[U-Boot] [PATCH v2 1/6] dm: SMEM (Shared memory) uclass
This is a uclass for Shared memory manager drivers.
A Shared Memory Manager driver implements an interface for allocating and accessing items in the memory area shared among all of the processors.
Signed-off-by: Ramon Fried ramon.fried@gmail.com
Changes in v2: (As suggested by Simon Glass) - Introduced a new dm class (CLASS_SMEM) instead of CLASS_SOC. - Added sandbox driver - Added testing for DM class.
drivers/Makefile | 1 + drivers/smem/Kconfig | 2 + drivers/smem/Makefile | 5 +++ drivers/smem/smem-uclass.c | 53 ++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/smem.h | 84 ++++++++++++++++++++++++++++++++++++++ 6 files changed, 146 insertions(+) create mode 100644 drivers/smem/Kconfig create mode 100644 drivers/smem/Makefile create mode 100644 drivers/smem/smem-uclass.c create mode 100644 include/smem.h
diff --git a/drivers/Makefile b/drivers/Makefile index a213ea9671..ba4a561358 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -98,6 +98,7 @@ obj-y += pwm/ obj-y += reset/ obj-y += input/ # SOC specific infrastructure drivers. +obj-y += smem/ obj-y += soc/ obj-$(CONFIG_REMOTEPROC) += remoteproc/ obj-y += thermal/ diff --git a/drivers/smem/Kconfig b/drivers/smem/Kconfig new file mode 100644 index 0000000000..64337a8b8e --- /dev/null +++ b/drivers/smem/Kconfig @@ -0,0 +1,2 @@ +menuconfig SMEM + bool "SMEM (Shared Memory mamanger) support" diff --git a/drivers/smem/Makefile b/drivers/smem/Makefile new file mode 100644 index 0000000000..ca55c4512d --- /dev/null +++ b/drivers/smem/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Makefile for the U-Boot SMEM interface drivers + +obj-$(CONFIG_SMEM) += smem-uclass.o diff --git a/drivers/smem/smem-uclass.c b/drivers/smem/smem-uclass.c new file mode 100644 index 0000000000..07ed1a92d8 --- /dev/null +++ b/drivers/smem/smem-uclass.c @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2018 Ramon Fried ramon.fried@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <smem.h> + +int smem_alloc(struct udevice *dev, unsigned int host, + unsigned int item, size_t size) +{ + struct smem_ops *ops = smem_get_ops(dev); + + if (!ops->alloc) + return -ENOSYS; + + return ops->alloc(host, item, size); +} + +void *smem_get(struct udevice *dev, unsigned int host, + unsigned int item, size_t *size) +{ + struct smem_ops *ops = smem_get_ops(dev); + + if (!ops->get) + return NULL; + + return ops->get(host, item, size); +} + +int smem_get_free_space(struct udevice *dev, unsigned int host, size_t *free) +{ + struct smem_ops *ops = smem_get_ops(dev); + + int ret; + + if (!ops->get_free_space) + return -ENOSYS; + + ret = ops->get_free_space(host); + if (ret > 0) + *free = ret; + else + return ret; + + return 0; +} + +UCLASS_DRIVER(smem) = { + .id = UCLASS_SMEM, + .name = "smem", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index d7f9df3583..a39643ec5e 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -74,6 +74,7 @@ enum uclass_id { UCLASS_RTC, /* Real time clock device */ UCLASS_SCSI, /* SCSI device */ UCLASS_SERIAL, /* Serial UART */ + UCLASS_SMEM, /* Shared memory interface */ UCLASS_SPI, /* SPI bus */ UCLASS_SPMI, /* System Power Management Interface bus */ UCLASS_SPI_FLASH, /* SPI flash */ diff --git a/include/smem.h b/include/smem.h new file mode 100644 index 0000000000..201960232c --- /dev/null +++ b/include/smem.h @@ -0,0 +1,84 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * header file for smem driver. + * + * Copyright (c) 2018 Ramon Fried ramon.fried@gmail.com + */ + +#ifndef _smemh_ +#define _smemh_ + +/* struct smem_ops: Operations for the SMEM uclass */ +struct smem_ops { + /** + * alloc() - allocate space for a smem item + * + * @host: remote processor id, or -1 + * @item: smem item handle + * @size: number of bytes to be allocated + * @return 0 if OK, -ve on error + */ + int (*alloc)(unsigned int host, + unsigned int item, size_t size); + + /** + * get() - Resolve ptr of size of a smem item + * + * @host: the remote processor, of -1 + * @item: smem item handle + * @size: pointer to be filled out with the size of the item + * @return pointer on success, NULL on error + */ + void *(*get)(unsigned int host, + unsigned int item, size_t *size); + + /** + * get_free_space() - Set the PWM invert + * + * @host: the remote processor identifying a partition, or -1 + * @return free space, -ve on error + */ + int (*get_free_space)(unsigned int host); +}; + +#define smem_get_ops(dev) ((struct smem_ops *)(dev)->driver->ops) + +/** + * smem_alloc() - allocate space for a smem item + * @host: remote processor id, or -1 + * @item: smem item handle + * @size: number of bytes to be allocated + * @return 0 if OK, -ve on error + * + * Allocate space for a given smem item of size @size, given that the item is + * not yet allocated. + */ +int smem_alloc(struct udevice *dev, unsigned int host, + unsigned int item, size_t size); + +/** + * smem_get() - resolve ptr of size of a smem item + * @host: the remote processor, or -1 + * @item: smem item handle + * @size: pointer to be filled out with size of the item + * @return pointer on success, NULL on error + * + * Looks up smem item and returns pointer to it. Size of smem + * item is returned in @size. + */ +void *smem_get(struct udevice *dev, unsigned int host, + unsigned int item, size_t *size); + +/** + * smem_get_free_space() - retrieve amount of free space in a partition + * @host: the remote processor identifying a partition, or -1 + * @free_space: pointer to be filled out with free space + * @return 0 if OK, -ve on error + * + * To be used by smem clients as a quick way to determine if any new + * allocations has been made. + */ +int smem_get_free_space(struct udevice *dev, unsigned int host, size_t *free_space); + +#endif /* _smem_h_ */ +
Hi Ramon,
A few nits below.
