[U-Boot] [PATCH] dfu: add write error handling
Fix calls to dfu_write() and dfu_flush() to detect errors in the I/O itself. This could happen due to problems with the storage medium, or simply when trying to write a FAT/ext file that is larger than the buffer dfu_mmc.c maintains for this purpose.
Signal the error by switching the DFU state/status. This will be picked up by the DFU client when it sends the next DFU request. Note that errors can't simply be returned from e.g. dnload_request_complete(), since that function has no way to pass errors back to the DFU client; a call to dnload_request_complete() simply means that a USB OUT completed.
This error state/status needs to be cleared when the next DFU client connects. While there is a DFU_CLRSTATUS request, no DFU client seems to send this. Hence, clear this when selecting the USB alternate setting on the USB interface.
Finally, dfu.c relies on a call to dfu_flush() to clear up the internal state of the write transaction. Now that errors in dfu_write() are detected, dfu_flush() may no longer be called for every transaction. Separate out the cleanup code into a new function, and call it whenever dfu_write() fails, as well as from any call to dfu_flush().
Signed-off-by: Stephen Warren swarren@nvidia.com --- This probably depends on "dfu: fix some issues with reads/uploads", for context if nothing else. --- drivers/dfu/dfu.c | 46 ++++++++++++++++++++++++++++------------------ drivers/usb/gadget/f_dfu.c | 20 ++++++++++++++++---- 2 files changed, 44 insertions(+), 22 deletions(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index dab5e7048ed5..1bf66d0613c9 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -147,6 +147,19 @@ static int dfu_write_buffer_drain(struct dfu_entity *dfu) return ret; }
+void dfu_write_transaction_cleanup(struct dfu_entity *dfu) +{ + /* clear everything */ + dfu_free_buf(); + dfu->crc = 0; + dfu->offset = 0; + dfu->i_blk_seq_num = 0; + dfu->i_buf_start = dfu_buf; + dfu->i_buf_end = dfu_buf; + dfu->i_buf = dfu->i_buf_start; + dfu->inited = 0; +} + int dfu_flush(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) { int ret = 0; @@ -162,23 +175,14 @@ int dfu_flush(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) printf("\nDFU complete %s: 0x%08x\n", dfu_hash_algo->name, dfu->crc);
- /* clear everything */ - dfu_free_buf(); - dfu->crc = 0; - dfu->offset = 0; - dfu->i_blk_seq_num = 0; - dfu->i_buf_start = dfu_buf; - dfu->i_buf_end = dfu_buf; - dfu->i_buf = dfu->i_buf_start; - dfu->inited = 0; + dfu_write_transaction_cleanup(dfu);
return ret; }
int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) { - int ret = 0; - int tret; + int ret;
debug("%s: name: %s buf: 0x%p size: 0x%x p_num: 0x%x offset: 0x%llx bufoffset: 0x%x\n", __func__, dfu->name, buf, size, blk_seq_num, dfu->offset, @@ -202,6 +206,7 @@ int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) if (dfu->i_blk_seq_num != blk_seq_num) { printf("%s: Wrong sequence number! [%d] [%d]\n", __func__, dfu->i_blk_seq_num, blk_seq_num); + dfu_write_transaction_cleanup(dfu); return -1; }
@@ -223,15 +228,18 @@ int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num)
/* flush buffer if overflow */ if ((dfu->i_buf + size) > dfu->i_buf_end) { - tret = dfu_write_buffer_drain(dfu); - if (ret == 0) - ret = tret; + ret = dfu_write_buffer_drain(dfu); + if (ret) { + dfu_write_transaction_cleanup(dfu); + return ret; + } }
