[PATCH] mtd: spi-nor-ids: Add NO_CHIP_ERASE flag to Infineon 2Gb parts
S25HS02GT, S25HL02GT, and S28HS02GT are dual-die package parts and do not support chip erase.
Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- drivers/mtd/spi/spi-nor-ids.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 88709a52b3..457965dad1 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -369,7 +369,7 @@ const struct flash_info spi_nor_ids[] = { SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) }, { INFO6("s25hl02gt", 0x342a1c, 0x0f0090, 256 * 1024, 1024, - SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | NO_CHIP_ERASE) }, { INFO6("s25hs512t", 0x342b1a, 0x0f0390, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) }, @@ -377,7 +377,7 @@ const struct flash_info spi_nor_ids[] = { SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) }, { INFO6("s25hs02gt", 0x342b1c, 0x0f0090, 256 * 1024, 1024, - SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | NO_CHIP_ERASE) }, { INFO6("s25fs256t", 0x342b19, 0x0f0890, 128 * 1024, 256, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, #ifdef CONFIG_SPI_FLASH_S28HX_T @@ -385,7 +385,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("s28hl01gt", 0x345a1b, 0, 256 * 1024, 512, SPI_NOR_OCTAL_DTR_READ) }, { INFO("s28hs512t", 0x345b1a, 0, 256 * 1024, 256, SPI_NOR_OCTAL_DTR_READ) }, { INFO("s28hs01gt", 0x345b1b, 0, 256 * 1024, 512, SPI_NOR_OCTAL_DTR_READ) }, - { INFO("s28hs02gt", 0x345b1c, 0, 256 * 1024, 1024, SPI_NOR_OCTAL_DTR_READ) }, + { INFO("s28hs02gt", 0x345b1c, 0, 256 * 1024, 1024, SPI_NOR_OCTAL_DTR_READ | NO_CHIP_ERASE) }, #endif #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */
Please split the patch and add fixes tag so that the fixes can be applied/tracked easily. I already checked when those flashes were introduced
{ INFO6("s25hs512t", 0x342b1a, 0x0f0390, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) },SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | NO_CHIP_ERASE) },
one patch for these two changes please with the following fixes tag: Fixes: c95a914aed7 ("mtd: spi-nor-ids: Add Cypress s25hl-t/s25hs-t")
- { INFO("s28hs02gt", 0x345b1c, 0, 256 * 1024, 1024, SPI_NOR_OCTAL_DTR_READ | NO_CHIP_ERASE) },
and another patch for this change: Fixes: 16dd1095101 ("mtd: spi-nor-ids: Add Infineon(Cypress) s28hs02gt ID")
With that feel free to my R-b tag on both: Reviewed-by: Tudor Ambarus tudor.ambarus@linaro.org
Tudor Ambarus
