[U-Boot] [PATCH 1/2] Fix boards missing CONFIG_NAND after Kconfig migration
Several boards need CONFIG_NAND in order to migrate additional settings to Kconfig. These configs include: SYS_NAND_ECCSIZE, SYS_NAND_ECCBYTES, SYS_NAND_ECCSTEPS, SYS_NAND_MAX_ECCPOS, and SYS_NAND_MAX_OOBFREE
Fixes 5bbc265becbe ("Convert CONFIG_NAND to Kconfig")
Signed-off-by: Adam Ford aford173@gmail.com --- configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/T4160QDS_SDCARD_defconfig | 1 + configs/T4160QDS_SECURE_BOOT_defconfig | 1 + configs/T4160QDS_defconfig | 1 + configs/T4160RDB_defconfig | 1 + configs/T4240QDS_SDCARD_defconfig | 1 + configs/T4240QDS_SECURE_BOOT_defconfig | 1 + configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T4240QDS_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/axm_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/corvus_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/ls2080a_simu_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/taurus_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + 45 files changed, 45 insertions(+)
diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 6e37669..b6583d2 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -22,6 +22,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index beeaa82..95f4fb2 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -21,6 +21,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index f756d00..ddf26db 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index e9a4a07..3eb9b3a 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -22,6 +22,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index e89b132..600e055 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT2=y CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 5a22a8b..995808f 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -21,6 +21,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 1c4ab11..b4ab061 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT2=y CONFIG_SYS_FSL_DDR2=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y CONFIG_PHY_GIGE=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 8881713..cf70a5f 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_SYS_FSL_DDR2=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 5e510b9..89fadb5 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index ec39ffb..71d1d2e 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index d2922f3..1f0d3ed 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index 198968e..496ca01 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 619b7ca..02bcce9 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index 4b1b4c3..dc65490 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index e4b0912..05dfed9 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index 1d13bcf..40ddf34 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index a9df2ad..91cca13 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 1142491..e1fa021 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index 6f0fcf2..683a85d 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index 367ca86..e9c7e63 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig index 43320b5..8d756a4 100644 --- a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index d4d2caf..e46933c 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 18364a6..6d693de 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index e902080..0e03fcc 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 42260b1..fd5993e 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 3d73f83..e131ef9 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -37,6 +37,7 @@ CONFIG_DM_GPIO=y CONFIG_AT91_GPIO=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_NAND=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 81654b2..248be12 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -37,6 +37,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 382fc1a..b203752 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -39,6 +39,7 @@ CONFIG_LED_STATUS_STATE=2 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 705e001..8650e4d 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -42,6 +42,7 @@ CONFIG_CLK_AT91=y CONFIG_AT91_UTMI=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set +CONFIG_NAND=y CONFIG_PHYLIB=y # CONFIG_SPL_DM_SERIAL is not set CONFIG_ATMEL_USART=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index b46de7d..c2c9e30 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_DM=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_PHYLIB=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index e9c82ba..8e8ebde 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -32,4 +32,5 @@ CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_NAND=y CONFIG_SYS_NS16550=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index 23f3d42..dfdbd82 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_CACHE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index c80a837..902c14b 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index ef1d9dc..8711eac 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -28,6 +28,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 79307f8..908e54e 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y +CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 0e8b7d0..4e75b33 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 4a462ce..e372ca7 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index c44ac48..feeb71e 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -27,6 +27,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 9977e8e..a64151d 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_DM=y CONFIG_DM_GPIO=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_NAND=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index c31a86d..4629c04 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 8703316..e7eaad0 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -42,6 +42,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set +CONFIG_NAND=y CONFIG_PHYLIB=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index 0593e9a..92ce6f3 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 71a382a..dc884e6 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -47,6 +47,7 @@ CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set +CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 1a07489..63eeb00 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -35,6 +35,7 @@ CONFIG_LED_STATUS_BIT2=4 CONFIG_LED_STATUS_STATE2=2 CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_BCH=y CONFIG_OF_LIBFDT=y diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index dba3b1d..fd9e0e8 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -34,6 +34,7 @@ CONFIG_LED_STATUS_BIT2=4 CONFIG_LED_STATUS_STATE2=2 CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y CONFIG_SYS_NS16550=y CONFIG_BCH=y CONFIG_OF_LIBFDT=y
Adam Ford