- Copyright (c) 2018 Ramon Fried ramon.fried@gmail.com
if (!ops->alloc)
return -ENOSYS;
if (!ops->get)
return NULL;
int ret;
return -ENOSYS;
if (ret > 0)
*free = ret;
else
return ret;
It seems odd that get_free_space() has a different return value than smem_get_free_space(). Can you make the latter return the amount of free space? If not, change the op to return it in a param. You can use long as the return value if that helps.
.id = UCLASS_SMEM,
.name = "smem",
- header file for smem driver.
If you have a README somewhere please point to it here.
What does -1 mean? Please expand commment
How does one choose this? What does it mean? Can you expand this comment a bit?
Fits on one line?
Fits on one line?
free space in bytes ?
- smem_alloc() - allocate space for a smem item
- @host: remote processor id, or -1
- @item: smem item handle
- @size: number of bytes to be allocated
- @return 0 if OK, -ve on error
- Allocate space for a given smem item of size @size, given that the item is
- not yet allocated.
- smem_get() - resolve ptr of size of a smem item
- @host: the remote processor, or -1
- @size: pointer to be filled out with size of the item
- @return pointer on success, NULL on error
- Looks up smem item and returns pointer to it. Size of smem
- item is returned in @size.
- smem_get_free_space() - retrieve amount of free space in a partition
- @host: the remote processor identifying a partition, or -1
- @free_space: pointer to be filled out with free space
- To be used by smem clients as a quick way to determine if any new
- allocations has been made.
-- 2.17.1
Hi Simon
On Tue, Jun 26, 2018 at 6:59 AM Simon Glass sjg@chromium.org wrote:
Hi Ramon,
A few nits below.
if (!ops->alloc)
return -ENOSYS;
if (!ops->get)
return NULL;
*free)
int ret;
return -ENOSYS;
if (ret > 0)
*free = ret;
else
return ret;
I fixed smem_get_free_space() to look the same as get_free_space().
.id = UCLASS_SMEM,
.name = "smem",
Done.
Fits on one line?
Checkpatch complained, but I agree, this should be one line.
item
Fits on one line?
Yes. Fixed.
item is
*free_space);
-- 2.17.1
Thanks, Ramon.
Hi Ramon,
A few nits below.
if (!ops->alloc)
return -ENOSYS;
if (!ops->get)
return NULL;
*free)
int ret;
return -ENOSYS;
if (ret > 0)
*free = ret;
else
return ret;
.id = UCLASS_SMEM,
.name = "smem",
It can be an index (like in QCOM implementation) but honestly, it can be a hash as well. it's up to the implementation to decide how to access the items.
Fits on one line?
item
Fits on one line?
item is
*free_space);
-- 2.17.1
HI Ramon,
Hi Ramon,
A few nits below.
OK that's fine. The key thing is to document this. Your API at present is pretty vague which is why I am asking for more comments showing what is going on. Even a comment at the top of your header file with an example of usage would be useful.
I just saw your latest v3 patch and it still seems to me that it needs more details. I had to read the qualcomm driver to try to understand how the uclass API is supposed to work.
On Wed, Jun 27, 2018 at 2:18 AM Simon Glass sjg@chromium.org wrote:
HI Ramon,
Hi Ramon,
A few nits below.
comment a
bit?
a
Thanks for the feedback. I'll look in to it soon.
Thanks, Ramon.
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
See below for a requested correction.
- bool "SMEM (Shared Memory mamanger) support"
- struct smem_ops *ops = smem_get_ops(dev);
- if (!ops->alloc)
return -ENOSYS;
- return ops->alloc(host, item, size);
- if (!ops->get)
return NULL;
- return ops->get(host, item, size);
- int ret;
- if (!ops->get_free_space)
return -ENOSYS;
- ret = ops->get_free_space(host);
- if (ret > 0)
*free = ret;
- else
return ret;
- .id = UCLASS_SMEM,
- .name = "smem",
- UCLASS_SMEM, /* Shared memory interface */ UCLASS_SPI, /* SPI bus */ UCLASS_SPMI, /* System Power Management Interface bus */ UCLASS_SPI_FLASH, /* SPI flash */
- int (*alloc)(unsigned int host,
- void *(*get)(unsigned int host,
The “Set the PWM invert” part seems like a mistake here...
- int (*get_free_space)(unsigned int host);
-- 2.17.1
On June 26, 2018 9:39:55 AM GMT+03:00, "Dr. Philipp Tomsich" philipp.tomsich@theobroma-systems.com wrote:
Thanks. Nice catch...
- if (!ops->alloc)
return -ENOSYS;
- if (!ops->get)
return NULL;
size_t *free)
- int ret;
return -ENOSYS;
- if (ret > 0)
*free = ret;
- else
return ret;
- .name = "smem",
the item is
partition
-- 2.17.1
Dr. Philipp Tomsich
Ramon Fried
