[U-Boot] [PATCH] spi:ls102xqds:Support for compatibility for QSPI and DSPI modules drivers
Useage: For exmaple(ls1021 ls1021aqds):
SPI bus defination can be find in arch/arm/include/asm/arch-ls102xa/config.h
SPI_BUS_FSL_QSPI 0 SPI_BUS_FSL_DSPI1 1 SPI_BUS_FSL_DSPI2 2
and SPI devices info: AT45DB021 is on spi bus 1 cs 0 S25FL064 is on spi bus 2 cs 0 S25FL128S is on spi bus 0 cs 0
Before using any SPI bus and SPI flash, execute sf probe bus:cs in uboot cmdline Such as use S25FL064, sf probe 2:0
Signed-off-by: Chao Fu B44548@freescale.com --- arch/arm/include/asm/arch-ls102xa/config.h | 5 +- board/freescale/ls1021aqds/ls1021aqds.c | 33 ++++ drivers/spi/Makefile | 1 + drivers/spi/fsl_dspi.c | 78 +++------ drivers/spi/fsl_qspi.c | 35 ++-- drivers/spi/fsl_spi_interface.c | 267 +++++++++++++++++++++++++++++ 6 files changed, 339 insertions(+), 80 deletions(-) create mode 100644 drivers/spi/fsl_spi_interface.c
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index ed78c33..ccaf667 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -42,7 +42,7 @@
#define WDOG1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01ad0000)
-#define QSPI0_BASE_ADDR (CONFIG_SYS_IMMR + 0x00550000) +#define QSPI_BASE_ADDR (CONFIG_SYS_IMMR + 0x00550000) #define DSPI1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01100000)
#define LPUART_BASE (CONFIG_SYS_IMMR + 0x01950000) @@ -63,6 +63,9 @@ #define CONFIG_SYS_FSL_QSPI_BE #define CONFIG_SYS_FSL_DCU_BE
+#define SPI_BUS_FSL_QSPI 0 +#define SPI_BUS_FSL_DSPI1 1 + #define DCU_LAYER_MAX_NUM 16
#define CONFIG_SYS_FSL_SRDS_1 diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 12e83f7..5db2126 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -230,6 +230,39 @@ int board_init(void) return 0; }
+int board_spi_find_bus(unsigned int bus, unsigned int cs) +{ + switch (bus) { + case SPI_BUS_FSL_DSPI1: + case SPI_BUS_FSL_DSPI2: + case SPI_BUS_FSL_QSPI: + break; + default: + return -1; + } + + switch (bus) { + case SPI_BUS_FSL_DSPI1: + if (cs == 0) + return 0; + case SPI_BUS_FSL_DSPI2: + if (cs == 0) + return 0; + case SPI_BUS_FSL_QSPI: + if (cs == 0) + return 0; + default: + return -1; + } +} + +void board_print_spi_device(void) +{ + printf("LS1021aqds spi flash info:\n"); + printf("S25FL128S is on spi bus 0 cs 0\n"); + printf("AT45DB021 is on spi bus 1 cs 0\n"); +} + void ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd); diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 6511263..82c3457 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -42,3 +42,4 @@ obj-$(CONFIG_TI_QSPI) += ti_qspi.o obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o obj-$(CONFIG_FSL_QSPI) += fsl_qspi.o +obj-$(CONFIG_FSL_SPI_INTERFACE) += fsl_spi_interface.o diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index 72a5fa3..9d4133d 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -40,6 +40,8 @@ struct dspi_slave { int charbit; };
+unsigned long get_spi_bus_base(unsigned int bus); + static inline struct dspi_slave *to_dspi_spi(struct spi_slave *slave) { return container_of(slave, struct dspi_slave, slave); @@ -125,22 +127,11 @@ int dspi_xfer(struct spi_slave *slave, uint bitlen, const void *dout,
