[U-Boot-Users] [PATCH 2/9] 85xx: convert MPC8544 DS over to use new LAW init code
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8544ds/Makefile | 2 +- board/freescale/mpc8544ds/init.S | 48 ------------------------------------ board/freescale/mpc8544ds/law.c | 42 +++++++++++++++++++++++++++++++ include/configs/MPC8544DS.h | 2 + 4 files changed, 45 insertions(+), 49 deletions(-) create mode 100644 board/freescale/mpc8544ds/law.c
diff --git a/board/freescale/mpc8544ds/Makefile b/board/freescale/mpc8544ds/Makefile index c6f159a..665251d 100644 --- a/board/freescale/mpc8544ds/Makefile +++ b/board/freescale/mpc8544ds/Makefile @@ -26,7 +26,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := $(BOARD).o +COBJS := $(BOARD).o law.o
SOBJS := init.o
diff --git a/board/freescale/mpc8544ds/init.S b/board/freescale/mpc8544ds/init.S index 544dc07..3918176 100644 --- a/board/freescale/mpc8544ds/init.S +++ b/board/freescale/mpc8544ds/init.S @@ -172,51 +172,3 @@ tlb1_entry: .long FSL_BOOKE_MAS3(CFG_LBC_NONCACHE_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) 2: entry_end - -/* - * LAW(Local Access Window) configuration: - * - * - * Notes: - * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. - * If flash is 8M at default position (last 8M), no LAW needed. - * - * LAW 0 is reserved for boot mapping - */ - - .section .bootpg, "ax" - .globl law_entry -law_entry: - entry_start - - .long (4f-3f)/8 -3: - .long 0 - .long (LAWAR_TRGT_IF_DDR | (LAWAR_SIZE & LAWAR_SIZE_128M)) & ~LAWAR_EN - - .long (CFG_PCI1_MEM_PHYS>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_PCI1 | (LAWAR_SIZE & LAWAR_SIZE_512M) - - .long (CFG_PCI1_IO_PHYS>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_PCI1 | (LAWAR_SIZE & LAWAR_SIZE_64K) - - .long (CFG_LBC_CACHE_BASE>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_LBC | (LAWAR_SIZE & LAWAR_SIZE_256M) - - .long (CFG_PCIE1_MEM_PHYS>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_PCIE1 | (LAWAR_SIZE & LAWAR_SIZE_256M) - - .long (CFG_PCIE1_IO_PHYS>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_PCIE1 | (LAWAR_SIZE & LAWAR_SIZE_64K) - - .long (CFG_PCIE2_MEM_PHYS>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_PCIE2 | (LAWAR_SIZE & LAWAR_SIZE_512M) - - .long (CFG_PCIE2_IO_PHYS>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_PCIE2 | (LAWAR_SIZE & LAWAR_SIZE_64K) - - /* contains both PCIE3 MEM & IO space */ - .long (CFG_PCIE3_MEM_PHYS>>12) & 0xfffff - .long LAWAR_EN | LAWAR_TRGT_IF_PCIE3 | (LAWAR_SIZE & LAWAR_SIZE_4M) -4: - entry_end diff --git a/board/freescale/mpc8544ds/law.c b/board/freescale/mpc8544ds/law.c new file mode 100644 index 0000000..433e509 --- /dev/null +++ b/board/freescale/mpc8544ds/law.c @@ -0,0 +1,42 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW_ENTRY(2, CFG_PCI1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI), + SET_LAW_ENTRY(3, CFG_PCI1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCI), + SET_LAW_ENTRY(4, CFG_LBC_CACHE_BASE, LAWAR_SIZE_256M, LAW_TRGT_IF_LBC), + SET_LAW_ENTRY(5, CFG_PCIE1_MEM_PHYS, LAWAR_SIZE_256M, LAW_TRGT_IF_PCIE_1), + SET_LAW_ENTRY(6, CFG_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), + SET_LAW_ENTRY(7, CFG_PCIE2_MEM_PHYS, LAWAR_SIZE_512M, LAW_TRGT_IF_PCIE_2), + SET_LAW_ENTRY(8, CFG_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), + /* contains both PCIE3 MEM & IO space */ + SET_LAW_ENTRY(9, CFG_PCIE3_MEM_PHYS, LAW_SIZE_4M, LAW_TRGT_IF_PCIE_3), +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 5a96db5..a894209 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -42,6 +42,8 @@ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */
+#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ + #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup */
Kumar Gala
