is already "serial-number" (a string) which exists for OpenFirmware. Also, "copyright" corresponds to vendor/manufacturer string. Both of these are supported by lshw already.
Rob
Regards,
Hans _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi All,
Ok, so if I understand you correctly then you're saying that we should set a "serial-number" string property at the dt root level and that this may contain pretty much anything, e.g. in the sunxi case the full 128 bit SID in hex.
Is the use of the "serial-number" string property already documented somewhere? If not I'll submit a kernel patch to document it.
And for older kernels we should not set any serial atag (u-boot always sets it, so this leaves it at 0) and old kernel users are out of luck wrt getting to the serial ?
Regards,
Hans
Hi All,
Right.
Not that I'm aware of. It is something that predates our documentation requirements. It could be in OpenFirmware specs. Documenting it in the DT bindings does not hurt.
If there is sufficient reason to support this on old kernels you could.
Rob
<snip>
Right.
Ok.
One problem with supporting this for older kernels is that if a non 0 serial gets shown in /proc/cpuinfo with older atag booted kernels, we should really show the same number in /proc/cpuinfo which means adding code to the kernel to get the devicetree "serial-number" string property and somehow put that into the 64 bits which we have in /proc/cpuinfo, but given that the "serial-number" string could be hex or decimal or what ever and > 64 bits that will likely require a platform specific solution. All doable, but the question then becomes is this worth the effort ?
Regards,
Hans
<snip>
Right.
Ok.
After investigating a bit more, I found out that the USB serial number is expected to be a string of 32 bytes, so a 128 bit numeric serial doesn't fit (it takes 32 bytes for the hex representation of 128 bits, so there is no room left for the terminating null byte), hence it makes sense to keep a 64 bit limitation for the serial number, if users are going to rely on it as USB serial string. Moreover, it seems that Android devices are mostly used 64 bit numbers for serial numbers/
I was initially going to suggest that we set it in stone that serial must be 64 numeric bits (as it was in the ATAGs days) and that bootloaders would pass it that way to the kernel through device tree (with two 32 bits numeric integers), but Hans talked me out of it. I just want to expose the situation (especially the USB and Android thing) here to double-check that everyone still is convinced that a string approach in device tree is best (which is fine with me).
This way, users that still want to use the serial passed through device tree as a USB serial number will have to use a string of 32 bits, including the null terminating byte (which is what I'll suggest for sunxi by using only 64 bits for the serial number).
Also, I suggest that we show that serial-number string as-is in cpuinfo as well and instead make a string out of the serial ATAG in the kernel prior to showing it in cpuinfo (as opposed to translating the string coming from device tree to a numeric value that cpuinfo will end up showing as a string at the end of the day). Thus, the serial number coming from device tree will still be shown in cpuinfo as well and no ABI gets broken.
If you're all okay with this, I'll be sending patches to both U-Boot and Linux to start documenting/implementing this.
<snip>
Right.
Ok.
There are already existing users of the serial-number property in devicetree, and these already use a free-format string, so AFAICT we have no choice but to do the same as the existing users.
But Rob is the expert here, so lets see what Rob has to say.
We cannot do that because we must guarantee that the serial shown in cpu info is a 64 bits / 16 hex values (0 padded) number, anything else would break the kernel <-> userspace API and potentially break userspace apps. So we must do the devicetree -> serialnumber low/high -> /proc/cpinfo version to guarantee that this format does not change.
And as discussed before if you want a non 0 serial in cpuinfo then the devicetree -> serialnumber low/high should be done in sunxi specific kernel code, as on sunxi we will know that the string in devicetree will be a hex value, but we've no such guarantee for other platforms, so we cannot simply have a generic function to populate erialnumber low/high from the devicetree serial-number string.
You're forgetting the userspace <-> kernel ABI here, the serial line in /proc/cpuinfo is not a free form string it is a 64 bit int shown as 0 padded hex, and we cannot change that as changing that would be an ABI break.
