[U-Boot] [PATCH 1/3] video: Add information about using TrueType fonts
U-Boot supports using TrueType fonts on the console, which is useful for presenting a nice UI to users, e.g. for system recovery.
Add information about how to compile this on ARM platforms, since this is not obvious.
doc/README.video | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/doc/README.video b/doc/README.video index 09a26b17936..7a30512c96d 100644 --- a/doc/README.video +++ b/doc/README.video @@ -75,3 +75,23 @@ The sunxi U-Boot driver supports the following video-mode options: For example to always use the hdmi connector, even if no cable is inserted, using edid info when available and otherwise initalizing it at 1024x768@60Hz, use: "setenv video-mode sunxi:1024x768-24@60,monitor=dvi,hpd=0,edid=1". + + +TrueType fonts +-------------- + +U-Boot supports the use of antialiased TrueType fonts on some platforms. This +has been tested in x86, ARMv7 and sandbox. + +To enable this, select CONFIG_CONSOLE_TRUETYPE. You can choose between several +fonts, with CONSOLE_TRUETYPE_NIMBUS being the default. + +TrueType supports requires floating point at present. On ARMv7 platforms you +need to disable use of the private libgcc. You can do this by disabling +CONFIG_USE_PRIVATE_LIBGCC. See chromebook_jerry for an example. Note that this +increases U-Boot's size by about 70KB at present. + +On ARM you should also make sure your toolchain supports hardfp. This is +normally given in the name of your toolchain, e.g. arm-linux-gnueabihf (hf +means hardware floating point). You can also run gcc with -v to see if it has +this option.
At present it is possible to enable TrueType support but not include any fonts. This results in a blank display. Select Nimbus as the default font to avoid this.
drivers/video/fonts/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/video/fonts/Kconfig b/drivers/video/fonts/Kconfig index 3f1398db50c..c692fa9602f 100644 --- a/drivers/video/fonts/Kconfig +++ b/drivers/video/fonts/Kconfig @@ -7,6 +7,7 @@ menu "TrueType Fonts" config CONSOLE_TRUETYPE_NIMBUS bool "Nimbus Sans Regular" depends on CONSOLE_TRUETYPE + default y help Nimbus Sans L is a version of Nimbus Sans using Adobe font sources. It was designed in 1987. A subset of Nimbus Sans L were released
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-video/master, thanks!
-- Anatolij
As an example of how to enable TrueType fonts, move chromebook_jerry over to use these.
configs/chromebook_jerry_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index d892d65bf0a..94a1af01be0 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -80,7 +80,6 @@ CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_ROCKCHIP_USB2_PHY=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Rockchip" CONFIG_USB_GADGET_VENDOR_NUM=0x2207 @@ -88,10 +87,12 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x320a CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_FUNCTION_MASS_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_CONSOLE_TRUETYPE=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_EDP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y +# CONFIG_USE_PRIVATE_LIBGCC is not set CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y
-- Anatolij
Hi Simon,
-- Anatolij
Anatolij Gustschin
Philipp Tomsich
