[U-Boot] [PATCH 1/1] am33xx: add CONFIG_SYS_NAND_DEVICE_WIDTH to determine NAND device bus-width
NAND driver needs to know bus-width of the connected NAND device, in order to perform proper I/O and initialize itself. Currently there is no CONFIG option to provide this information to NAND driver. - SPL NAND driver does not have framework to parse ONFI parameter page. - NAND drivers which cannot self initialize !defined(CONFIG_SYS_NAND_SELF_INIT) do not have any information about device bus-width during board_nand_init(), So, any device-width specific configurations are not possible there. - There should be some mechanism to pass device bus-width information for non-ONFI compliant devices.
This patch (1) adds CONFIG_SYS_NAND_DEVICE_WIDTH which can take following value 16: NAND device with x16 bus-width 8: NAND device with x8 bus-width (2) removes GPMC_NAND_ECC_LP_x16_LAYOUT, as NAND layout is determined based on ecc-scheme and oobsize during initialization in board_nand_init(). Thus this config is redundant.
Signed-off-by: Pekon Gupta pekon@ti.com --- doc/README.nand | 9 +++++++++ drivers/mtd/nand/omap_gpmc.c | 18 +++++++++++------- include/configs/am335x_evm.h | 2 +- include/configs/am3517_crane.h | 2 +- include/configs/am3517_evm.h | 2 +- include/configs/cm_t35.h | 2 -- include/configs/devkit8000.h | 3 +-- include/configs/dig297.h | 2 -- include/configs/igep0033.h | 8 ++++---- include/configs/igep00x0.h | 2 +- include/configs/mcx.h | 2 +- include/configs/omap3_beagle.h | 3 +-- include/configs/omap3_evm_common.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 3 +-- include/configs/omap3_pandora.h | 2 -- include/configs/omap3_zoom1.h | 2 -- include/configs/omap3_zoom2.h | 1 - include/configs/siemens-am33x-common.h | 8 ++++---- include/configs/tam3517-common.h | 2 +- include/configs/tricorder.h | 3 +-- 21 files changed, 38 insertions(+), 40 deletions(-)
diff --git a/doc/README.nand b/doc/README.nand index f9c921e..5726ff2 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -179,6 +179,15 @@ Configuration Options: This is used by SoC platforms which do not have built-in ELM hardware engine required for BCH ECC correction.
+ CONFIG_SYS_NAND_DEVICE_WIDTH + Specifies bus-width of the default NAND device connected to SoC. + This config is useful for driver which cannot self initialize or + parse ONFI parameter (like SPL drivers), or for supporting non-ONFI + compliant devices. + This config can take following values: + - 8: NAND devices has bus-width=x8 + - 16: NAND device has bus-width=x16 + Platform specific options =========================
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 68786f9..584e33e 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -214,11 +214,7 @@ static void omap_enable_hwecc(struct mtd_info *mtd, int32_t mode) unsigned int eccsize1 = 0x00, eccsize0 = 0x00, bch_wrapmode = 0x00; u32 ecc_size_config_val = 0; u32 ecc_config_val = 0; - u32 cs_config1_val;
- /* reconfigure GPMC device-width */ - cs_config1_val = readl(&gpmc_cfg->cs[cs].config1); - writel((cs_config1_val | dev_width << 12), &gpmc_cfg->cs[cs].config1); /* configure GPMC for specific ecc-scheme */ switch (bch->ecc_scheme) { case OMAP_ECC_HAM1_CODE_SW: @@ -772,10 +768,10 @@ int board_nand_init(struct nand_chip *nand) nand->priv = &bch_priv; nand->cmd_ctrl = omap_nand_hwcontrol; nand->options |= NAND_NO_PADDING | NAND_CACHEPRG; - /* If we are 16 bit dev, our gpmc config tells us that */ - if ((readl(&gpmc_cfg->cs[cs].config1) & 0x3000) == 0x1000) + if (CONFIG_SYS_NAND_DEVICE_WIDTH == 16) nand->options |= NAND_BUSWIDTH_16; - + else + nand->options &= ~NAND_BUSWIDTH_16; nand->chip_delay = 100; nand->ecc.layout = &omap_ecclayout;
@@ -795,5 +791,13 @@ int board_nand_init(struct nand_chip *nand) nand->dev_ready = omap_spl_dev_ready; #endif
+ /* reconfigure GPMC.CONFIG1 register with correct device-width */ + gpmc_config = readl(&gpmc_cfg->cs[cs].config1); + if (nand->options & NAND_BUSWIDTH_16) + gpmc_config |= (0x1 << 12); + else + gpmc_config &= ~(0x1 << 12); + writel(gpmc_config, &gpmc_cfg->cs[cs].config1); + return 0; } diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 978bca7..c92cb2f 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -216,6 +216,7 @@
#ifdef CONFIG_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_BLOCK_SIZE 131072 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 @@ -366,7 +367,6 @@ /* NAND support */ #ifdef CONFIG_NAND #define CONFIG_CMD_NAND -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #if !defined(CONFIG_SPI_BOOT) && !defined(CONFIG_NOR_BOOT) #define MTDIDS_DEFAULT "nand0=omap2-nand.0" #define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:128k(SPL)," \ diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 1fd2508..0985221 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -269,7 +269,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_ENV_IS_IN_NAND 1 #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
@@ -332,6 +331,7 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 6500878..8593d44 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -263,7 +263,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
@@ -326,6 +325,7 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index bc5b66c..1e3dd0d 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -164,8 +164,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x8_LAYOUT - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ /* Environment information */ diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index cb79b4e..d6c64a3 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -116,8 +116,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_JFFS2_NAND @@ -318,6 +316,7 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/dig297.h b/include/configs/dig297.h index 30e3908..f69bcec 100644 --- a/include/configs/dig297.h +++ b/include/configs/dig297.h @@ -143,8 +143,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */
