[U-Boot] [PATCH v2] ARM: tegra: Add support for norrin board
Norrin (PM370) is a Tegra124 clamshell board that is very similar to venice2, but it has a different panel, the sdcard cd and wp sense are flipped, and it has a different revision of the AS3722 PMIC. This board is also refered to as "nyan" in the ChromeOS trees.
This is the Acer Chromebook 13 CB5-311-T7NN (13.3-inch HD, NVIDIA Tegra K1, 2GB).
Signed-off-by: Allen Martin amartin@nvidia.com Signed-off-by: Simon Glass sjg@chromium.org (rebase, fix pinmux that resets norrin)
Changes in v2: - Rebase and adjust for Kconfig - Fix up pinmux that reset norrin - Add note as to the Chromebook's retail name, since it is now released
arch/arm/cpu/armv7/tegra124/Kconfig | 11 ++ arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-norrin.dts | 92 +++++++++ board/nvidia/norrin/Kconfig | 24 +++ board/nvidia/norrin/MAINTAINERS | 6 + board/nvidia/norrin/Makefile | 9 + board/nvidia/norrin/norrin.c | 29 +++ board/nvidia/norrin/pinmux-config-norrin.h | 290 +++++++++++++++++++++++++++++ board/nvidia/venice2/as3722_init.h | 2 +- configs/norrin_defconfig | 5 + include/configs/norrin.h | 76 ++++++++ 11 files changed, 544 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/tegra124-norrin.dts create mode 100644 board/nvidia/norrin/Kconfig create mode 100644 board/nvidia/norrin/MAINTAINERS create mode 100644 board/nvidia/norrin/Makefile create mode 100644 board/nvidia/norrin/norrin.c create mode 100644 board/nvidia/norrin/pinmux-config-norrin.h create mode 100644 configs/norrin_defconfig create mode 100644 include/configs/norrin.h
diff --git a/arch/arm/cpu/armv7/tegra124/Kconfig b/arch/arm/cpu/armv7/tegra124/Kconfig index 6a1c83a..db17819 100644 --- a/arch/arm/cpu/armv7/tegra124/Kconfig +++ b/arch/arm/cpu/armv7/tegra124/Kconfig @@ -6,6 +6,16 @@ choice config TARGET_JETSON_TK1 bool "NVIDIA Tegra124 Jetson TK1 board"
+config TARGET_NORRIN + bool "NVIDIA Tegra124 Norrin" + help + Norrin (PM370) is a Tegra124 clamshell board that is very similar + to venice2, but it has a different panel, the sdcard CD and WP + sense are flipped, and it has a different revision of the AS3722 + PMIC. This board is also refered to as "nyan" in the Chrome OS + trees. The retail name is the Acer Chromebook 13 CB5-311-T7NN + (13.3-inch HD, NVIDIA Tegra K1, 2GB). + config TARGET_VENICE2 bool "NVIDIA Tegra124 Venice2"
@@ -15,6 +25,7 @@ config SYS_SOC default "tegra124"
source "board/nvidia/jetson-tk1/Kconfig" +source "board/nvidia/norrin/Kconfig" source "board/nvidia/venice2/Kconfig"
endif diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 52f8926..aa1e81a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -30,6 +30,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra30-tec-ng.dtb \ tegra114-dalmore.dtb \ tegra124-jetson-tk1.dtb \ + tegra124-norrin.dtb \ tegra124-venice2.dtb dtb-$(CONFIG_ZYNQ) += zynq-zc702.dtb \ zynq-zc706.dtb \ diff --git a/arch/arm/dts/tegra124-norrin.dts b/arch/arm/dts/tegra124-norrin.dts new file mode 100644 index 0000000..b07630c --- /dev/null +++ b/arch/arm/dts/tegra124-norrin.dts @@ -0,0 +1,92 @@ +/dts-v1/; + +#include "tegra124.dtsi" + +/ { + model = "NVIDIA Norrin"; + compatible = "nvidia,norrin", "nvidia,tegra124"; + + aliases { + console = &uarta; + i2c0 = "/i2c@7000d000"; + i2c1 = "/i2c@7000c000"; + i2c2 = "/i2c@7000c400"; + i2c3 = "/i2c@7000c500"; + i2c4 = "/i2c@7000c700"; + i2c5 = "/i2c@7000d100"; + sdhci0 = "/sdhci@700b0600"; + sdhci1 = "/sdhci@700b0400"; + spi0 = "/spi@7000d400"; + spi1 = "/spi@7000da00"; + usb0 = "/usb@7d000000"; + usb1 = "/usb@7d008000"; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; + + i2c@7000c000 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c400 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c500 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c700 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + }; + + i2c@7000d100 { + status = "okay"; + clock-frequency = <400000>; + }; + + spi@7000d400 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + spi@7000da00 