[U-Boot] [PATCH] sunxi: Use "usb start" rather then "run usb_init" for preboot with usb-kbd
In an effort to avoid usb getting scanned twice when using an usb keyboard, and booting from usb, I've set preboot to "run usb_init" in the CONFIG_USB_KEYBOARD patch.
This is wrong however, as it causes usb to not be scanned (and the keyboard to not be found) if an "env save" is done, since then the env contains usb_need_init=false.
This commit fixes this by changing the preboot value to "usb start", so that usb gets scanned for a keyboard unconditionally when usb-keyboard support is enabled.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index fcaa249..3f890b2 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -306,7 +306,7 @@
#ifdef CONFIG_USB_KEYBOARD #define CONSOLE_STDIN_SETTINGS \ - "preboot=run usb_init\0" \ + "preboot=usb start\0" \ "stdin=serial,usbkbd\0" #else #define CONSOLE_STDIN_SETTINGS \
Acked-by: Ian Campbell ijc@hellion.org.uk
- "preboot=usb start\0" \ "stdin=serial,usbkbd\0"
Hans de Goede
Ian Campbell