if (len) { if (dout != NULL) { -#ifdef CONFIG_LS102XA - if (flags == SPI_XFER_END) - ctrl |= DSPI_TFR_CONT; -#endif if (dspislave->charbit == 16) dspi_tx(dspislave, ctrl, *spi_wr16); else dspi_tx(dspislave, ctrl, *spi_wr); dspi_rx(dspislave); -#ifdef CONFIG_LS102XA - if (flags == SPI_XFER_END) { - ctrl &= ~DSPI_TFR_CONT; - dspi_tx(dspislave, ctrl, CONFIG_SPI_IDLE_VAL); - dspi_rx(dspislave); - } -#endif }
if (din != NULL) { @@ -159,7 +150,8 @@ int dspi_xfer(struct spi_slave *slave, uint bitlen, const void *dout, return 0; }
-struct spi_slave *dspi_setup_slave(struct dspi_slave *dspislave, uint mode) +struct spi_slave *dspi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) { /* * bit definition for mode: @@ -174,6 +166,7 @@ struct spi_slave *dspi_setup_slave(struct dspi_slave *dspislave, uint mode) * 11 - 8: Delay after transfer scaler * 7 - 0: SPI_CPHA, SPI_CPOL, SPI_LSB_FIRST */ + struct dspi_slave *dspislave; int prescaler[] = { 2, 3, 5, 7 }; int scaler[] = { 2, 4, 6, 8, @@ -185,7 +178,12 @@ struct spi_slave *dspi_setup_slave(struct dspi_slave *dspislave, uint mode) int best_i, best_j, bestmatch = 0x7FFFFFFF, baud_speed, bus_clk; u32 bus_setup = 0;
- dspislave->regs = (dspi_t *)MMAP_DSPI; + dspislave = spi_alloc_slave(struct dspi_slave, bus, cs); + if (!dspislave) + return NULL; + + dspislave->baudrate = max_hz; + dspislave->regs = (struct dspi *)get_spi_bus_base(bus);
#if !defined(CONFIG_VF610) && !defined(CONFIG_LS102XA) cfspi_port_conf(); /* port configuration */ @@ -255,9 +253,9 @@ struct spi_slave *dspi_setup_slave(struct dspi_slave *dspislave, uint mode)
if ((mode & 0xF0000000) == 0) bus_setup |= - dspi_read32(&dspislave->regs-> - ctar[dspislave->slave.bus]) - & 0x78000000; + dspi_read32(&dspislave->regs-> + ctar[dspislave->slave.cs]) + & 0x78000000; else bus_setup |= ((mode & 0xF0000000) >> 1);
@@ -273,13 +271,13 @@ struct spi_slave *dspi_setup_slave(struct dspi_slave *dspislave, uint mode) bus_setup |= (mode & 0x000FFF00) >> 4; /* CSSCK, ASC, DT */ } else bus_setup |= - dspi_read32(&dspislave->regs->ctar[dspislave->slave.bus]) + dspi_read32(&dspislave->regs->ctar[dspislave->slave.cs]) & 0x78FCFFF0;
dspislave->charbit = - ((dspi_read32(&dspislave->regs->ctar[dspislave->slave.bus]) - & 0x78000000) - == 0x78000000) ? 16 : 8; + ((dspi_read32(&dspislave->regs->ctar[dspislave->slave.cs]) + & 0x78000000) + == 0x78000000) ? 16 : 8;
pbrcnt = sizeof(prescaler) / sizeof(int); brcnt = sizeof(scaler) / sizeof(int); @@ -304,21 +302,12 @@ struct spi_slave *dspi_setup_slave(struct dspi_slave *dspislave, uint mode) }
bus_setup |= (DSPI_CTAR_PBR(best_i) | DSPI_CTAR_BR(best_j)); - dspi_write32(&dspislave->regs->ctar[dspislave->slave.bus], bus_setup); + dspi_write32(&dspislave->regs->ctar[dspislave->slave.cs], bus_setup);
return &dspislave->slave; } #endif /* CONFIG_FSL_DSPI */
-#ifdef CONFIG_CMD_SPI -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - if (((cs >= 0) && (cs < 8)) && ((bus >= 0) && (bus < 8))) - return 1; - else - return 0; -} - void spi_init_f(void) { } @@ -327,32 +316,17 @@ void spi_init_r(void) { }