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + sdhci@700b0400 { + status = "okay"; + cd-gpios = <&gpio 170 1>; /* gpio PV2 */ + power-gpios = <&gpio 136 0>; /* gpio PR0 */ + bus-width = <4>; + }; + + sdhci@700b0600 { + status = "okay"; + bus-width = <8>; + }; + + usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + nvidia,vbus-gpio = <&gpio 108 0>; /* gpio PN4, USB_VBUS_EN0 */ + }; + + usb@7d008000 { + status = "okay"; + nvidia,vbus-gpio = <&gpio 109 0>; /* gpio PN5, USB_VBUS_EN1 */ + }; +}; diff --git a/board/nvidia/norrin/Kconfig b/board/nvidia/norrin/Kconfig new file mode 100644 index 0000000..cea6528 --- /dev/null +++ b/board/nvidia/norrin/Kconfig @@ -0,0 +1,24 @@ +if TARGET_NORRIN + +config SYS_CPU + string + default "arm720t" if SPL_BUILD + default "armv7" if !SPL_BUILD + +config SYS_BOARD + string + default "norrin" + +config SYS_VENDOR + string + default "nvidia" + +config SYS_SOC + string + default "tegra124" + +config SYS_CONFIG_NAME + string + default "norrin" + +endif diff --git a/board/nvidia/norrin/MAINTAINERS b/board/nvidia/norrin/MAINTAINERS new file mode 100644 index 0000000..e1463ae --- /dev/null +++ b/board/nvidia/norrin/MAINTAINERS @@ -0,0 +1,6 @@ +NORRIN BOARD +M: Allen Martin amartin@nvidia.com +S: Maintained +F: board/nvidia/norrin/ +F: include/configs/norrin.h +F: configs/norrin_defconfig diff --git a/board/nvidia/norrin/Makefile b/board/nvidia/norrin/Makefile new file mode 100644 index 0000000..5e490bb --- /dev/null +++ b/board/nvidia/norrin/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2014 +# NVIDIA Corporation <www.nvidia.com> +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ../venice2/as3722_init.o +obj-y += norrin.o diff --git a/board/nvidia/norrin/norrin.c b/board/nvidia/norrin/norrin.c new file mode 100644 index 0000000..6f0050c --- /dev/null +++ b/board/nvidia/norrin/norrin.c @@ -0,0 +1,29 @@ +/* + * (C) Copyright 2014 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include "pinmux-config-norrin.h" + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_set_tristate_input_clamping(); + + gpio_config_table(norrin_gpio_inits, + ARRAY_SIZE(norrin_gpio_inits)); + + pinmux_config_pingrp_table(norrin_pingrps, + ARRAY_SIZE(norrin_pingrps)); + + pinmux_config_drvgrp_table(norrin_drvgrps, + ARRAY_SIZE(norrin_drvgrps)); +} diff --git a/board/nvidia/norrin/pinmux-config-norrin.h b/board/nvidia/norrin/pinmux-config-norrin.h new file mode 100644 index 0000000..d4f1f66 --- /dev/null +++ b/board/nvidia/norrin/pinmux-config-norrin.h @@ -0,0 +1,290 @@ +/* + * Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _PINMUX_CONFIG_NORRIN_H_ +#define _PINMUX_CONFIG_NORRIN_H_ + +#define GPIO_INIT(_gpio, _init) \ + { \ + .gpio = GPIO_P##_gpio, \ + .init = TEGRA_GPIO_INIT_##_init, \ + } + +static const struct tegra_gpio_config norrin_gpio_inits[] = { + /* gpio, init_val */ + GPIO_INIT(A0, IN), + GPIO_INIT(C7, IN), + GPIO_INIT(G0, IN), + GPIO_INIT(G1, IN), + GPIO_INIT(G2, IN), + GPIO_INIT(G3, IN), + GPIO_INIT(H2, IN), + GPIO_INIT(H4, IN), + GPIO_INIT(H6, IN), + GPIO_INIT(H7, OUT1), + GPIO_INIT(I0, IN), + GPIO_INIT(I1, IN), + GPIO_INIT(I5, OUT1), + GPIO_INIT(I6, IN), + GPIO_INIT(I7, IN), + GPIO_INIT(J0, IN), + GPIO_INIT(J7, IN), + GPIO_INIT(K1, OUT0), + GPIO_INIT(K2, IN), + GPIO_INIT(K4, OUT0), + GPIO_INIT(K6, OUT0), + GPIO_INIT(K7, IN), + GPIO_INIT(N7, IN), + GPIO_INIT(P2, OUT0), + GPIO_INIT(Q0, IN), + GPIO_INIT(Q2, IN), + GPIO_INIT(Q3, IN), + GPIO_INIT(Q6, IN), + GPIO_INIT(Q7, IN), + GPIO_INIT(R0, OUT0), + GPIO_INIT(R1, IN), + GPIO_INIT(R4, IN), + GPIO_INIT(R7, IN), + GPIO_INIT(S3, OUT0), + GPIO_INIT(S4, OUT0), + GPIO_INIT(S7, IN), + GPIO_INIT(T1, IN), + GPIO_INIT(U4, IN), + GPIO_INIT(U5, IN), + GPIO_INIT(U6, IN), + GPIO_INIT(V0, IN), + GPIO_INIT(W3, IN), + GPIO_INIT(X1, IN), + GPIO_INIT(X4, IN), + GPIO_INIT(X7, OUT0), +}; + +#define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .od = PMUX_PIN_OD_##_od, \ + .rcv_sel = PMUX_PIN_RCV_SEL_##_rcv_sel, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +static const struct pmux_pingrp_config