/* we should be in buffer now (if not then size too large) */ if ((dfu->i_buf + size) > dfu->i_buf_end) { error("Buffer overflow! (0x%p + 0x%x > 0x%p)\n", dfu->i_buf, size, dfu->i_buf_end); + dfu_write_transaction_cleanup(dfu); return -1; }
@@ -240,12 +248,14 @@ int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num)
/* if end or if buffer full flush */ if (size == 0 || (dfu->i_buf + size) > dfu->i_buf_end) { - tret = dfu_write_buffer_drain(dfu); - if (ret == 0) - ret = tret; + ret = dfu_write_buffer_drain(dfu); + if (ret) { + dfu_write_transaction_cleanup(dfu); + return ret; + } }
- return ret; + return 0; }
static int dfu_read_buffer_fill(struct dfu_entity *dfu, void *buf, int size) diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index 859fe828de74..9863dec44d99 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -162,17 +162,27 @@ static void dfu_set_poll_timeout(struct dfu_status *dstat, unsigned int ms) static void dnload_request_complete(struct usb_ep *ep, struct usb_request *req) { struct f_dfu *f_dfu = req->context; + int ret;
- dfu_write(dfu_get_entity(f_dfu->altsetting), req->buf, - req->length, f_dfu->blk_seq_num); + ret = dfu_write(dfu_get_entity(f_dfu->altsetting), req->buf, + req->length, f_dfu->blk_seq_num); + if (ret) { + f_dfu->dfu_status = DFU_STATUS_errUNKNOWN; + f_dfu->dfu_state = DFU_STATE_dfuERROR; + } }
static void dnload_request_flush(struct usb_ep *ep, struct usb_request *req) { struct f_dfu *f_dfu = req->context; + int ret;
- dfu_flush(dfu_get_entity(f_dfu->altsetting), req->buf, - req->length, f_dfu->blk_seq_num); + ret = dfu_flush(dfu_get_entity(f_dfu->altsetting), req->buf, + req->length, f_dfu->blk_seq_num); + if (ret) { + f_dfu->dfu_status = DFU_STATUS_errUNKNOWN; + f_dfu->dfu_state = DFU_STATE_dfuERROR; + } }
static inline int dfu_get_manifest_timeout(struct dfu_entity *dfu) @@ -770,6 +780,8 @@ static int dfu_set_alt(struct usb_function *f, unsigned intf, unsigned alt) debug("%s: intf:%d alt:%d\n", __func__, intf, alt);
f_dfu->altsetting = alt; + f_dfu->dfu_state = DFU_STATE_dfuIDLE; + f_dfu->dfu_status = DFU_STATUS_OK;
return 0; }
Hi Stephen,
Stephen, thanks for the patch.
Acked-by: Lukasz Majewski l.majewski@samsung.com
Test HW: Exynos4412 - Trats2
Tested-by: Lukasz Majewski l.majewski@samsung.com
- dfu_free_buf();
- dfu->crc = 0;
- dfu->offset = 0;
- dfu->inited = 0;
- dfu_free_buf();
- dfu->crc = 0;
- dfu->offset = 0;
- dfu->inited = 0;
return ret;
- int ret = 0;
- int tret;
int ret;
return -1; }dfu_write_transaction_cleanup(dfu);
@@ -223,15 +228,18 @@ int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) /* flush buffer if overflow */ if ((dfu->i_buf + size) > dfu->i_buf_end) {
if (ret == 0)
ret = tret;
if (ret) {
return ret;
@@ -240,12 +248,14 @@ int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) /* if end or if buffer full flush */ if (size == 0 || (dfu->i_buf + size) > dfu->i_buf_end) {
if (ret == 0)
ret = tret;
if (ret) {
return ret;
- return ret;
- int ret;
- ret = dfu_write(dfu_get_entity(f_dfu->altsetting), req->buf,
- if (ret) {
- int ret;
- ret = dfu_flush(dfu_get_entity(f_dfu->altsetting), req->buf,
- if (ret) {
static inline int dfu_get_manifest_timeout(struct dfu_entity *dfu) @@ -770,6 +780,8 @@ static int dfu_set_alt(struct usb_function *f, unsigned intf, unsigned alt) debug("%s: intf:%d alt:%d\n", __func__, intf, alt); f_dfu->altsetting = alt;
Hi Stephen,
Applied to u-boot-dfu
Thanks for the patch.
Lukasz Majewski
Stephen Warren