-void spi_init(void) +void dspi_init(void) { }
-struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct dspi_slave *dspislave;
- if (!spi_cs_is_valid(bus, cs)) - return NULL; - dspislave = spi_alloc_slave(struct dspi_slave, bus, cs); - if (!dspislave) - return NULL; - - dspislave->baudrate = max_hz; - /* specific setup */ - return dspi_setup_slave(dspislave, mode); -} - -void spi_free_slave(struct spi_slave *slave) +void dspi_free_slave(struct spi_slave *slave) { free(slave); }
-int spi_claim_bus(struct spi_slave *slave) +int dspi_claim_bus(struct spi_slave *slave) { #if defined(CONFIG_VF610) || defined(CONFIG_LS102XA) return 0; @@ -361,16 +335,10 @@ int spi_claim_bus(struct spi_slave *slave) #endif }
-void spi_release_bus(struct spi_slave *slave) +void dspi_release_bus(struct spi_slave *slave) { #if !defined(CONFIG_VF610) && !defined(CONFIG_LS102XA) cfspi_release_bus(slave->bus, slave->cs); #endif }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) -{ - return dspi_xfer(slave, bitlen, dout, din, flags); -} -#endif /* CONFIG_CMD_SPI */ diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index ba20bef..0957bac 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -9,7 +9,7 @@ #include <common.h> #include <malloc.h> #include <spi.h> -#include <asm/io.h> +#include <linux/io.h> #include <linux/sizes.h> #include "fsl_qspi.h"
@@ -51,14 +51,6 @@ #define qspi_write32 out_be32 #endif
-static unsigned long spi_bases[] = { - QSPI0_BASE_ADDR, -}; - -static unsigned long amba_bases[] = { - QSPI0_AMBA_BASE, -}; - struct fsl_qspi { struct spi_slave slave; unsigned long reg_base; @@ -67,6 +59,9 @@ struct fsl_qspi { u8 cur_seqid; };
+unsigned long get_spi_bus_base(unsigned int bus); +unsigned long get_qspi_amba_base(unsigned int bus); + /* QSPI support swapping the flash read/write data * in hardware for LS102xA, but not for VF610 */ static inline u32 qspi_endian_xchg(u32 data) @@ -176,12 +171,7 @@ static void qspi_set_lut(struct fsl_qspi *qspi) qspi_write32(®s->lckcr, QSPI_LCKCR_LOCK); }
-void spi_init() -{ - /* do nothing */ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, +struct spi_slave *qspi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { struct fsl_qspi *qspi; @@ -189,15 +179,12 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, u32 reg_val, smpr_val; u32 total_size, seq_id;
- if (bus >= ARRAY_SIZE(spi_bases)) - return NULL; - qspi = spi_alloc_slave(struct fsl_qspi, bus, cs); if (!qspi) return NULL;
- qspi->reg_base = spi_bases[bus]; - qspi->amba_base = amba_bases[bus]; + qspi->reg_base = get_spi_bus_base(bus); + qspi->amba_base = get_qspi_amba_base(bus);
qspi->slave.max_write_size = TX_BUFFER_SIZE;
@@ -232,14 +219,14 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, return &qspi->slave; }
-void spi_free_slave(struct spi_slave *slave) +void qspi_free_slave(struct spi_slave *slave) { struct fsl_qspi *qspi = to_qspi_spi(slave);
free(qspi); }