#if defined(CONFIG_CMD_NET) diff --git a/include/configs/igep0033.h b/include/configs/igep0033.h index 3e18a65..ce6b9be 100644 --- a/include/configs/igep0033.h +++ b/include/configs/igep0033.h @@ -188,7 +188,6 @@ /* NAND support */ #define CONFIG_NAND #define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_SYS_NAND_BASE (0x08000000) /* phys address CS0 */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_ONFI_DETECTION 1 @@ -248,11 +247,12 @@ #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/igep00x0.h b/include/configs/igep00x0.h index 9982cf6..7e5bc9b 100644 --- a/include/configs/igep00x0.h +++ b/include/configs/igep00x0.h @@ -268,7 +268,6 @@ #define PISMO1_NAND_SIZE GPMC_SIZE_128M /* Configure the PISMO */ #define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_BASE NAND_BASE -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ @@ -354,6 +353,7 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 5e27ab2..d508978 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -322,7 +322,6 @@ #define PISMO1_NAND_SIZE GPMC_SIZE_128M
#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT #define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */
@@ -385,6 +384,7 @@ #define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img"
/* NAND boot config */ +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index c1245e7..9050f55 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -184,8 +184,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */
@@ -424,6 +422,7 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/omap3_evm_common.h b/include/configs/omap3_evm_common.h index edf6543..564af9a 100644 --- a/include/configs/omap3_evm_common.h +++ b/include/configs/omap3_evm_common.h @@ -210,7 +210,6 @@ #define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE
#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #elif defined(CONFIG_CMD_ONENAND) #define CONFIG_SYS_FLASH_BASE PISMO1_ONEN_BASE diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index ee6db51..e198c4c 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -298,7 +298,6 @@
#if defined(CONFIG_CMD_NAND) #define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #endif diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 88380a4..de06e20 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -120,8 +120,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand */ /* at CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_JFFS2_NAND @@ -317,6 +315,7 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 91a2568..6ea106d 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -131,8 +131,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand */ /* at CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */
diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index c747d52..1dd7b9c 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -138,8 +138,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_JFFS2_NAND diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index cb8c7ec..9ca7fbe 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -158,7 +158,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment information */ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 5426ee8..197accc 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -182,11 +182,12 @@ #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ @@ -433,7 +434,6 @@ "\0"
#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_SYS_NAND_BASE (0x08000000) /* physical address */ /* to access nand at */ /* CS0 */ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 60dd8ff..1f31a87 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -188,7 +188,6 @@ #define PISMO1_NAND_SIZE GPMC_SIZE_128M
@@ -252,6 +251,7 @@ #define CONFIG_SPL_BSS_MAX_SIZE 0x80000
/* NAND boot config */ +#define CONFIG_SYS_NAND_DEVICE_WIDTH 8 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 6daea50..95bbbaa 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -106,8 +106,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_BCH @@ -284,6 +282,7 @@
Short comment. Apologies for top posting:
The first incarnations of SPL and loader mainly cared about the boot flash device.
OMAPs require a resistor strap to specify the width of the boot device. The values is latched for SW to read.
As such always a run time check of width was sufficient for boot device.
On dev board we would have many devices and use DIP switch to select which one was in use. A run time not compile time was way to support this.
If information is dynamically available it is better to use this if focus is boot device management.
Other tricks writing patterns and reading results is also possible but simplicity of compile vs. that is debatable.
Regards, Richard W.
-----Original Message----- From: Gupta, Pekon Sent: Wednesday, September 25, 2013 12:18 AM To: scottwood@freescale.com; Rini, Tom Cc: u-boot@lists.denx.de; Balbi, Felipe; Kipisz, Steven; sbabic@denx.de; notasas@gmail.com; luca.ceresoli@comelit.it; Woodruff, Richard; weber@corscience.de; peter.barada@logicpd.com; frederik@kriewitz.eu; Tom.Rix@windriver.com; Menon, Nishanth; srinath@mistralsolutions.com; Hiremath, Vaibhav; Gupta, Pekon Subject: [PATCH 1/1] am33xx: add CONFIG_SYS_NAND_DEVICE_WIDTH to determine NAND device bus-width
Is there an SPL that cares about something other than the boot device now?
Regards, Richard W.
I agree. Outside of SPL (where hardcoding can be useful due to size constraints, and you only care about the boot device), it's best to let drivers determine the best way to learn about such configuration.
Is this about SPL? It looks like a more general change.
Convert to self-init. That's what it's for.
-Scott
Pekon Gupta
Scott Wood
Woodruff, Richard