Thanks for your work on this, lets first hash out to few remaining unclear details and then I'm looking forward to your patch set for this.
Regards,
Hans
<snip>
Right.
Ok.
IMHO this really is all about interpretation. If you consider that the serial is already a *string* and not a hex-representation of a number (which it is when using ATAGs, but has no reason to be in general), then my suggestion will introduce no ABI break.
Generally speaking, I found no documentation that indicates that the serial has to be in that format. It just happens to be the case when using ATAGs.
Also, I found an email from Rob suggesting he would be fine with wiring the dts serial-number string to cpuinfo: http://lkml.iu.edu/hypermail/linux/kernel/1412.0/02975.html
I think it's the most flexible solution and we can think of it as an extension of the current scheme: the serial string will no longer be limited to a hex representation of a number but can become any string.
Now I would appreciate it if Rob could weigh-in and state whether he changed his mind on this or not.
Regards,
Hans
<snip>
> There is already "serial-number" (a string) which exists for > OpenFirmware. Also, "copyright" corresponds to vendor/manufacturer > string. Both of these are supported by lshw already.
Right.
Ok.
Oh, and Russell King also seemed to agree back then: http://lkml.iu.edu/hypermail/linux/kernel/1412.0/03318.html
Russell, Rob, what are your thoughts on this?
Regards,
Hans
<snip>
Right.
Ok.
The only ABI is on platforms that used ATAGS as any DT only platform has so far had a serial# in cpuinfo of 16 0's. With a variable length string we can still have a fixed 16 char hex serial number that is compatible with ATAGS. I can't imagine that we have userspace that cares about the length and yet doesn't care the value is always 0's since converting to DT. As long as we keep 16 0's as the default I don't see an issue with allowing other lengths.
It is only an ABI if someone notices and if we find an ABI issue later we can always fix it.
Rob
On Mon, Mar 23, 2015 at 6:30 AM, Hans de Goede hdegoede@redhat.com wrote: > Hi, > > > On 22-03-15 22:01, Rob Herring wrote:
<snip>
>> There is already "serial-number" (a string) which exists for >> OpenFirmware. Also, "copyright" corresponds to vendor/manufacturer >> string. Both of these are supported by lshw already. > > > Ok, so if I understand you correctly then you're saying that we > should set a "serial-number" string property at the dt root level > and that this may contain pretty much anything, e.g. in the > sunxi case the full 128 bit SID in hex.
Right.
> Is the use of the "serial-number" string property already documented > somewhere? If not I'll submit a kernel patch to document it.
Ok.
> And for older kernels we should not set any serial atag (u-boot > always sets it, so this leaves it at 0) and old kernel users are > out of luck wrt getting to the serial ?
There are 2 problems with playing around with the serial line in /proc/cpuinfo:
1) Length, currently it is always 16 chars, making it either shorter or longer may break some userspace parsing code for it.
2) Contents, currently it is always in hex, so we cannot simply copy a string from devicetree in there without verifying that that string contains hex.
Now if we were to add code to: 1) Verify that the serial from devicetree is hex 2) Truncate it to 16 chars max
That would work, the easiest way to get there is to simply store the serial from devicetree in the existing serial low and high 32 bit ints.
Erm, no it is an ABI once it has shipped, and we cannot always fix it later because in the mean time other apps may have started depending on the new ABI and then we've a big problem.
There are plenty of examples of "innocent" changes to files in /proc breaking stuff, so we really really should be careful here.
Also I don't see why this is that important at all, we can limit things to not break the ABI and apps who want the full serial in the original string format can always get it from
/sys/firmware/devicetree/base/serial-number
Regards,
Hans
Rob
<snip>
Right.
Ok.
Alright then, I think that all makes sense. I have a first proposal in that direction ready then.
Russell, I'll just wait for your ack and start sending this to both the U-Boot and ARM kernel lists.
Hans de Goede
Paul Kocialkowski
Rob Herring
