[U-Boot] question about add new board to MAKEALL
Hi all.
I am try to add new board to "MAKEALL" here[1] is the patch. but "MAKEALL" doesn't compile the new board qi_lb60. here[2] is the tail of compile log
this board is base on next branch commit: 953b7e629198fe2eb0adf272fb9140f2a4a51826
I am sure that when I use mipsel-openwrt-linux-, the qi_lb60 compile fine. did I need add the "mipsel-openwrt-linux-" to MAKEALL??
give me some advice? thanks.
[1]------------------ diff --git a/MAKEALL b/MAKEALL index d6d5f5b..3b6953b 100755 --- a/MAKEALL +++ b/MAKEALL @@ -786,7 +786,8 @@ LIST_mips=" \ ## MIPS Systems (little endian) #########################################################################
-LIST_mips4kc_el="" +LIST_mips4kc_el=" \ + qi_lb60"
LIST_mips5kc_el=""
[2] xiangfu@openmobilefree:~/u-boot/u-boot.git$ tail ../build.all.log text data bss dec hex filename 191056 14820 22604 228480 37c80 ../u-boot-build/u-boot Configuring for ppmc7xx board... text data bss dec hex filename 144420 9768 22464 176652 2b20c ../u-boot-build/u-boot
--------------------- SUMMARY ---------------------------- Boards compiled: 354 Boards with warnings or errors: 19 ( MVBC_P lwmon TQM823L_LCD BMW caddy2 MPC8536DS MPC8536DS_NAND MPC8536DS_SDCARD MPC8536DS_SPIFLASH MPC8544DS P2020DS P2020DS_36BIT PM854 AP1000 ML2 sc3 EVB64260 P3G4 ZUMA ) ----------------------------------------------------------
Dear =?UTF-8?B?IlhpYW5nZnUgTGl1KOWImOWQkeWvjCki?=,
MAKEALL is just a wrapper script that runs "make xxx_config" and "make all" for you. It has zero impact on the actual compilation of your board. If it doesn't work, then pothe problem is elsewhere.
No, never. Maybe you did not read the documentation and forgot to set the CROSS_COMPILE environment variable?
These are all PowerPC boards - if your cross compiler is set for the Power Architecture, you should not be surprised that it cannot compile your MIPS code.
Hi Wolfgang
thanks for reply.
before I apply the new board patches. the "MAKEALL" compile 359 boards. after I applied the new board patches. the "MAKEALL" still compile 359 boards. and the build log is the same. is that mean my patch is ok to send to mailist list??
if I am wrong just correct me :)
---- some git question: I try to update my local [next] branch with upstream. but I got this error: "fatal: Couldn't find remote ref next".
but I run the same command in [master] branch. works fine. please give me some advice. very thanks.
more info about my git: xiangfu@openmobilefree:~/u-boot/u-boot.git$ git br -a master * next remotes/origin/GPL-Cleanup remotes/origin/HEAD -> origin/master remotes/origin/i.MX31 remotes/origin/lwmon5 remotes/origin/master remotes/origin/next remotes/origin/origin remotes/origin/tx25 remotes/origin/u-boot-2009.11.y xiangfu@openmobilefree:~/u-boot/u-boot.git$ git pull origin next fatal: Couldn't find remote ref next xiangfu@openmobilefree:~/u-boot/u-boot.git$
Then you obviously missed to add your board to the MAKEALL script.
No, on contrary.
Try: "git checkout master; git remote prune origin"
There is no "next" branch in the mainline repository at this point of the release cycle.
Hi Wolfgang Denk
No, on contrary.
ok. will keep working on that today.
thanks for the info.
thanks again :)
Hi Wolfgang
is this patch[1] ok for "MAKEALL"? or how to add my board "qi_lb60_config" to "MAKEALL"
I am just apply the patch_[1]. now it's making. it need several hours for "MAKEALL" in my pc. so I will got the build log several hours later. but I would also ask in list for some advice.
thanks.
