[U-Boot-Users] [PATCH] (Re-re-submited) Added support to flash_real_protect for Atmel flash devices (tested with AT49BV6416)
Some of the flash memories produced by ATMEL start in read-only mode. We need to unprotect it. This patch allows the AT49BV6416 to work with cfi_flash memories. Tested in the at91rm9200ek board.
Signed-off-by: Rafael Campos Las Heras rafael.campos@hanscan.com --- drivers/mtd/cfi_flash.c | 40 ++++++++++++++++++++++++++++++++++------ 1 files changed, 34 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 4340b1b..8d12eb8 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -103,6 +103,10 @@ #define AMD_STATUS_TOGGLE 0x40 #define AMD_STATUS_ERROR 0x20
+#define ATM_CMD_UNLOCK_SECT 0x70 +#define ATM_CMD_SOFTLOCK_START 0x80 +#define ATM_CMD_LOCK_SECT 0x40 + #define FLASH_OFFSET_MANUFACTURER_ID 0x00 #define FLASH_OFFSET_DEVICE_ID 0x01 #define FLASH_OFFSET_DEVICE_ID2 0x0E @@ -1348,12 +1352,36 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) { int retcode = 0;
- flash_write_cmd (info, sector, 0, FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); - if (prot) - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_SET); - else - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + switch (info->vendor) { + case CFI_CMDSET_INTEL_PROG_REGIONS: + case CFI_CMDSET_INTEL_STANDARD: + flash_write_cmd (info, sector, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); + if (prot) + flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_SET); + else + flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + break; + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_STANDARD: +#ifdef CONFIG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif + /* U-Boot only checks the first byte */ + if (info->manufacturer_id == (uchar)ATM_MANUFACT ) { + if (prot) { + flash_unlock_seq(info, 0); + flash_write_cmd (info, 0, info->addr_unlock1, ATM_CMD_SOFTLOCK_START); + flash_unlock_seq(info, 0); + flash_write_cmd (info, sector, 0, ATM_CMD_LOCK_SECT); + } else { + flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_UNLOCK_START); + if (info->device_id == ATM_ID_BV6416) + flash_write_cmd (info, sector, 0, ATM_CMD_UNLOCK_SECT); + } + } + break; + }
if ((retcode = flash_full_status_check (info, sector, info->erase_blk_tout,
This is your 5th posting to the very same subject, without threading, without patch version numbers, nor with any other indication why you are submitting this.
I'm sorry, but I have to tell you that it is becoming a major nuisance to track all your patches and find out what we are supposed to do with these.
Please try being a bit more efficient here on the list.
Please see also the private mail I sent you before.
Rafael,
Thanks. I finally find the time to review this patch. Sorry for the delay. But as Wolfgang already mentioned, resending the same patch over and over again is not the best way to handle things. Please find some nitpicking comments below.
- if (prot)
- else
- switch (info->vendor) {
if (prot)
else
break;
Drop the space before ')'.
if (prot) {
This line gets pretty long. Please wrap this (and others) line that exceed the 80 chars.
Decide for one coding style: func () or func(). As this file used the func () version, please use it all the time.
} else {
break;
BTW: Did you test this patch with other FLASH chips too (Intel, Spansion ...)? Or only the Atmel one?
And please CC me directly on CFI related patches.
Thanks.
Best regards, Stefan
Rafael Campos
Stefan Roese
