[PATCH v3 0/1] Add Radxa ROCK 3 Model A support in U-boot.
ROCK 3 Model A is rk3568 based soc board from Radxa, Add board support in u-boot. Booting logs is accessible at https://paste.ubuntu.com/p/v9BNrB7MdM/
Akash Gajjar (1): arm64: dts: rockchip: rk3568: Add Radxa ROCK 3 Model A board support
arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 24 + arch/arm/dts/rk3568-rock-3a.dts | 609 ++++++++++++++++++++++++ configs/rock-3a-rk3568_defconfig | 74 +++ 4 files changed, 709 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3568-rock-3a-u-boot.dtsi create mode 100644 arch/arm/dts/rk3568-rock-3a.dts create mode 100644 configs/rock-3a-rk3568_defconfig
Add Radxa ROCK 3 Model A support. sync rk3568-rock-3a.dts from Linux 6.2.0-rc7
Board Specifications - Rockchip RK3568 - 2/4/8GB LPDDR4 3200MT/s - eMMC socket, SD card slot - GbE LAN - PCIe 3.0/2.0 - M.2 Connector - 3.5mm Audio jack with mic - HDMI 2.0, MIPI DSI/CSI - USB 3.0 Host/OTG, USB 2.0 Host - 40-pin GPIO expansion ports - USB Type C PD 2.0, 9V/2A, 12V/2A, 15V/2A, 20V/2A
Signed-off-by: Akash Gajjar gajjar04akash@gmail.com --- Changes in v2: * Ammend the commit message, Replace Rock Pi 3a with ROCK3A Model A. Update the specs from https://wiki.radxa.com/Rock3/3a * Sync missing node in dts, still some of the nodes like vop, vop mmu, i2s2_2ch gpu, hdmi removed as there is no driver support present in u-boot. * Duplicated sdmmc node removed from dts. Changes in v3: * Replace rock-pi-3a-rk3568_defconfig with rock-3a-rk3568_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9b719f85d..7c28418c82 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -165,7 +165,8 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399pro-rock-pi-n10.dtb
dtb-$(CONFIG_ROCKCHIP_RK3568) += \ - rk3568-evb.dtb + rk3568-evb.dtb \ + rk3568-rock-3a.dtb
dtb-$(CONFIG_ROCKCHIP_RV1108) += \ rv1108-elgin-r1.dtb \ diff --git a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi new file mode 100644 index 0000000000..ae23ae8587 --- /dev/null +++ b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021 Rockchip Electronics Co., Ltd + * (C) Copyright 2023 Akash Gajjar gajjar04akash@gmail.com + */ + +#include "rk356x-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart2; + u-boot,spl-boot-order = "same-as-spl", &sdmmc0; + }; +}; + +&sdmmc0 { + status = "okay"; +}; + +&uart2 { + clock-frequency = <24000000>; + u-boot,dm-spl; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3568-rock-3a.dts b/arch/arm/dts/rk3568-rock-3a.dts new file mode 100644 index 0000000000..a2f2baa4ea --- /dev/null +++ b/arch/arm/dts/rk3568-rock-3a.dts @@ -0,0 +1,609 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2021 Rockchip Electronics Co., Ltd. + * Copyright (c) 2023 Akash Gajjar gajjar04akash@gmail.com + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3568.dtsi" + +/ { + model = "Radxa ROCK3 Model A"; + compatible = "radxa,rock3a", "rockchip,rk3568"; + + chosen: chosen { + stdout-path = "serial2:1500000n8"; + }; + + gmac1_clkin: external-gmac1-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac1_clkin"; + #clock-cells = <0>; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_usb: vcc5v0-usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_usb_host: vcc5v0-usb-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb_host_en>; + regulator-name = "vcc5v0_usb_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_usb_hub: vcc5v0-usb-hub-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb_hub_en>; + regulator-name = "vcc5v0_usb_hub"; + regulator-always-on; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + regulator-name = "vcc5v0_usb_otg"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usb>; + }; + + vcc_cam: vcc-cam-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc_cam_en>; + regulator-name = "vcc_cam"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_mipi: vcc-mipi-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc_mipi_en>; + regulator-name = "vcc_mipi"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&combphy0 { + status = "okay"; +}; + +&combphy1 { + status = "okay"; +}; + +&combphy2 { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&gmac1 { + assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; + assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>; + clock_in_out = "input"; + phy-handle = <&rgmii_phy1>; + phy-mode = "rgmii-id"; + pinctrl-names = "default"; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + vdd_cpu: regulator@1c { + compatible = "tcs,tcs4525"; + reg = <0x1c>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + assigned-clocks = <&cru I2S1_MCLKOUT_TX>; + assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; + #clock-cells = <1>; + clock-names = "mclk"; + clocks = <&cru I2S1_MCLKOUT_TX>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int>, <&i2s1m0_mclk>; + rockchip,system-power-controller; + #sound-dai-cells = <0>; + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc5-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + wakeup-source; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_npu: DCDC_REG4 { + regulator-name = "vdd_npu"; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG5 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_image: LDO_REG1 { + regulator-name = "vdda0v9_image"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_1v8: LDO_REG7 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_pmu: LDO_REG8 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_image: LDO_REG9 { + regulator-name = "vcca1v8_image"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3: SWITCH_REG1 { + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: SWITCH_REG2 { + regulator-name = "vcc3v3_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + + codec { + mic-in-differential; + }; + }; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c3m1_xfer>; + status = "disabled"; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c4m1_xfer>; + status = "disabled"; +}; + +&i2c5 { + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <0>; + clock-output-names = "rtcic_32kout"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + wakeup-source; + }; +}; + +&i2s0_8ch { + status = "okay"; +}; + +&i2s1_8ch { + rockchip,trcm-sync-tx-only; + status = "okay"; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x0>; + pinctrl-names = "default"; + pinctrl-0 = <ð_phy_rst>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>; + }; +}; + +&pinctrl { + cam { + vcc_cam_en: vcc_cam_en { + rockchip,pins = <1 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + display { + vcc_mipi_en: vcc_mipi_en { + rockchip,pins = <3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + ethernet { + eth_phy_rst: eth_phy_rst { + rockchip,pins = <3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + leds { + led_user_en: led_user_en { + rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie_enable_h: pcie-enable-h { + rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie_reset_h: pcie-reset-h { + rockchip,pins = <3 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int: pmic_int { + rockchip,pins = + <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + vcc5v0_usb_host_en: vcc5v0_usb_host_en { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + vcc5v0_usb_hub_en: vcc5v0_usb_hub_en { + rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + vcc5v0_usb_otg_en: vcc5v0_usb_otg_en { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + bt { + bt_enable: bt-enable { + rockchip,pins = <4 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake: bt-host-wake { + rockchip,pins = <4 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + bt_wake: bt-wake { + rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio-pwrseq { + wifi_enable: wifi-enable { + rockchip,pins = <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc3v3_pmu>; + vccio1-supply = <&vccio_acodec>; + vccio2-supply = <&vcc_1v8>; + vccio3-supply = <&vccio_sd>; + vccio4-supply = <&vcc_1v8>; + vccio5-supply = <&vcc_3v3>; + vccio6-supply = <&vcc_1v8>; + vccio7-supply = <&vcc_3v3>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host0_xhci { + extcon = <&usb2phy0>; + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; + +&usb2phy0 { + status = "okay"; +}; + +&usb2phy0_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&usb2phy0_otg { + phy-supply = <&vcc5v0_usb_otg>; + status = "okay"; +}; + +&usb2phy1 { + status = "okay"; +}; + +&usb2phy1_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&usb2phy1_otg { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig new file mode 100644 index 0000000000..1686c8c1aa --- /dev/null +++ b/configs/rock-3a-rk3568_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_DEFAULT_DEVICE_TREE="rk3568-rock-3a" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3568=y +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-rock-3a.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_PMIC_RK8XX=y +CONFIG_SPL_STACK=0x400000 +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +# CONFIG_BINMAN_FDT is not set +CONFIG_ERRNO_STR=y
Hi Akash,
Please add MAINTAINER for the board.