[1] diff --git a/MAKEALL b/MAKEALL index 2133559..ac9c16d 100755 --- a/MAKEALL +++ b/MAKEALL @@ -797,7 +797,9 @@ LIST_mips=" \ ## MIPS Systems (little endian) #############################################################
-LIST_mips4kc_el="" +LIST_mips4kc_el=" \ + qi_lb60 \ +"
LIST_mips5kc_el=""
Dear Xiangfu Liu,
Well, did you try it out? And did it work for you?
It looks good, buty I cannot test it.
MIPS has only few targets - building should be much faster. You may try and find a faster machine, especially with faster storage and more RAM?
On 07/20/2010 05:51 PM, Wolfgang Denk wrote:
Dear Xiangfu Liu,
I modify the patch to a new one[1], since this board use a new cpu named "xburst". this new patch works fine when I run "./MAKEALL mips_el" :)
(this company name is "Ingenic". their cpu name is xburst jz4740 #which is our board used :) xburst jz4760 just FYI.)
[1]diff --git a/MAKEALL b/MAKEALL index 2133559..d909700 100755 --- a/MAKEALL +++ b/MAKEALL @@ -806,10 +806,15 @@ LIST_au1xx0_el=" \ pb1000 \ "
+LIST_xburst_el=" \ + qi_lb60 \ +" + LIST_mips_el=" \ ${LIST_mips4kc_el} \ ${LIST_mips5kc_el} \ ${LIST_au1xx0_el} \ + ${LIST_xburst_el} \ "
Dear Xiangfu Liu,
Well, we don't want to add lists for each and every CPU, especially not for MIPS where we have only very few systems supported; which family does xburst best fit in?
Hi Wolfgang
On 07/20/2010 11:47 PM, Wolfgang Denk wrote:
Dear Xiangfu Liu,
ok. understand.
in there website[1], they don't mention MIPS at all, but I found this in their head file: "MIPS 4Kc (32 bit RISC)" and the gcc argument is "-march=4kc -mtune=4kc -EL -mabicalls -mips32"
here[2] is the new files for the jz4740 soc. give me some advice on this. thanks.
(some linke for our board: http://sharism.cc/products/ben-nanonote/ http://en.qi-hardware.com/wiki/Ben_NanoNote in this wiki you can find all the document of our boards. include hardware design files. )
[1] http://www.ingenic.cn/eng/productServ/AppPro/JZ4740/pfCustomPage.aspx ftp://ftp.ingenic.cn/2soc/Jz4740_ds.pdf
[2] . ├── arch │ └── mips │ ├── cpu │ │ └── xburst │ │ ├── cache.S │ │ ├── config.mk │ │ ├── cpu.c │ │ ├── interrupts.c │ │ ├── jz4740.c │ │ ├── jz_mmc.c │ │ ├── jz_mmc.h │ │ ├── jz_serial.c │ │ ├── Makefile │ │ ├── nanonote_gpm940b0.c │ │ ├── nanonote_gpm940b0.h │ │ ├── start.S │ │ ├── start_spl.S │ │ └── usbboot.S │ └── include │ └── asm │ └── jz4740.h ├── board │ └── xburst │ ├── nanonote │ ├── config.mk │ ├── config.tmp │ ├── Makefile │ ├── nanonote.c │ ├── u-boot.lds │ └── u-boot-nand.lds ├── drivers │ └── mtd │ └── nand │ └── jz4740_nand.c ├── include │ └── configs │ ├── nanonote.h │ └── qi_lb60.h └── nand_spl ├── board │ └── xburst │ └── nanonote │ ├── config.mk │ ├── Makefile │ └── u-boot.lds └── nand_boot_jz4740.c
Dear Xiangfu Liu,
OK. So please add the entry to the mips4kc (or mips4kc_el) list, please.
"Xiangfu Liu(刘向富)"
Xiangfu Liu
