[PATCH/RFC] rockchip: derive GPIO bank from alias if available
Upstream device trees now use standard node names like "gpio@ff..." but the rk_gpio driver expects a name like "gpio0@ff..." (note the index before the @).
This is not a change that can be made in a -u-boot.dtsi file, so updating to the latest upstream device trees requires updating the driver.
When a sequence number is given explicitly via an alias it makes sense to use this for the bank number (and aliases can be added via -u-boot.dtsi when they are not present upstream), so make this the preferred scheme for assigning a bank index, falling back to the current method if no alias is defined.
Signed-off-by: John Keeping john@metanate.com --- I'm not sure if it would be better just to use dev_seq(dev) unconditionally here. If no aliases are defined, then the device tree nodes are in the right order for all Rockchip SoCs anyway so the sequence numbers will be sensible.
But this feels like the change with less risk of unintentionally introducing a regression.
drivers/gpio/rk_gpio.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/gpio/rk_gpio.c b/drivers/gpio/rk_gpio.c index 68f30157a9..b2f6d0e925 100644 --- a/drivers/gpio/rk_gpio.c +++ b/drivers/gpio/rk_gpio.c @@ -151,8 +151,13 @@ static int rockchip_gpio_probe(struct udevice *dev) return ret;
uc_priv->gpio_count = ROCKCHIP_GPIOS_PER_BANK; - end = strrchr(dev->name, '@'); - priv->bank = trailing_strtoln(dev->name, end); + + ret = dev_read_alias_seq(dev, &priv->bank); + if (ret) { + end = strrchr(dev->name, '@'); + priv->bank = trailing_strtoln(dev->name, end); + } + priv->name[0] = 'A' + priv->bank; uc_priv->bank_name = priv->name;
Hi John,
Well dev_seq() should now match the alias numbers if provided, so it seems better.
if (ret) {
-- 2.37.1
Hi Simon,
Right, when there are aliases dev_seq() is definitely right, but currently the bank number is derived from a node like:
gpio0: gpio0@ff750000 {
where the name is "gpio0@..." and it's that zero that is used to determine the bank.
I don't think all boards define aliases for the GPIOs, so I thought it might be better to preserve the existing node-name scheme when no alias is set. But there seems to be quite a push towards standardised node names upstream so eventually updating the device trees from upstream will break this scheme.
Having looked around a bit more, it seems that of the drivers generating a bank name with 'A'+index, while PIC32 uses the same node name scheme as Rockchip, both octeon and mvebu use dev_seq(), so it does seem sensible to just switch to dev_seq() as the right way to do this.
Regards, John
John Keeping