Other parts looks good to me.
Thanks,
- Kever
- Rockchip RK3568
- GbE LAN
- PCIe 3.0/2.0
- M.2 Connector
Changes in v2:
- Ammend the commit message, Replace Rock Pi 3a with ROCK3A Model A. Update the specs from https://wiki.radxa.com/Rock3/3a
- Sync missing node in dts, still some of the nodes like vop, vop mmu, i2s2_2ch gpu, hdmi removed as there is no driver support present in u-boot.
- Duplicated sdmmc node removed from dts.
Changes in v3:
- rk3568-evb.dtb
rk3568-evb.dtb \
rk3568-rock-3a.dtb
- (C) Copyright 2021 Rockchip Electronics Co., Ltd
- (C) Copyright 2023 Akash Gajjar gajjar04akash@gmail.com
- chosen {
+&sdmmc0 {
- status = "okay";
+&uart2 {
- clock-frequency = <24000000>;
- u-boot,dm-spl;
- status = "okay";
- Copyright (c) 2021 Rockchip Electronics Co., Ltd.
- Copyright (c) 2023 Akash Gajjar gajjar04akash@gmail.com
- model = "Radxa ROCK3 Model A";
- compatible = "radxa,rock3a", "rockchip,rk3568";
- chosen: chosen {
- gmac1_clkin: external-gmac1-clock {
#clock-cells = <0>;
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-boot-on;
- vcc5v0_usb_host: vcc5v0-usb-host-regulator {
enable-active-high;
- vcc5v0_usb_hub: vcc5v0-usb-hub-regulator {
enable-active-high;
- vcc5v0_usb_otg: vcc5v0-usb-otg-regulator {
enable-active-high;
- vcc_cam: vcc-cam-regulator {
enable-active-high;
- vcc_mipi: vcc-mipi-regulator {
enable-active-high;
+&combphy0 {
- status = "okay";
+&combphy1 {
- status = "okay";
+&combphy2 {
- status = "okay";
+&cpu0 {
- cpu-supply = <&vdd_cpu>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&gmac1 {
- assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>;
- clock_in_out = "input";
- phy-handle = <&rgmii_phy1>;
- phy-mode = "rgmii-id";
- pinctrl-names = "default";
- status = "okay";
+&i2c0 {
- status = "okay";
- vdd_cpu: regulator@1c {
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
codec {
+&i2c3 {
- pinctrl-0 = <&i2c3m1_xfer>;
- status = "disabled";
+&i2c4 {
- pinctrl-0 = <&i2c4m1_xfer>;
+&i2c5 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&i2s0_8ch {
- status = "okay";
+&i2s1_8ch {
- rockchip,trcm-sync-tx-only;
- status = "okay";
+&mdio1 {
- rgmii_phy1: ethernet-phy@0 {
reg = <0x0>;
+&pinctrl {
- cam {
- display {
- ethernet {
- hym8563 {
- leds {
- pcie {
- pmic {
rockchip,pins =
- usb {
- bt {
bt_wake: bt-wake {
- sdio-pwrseq {
+&pmu_io_domains {
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio2-supply = <&vcc_1v8>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_1v8>;
- vccio5-supply = <&vcc_3v3>;
- vccio6-supply = <&vcc_1v8>;
- vccio7-supply = <&vcc_3v3>;
- status = "okay";
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host0_xhci {
- extcon = <&usb2phy0>;
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usb_host1_xhci {
- status = "okay";
+&usb2phy0 {
- status = "okay";
+&usb2phy0_host {
- phy-supply = <&vcc5v0_usb_host>;
- status = "okay";
+&usb2phy0_otg {
- phy-supply = <&vcc5v0_usb_otg>;
- status = "okay";
+&usb2phy1 {
- status = "okay";
+&usb2phy1_host {
- status = "okay";
+&usb2phy1_otg {
- status = "okay";
Akash Gajjar
Kever Yang