norrin_pingrps[] = { + /* pingrp, mux, pull, tri, e_input, od, rcv_sel */ + PINCFG(CLK_32K_OUT_PA0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_CTS_N_PA1, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DIN_PA4, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PB1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RTS_N_PC0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_TXD_PC2, IRDA, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RXD_PC3, IRDA, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PC7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG4, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG7, SPI4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH1, PWM1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI3, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI4, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), +/* + * This casues nyan to reset after 4 seconds + * PINCFG(PI5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + */ + PINCFG(PI6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ2, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_CTS_N_PJ5, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RTS_N_PJ6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK0, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK4, DEFAULT, UP, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, DEFAULT, DOWN, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_FS_PN0, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DIN_PN1, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DOUT_PN2, I2S0, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_SCLK_PN3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN0_PN4, USB, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(USB_VBUS_EN1_PN5, USB, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(HDMI_INT_PN7, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_SCLK_PP3, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_FS_PP4, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DIN_PP5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DOUT_PP6, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_SCLK_PP7, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL3_PQ3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL4_PQ4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW3_PR3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW6_PR6, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW9_PS1, UARTA, DOWN, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW10_PS2, UARTA, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW15_PS7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_CMD_PT7, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU2, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CD_N_PV2, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_WP_N_PV3, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(GPIO_W2_AUD_PW2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_OUT_PW5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_TXD_PW6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RXD_PW7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DIR_PY1, SPI1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB0, VGP6, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, RSVD3, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, RSVD3, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(PBB3, VGP3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB4, VGP4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_MCLK_PCC0, VI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_RST_N_PDD1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_CLKREQ_N_PDD2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_WAKE_N_PDD3, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_RST_N_PDD5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_CLKREQ_N_PDD6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_OUT_PEE0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_REQ_PEE2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DP_HPD_PFF0, DP, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(PFF2, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CPU_PWR_REQ, CPU, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_INT_N, PMI, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(OWR, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, NORMAL), + PINCFG(CLK_32K_IN, CLK, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(JTAG_RTCK, RTCK, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), +}; + +#define DRVCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static const struct pmux_drvgrp_config norrin_drvgrps[] = { +}; + +#endif /* PINMUX_CONFIG_NORRIN_H */ diff --git a/board/nvidia/venice2/as3722_init.h b/board/nvidia/venice2/as3722_init.h index 06c366e..d1e0ec3 100644 --- a/board/nvidia/venice2/as3722_init.h +++ b/board/nvidia/venice2/as3722_init.h @@ -18,7 +18,7 @@ #define AS3722_LDO6VOLTAGE_REG 0x16 /* VDD_SDMMC */ #define AS3722_LDCONTROL_REG 0x4E
-#ifdef CONFIG_TARGET_JETSON_TK1 +#if defined(CONFIG_TARGET_JETSON_TK1) || defined(CONFIG_TARGET_NORRIN) #define AS3722_SD0VOLTAGE_DATA (0x3C00 | AS3722_SD0VOLTAGE_REG) #else #define AS3722_SD0VOLTAGE_DATA (0x2800 | AS3722_SD0VOLTAGE_REG) diff --git a/configs/norrin_defconfig b/configs/norrin_defconfig new file mode 100644 index 0000000..a18c09b --- /dev/null +++ b/configs/norrin_defconfig @@ -0,0 +1,5 @@ ++S:CONFIG_ARM=y ++S:CONFIG_TEGRA=y ++S:CONFIG_TEGRA124=y ++S:CONFIG_TARGET_NORRIN=y +CONFIG_DEFAULT_DEVICE_TREE="tegra124-norrin" diff --git a/include/configs/norrin.h b/include/configs/norrin.h new file mode 100644 index 0000000..ef0b63d --- /dev/null +++ b/include/configs/norrin.h @@ -0,0 +1,76 @@ +/* + * (C) Copyright 2014 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#include "tegra124-common.h" + +/* High-level configuration options */ +#define V_PROMPT "Tegra124 (Norrin) # " +#define CONFIG_TEGRA_BOARD_STRING "NVIDIA Norrin" + +/* Board-specific serial config */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_TEGRA_ENABLE_UARTA +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#define CONFIG_BOARD_EARLY_INIT_F + +/* I2C */ +#define CONFIG_SYS_I2C_TEGRA +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS TEGRA_I2C_NUM_CONTROLLERS +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC +#define CONFIG_CMD_MMC + +/* Environment in eMMC, at the end of 2nd "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 2 +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) + +/* SPI */ +#define CONFIG_TEGRA114_SPI /* Compatible w/ Tegra114 SPI */ +#define CONFIG_TEGRA114_SPI_CTRLS 6 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 24000000 +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH_SIZE (4 << 20) + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX + +/* General networking support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP + +#include "tegra-common-usb-gadget.h" +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */
Did the pinmux come directly from: https://github.com/NVIDIA/tegra-pinmux-scripts
If not, we should fix the Norrin data that's there so that it's correct, and generates exactly what you want to check into U-Boot.
Hi Stephen,
Allen posted the original patch - my change was to take out the pinmux which causes the board to reset. Maybe that is a difference between nyan and norrin?
Isn't Norrin a development board for that? I believe there are differences between Norrin and the final CB5. If this patch really is for CB5 specifically, shouldn't it be named that way? Ideally, the U-Boot board name should exactly match the DTB filename in the DT tree (i.e. arch/arm/boot/dts in the Linux kernel at present) so that the U-Boot environment doesn't have to override the automatic $dtbfile calculation.
Hi Stephen,
My intent was to get this patch merged as it has been sitting around for ages. I don't have a Norrin dev board though. We could perhaps have two device tree files but use a generic config?
Perhaps I was mislead by the comment that it is called 'nyan' in the Chrome OS tree. If you like I can change this to nyan?
Stephen Warren