-int spi_claim_bus(struct spi_slave *slave) +int qspi_claim_bus(struct spi_slave *slave) { return 0; } @@ -436,7 +423,7 @@ static void qspi_op_se(struct fsl_qspi *qspi) qspi_write32(®s->mcr, mcr_reg); }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, +int qspi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { struct fsl_qspi *qspi = to_qspi_spi(slave); @@ -476,7 +463,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, return 0; }
-void spi_release_bus(struct spi_slave *slave) +void qspi_release_bus(struct spi_slave *slave) { /* Nothing to do */ } diff --git a/drivers/spi/fsl_spi_interface.c b/drivers/spi/fsl_spi_interface.c new file mode 100644 index 0000000..1f17ef0 --- /dev/null +++ b/drivers/spi/fsl_spi_interface.c @@ -0,0 +1,267 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * Freescale Muti Serial Peripheral Interface (QSPI and DSPI) driver support + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <linux/io.h> +#include <linux/errno.h> + +void dspi_init(void); +int dspi_claim_bus(struct spi_slave *slave); +int dspi_release_bus(struct spi_slave *slave); +int dspi_cs_is_valid(unsigned int bus, unsigned int cs); +struct spi_slave *dspi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode); +void dspi_free_slave(struct spi_slave *slave); +void dspi_cs_activate(struct spi_slave *slave); +void dspi_cs_deactivate(struct spi_slave *slave); +int dspi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *data_out, void *data_in, unsigned long flags); +void qspi_init(void); +int qspi_claim_bus(struct spi_slave *slave); +int qspi_release_bus(struct spi_slave *slave); +int qspi_cs_is_valid(unsigned int bus, unsigned int cs); +struct spi_slave *qspi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode); +void qspi_free_slave(struct spi_slave *slave); +void qspi_cs_activate(struct spi_slave *slave); +void qspi_cs_deactivate(struct spi_slave *slave); +int qspi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *data_out, void *data_in, unsigned long flags); + +void board_print_spi_device(void); +int board_spi_find_bus(unsigned int bus, unsigned int cs); + +struct fsl_spi_driver { + void (*init)(void); + int (*claim_bus)(struct spi_slave *slave); + int (*release_bus)(struct spi_slave *slave); + int (*cs_is_valid)(unsigned int bus, unsigned int cs); + struct spi_slave *(*setup_slave)(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode); + void (*free_slave)(struct spi_slave *slave); + void (*cs_activate)(struct spi_slave *slave); + void (*cs_deactivate)(struct spi_slave *slave); + int (*xfer)(struct spi_slave *slave, unsigned int bitlen, + const void *data_out, void *data_in, unsigned long flags); +}; + +static struct fsl_spi_driver fsl_spi_drivers[] = { +#ifdef CONFIG_FSL_DSPI + { + .init = dspi_init, + .claim_bus = dspi_claim_bus, + .cs_is_valid = NULL, + .setup_slave = dspi_setup_slave, + .free_slave = dspi_free_slave, + .cs_activate = NULL, + .cs_deactivate = NULL, + .xfer = dspi_xfer, + }, +#endif +#ifdef CONFIG_FSL_QSPI + { + .init = NULL, + .claim_bus = qspi_claim_bus, + .cs_is_valid = NULL, + .setup_slave = qspi_setup_slave, + .free_slave = qspi_free_slave, + .cs_activate = NULL, + .cs_deactivate = NULL, + .xfer = qspi_xfer, + }, +#endif +}; + +enum fsl_spi_driver_sel { +#ifdef CONFIG_FSL_DSPI + DSPI_DRIVER, +#endif +#ifdef CONFIG_FSL_QSPI + QSPI_DRIVER, +#endif +}; + +struct fsl_spi_driver *find_fsl_spi_driver(unsigned int bus, unsigned int cs) +{ + unsigned int driver_sel; + + if (board_spi_find_bus(bus, cs)) { + board_print_spi_device(); + printf("can't find device on bus %d cs %d in board.