[U-Boot-Users] [PATCH 6/8] mpc83xx: Reduce the latency of DDR
Reduce the AL from 2 to 1 clock to improve the performance.
Signed-off-by: Dave Liu daveliu@freescale.com --- include/configs/MPC837XEMDS.h | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 46fc239..0b4e562 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -132,7 +132,7 @@ #else /* * Manually set up DDR parameters - * WHITE ELECTRONIC DESGGNS - W3HG64M72EEU403PD4 SO-DIMM + * WHITE ELECTRONIC DESIGNS - W3HG64M72EEU403PD4 SO-DIMM * consist of nine chips from SAMSUNG K4T51083QE-ZC(L)D5 */ #define CFG_DDR_SIZE 512 /* MB */ @@ -160,22 +160,22 @@ | ( 2 << TIMING_CFG1_ACTTOACT_SHIFT ) \ | ( 2 << TIMING_CFG1_WRTORD_SHIFT ) ) /* 0x3935d322 */ -#define CFG_DDR_TIMING_2 ( ( 2 << TIMING_CFG2_ADD_LAT_SHIFT ) \ +#define CFG_DDR_TIMING_2 ( ( 1 << TIMING_CFG2_ADD_LAT_SHIFT ) \ | ( 6 << TIMING_CFG2_CPO_SHIFT ) \ | ( 2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT ) \ | ( 4 << TIMING_CFG2_RD_TO_PRE_SHIFT ) \ | ( 2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT ) \ | ( 3 << TIMING_CFG2_CKE_PLS_SHIFT ) \ | ( 8 << TIMING_CFG2_FOUR_ACT_SHIFT) ) - /* 0x231088c8 */ + /* 0x131088c8 */ #define CFG_DDR_INTERVAL ( ( 0x03E0 << SDRAM_INTERVAL_REFINT_SHIFT ) \ | ( 0x0100 << SDRAM_INTERVAL_BSTOPRE_SHIFT ) ) /* 0x03E00100 */ #define CFG_DDR_SDRAM_CFG 0x43000000 #define CFG_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */ -#define CFG_DDR_MODE ( ( 0x0450 << SDRAM_MODE_ESD_SHIFT ) \ +#define CFG_DDR_MODE ( ( 0x0448 << SDRAM_MODE_ESD_SHIFT ) \ | ( 0x1432 << SDRAM_MODE_SD_SHIFT ) ) - /* ODT 150ohm CL=3, AL=2 on SDRAM */ + /* ODT 150ohm CL=3, AL=1 on SDRAM */ #define CFG_DDR_MODE2 0x00000000 #endif
Dave Liu