\n", + bus, cs); + return NULL; + } + + switch (bus) { +#ifdef SPI_BUS_FSL_DSPI1 + case SPI_BUS_FSL_DSPI1: +#endif +#ifdef SPI_BUS_FSL_DSPI2 + case SPI_BUS_FSL_DSPI2: +#endif +#ifdef SPI_BUS_FSL_DSPI3 + case SPI_BUS_FSL_DSPI3: +#endif +#ifdef SPI_BUS_FSL_DSPI4 + case SPI_BUS_FSL_DSPI4: +#endif + driver_sel = DSPI_DRIVER; + break; +#ifdef SPI_BUS_FSL_QSPI + case SPI_BUS_FSL_QSPI: +#endif +#ifdef SPI_BUS_FSL_QSPI2 + case SPI_BUS_FSL_QSPI2: +#endif + driver_sel = QSPI_DRIVER; + break; + default: + return NULL; + } + + return &fsl_spi_drivers[driver_sel]; +} + +unsigned long get_spi_bus_base(unsigned int bus) +{ + switch (bus) { +#ifdef SPI_BUS_FSL_DSPI1 + case SPI_BUS_FSL_DSPI1: + return DSPI1_BASE_ADDR; +#endif +#ifdef SPI_BUS_FSL_DSPI2 + case SPI_BUS_FSL_DSPI2: + return DSPI2_BASE_ADDR; +#endif +#ifdef SPI_BUS_FSL_DSPI3 + case SPI_BUS_FSL_DSPI3: + return DSPI3_BASE_ADDR; +#endif +#ifdef SPI_BUS_FSL_DSPI4 + case SPI_BUS_FSL_DSPI4: + return DSPI4_BASE_ADDR; +#endif +#ifdef SPI_BUS_FSL_QSPI + case SPI_BUS_FSL_QSPI: + return QSPI_BASE_ADDR; +#endif +#ifdef SPI_BUS_FSL_QSPI2 + case SPI_BUS_FSL_QSPI2: + return QSPI2_BASE_ADDR; +#endif + default: + printf("FSL SPL:get bus base error %d", bus); + return 0; + } +} + +unsigned long get_qspi_amba_base(unsigned int bus) +{ + switch (bus) { +#ifdef SPI_BUS_FSL_QSPI + case SPI_BUS_FSL_QSPI: + return QSPI_AMBA_BASE; +#endif +#ifdef SPI_BUS_FSL_QSPI2 + case SPI_BUS_FSL_QSPI2: + return QSPI2_AMBA_BASE; +#endif + default: + printf("FSL SPL:get qspi amba bus base error %d", bus); + return 0; + } + + return 0; +} + +void spi_init() +{ + int i; + struct fsl_spi_driver *driver; + + for (i = 0; i < ARRAY_SIZE(fsl_spi_drivers); i++) { + driver = &fsl_spi_drivers[i]; + if (driver && driver->init) + driver->init(); + } +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct fsl_spi_driver *driver = find_fsl_spi_driver(bus, cs); + + if (!driver || !driver->setup_slave) + return NULL; + + return driver->setup_slave(bus, cs, max_hz, mode); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct fsl_spi_driver *driver = find_fsl_spi_driver(slave->bus, + slave->cs); + + if (!driver) + return 1; + if (!driver->claim_bus) + return 0; + + return driver->claim_bus(slave); +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct fsl_spi_driver *driver = find_fsl_spi_driver(slave->bus, + slave->cs); + + if (driver && driver->free_slave) + return driver->free_slave(slave); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct fsl_spi_driver *driver = find_fsl_spi_driver(slave->bus, + slave->cs); + + if (!driver || !driver->xfer) + return -1; + + return driver->xfer(slave, bitlen, dout, din, flags); +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct fsl_spi_driver *driver = find_fsl_spi_driver(slave->bus, + slave->cs); + + if (driver && driver->release_bus) + driver->release_bus(slave); +} + + +void spi_cs_activate(struct spi_slave *slave) +{ + struct fsl_spi_driver *driver = find_fsl_spi_driver(slave->bus, + slave->cs); + + if (driver && driver->cs_activate) + driver->cs_activate(slave); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct fsl_spi_driver *driver = find_fsl_spi_driver(slave->bus, + slave->cs); + + if (driver && driver->cs_deactivate) + driver->cs_deactivate(slave); +}
Am 26.09.2014 um 09:56 schrieb Chao Fu:
This could use some spellchecking... (usage, example, definition, found)
- switch (bus) {
- case SPI_BUS_FSL_DSPI1:
- case SPI_BUS_FSL_DSPI2:
- case SPI_BUS_FSL_QSPI:
break;
- default:
return -1;
- switch (bus) {
if (cs == 0)
if (cs == 0)
if (cs == 0)
- default:
return -1;
[snip]
This code is both redundant and potentially dangerous. In the cs != 0 case, it falls through to the next case label, where the same if is being executed - no harm done, but someone might want to touch that code in the future. Why not simply move a single if+return into the first switch?
Regards, Andreas
SPI bus defination can be find in arch/arm/include/asm/arch-ls102xa/config.h SPI_BUS_FSL_QSPI 0 SPI_BUS_FSL_DSPI1 1 SPI_BUS_FSL_DSPI2 2 and SPI devices info: AT45DB021 is on spi bus 1 cs 0 S25FL064 is on spi bus 2 cs 0 S25FL128S is on spi bus 0 cs 0 Before using any SPI bus and SPI flash, execute sf probe bus:cs in uboot cmdline Such as use S25FL064, sf probe 2:0
switch (bus) {
break;
default:
return -1;
switch (bus) {
if (cs == 0)
if (cs == 0)
if (cs == 0)
default:
return -1;
dspi_rx(dspislave);
-#endif }
if (din != NULL) {
if (!dspislave)
return NULL;
& 0x78000000;
dspi_read32(&dspislave->regs->ctar[dspislave->slave.cs]) & 0x78FCFFF0; dspislave->charbit =
& 0x78000000)
& 0x78000000)
== 0x78000000) ? 16 : 8; pbrcnt = sizeof(prescaler) / sizeof(int); brcnt = sizeof(scaler) / sizeof(int);
dspi_write32(&dspislave->regs->ctar[dspislave->slave.cs], bus_setup); return &dspislave->slave;
return 1;
else
return NULL;
if (!dspislave)
return NULL;
QSPI0_BASE_ADDR,
QSPI0_AMBA_BASE,
- in hardware for LS102xA, but not for VF610 */
-void spi_init() -{
/* do nothing */
return NULL;
qspi->amba_base = get_qspi_amba_base(bus); qspi->slave.max_write_size = TX_BUFFER_SIZE;
free(qspi);
- Copyright 2014 Freescale Semiconductor, Inc.
- Freescale Muti Serial Peripheral Interface (QSPI and DSPI) driver support
void (*init)(void);
This is duplicating the SPI uclass used by driver model. Please take a look at u-boot-dm.git branch spi-working. If you use driver model you can avoid this.
.init = dspi_init,
.xfer = dspi_xfer,
.init = NULL,
.xfer = qspi_xfer,
+#endif +};
DSPI_DRIVER,
QSPI_DRIVER,
+#endif +};
bus, cs);
return NULL;
switch (bus) {
break;
break;
default:
return NULL;
switch (bus) {
default:
switch (bus) {
default:
+void spi_init() +{
int i;
driver->init();
return NULL;
slave->cs);
if (!driver)
return 1;
slave->cs);
slave->cs);
return -1;
slave->cs);
slave->cs);
slave->cs);
This really is crying out for conversion to driver model.
Andreas Färber
Chao Fu
